JEC07D471KS0517
JEC07D471KS0517
    JEC(智旭)
    JEC07D471KS0517
JEC07D471KS0517 数据手册
JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 Disc Varistor FEATURES * Wide operating voltages ranging from 5Vrms to 1000Vrms (6Vdc to 1465Vdc). * Fast response time of less than 25nS, instantly clamping the transient over voltage. * High surge current handling capability. * High energy absorption capability. * Low clamping voltages, providing better surge protection * Low capacitance values, providing digital switching circuitry protection. * High insulation resistance, preventing electric arching to the adjacent devices or circuits. APPLICATIONS * Transistor, Diode, IC, Thyristor or Triac semiconductor protection. * Surge protection in consumer electronics. * Surge protection in industrial electronics. * Surge protection in electronic home appliances, gas and petroleum appliances. * Relay and electromagnetic valve surge absorption. General Characteristics Definition *Operating Temperature: -40 oC ~ +85 oC *Storage Temperature: -40 oC ~ +125 oC *Working Surface Temperature: +115 oC *Insulation Resistance: > 100M Ω *Coating (Epoxy Resin): Flame-Retardant to UL 94 V-0 Material *Coating: Epoxy Resin *Lead Wire: The Copper Wire *Electrode: Silver Solder *Disk: Zinc Oxide 1 JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 JYH HSU(JEC)料号编码: JEC□□D□□□K □ □ □ □ Brand Mark :JYH HSU(JEC)(智旭) Coating :Sapce is 85℃ “H”Epoxy Coating 125℃ Size(mm) : 05mm to 32mm Short leg : NO : □.□ Type: D: Disk , S: Square Foot distance :05mm to 10mm Varistor Voltage : 180L(18V) to 821K(820V) Lead Form : S:Straight, C:Crimped, I:Inner, Y:Y kink E: 4KV2KA S:6KV/3KA Y:10KV/5KA J:High Surge & High Energy Tolerance : K±10%, L±15%, M±20% MARKING 1 JYH HSU (JEC) Logo 2 Disk Size 3 CUL Accreditation Logo 4 “Y” &“M” Product Line Code 5 Varistor Voltage 6 VDE Accreditation Logo 7 “J” is High Surge Code,not “J” is Standard Surge “H” is High temperature range ,not “H” is Standard 07D 471K 2 JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 Prouduct Shape 承认规格详细参数 (Approved Spec. Data) 规格型号 压敏电压 最大使用电压 07D471K 423-517 300VAC385VDC 07D471K 423-517 300VAC385VDC Dmax Tmax F±0.8 Hmax L=20MIN d± 0.05 1200 9.0 6.0 5.0 11.0 20.0 0.60 2500 12.5 6.5 7.5 14.0 25.0 0.80 通流(A) 8/20μS 3 备注 JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 TYPE Series Varistor Voltage T Max. 180L~680K 4.0 4.5 5.0 5.5 6.0 6.5 4.0 4.5 5.0 5.5 6.0 6.5 4.0 5.0 5.5 6.0 6.5 7.0 7.5 4.5 5.0 5.5 6.0 6.5 8.0 11.5 4.5 5.0 5.2 5.5 6.5 7.0 8.5 12.0 5.5 6.0 6.5 7.0 7.5 8.5 10.5 13.0 820K~151K 05D 181K~271K 301K~391K 431K~561K 621K~751K 180L~390K 470K~820K 07D 101K~271K 331K~391K 431K~561K 621K~821K 180L~680K 820K~151K 181K~271K 10D 331K~391K 431K~561K 621K~751K 821K~112K 180L~680K 820K~271K 331K~391K 14D 431K~561K 621K~781K 821K~112K 152K~182K 180L~680K 820K~151K 181K~271K 331K~391K 20D 431K~561K 621K~781K 821K~112K 152K~182K 180L~680K 820K~151K 181K~271K 331K~391K 25D 431K~561K 621K~781K 821K~122K 142K~182K D Max. H Max. L min. F ±0.8 d + 0.05 13.0 20.0 5.0 0.6 11.0 14.0 20.0 5.0 0.6 12.5 14.0 17.0 25.0 7.5/10 0.8 17.0 18.0 21.0 20.0 7.5 0.8 22.0 25.0 28.0 20.0 10.0 1.0 28.0 32.0 34.0 20.0 10.0±1.0 1.0 S I/C/Y 7.5 10.5 9.0 4 JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 05D Standard & High Surge 产品型号 Part Number 标准系列 Standard 最大允许回路 电压 Maximum Allowable Voltage 压敏电压 Varistor Voltage 最大限制电压 Maximum Clamping Voltage 最大峰值电流 8/20μS Withstanding Surge Current 标准系列 AC (V) DC (V) V0.1mA(V) IP(A) VC(V) I(A) 高焦尔 I(A) 能量/耐量 Energy 10/1000μS 标准系列 (J) 最大额定电 压 Rated Powe 电容量 (参考值) Typical Capacitance (Reference) 高焦尔 (J) Standard High Surge Standard High Surge (W) @1KJzPF JEC-05D180L 11 14 18(15.3~20.7) 1 40 100 250 0.4 0.6 0.01 1400 JEC-05D220K 14 18 22(19.8~24.2) 1 48 100 250 0.5 0.7 0.01 1150 JEC-05D270K 17 22 27(24.3-29.7) 1 60 100 250 0.6 0.9 0.01 930 JEC-05D330K 20 26 33(29.7~36.3) 1 73 100 250 0.8 1.1 0.01 760 JEC-05D390K 25 31 39(35.1~42.9) 1 80 100 250 0.9 1.2 0.01 640 JEC-05D470K 30 38 47(42.3~51.7) 1 104 100 250 1.1 1.5 0.01 530 JEC-05D560K 35 45 56(50.4~61.6) 1 123 100 250 1.3 1.8 0.01 450 JEC-05D680K 40 56 68(61.2~74.8) 1 145 100 250 1.6 2.2 0.01 370 JEC-05D820K 50 65 82(73.8~90.2) 5 150 400 800 2.5 4.0 0.1 300 