SI2302
N-Channel 20-V(D-S) MOSFET
V(BR)DSS
RDS(on)MAX
ID
SOT-23
0.050Ω@ 4.5V
20V
0.065Ω@ 2.5V
3A
3
1.GATE
2.SOURCE
1
General FEATURE
3.DRAIN
2
●TrenchFET Power MOSFET
●Lead free product is acquired
MARKING
●Surface mount package
Equivalent Circuit
A2Shb
APPLICATION
●Load Switch for Portable Devices
●DC/DC Converter
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±10
Continuous Drain Current
Pulsed Drain Current*1
ID
3.0
IDM
10
Continuous Source-Drain Diode Current
IS
1.0
Maximum Power Dissipation
PD
1.0
W
R θJA
156
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~+150
Thermal Resistance from Junction to Ambient(t ≤5s)
V
A
Note :
*1. Pulse Width ≤ 300μs, Duty cycle ≤2%
www.yongyutai.com
PAGE 1
SI2302
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
0.8
1.0
Units
Static
Drain-source breakdown voltage
V(BR)DSS VGS = 0V, ID =-250µA
Gate-source threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
0.5
Gate-source leakage
IGSS
VDS =0V, VGS =±10V
±100
nA
Zero gate voltage drain current
IDSS
VDS =16V, VGS =0V
1
µA
Drain-source on-state resistance a
RDS(on)
Forward transconductance a
gfs
VGS =4.5V, ID =3A
0.045
0.050
VGS =2.5V, ID =2A
0.055
0.065
8.0
VDS =5V, ID =3A
V
Ω
S
Dynamicb
300
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
80
Total gate charge
Qg
4.0
Gate-source charge
Qgs
Gate-drain charge
Qgd
Turn-on delay time
td(on)
Rise time
Turn-off delay time
Fall time
tr
td(off)
VDS =10V,VGS =0V,f =1MHz
VDS =10V,VGS =4.5V,ID =3A
120
pF
nC
0.65
1.6
VDD=10V,ID =3A
VGEN=4.5V,Rg=6Ω
tf
15.0
85.0
ns
45.0
20.0
Drain-source body diode characteristics
Continuous source-drain diode current
Body diode voltage
IS
TC=25℃
VSD
IS=1.0A
1.0
0.7
1.3
A
V
Notes :
a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
b.Guaranteed by design, not subject to production testing.
www.yongyutai.com
PAGE 2
SI2302
Typical Electrical and Thermal Characteristics
Vdd
Vgs
Rgen
td(on)
Rl
Vin
D
ton
tr
Vout
90%
VOUT
G
toff
tf
td(off)
90%
INVERTED
10%
10%
90%
S
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
PD Power(W)
ID- Drain Current (A)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(mΩ)
Figure 3 Power Dissipation
115
95
75
55
35
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
www.yongyutai.com
Figure 6 Drain-Source On-Resistance
PAGE 3
Normalized On-Resistance
SI2302
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
110
100
90
C Capacitance (pF)
Figure 7 Transfer Characteristics
80
70
60
50
40
30
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Figure 11 Gate Charge
www.yongyutai.com
Vsd Source-Drain Voltage (V)
Figure 12 Source- Drain Diode Forward
PAGE 4
SI2302
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
www.yongyutai.com
PAGE 5
SI2302
SOT-23 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
Dimensions In Inches
Min
Max
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
SOT-23 Suggested Pad Layout
www.yongyutai.com
PAGE 6
很抱歉,暂时无法提供与“SI2302”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.25960
- 200+0.08679
- 1500+0.05423
- 3000+0.04301
- 国内价格
- 50+0.10682
- 500+0.08813
- 3000+0.06189
- 6000+0.05562
- 24000+0.05314
- 51000+0.05141
