RT12-ZZ-0023
RT12-ZZ-0023
    UDE
RT12-ZZ-0023 数据手册
To: Customer P/N: UDE P/N: RT12-ZZ-0023 Description: RJ45 1X1 Tab Up Through Hole Pure Connector Contact Area : Gold Flash LED: L-Yellow;R-Green Packing with Hard Tray Spec No. RT1217037-00 Approved Checked Update Date 2017/6/9 Revision A Prepared RT12-ZZ-0023 Spec No. : RT1217037-00 1. MECHANICAL DIMENSION 1.1 Product Dimension Unit : mm -1- General Tolerance : X.X : ± 0.38 X.XX : ± 0.20 www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 1.2 Recommended PCB Layout Component Side of Board All dimension tolerance are ±0.05mm unless otherwise specified Table1 Layout Trace component Grounding Test Point Via Hole PTH NPTH Component side X X O X X X O Inner layer O NA O NA O X O Bottom side O O O O O X O Layer X--Forbid; O--OK; NA--Not Applicable. -2- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 1.3 Recommended Panel Cutout 1.4 Packing Information 70 pcs finished goods per tray 7 trays(490 pcs finished goods) per inner box 4 Inner boxes(1960 pcs finished goods) per master carton -3- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 1.5 Standard RJ45 Plug Specification - All dimensions follow : FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i) IEC 60603-7 - All plugs must be meeting the requirements of plug Go & No-Go gauge. Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i) - There must be no damage to Housing and Locking Latch. - There must be no nicks and cuts in cable. - Durability : 750 cycles generally -4- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 2. REQUIREMENTS 2.1 Design and Construction Product shall be of design, construction and physical dimensions specified on applicable. 2.2 Material 2.2.1 Terminal Parts (Underplating : 50μ" min. Nickel overall) 2.2.1.1 RJ Terminal : Phosphor Bronze,Thickness=0.30mm Finish : Contact Area : Gold Flash Finish : Solder Tail : 100μ" min. Matte Tin 2.2.2 Plastic Parts 2.2.2.1 Housing : PBT, Black 2.2.3 Shield Parts 2.2.3.1 Shield : Stainless, Thickness=0.20mm, Pre-soldering -5- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 2.3 Operating and Storage Temperature Operating Temperature : -40°C to +85°C Storage Temperature : -40°C to +85°C 2.4 RJ45 specifications Insulation Resistance : 500MΩ min. Insertion force with the latch depressed : 20N max Removal force with the latch depressed :20N max Locking Force of Plug Latch : 50N min. @ 60+/-5 sec Durability : 750 cycles 2.5 Performance and Test Description Product is designed to meet electrical, mechanical and environmental performance requirements specified in below table. All tests are performed at ambient environmental conditions per MIL-STD-1344A and EIA-364 unless otherwise specified. 2.6 Packaging and Packing All parts shall be packaged and packed to protect against physical damage、corrosion and deterioration during shipment and storage. -6- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 3. ELECTRICAL CHARACTERISTICS 3.1 LED L1 L3 Green Yellow L4 L2 Emitting Color λp (nm) Vf @If=20mA Ir @Vr=5V Green 570 1.7 ~2.6 V 10μA max. Yellow 588 1.7 ~2.6 V 10μA max. -7- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 4. WAVE SOLDERING TEMPERATURE PROFILE -8- www.ude-corp.com RT12-ZZ-0023 Spec No. : RT1217037-00 5. Revision History Issue Date Revision 2017/6/9 A Comments Initial Release . Operator Mandy -9- www.ude-corp.com
RT12-ZZ-0023 价格&库存
很抱歉,暂时无法提供与“RT12-ZZ-0023”相匹配的价格&库存,您可以联系我们找货