JEC-05D101K 60 85 100(90~110) 5 177 400 800 3.0 4.1 0.1 250 JEC-05D121K 75 100 120(108~132) 5 210 400 800 4.0 4.9 0.1 210 JEC-05D151K 95 125 150(135~165) 5 260 400 800 4.1 6.5 0.1 165 JEC-05D181K 115 150 180(162~198) 5 320 400 800 4.9 7.5 0.1 140 JEC-05D201K 130 170 200(185~225) 5 355 400 800 6.5 8.5 0.1 125 JEC-05D221K 140 180 220(198~242) 5 380 400 800 7.5 9.0 0.1 110 JEC-05D241K 150 200 240(216~264) 5 415 400 800 8.0 10.5 0.1 100 JEC-05D271K 175 225 270(243~297) 5 475 400 800 8.5 11.0 0.1 95 JEC-05D301K 190 250 300(270~330) 5 520 400 800 9.0 12.0 0.1 85 JEC-05D331K 210 275 330(297~363) 5 570 400 800 9.5 13.0 0.1 75 JEC-05D361K 230 300 360(324~396) 5 620 400 800 10.0 16.0 0.1 70 JEC-05D391K 250 320 390(351~429) 5 675 400 800 12.0 17.0 0.1 65 JEC-05D431K 275 350 430(387~473) 5 745 400 800 13.0 20.0 0.1 60 JEC-05D471K 300 385 470(423~517) 5 810 400 800 15.0 21.0 0.1 55 JEC-05D511K 320 415 510(459~561) 5 845 400 800 16.0 22.5 0.1 50 JEC-05D561K 350 460 560(504~616) 5 920 400 800 16.5 24.0 0.1 45 JEC-05D621K 385 505 620(558~682) 5 1025 400 800 21.0 25.0 0.1 40 JEC-05D681K 420 560 680(612~748) 5 1120 400 800 22.0 29.0 0.1 35 JEC-05D751K 460 615 750(675~825) 5 1240 400 800 22.4 32.0 0.1 30 5 JYH HSU (JEC) ELECTRONICS LTD., 07D Standard & High Surge 最大允许回路电压 产品型号 Maximum Part Number Allowable Voltage 标准系列 高焦尔 Standard High Surge 壓敏電阻 压敏电压 最大限制电压 Maximum Varistor Clamping Voltage Voltage 最大峰值电流 8/20μS Withstanding Surge Current 电容量 能量/耐量 Energy 10/1000μS 最大额定 (参考值) 电压 Typical Capacitance Powe (Reference) Rated 标准系列 高焦尔 标准系列 高焦尔 IP(A) VC(V) DC (V) V1mA(V) (J) JEC-07D180L JEC-07D180LJ 11 14 18(15.3~20.7) 2.5 36 250 500 0.9 JEC-07D220K JEC-07D220KJ 14 18 22(19.8~24.2) 2.5 43 250 500 JEC-07D270K JEC-07D270KJ 17 22 27(24.3-29.7) 2.5 53 250 JEC-07D330K JEC-07D330KJ 20 26 33(29.7~36.3) 2.5 65 JEC-07D390K JEC-07D390KJ 25 31 39(35.1~42.9) 2.5 JEC-07D470K JEC-07D470KJ 30 38 47(42.3~51.7) JEC-07D560K JEC-07D560KJ 35 45 JEC-07D680K JEC-07D680KJ 40 JEC-07D820K JEC-07D820KJ (J) (W) @1KJzPF 2.0 0.02 2800 1.1 2.4 0.02 2300 500 1.4 3.0 0.02 1800 250 500 1.7 3.5 0.02 1500 77 250 500 2.1 4.0 0.02 1300 2.5 93 250 500 2.5 5.0 0.02 1100 56(50.4~61.6) 2.5 110 250 500 3.1 6.0 0.02 890 56 68(61.2~74.8) 2.5 135 250 500 3.6 7.0 0.02 740 50 65 82(73.8~90.2) 10 135 1200 1750 5.5 10 0.25 600 JEC-07D101K JEC-07D101KJ 60 85 100(90~110) 10 165 1200 1750 6.5 12 0.25 500 JEC-07D121K JEC-07D121KJ 75 100 120(108~132) 10 200 1200 1750 7.8 12 0.25 420 JEC-07D151K JEC-07D151KJ 95 125 150(135~165) 10 250 1200 1750 9.7 13 0.25 330 JEC-07D181K JEC-07D181KJ 115 150 180(162~198) 10 300 1200 1750 11.7 16 0.25 280 JEC-07D201K JEC-07D201KJ 130 170 200(185~225) 10 330 1200 1750 13 17 0.25 250 JEC-07D221K JEC-07D221KJ 140 180 220(198~242) 10 360 1200 1750 14 19 0.25 230 JEC-07D241K JEC-07D241KJ 150 200 240(216~264) 10 395 1200 1750 15 21 0.25 210 JEC-07D271K JEC-07D271KJ 175 225 270(243~297) 10 455 1200 1750 18 24 0.25 185 JEC-07D301K JEC-07D301KJ 190 250 300(270~330) 10 505 1200 1750 20 26 0.25 165 JEC-07D331K JEC-07D331KJ 210 275 330(297~363) 10 550 1200 1750 23 28 0.25 150 JEC-07D361K JEC-07D361KJ 230 300 360(324~396) 10 595 1200 1750 25 32 0.25 140 JEC-07D391K JEC-07D391KJ 250 320 390(351~429) 10 650 1200 1750 25 35 0.25 130 JEC-07D431K JEC-07D431KJ 275 350 430(387~473) 10 710 1200 1750 28 40 0.25 115 JEC-07D471K JEC-07D471KJ 300 385 470(423~517) 10 775 1200 1750 30 42 0.25 105 JEC-07D511K JEC-07D511KJ 320 415 510(459~561) 10 845 1200 1750 30 45 0.25 100 JEC-07D561K JEC-07D561KJ 350 460 560(504~616) 10 920 1200 1750 30 49 0.25 90 JEC-07D621K JEC-07D621KJ 385 505 620(558~682) 10 1025 1200 1750 33 55 0.25 80 JEC-07D681K JEC-07D681KJ 420 560 680(612~748) 10 1120 1200 1750 33 60 0.25 75 JEC-07D751K JEC-07D751KJ 460 615 750(675~825) 10 1240 1200 1750 65 67 0.25 70 JEC-07D781K JEC-07D781KJ 485 640 780(702~858) 10 1290 1200 1750 65 67 0.25 70 JEC-07D821K JEC-07D821KJ 510 670 820(738~902) 10 1355 1200 1750 65 70 0.25 60 6 I(A) I(A) AC (V) High High Standard Surge Standard Surge JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 10D Standard & High Surge 最大允许回路电压 产品型号 Maximum Part Number Allowable Voltage 标准系列 高焦尔 Standard High Surge JEC-10D180L 最大限制电压 压敏电压 Maximum Varistor Clamping Voltage Voltage 最大峰值电流 8/20μS