S1AD3 THRU S1MD3
1.0A Surface Mount General Purpose
Rectifiers - 50V-1000V
Package outline
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds at terminals
Glass passivated chip junction
0.071(1.80)
0.063(1.40)
0.016(0.40)
0.010(0.25)
0.055(1.40)
0.047(1.20)
SOD-323
Mechanical data
Case: JEDEC SOD-323 molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
0.003(0.08)
0.008(0.20)
0.039(1.00)
0.031(0.80)
0.108(2.75)
0.096(2.45)
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
T A=25 oC unless otherwise noted)
SYMBOLS S1AD3 S1BD3 S1DD3 S1GD3 S1JD3 S1KD3 S1MD3
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL =110C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
50
35
50
VRRM
VRMS
VDC
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
IFSM
15.0
A
VF
1.1
V
IR
5.0
50.0
µA
CJ
RθJA
TJ,TSTG
5.0
55.0
-55 to +150
pF
C/W
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.fuxinsemi.com
Page 1
Ver2.1
S1AD3 THRU S1MD3
Rating and characteristic curves
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
1.2
1.0
0.8
0.6
P.C.B. Mounted on
0.2" x 0.2" (5 mm x 5 mm)
Copper Pad Areas
0.4
0.2
TJ=25 C
60
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.7
.8
.9
1.0
1.1
1.2
1.3
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWAARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
50
40
30
8.3ms Single Half
TJ=25 C
Sine Wave
JEDEC method
10
1
5
50
10
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
10
35
TJ=125 C
JUNCTION CAPACITANCE,(pF)
REVERSE LEAKAGE CURRENT, (m
A)
NUMBER OF CYCLES AT 60Hz
1.0
.1
TJ=25 C
30
25
10
5
.01
60
80
.01
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
PERCENTAGE RATED PEAK REVERSE VOLTAGE,(%)
www.fuxinsemi.com
.05
100 120 140
Page 2
Ver2.1
S1AD3 THRU S1MD3
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
S1AD3
S1BD3
S1DD3
S1GD3
S1JD3
S1KD3
S1MD3
1A
2A
3A
4A
5A
6A
7A
Suggested solder pad layout
C
A
B
PACKAGE
A
B
C
SOD-323
0.047 (1.20)
0.047 (1.20)
0.055 (1.40)
Reel packing
PACKAGE
SOD-323
REEL SIZE
7"
www.fuxinsemi.com
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
3,000
4.0
30,000
183*183*123
178
Page 3
CARTON
SIZE
(m/m)
382*262*387
CARTON
(pcs)
240,000
Ver2.1
S1AD3 THRU S1MD3
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“S1MD3”相匹配的价格&库存,您可以联系我们找货
