SI2301
P-Channel 20-V(D-S) MOSFET
V(BR)DSS
-20 V
RDS(on)MAX
90mΩ@-4.5V
115mΩ@-2.5V
FEATURE
※ TrenchFET Power MOSFET
MARKING
ID
-3A
APPLICATION
※ Load Switch for Portable Devices
※ DC/DC Converter
Equivalent Circuit
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±12
ID
-3
IDM
-15
Continuous Source-Drain Current(Diode Conduction)
IS
-0.8
Power Dissipation
PD
1.25
W
RθJA
150
℃/W
TJ
150
TSTG
-55~+150
Continuous Drain Current
Pulsed Diode Curren
Thermal Resistance from Junction to Ambient (t≤5s)
Operating Junction
Storage Temperature
1/3
Unit
V
A
SI2301
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
V(BR)DSS
VGS = 0V, ID = -250µA
-20
VGS(th)
VDS =VGS, ID = -250µA
-0.4
Gate-source leakage
IGSS
Zero gate voltage drain current
IDSS
Typ
Max
Unit
Static
Drain-source breakdown voltage
Gate-source threshold voltage
Drain-source on-state resistancea
Forward transconductancea
Diode forward voltage
V
-1.
V
VDS =0V, VGS = ±12V
±100
nA
VDS = -20V, VGS =0V
-1
µA
VGS = -4.5V, ID = -2.8A
66
90
mΩ
VGS = -2.5V, ID = -2A
83
115
mΩ
gfs
VDS = -4.5V, ID = -3A
4
VSD
IS=-1A,VGS=0V
-0.8
RDS(on)
S
-1.3
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qgs
Gate-drain charge
Qgd
589
pF
92
pF
68
pF
5.5
Qg
Gate-source charge
Gate resistance
VDS = -16V,VGS =0V,
f=1MHz
VDS = -16V,VGS = -4.5V,
ID =-3A
Rg
f=1MHz
10
nC
0.8
nC
1.3
nC
6
Ω
Switchingb
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
VDD= -10V
RL=6Ω, ID ≈ -3A,
VGEN= -4.5V,Rg=6Ω
tf
10
ns
35
60
ns
30
50
ns
10
ns
-1.3
A
-20
A
Drain-source body diode characteristics
Continuous Source-Drain Diode Current
Pulsed Diode forward Curren
IS
Tc=25 ℃
ISM
Note :
1. Repetitive Rating : Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t < 5 sec.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production testing.
2/3
SI2301
3/3
很抱歉,暂时无法提供与“SI2301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12755
- 500+0.10109
- 3000+0.07517
- 6000+0.06632
- 24000+0.06286
- 51000+0.06048
- 国内价格
- 1+0.33330
- 200+0.11110
- 1500+0.06941
- 3000+0.05489
- 国内价格
- 20+0.17464
- 200+0.13697
- 600+0.11604
- 3000+0.10348
- 9000+0.09261
- 21000+0.08674