Withstanding Surge Current 标准系列 I(A) Energy 10/1000μS 最大 电容量 额定 (参考值) 电压 Typical Rated Capacitance Powe (Reference) 标准系列 高焦尔 AC (V) DC (V) V1mA(V) JEC-10D180LJ 11 14 18(15.3~20.7) 5 36 500 1000 2.1 JEC-10D220K JEC-10D220KJ 14 18 22(19.8~24.2) 5 43 500 1000 JEC-10D270K JEC-10D270KJ 17 22 27(24.3~29.7) 5 53 500 JEC-10D330K JEC-10D330KJ 20 26 33(29.7~36.3) 5 65 JEC-10D390K JEC-10D390KJ 25 31 39(35.1~42.9) 5 JEC-10D470K JEC-10D470KJ 30 38 47(42.3~51.7) JEC-10D560K JEC-10D560KJ 35 45 JEC-10D680K JEC-10D680KJ 40 JEC-10D820K JEC-10D820KJ JEC-10D101K (J) (W) @1KJzPF 3 0.05 5600 2.5 5 0.05 4500 1000 3.0 6 0.05 3700 500 1000 4.0 7 0.05 3000 77 500 1000 4.6 9 0.05 2400 5 93 500 1000 5.5 11 0.05 2100 56(50.4~61.6) 5 110 500 1000 7.0 13 0.05 1800 56 68(61.2~74.8) 5 135 500 1000 8.2 15 0.05 1500 50 65 82(73.8~90.2) 25 135 2500 3500 12 17 0.4 1200 JEC-10D101KJ 60 85 100(90~110) 25 165 2500 3500 15 18 0.4 1000 JEC-10D121K JEC-10D121KJ 75 100 120(108~132) 25 200 2500 3500 18 21 0.4 830 JEC-10D151K JEC-10D151KJ 95 125 150(135~165) 25 250 2500 3500 22 25 0.4 670 JEC-10D181K JEC-10D181KJ 115 150 180(162~198) 25 300 2500 3500 27 30 0.4 560 JEC-10D201K JEC-10D201KJ 130 170 200(185~225) 25 330 2500 3500 30 35 0.4 500 JEC-10D221K JEC-10D221KJ 140 180 220(198~242) 25 360 2500 3500 32 39 0.4 450 JEC-10D241K JEC-10D241KJ 150 200 240(216~264) 25 395 2500 3500 35 42 0.4 420 JEC-10D271K JEC-10D271KJ 175 225 270(243~297) 25 455 2500 3500 37 49 0.4 370 JEC-10D301K JEC-10D301KJ 190 250 300(270~330) 25 505 2500 3500 40 54 0.4 330 JEC-10D331K JEC-10D331KJ 210 275 330(297~363) 25 550 2500 3500 43 58 0.4 300 JEC-10D361K JEC-10D361KJ 230 300 360(324~396) 25 595 2500 3500 47 65 0.4 280 JEC-10D391K JEC-10D391KJ 250 320 390(351~429) 25 650 2500 3500 60 70 0.4 260 JEC-10D431K JEC-10D431KJ 275 350 430(387~473) 25 710 2500 3500 65 80 0.4 230 JEC-10D471K JEC-10D471KJ 300 385 470(423~517) 25 775 2500 3500 67 85 0.4 210 JEC-10D511K JEC-10D511KJ 320 415 510(459~561) 25 845 2500 3500 69 90 0.4 200 JEC-10D561K JEC-10D561KJ 350 460 560(504~616) 25 920 2500 3500 70 92 0.4 180 JEC-10D621K JEC-10D621KJ 385 505 620(558~682) 25 1025 2500 3500 72 95 0.4 160 JEC-10D681K JEC-10D681KJ 420 560 680(612~748) 25 1120 2500 3500 75 98 0.4 150 JEC-10D751K JEC-10D751KJ 460 615 750(675~825) 25 1240 2500 3500 77 100 0.4 140 JEC-10D781K JEC-10D781KJ 485 640 780(702~858) 25 1290 2500 3500 80 105 0.4 130 JEC-10D821K JEC-10D821KJ 510 670 820(738~902) 25 1355 2500 3500 85 110 0.4 120 JEC-10D911K JEC-10D911KJ 550 745 910(819~1001) 25 1500 2500 3500 93 130 0.4 110 JEC-10D102K JEC-10D102KJ 625 825 1000(900~110 25 1650 2500 3500 102 140 0.4 100 JEC-10D112K JEC-10D112KJ 680 895 0) 1100(990~121 25 1815 2500 3500 115 150 0.4 90 0) IP(A) VC(V) 高焦尔 能量/耐量 7 I(A) High Standard Surge (J) High Standard Surge JYH HSU (JEC) ELECTRONICS LTD., 14D Standard & High Surge 最大允许回路电压 产品型号 Maximum Part Number Allowable Voltage 标准系列 Standard 壓敏電阻 高焦尔 High Surge 最大限制电压 压敏电压 Maximum Varistor Clamping Voltage Voltage 最大峰值电流 8/20μS Withstanding Surge Current 能量/耐量 Energy 10/1000μS 电容量 (参考值) 定电压 Typical Rated Capacitance Powe (Reference) 最大额 标准系列 高焦尔 标准系列 高焦尔 AC (V) DC (V) V1mA(V) IP(A) VC(V) I(A) I(A) (J) (J) High High Standard Surge Standar Surge (W) @1KJzPF JEC-14D180L JEC-14D180LJ 11 14 18(15.3~20.7) 10 36 1000 2000 4 7 0.1 11000 JEC-14D220K JEC-14D220KJ 14 18 22(19.8~24.2) 10 43 1000 2000 5 8 0.1 9100 JEC-14D270K JEC-14D270KJ 17 22 27(24.3~29.7) 10 53 1000 2000 6 10 0.1 7400 JEC-14D330K JEC-14D330KJ 20 26 33(29.7~36.3) 10 65 1000 2000 8 12 0.1 6100 JEC-14D390K JEC-14D390KJ 25 31 39(35.1~42.9) 10 77 1000 2000 9 13 0.1 5100 JEC-14D470K JEC-14D470KJ 30 38 47(42.3~51.7) 10 93 1000 2000 10 17 0.1 4300 JEC-14D560K JEC-14D560KJ 35 45 56(50.4~61.6) 10 110 1000 2000 11 20 0.1 3600 JEC-14D680K JEC-14D680KJ 40 56 68(61.2~74.8) 10 135 1000 2000 14 24 0.1 2900 JEC-14D820K JEC-14D820KJ 50 65 82(73.8~90.2) 50 135 4500 6000 22 27 0.6 2400 JEC-14D101K JEC-14D101KJ 60 85 100(90~110) 50 165 4500 6000 28 33 0.6 2000 JEC-14D121K JEC-14D121KJ 75 100 120(108~132) 50 200 4500 6000 32 40 0.6 1700 JEC-14D151K JEC-14D151KJ 95 125 150(135~165) 50 250 4500 6000 40 53 0.6 1300 JEC-14D181K JEC-14D181KJ 115 150 180(162~198) 50 300 4500 6000 50 60 0.6 1100 JEC-14D201K JEC-14D201KJ 130 170 200(185~225) 50 330 4500 6000 57 70 0.6 1000 JEC-14D221K JEC-14D221KJ 140 180 220(198~242) 50 360 4500 6000 60 78 0.6 830 JEC-14D241K JEC-14D241KJ 150 200 240(216~264) 50 395 4500 6000 63 84 0.6 740 JEC-14D271K JEC-14D271KJ 175 225 270(243~297) 50 455 4500 6000 70 99 0.6 670 JEC-14D301K JEC-14D301KJ 190 250 300(270~330) 50 505 4500 6000 77 108 0.6 610 JEC-14D331K JEC-14D331KJ 210 275 330(297~363) 50 550 4500 6000 85 115 0.6 560 JEC-14D361K JEC-14D361KJ 230 300 360(324~396) 50 595 4500 6000 93 130 0.6 510 JEC-14D391K JEC-14D391KJ 250 320 390(351~429) 50 650 4500 6000 100 140 0.6 460 JEC-14D431K JEC-14D431KJ 275 350 430(387~473) 50 710 4500 6000 115 155 0.6 230 JEC-14D471K JEC-14D471KJ 300 385 470(423~517) 50 775 4500 6000 125 175 0.6 430 JEC-14D511K JEC-14D511KJ 320 415 510(459~561) 50 845 4500 6000 126 180 0.6 390 JEC-14D561K JEC-14D561KJ 350 460 560(504~616) 50 920 4500 6000 127 185 0.6 360 JEC-14D621K JEC-14D621KJ 385 505 620(558~682) 50 1025 4500 6000 128 190 0.6 320 JEC-14D681K JEC-14D681KJ 420 560 680(612~748) 50 1120 4500 6000 130 200 0.6 290 JEC-14D751K JEC-14D751KJ 460 615 750(675~825) 50 1240 4500 6000 143 210 0.6 270 JEC-14D781K JEC-14D781KJ 485 640 780(702~858) 50 1290 4500 6000 148 220 0.6 260 JEC-14D821K JEC-14D821KJ 510 670 820(738~902) 50 1355 4500 6000 157 235 0.6 240 JEC-14D911K JEC-14D911KJ 550 745 910(819~1001) 50 1500 4500 6000 175 255 0.6 220 JEC-14D102K JEC-14D102KJ 625 825 1000(900~1100) 50 1650 4500 6000 190 280 0.6 200 JEC-14D112K JEC-14D112KJ 680 895 1100(990~1210) 50 1815 4500 6000 213 310 0.6 180 JEC-14D122K JEC-14D122KJ 750 990 1200(1080~1320) 50 1980 4500 6000 232 324 0.6 160 JEC-14D142K JEC-14D142KJ 880 1140 1400(1260~1540) 50 2310 4500 6000 238 327 0.6 150 JEC-14D162K JEC-14D162KJ 1000 1280 1600(1400~1760) 50 2640 4500 6000 243 331 0.6 140 JEC-14D182K JEC-14D182KJ 1100 1465 1800(1620~1980) 50 2970 4500 6000 250 335 0.6 130 8 JYH HSU (JEC) ELECTRONICS LTD., 20D Standard & High Surge 最大允许回路电压 产品型号 Maximum Part Number Allowable Voltage 标准系列 高焦尔 Standard High Surge 壓敏電阻 压敏电压 最大限制电压 Maximum Varistor Clamping Voltage Voltage IP(A) VC(V) 最大峰值电流 8/20μS Withstanding Surge Current 能 量 / 耐 最大额 量 Energy 10/1000μS 标准系列 高焦尔 I(A) 系列 I(A) 标准 高焦尔 (J) 定电压 电容量 (参考值) (W) @1KJzPF Typical Rated Capacitance Powe (Reference) AC (V) DC (V) V1mA(V) Standard High Surge (J) High Surge JEC-20D180L JEC-20D180LJ 11 14 18(15.3~20.7) 20 36 2000 3000 11 13 0.2 28500 JEC-20D220K JEC-20D220KJ 14 18 22(19.8~24.2) 20 43 2000 3000 14 16 0.2 18500 JEC-20D270K JEC-20D270KJ 17 22 27(24.3-29.7) 20 53 2000 3000 16 19 0.2 13000 JEC-20D330K JEC-20D330KJ 20 26 33(29.7~36.3) 20 65 2000 3000 23 24 0.2 11500 JEC-20D390K JEC-20D390KJ 25 31 39(35.1~42.9) 20 77 2000 3000 26 28 0.2 8500 JEC-20D470K JEC-20D470KJ 30 38 47(42.3~51.7) 20 93 2000 3000 30 34 0.2 7400 JEC-20D560K JEC-20D560KJ 35 45 56(50.4~61.6) 20 110 2000 3000 41 46 0.2 6500 JEC-20D680K JEC-20D680KJ 40 56 68(61.2~74.8) 20 135 2000 3000 46 49 0.2 5800 JEC-20D820K JEC-20D820KJ 50 65 82(73.8~90.2) 100 135 6500 10000 38 56 1.0 4900 JEC-20D101K JEC-20D101KJ 60 85 100(90~110) 100 165 6500 10000 45 70 1.0 4000 JEC-20D121K JEC-20D121KJ 75 100 120(108~132) 100 200 6500 10000 55 85 1.0 3300 JEC-20D151K JEC-20D151KJ 95 125 150(135~165) 100 250 6500 10000 70 106 1.0 2700 JEC-20D181K JEC-20D181KJ 115 150 180(162~198) 100 300 6500 10000 85 130 1.0 2200 JEC-20D201K JEC-20D201KJ 130 170 200(185~225) 100 330 6500 10000 95 140 1.0 2000 JEC-20D221K JEC-20D221KJ 140 180 220(198~242) 100 360 6500 10000 100 155 1.0 1800 JEC-20D241K JEC-20D241KJ 150 200 240(216~264) 100 395 6500 10000 108 168 1.0 1650 JEC-20D271K JEC-20D271KJ 175 225 270(243~297) 100 455 6500 10000 127 190 1.0 1500 JEC-20D301K JEC-20D301KJ 190 250 300(270~330) 100 505 6500 10000 136 210 1.0 1300 JEC-20D331K JEC-20D331KJ 210 275 330(297~363) 100 550 6500 10000 150 228 1.0 1200 JEC-20D361K JEC-20D361KJ 230 300 360(324~396) 100 595 6500 10000 163 255 1.0 1100 JEC-20D391K JEC-20D391KJ 250 320 390(351~429) 100 650 6500 10000 180 275 1.0 1000 JEC-20D431K JEC-20D431KJ 275 350 430(387~473) 100 710 6500 10000 190 305 1.0 930 JEC-20D471K JEC-20D471KJ 300 385 470(423~517) 100 775 6500 10000 220 350 1.0 850 JEC-20D511K JEC-20D511KJ 320 415 510(459~561) 100 845 6500 10000 225 360 1.0 780 JEC-20D561K JEC-20D561KJ 350 460 560(504~616) 100 920 6500 10000 230 380 1.0 710 JEC-20D621K JEC-20D621KJ 385 505 620(558~682) 100 1025 6500 10000 235 390 1.0 650 JEC-20D681K JEC-20D681KJ 420 560 680(612~748) 100 1120 6500 10000 240 400 1.0 600 JEC-20D751K JEC-20D751KJ 460 615 750(675~825) 100 1240 6500 10000 255 420 1.0 530 JEC-20D781K JEC-20D781KJ 485 640 780(702~858) 100 1290 6500 10000 265 440 1.0 510 JEC-20D821K JEC-20D821KJ 510 670 820(738~902) 100 1355 6500 10000 282 460 1.0 500 JEC-20D911K JEC-20D911KJ 550 745 910(819~1001) 100 1500 6500 10000 310 510 1.0 440 JEC-20D102K JEC-20D102KJ 625 825 1000(900~1100 100 1650 6500 10000 342 565 1.0 400 JEC-20D112K JEC-20D112KJ 680 895 ) 1100(990~1210 100 1815 6500 10000 383 620 1.0 360 JEC-20D122K JEC-20D122KJ 750 990 ) 1200(1080~132 100 1980 6500 10000 408 660 1.0 350 JEC-20D142K JEC-20D142KJ 880 0) 1140 1400(1260~154 100 2310 6500 10000 532 784 1.0 340 JEC-20D162K JEC-20D162KJ 1000 0) 1280 1600(1400~176 100 2640 6500 10000 606 896 1.0 330 JEC-20D182K JEC-20D182KJ 1100 0) 1465 1800(1620~198 100 2970 6500 10000 625 990 1.0 320 0) 9 JYH HSU (JEC) ELECTRONICS LTD., 25D Standard & 壓敏電阻 High Surge 最大允许回路电压 产品型号 Maximum Part Number Allowable Voltage 高焦尔 最大限制电压 压敏电压 Maximum Varistor Clamping Voltage Voltage 最大峰值电流 8/20μS Withstanding Surge Current 标准系列 10/1000μS Rated Capacitance Powe (Reference) 高焦尔 标准系列 高焦尔 I(A) (J) AC (V) DC (V) V1mA(V) (W) @1KJzPF JEC-25D180L JEC-25D180LJ 11 14 18(15.3~20.7) 30 36 4500 8000 20 24 0.25 45000 JEC-25D220K JEC-25D220KJ 14 18 22(19.8~24.2) 30 43 4500 8000 25 30 0.25 29000 JEC-25D270K JEC-25D270KJ 17 22 27(24.3-29.7) 30 53 4500 8000 30 36 0.25 26500 JEC-25D330K JEC-25D330KJ 20 26 33(29.7~36.3) 30 65 4500 8000 35 42 0.25 18000 JEC-25D390K JEC-25D390KJ 25 31 39(35.1~42.9) 30 77 4500 8000 40 48 0.25 13500 JEC-25D470K JEC-25D470KJ 30 38 47(42.3~51.7) 30 93 4500 8000 50 60 0.25 11500 JEC-25D560K JEC-25D560KJ 35 45 56(50.4~61.6) 30 110 4500 8000 60 72 0.25 10500 JEC-25D680K JEC-25D680KJ 40 56 68(61.2~74.8) 30 135 4500 8000 70 84 0.25 9050 JEC-25D820K JEC-25D820KJ 50 65 82(73.8~90.2) 150 135 15000 20000 80 96 1.2 7700 JEC-25D101K JEC-25D101KJ 60 85 100(90~110) 150 165 15000 20000 100 120 1.2 6300 JEC-25D121K JEC-25D121KJ 75 100 120(108~132) 150 200 15000 20000 120 144 1.2 5200 JEC-25D151K JEC-25D151KJ 95 125 150(135~165) 150 250 15000 20000 160 192 1.2 4300 JEC-25D181K JEC-25D181KJ 115 150 180(162~198) 150 300 15000 20000 175 210 1.2 3500 JEC-25D201K JEC-25D201KJ 130 170 200(185~225) 150 330 15000 20000 190 228 1.2 3200 JEC-25D221K JEC-25D221KJ 140 180 220(198~242) 150 360 15000 20000 200 240 1.2 2900 JEC-25D241K JEC-25D241KJ 150 200 240(216~264) 150 395 15000 20000 220 264 1.2 2650 JEC-25D271K JEC-25D271KJ 175 225 270(243~297) 150 455 15000 20000 255 306 1.2 2400 JEC-25D301K JEC-25D301KJ 190 250 300(270~330) 150 505 15000 20000 275 330 1.2 2100 JEC-25D331K JEC-25D331KJ 210 275 330(297~363) 150 550 15000 20000 300 360 1.2 1900 JEC-25D361K JEC-25D361KJ 230 300 360(324~396) 150 595 15000 20000 330 396 1.2 1750 JEC-25D391K JEC-25D391KJ 250 320 390(351~429) 150 650 15000 20000 360 432 1.2 1600 JEC-25D431K JEC-25D431KJ 275 350 430(387~473) 150 710 15000 20000 380 456 1.2 1500 JEC-25D471K JEC-25D471KJ 300 385 470(423~517) 150 775 15000 20000 400 480 1.2 1400 JEC-25D511K JEC-25D511KJ 320 415 510(459~561) 150 845 15000 20000 420 504 1.2 1250 JEC-25D561K JEC-25D561KJ 350 460 560(504~616) 150 920 15000 20000 440 528 1.2 1150 JEC-25D621K JEC-25D621KJ 385 505 620(558~682) 150 1025 15000 20000 450 540 1.2 1050 JEC-25D681K JEC-25D681KJ 420 560 680(612~748) 150 1120 15000 20000 460 552 1.2 950 JEC-25D751K JEC-25D751KJ 460 615 750(675~825) 150 1240 15000 20000 510 612 1.2 850 JEC-25D781K JEC-25D781KJ 485 640 780(702~858) 150 1290 15000 20000 530 636 1.2 850 JEC-25D821K JEC-25D821KJ 510 670 820(738~902) 150 1355 15000 20000 570 684 1.2 500 JEC-25D911K JEC-25D911KJ 550 745 910(819~1001) 150 1500 15000 20000 620 744 1.2 700 JEC-25D102K JEC-25D102KJ 625 825 1000(900~1100) 150 1650 15000 20000 685 822 1.2 650 JEC-25D112K JEC-25D112KJ 680 895 1100(990~1210) 150 1815 15000 20000 720 864 1.2 600 JEC-25D122K JEC-25D122KJ 750 990 1200(1080~1320) 150 1980 15000 20000 795 954 1.2 550 JEC-25D142K JEC-25D142KJ 880 1140 1400(1260~1540) 150 2310 15000 20000 850 1020 1.2 500 JEC-25D162K JEC-25D162KJ 1000 1280 1600(1400~1760) 150 2640 15000 20000 970 1164 1.2 450 JEC-25D182K JEC-25D182KJ 1100 1465 1800(1620~1980) 150 2970 15000 20000 1092 1310 1.2 400 标准系列 Standard High Surge IP(A) VC(V) 电容量 能量/耐量 最大额 (参考值) 定电压 Energy Typical 10 I(A) (J) High High Surge Surge Standard Standard JYH HSU (JEC) ELECTRONICS LTD., 05D Surge Life Time Ratings N (Standard) / K (Low Capacitance) Series 05D V-I CURVE 11 壓敏電阻 JYH HSU (JEC) ELECTRONICS LTD., 07D Surge Life Time Ratings 壓敏電阻 N (Standard) / K (Low Capacitance) Series 07D V-I CURVE 12 JYH HSU (JEC) ELECTRONICS LTD., 10D Surge Life Time Ratings 壓敏電阻 N (Standard) / K (Low Capacitance) Series 10D V-I CURVE 13 JYH HSU (JEC) ELECTRONICS LTD., 14D Surge Life Time Ratings 壓敏電阻 N (Standard) / K (Low Capacitance) Series 14D V-I CURVE 14 JYH HSU (JEC) ELECTRONICS LTD., 20D Surge Life Time Ratings N (Standard) / K (Low Capacitance) Series 20D V-I CURVE 15 壓敏電阻 JYH HSU (JEC) ELECTRONICS LTD., 05DApproval Standard And File Number Model No. UL E486000 JEC-05D180L YES JEC-05D220K Certified CQC 壓敏電阻 07DApproval Standard And File Number UL Certified E486000 CQC 190012551485 Model No. UL,CUL E486000 40044685 YES YES JEC-07D180L YES YES YES YES YES YES JEC-07D220K YES YES YES JEC-05D270K YES YES YES JEC-07D270K YES YES YES JEC-05D330K YES YES YES JEC-07D330K YES YES YES JEC-05D390K YES YES YES JEC-07D390K YES YES YES JEC-05D470K YES YES YES JEC-07D470K YES YES YES JEC-05D560K YES YES YES JEC-07D560K YES YES YES JEC-05D680K YES YES YES JEC-07D680K YES YES YES JEC-05D820K YES YES YES JEC-07D820K YES YES YES JEC-05D101K YES YES YES JEC-07D101K YES YES YES JEC-05D121K YES YES YES JEC-07D121K YES YES YES JEC-05D151K YES YES YES JEC-07D151K YES YES YES JEC-05D181K YES YES YES JEC-07D181K YES YES YES JEC-05D201K YES YES YES JEC-07D201K YES YES YES JEC-05D221K YES YES YES JEC-07D221K YES YES YES JEC-05D241K YES YES YES JEC-07D241K YES YES YES JEC-05D271K YES YES YES JEC-07D271K YES YES YES JEC-05D301K YES YES YES JEC-07D301K YES YES YES JEC-05D331K YES YES YES JEC-07D331K YES YES YES JEC-05D361K YES YES YES JEC-07D361K YES YES YES JEC-05D391K YES YES YES JEC-07D391K YES YES YES JEC-05D431K YES YES YES JEC-07D431K YES YES YES JEC-05D471K YES YES YES JEC-07D471K YES YES YES JEC-05D511K YES YES JEC-07D511K YES YES YES JEC-05D561K YES YES JEC-07D561K YES YES YES JEC-05D621K YES YES JEC-07D621K YES / YES JEC-05D681K YES YES JEC-07D681K YES / YES JEC-05D751K / JEC-07D751K / / YES YES JEC-05D821K / JEC-07D821K / / YES YES 40044685 16 19001221471 JYH HSU (JEC) ELECTRONICS LTD., 10DApproval Standard And File Number CQC Certified Model No. UL,CUL E486000 40044685 JEC-10D180L YES YES JEC-10D220K YES JEC-10D270K 19001221472 壓敏電阻 14DApproval Standard And File Number CQC Certified 19001221473 Model No. UL,CUL E486000 YES JEC-14D180L YES / YES YES YES JEC-14D220K YES / YES YES YES YES JEC-14D270K YES YES YES JEC-10D330K YES YES YES JEC-14D330K YES YES YES JEC-10D390K YES YES YES JEC-14D390K YES YES YES JEC-10D470K YES YES YES JEC-14D470K YES YES YES JEC-10D560K YES YES YES JEC-14D560K YES YES YES JEC-10D680K YES YES YES JEC-14D680K YES YES YES JEC-10D820K YES YES YES JEC-14D820K YES 3KA/6KV YES 3KA/6KV YES JEC-10D101K YES YES YES JEC-14D101K YES 3KA/6KV YES 3KA/6KV YES JEC-10D121K YES YES YES JEC-14D121K YES 3KA/6KV YES 3KA/6KV YES JEC-10D151K YES YES YES JEC-14D151K YES 3KA/6KV YES 3KA/6KV YES JEC-10D181K YES YES YES JEC-14D181K YES 3KA/6KV YES 3KA/6KV YES JEC-10D201K YES YES YES JEC-14D201K YES 3KA/6KV YES 3KA/6KV YES JEC-10D221K YES YES YES JEC-14D221K YES 3KA/6KV YES 3KA/6KV YES JEC-10D241K YES YES YES JEC-14D241K YES 3KA/6KV YES 3KA/6KV YES JEC-10D271K YES YES YES JEC-14D271K YES 3KA/6KV YES 3KA/6KV YES JEC-10D301K YES YES YES JEC-14D301K YES 3KA/6KV YES 3KA/6KV YES JEC-10D331K YES YES YES JEC-14D331K YES 3KA/6KV YES 3KA/6KV YES JEC-10D361K YES YES YES JEC-14D361K YES 3KA/6KV YES 3KA/6KV YES JEC-10D391K YES YES YES JEC-14D391K YES 3KA/6KV YES 3KA/6KV YES JEC-10D431K YES YES 3KA/6KV YES JEC-14D431K YES 3KA/6KV YES 3KA/6KV YES JEC-10D471K YES 3KA/6KV YES 3KA/6KV YES JEC-14D471K YES 3KA/6KV YES 3KA/6KV YES JEC-10D511K YES 3KA/6KV YES 3KA/6KV YES JEC-14D511K YES 3KA/6KV YES 3KA/6KV YES JEC-10D561K YES 3KA/6KV YES 3KA/6KV YES JEC-14D561K YES 3KA/6KV YES 3KA/6KV YES JEC-10D621K YES 3KA/6KV YES 3KA/6KV YES JEC-14D621K YES 3KA/6KV YES 3KA/6KV YES JEC-10D681K YES 3KA/6KV YES 3KA/6KV YES JEC-14D681K YES 3KA/6KV YES 3KA/6KV YES YES 3KA/6KV YES 40044685 JEC-10D751K YES YES 3KA/6KV YES JEC-14D751K YES 3KA/6KV JEC-10D821K YES YES 3KA/6KV YES JEC-14D821K YES 3KA/6KV / YES JEC-10D911K YES YES 3KA/6KV YES JEC-14D911K YES 3KA/6KV / YES JEC-10D102K YES YES 3KA/6KV YES JEC-14D102K YES / YES JEC-10D112K YES YES 3KA/6KV YES JEC-14D112K YES / YES JEC-14D152K YES / YES JEC-14D182K YES / YES 17 JYH HSU (JEC) ELECTRONICS LTD., 20DApproval Standard And File Number 壓敏電阻 25DApproval Standard And File Number CQC CQC Certified 19001221470 Model No. / YES JEC-25D180L / YES YES / YES JEC-25D220K / YES JEC-20D270K YES YES YES JEC-25D270K / YES JEC-20D330K YES YES YES JEC-25D330K / YES JEC-20D390K YES YES YES JEC-25D390K / YES JEC-20D470K YES YES YES JEC-25D470K / YES JEC-20D560K YES YES YES JEC-25D560K / YES JEC-20D680K YES YES YES JEC-25D680K / YES JEC-20D820K YES Certified Model No. UL,CUL E486000 JEC-20D180L YES JEC-20D220K 40044685 UL E486000 19001221474 YES 3KA/6KV YES JEC-25D820K / YES JEC-20D101K YES 3KA/6KV YES 3KA/6KV YES JEC-25D101K / YES JEC-20D121K YES 3KA/6KV YES 3KA/6KV YES JEC-25D121K / YES JEC-20D151K YES 3KA/6KV YES 3KA/6KV YES JEC-25D151K / YES JEC-20D181K YES 3KA/6KV YES 3KA/6KV YES JEC-25D181K / YES JEC-20D201K YES 3KA/6KV YES 3KA/6KV YES JEC-25D201K YES YES JEC-20D221K YES 3KA/6KV YES 3KA/6KV YES JEC-25D221K YES YES JEC-20D241K YES 3KA/6KV YES 3KA/6KV YES JEC-25D241K YES YES JEC-20D271K YES 3KA/6KV YES 3KA/6KV YES JEC-25D271K YES YES JEC-20D301K YES 3KA/6KV YES 3KA/6KV YES JEC-25D301K YES YES JEC-20D331K YES 3KA/6KV YES 3KA/6KV YES JEC-25D331K YES YES JEC-20D361K YES 3KA/6KV YES 3KA/6KV YES JEC-25D361K YES YES JEC-20D391K YES 3KA/6KV YES 3KA/6KV YES JEC-25D391K YES YES JEC-20D431K YES 3KA/6KV YES 3KA/6KV YES JEC-25D431K YES YES JEC-20D471K YES 3KA/6KV YES 3KA/6KV YES JEC-25D471K YES YES JEC-20D511K YES 3KA/6KV YES 3KA/6KV YES JEC-25D511K YES YES JEC-20D561K YES 3KA/6KV YES 3KA/6KV YES JEC-25D561K YES YES JEC-20D621K YES 3KA/6KV YES 3KA/6KV YES JEC-25D621K YES YES JEC-20D681K YES 3KA/6KV YES 3KA/6KV YES JEC-25D681K YES YES JEC-20D751K YES 3KA/6KV YES 3KA/6KV YES JEC-25D751K YES YES JEC-20D821K YES 3KA/6KV YES 3KA/6KV YES JEC-25D781K YES YES JEC-20D911K YES 3KA/6KV YES 3KA/6KV YES JEC-25D821K YES YES JEC-20D102K YES / YES JEC-25D911K YES YES JEC-20D112K YES / YES JEC-25D102K / YES JEC-20D152K YES / YES JEC-25D112K / YES JEC-20D182K YES / YES JEC-25D122K / YES JEC-25D142K / YES JEC-25D162K / YES JEC-25D182K / YES 18 JYH HSU (JEC) ELECTRONICS LTD., Dimension - TA / TR / CA / CR Ammo & Reel 壓敏電阻 Series P P0 P1 P2 F W W0 W1 12.7±1.0 12.7±0.3 3.85±0.7 6.35±1.3 5.0±0.5 18.0±1.0 12.5max. 9.0±0.5 W2 H H0 H1 △h L D0 t 3.0max. 20.0±2.0 16.0±1.0 32.0max 0±2 1.0max. 4.0±0.2 0.6±0.3 Packing Specifications /Bulk Packing Dimension /Quantity per Packing Method Qualtity Per Packing Method Part No. Ammo Box Carton 180L to 561K 1,500 15,000 621k to 821K 1,300 13,000 180L to 471K 511k to 821K 180L to 471K 511k to 821K 180L to 471K 511k to 821K 1,000 10,000 800 8000 1,000 10,000 800 8,000 500 5,000 300 5,000 Dimension 05D 07D 05D 07D 10D 14D 20D 存储条件: 1. 储存温度: -10℃~+40℃ 2. 相对湿度: ≦75%RH 3. 不要将本产品存放在有腐蚀性气体或是阳光直接照射的环境中保管。 存储期限: 1 年 19 JYH HSU (JEC) ELECTRONICS LTD., Reliability Test Mechanical Ratings Test Parameter 壓敏電阻 Test Condition / Description Performance Requirements Diameter 0.6mm Loading 1.0 Kg 0.8mm 1.0mm 1.0 Kg 2.0 Kg Diameter 0.6mm Loading 0.5 Kg 0.8mm 1.0mm 0.5 Kg 1.0 Kg No visible damage Vibration The Specimen shall be vibrated by its lead wires with a total amplitude of 1.5 ㎜ and a varying frequency of 10~55~10HZ(each minutes) for a period of 2 hours respectively in each X,Yand Z directions. No visible damage △VB/VB%≦±5% Soldering-solderability After dipping the terminal to depth of approximately 3 ㎜ from the specimen in a soldering bath of 260℃ for 10±1(D5: 5±1) seconds. Thereafter the terminal shall be visually examined. Terminations shall be uniformly tinned Terminal Pull Strength After gradually applying the load specified below and keeping the unit fixed for ten seconds, the terminal shall be visually examined for any damage. The unit shall be secured with its terminal kept vertical and the weight specified below be applied in the axial direction. The terminal shall gradually be bent by 90° in Terminal Bending Strength one direction, then 90° in the opposite direction, and again back to the original position. The damage of the terminal shall be visually examined. After preheating the specimen, the specimen shall be completely immersed into a Soldering- Resistance to soldering bath having a temperature of 260±5℃ for 10±1 (D5: 5±1) seconds or Solder Heat iron of 400±5℃ for 3±0.5 seconds. There after the change of Vb and mechanical damage shall be examined. ENVIRONMENTAL RATINGS Dry Heat Loading High Temperature Storage No visible damage No visible damage △VB/VB%≦±5% The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal humidity over 2 hours. Thereafter, the change of Vb and mechanical △VB/VB%≦±10% damage shall be examined. Ambient temp:125±2℃ ; Period:1000±24hours. In a drying oven without load. Ambient temp:125±2℃ ; △VB/VB%≦±5% period:1000±24hours Damp Heat Loading The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal humidity over 2 hours. Thereafter, the change of Vb and mechanical △VB/VB%≦±10% damage shall be examined. Ambient condition:40±2℃ , 90 to 95%R.H. ; period:1000±24 hours Temperature Cycle Condition the specimen to each temperature form step 1 to step 4 in this order for the period shown in the table of specifications. The change of Vb and mechanical damage shall be examined after 2 hours. Surge Lifetime Rating Voltage Proof Step TempoC Period 1 2 -40+3 C 30 min. 15 min. 3 4 o Room Temp 85+2oC Room Temp 30 min. 15 min. No visible damage △VB/VB%≦±10% The change of Vb shall be measured after the impulse listed below is applied No visible damage 10,000 times continuously with the interval of ten seconds at room temperature. △VB/VB%≦±10% Voltage:2500VAC Leakage Current≦0.5mA 20 Time:60 Seconds No Breakdown JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 产品特性 编号 项目 性能要求 说明及测试方法 IEC 68-2-4, 试验 Db 干热: (125±2℃)×16hrs, 1.1 循环湿热:一个循环(55±2℃)×24hrs、 95~100%RH 气候顺序 寒冷:(-40±2℃)×2hrs, 无明显机械损伤 循环湿热:一次(55±2℃) ×24hrs,、95~100%RH、 剩余的循环 5 次, 24hrs/循环。 IEC68-2-3 环境特性 1.2 稳态湿热 温度/时间:(40±2℃)/500hrs、湿度:90~95%RH。 无明显机械损伤 1.3 温度快速变 化 IEC 68-2-14, 试验 Na ;共五个循环,每个极限温度下放置 30 分钟。 无明显机械损伤 IEC 68-2-2 上限类别温度 1.4 TA=- 40℃,TB= +125℃ 温度:125℃±2℃、时间:1000hrs。 耐久性 无明显机械损伤 电压:最大持续工作电压(交流)。 1.5 湿热环境耐 久性 IEC68-2-3 温度:125℃±2℃、时间:500hrs、湿度:90~95%RH。 无明显机械损伤 电压:最大持续工作电压(交流)。 IEC68-2-6, 试验 Fc 方法 B4 2.1 总持续时间:6hrs(三个方向,每方向各 2hrs)。 振动 无明显机械损伤 频率范围:10 Hz~55 Hz、振幅:0.75mm 或加速度 98 m/s2 IEC 68-2-27, Test Ea 机械特性 2.2 脉冲波形:半正弦波、加速度:490m/s2 冲击 无明显机械损伤 脉冲宽度:11ms,三个方向,每方向各 6 次。 2.3 可焊性 2.4 耐焊接热 浸渍部分的 95% IEC 68-2-20, 试验 Ta 方法 1 被焊锡覆盖 浸渍时间:2±0.5sec 无明显机械损伤 IEC 68-2-20, 试验 Tb 方法 1A IEC68-2-21, 试验 Ua 2.5 槽温:235±5℃ 锡温: 260℃、持续时间:5sec 拉伸-力量: 10 N ( ø 0.6 和ø 0.8mm 引线) 、20N( ø 1.0mm 引线)持续时间:10 sec. 引出端强度 弯折-力量: 5 N ( 无明显机械损伤 ø 0.6 和ø 0.8mm 引线)、 10N( ø 1.0mm 引线)弯折次数:2 次 总体特性 3.1 使用温度范 (-40℃ ~ + 125℃) 压敏电阻无须降额使用的温度范围 围 3.2 贮存温度范 (-40℃ ~ +150℃) 压敏电阻无负载情况下 围 3.3 绝缘耐压 ≥2500VAC 压敏电阻的电极引线与其包封层表面之间,1 min。 21 JYH HSU (JEC) ELECTRONICS LTD., 壓敏電阻 使用须知 为避免因 MOV 而引起的火灾或劣化而导致其它设备的损坏,请参考并遵守以下原则: 1)当压敏电阻器流入高电流或高电压时,MOV 本身可能被损坏、升温、冒烟、着火并发生爆裂。 为避免此种情况,可在 MOV 两端或电源两端安装保险丝或断电器; 以下规格之保险丝仅供参考使用: 直径 保险丝之额定电流 1-2A 05D 2-3A 07D 3-5A 10D 3-10A 14D 20D 5-15A 2)勿使压敏电阻器所流入的电流及能量超过其额定值. 3)注明的 VDR 产品商标名称和标记皆为本公司专利申请。 使用或销售未明确指定用于此类应用的 VDR 产品的客户自行承担风险。 4)所有 VDR 产品、产品规格和数据如有更改,恕不另行通知,请予以改进。对任何数据表 或任何其他数据表中 .包含的任何错误.不准确或不完整概不负责。 5)关于产品对特定应用的适用性。客户有责任确认具有产品规范中所述特性的产品适用于特定 应用。参数数据表和/或规范中提供的数据可能因不同的应用而不同,性能可能随时间而 变化。所有操作参数,包括典型参数,必须由客户的技术专家。产品规格不会扩大或 以其他方式修改 VDR 采购条款和条件,包括但不限于其中所述的保证。 6)请勿将易燃性物质置于压敏电阻器附近. 7)压敏电阻器仅可散发少量的热能, 因此不适合用于经常有突发热量产生的设备内. 此外,压敏电阻器所在的工作环境越高其所散发热能的比例就越小. 压敏电阻器仅可散发少量的热能, 因此不适合用于经常有突发热量产生的设备内. 如在瞬时间有较大的热量作用于压敏电阻上, 有可能因此热能不能在脉冲时间内散发出去 而导致压敏电阻器损坏. 8)焊接时, 请注意不要将压敏电阻器的焊接点及树脂涂料被熔化. 材料类别政策 VDR 所有产品特此证明皆符合 RoHS 的产品均符合欧洲议会和理事会指令 2011/65/EU 中定义和 限制 2011 年 6 月 8 日关于限制在电气和电子设备中使用某些有害物质(Reach)的规定。我们确认 所有 VDR 产品符合 IEC 61249-2-21 JEDEC JS709A 标准。 22
JEC07D471KS0517 价格&库存
很抱歉,暂时无法提供与“JEC07D471KS0517”相匹配的价格&库存,您可以联系我们找货
