TPESD0514PA
Low Capacitance TVS Diode Array
www.sot23.com.tw
Features
Mechanical Characteristics
120 Watts Peak Pulse Power per Line (tp=8/20μs)
u
Package: DFN1616-6
u
Protects two or four I/O lines
u
Ultra low leakage: nA level
u
Low capacitance: 0.35 pF typical (I/O to I/O)
u
Case Material: “Green” Molding Compound.
u
Low operating voltage: 5V
u
UL Flammability Classification Rating 94V-0
u
RoHS Compliant
u
Moisture Sensitivity: Level 3 per J-STD-020
u
IEC61000-4-2 (ESD) ±25kV (air), ±20kV (contact)
u
IEC61000-4-4 (EFT) 40A (5/50ηs)
u
IEC61000-4-5 (Lightning) 4A (8/20μs)
IC
u
Applications
u
High Definition Multimedia Interface (HDMI)
Digital Visual Interface (DVI)
BL
u
Unified Display Interface (UDI)
u
MDDI Ports
u
PCI Express
PU
u
Ordering Information
Part Number
Qty per Reel
3000
Reel Size
7”
TE
TPESD0514PA
Serial ATA
CH
u
Dimensions and Pin Configuration
5 VCC
1
3
4
6
I/O 1
I/O 2
I/O 3
I/O 4
GND
1
I/O 4
VCC
I/O 3
6
5
4
1
2
3
I/O 1
NC
I/O 2
TPESD0514PA
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
120
W
Peak Pulse Current (8/20µs)
IPP
4
A
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
IC
Operating Temperature Range
±20
Storage Temperature Range
Tstg
−55 to +150
kV
°C
°C
Symbol
Reverse Working Voltage
Breakdown Voltage
Unit
5
V
Any I/O pin to ground
9
V
IT = 1mA, any I/O pin to ground
0.2
µA
VRWM = 5V, any I/O pin to ground
VC
9
V
IPP = 1A (8 x 20µs pulse), any I/O
pin to ground
VC
25
V
IPP = 4A (8 x 20µs pulse), any I/O
pin to ground
pF
VR = 0V, f = 1MHz, between I/O
pins
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
VRWM
VBR
IR
Min
Typ
6
CH
Reverse Leakage Current
TE
Clamping Voltage
Clamping Voltage
Max
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Junction Capacitance
CJ
0.35
CJ
0.6
2
0.8
Test Condition
TPESD0514PA
www.sot23.com.tw
Characteristic Curves
8/20μs Pulse Waveform
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
100
Peak Value IPP
80
100%
TEST
WAVEFORM
PARAMETERS
tr=8μs
td=20μs
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
10
15
CH
0.1
TE
Peak Pulse Power - PPK (kW)
1
0.01
0.1
1
10
100
tr = 0.7~1ns
Time (ns)
60ns
Fig4. Normalized Capacitance vs. Reverse Voltage
PU
Non - Repetitive Peak Pulse Power vs. Pulse Time
10
10%
30ns
30
t - Time (μs)
Fig3.
90%
BL
IPP - Peak Pulse Current - % of IPP
120
IC
Fig1.
1000
Pulse Duration - tp (μs)
3
TPESD0514PA
www.sot23.com.tw
Outline Drawing - DFN1616-6
DFN1616-6
A
DIM
A
B
C
D
E
F
G
H
J
K
K
H
J
G
E
CH
PU
F
BL
C
D
NOTE
IC
B
DIMENSIONS
INCHES
MM
MIN
MAX
MIN
MAX
0.061
0.065
1.55
1.65
0.061
0.065
1.55
1.65
0.035
0.041
0.90
1.05
0.020
0.026
0.50
0.65
0.008
0.012
0.20
0.30
0.020 REF.
0.50 REF.
0.20
0.30
0.008
0.026
0.50
0.60
0.020
0.024
0.000
0.002
0.00
0.05
0.15 REF.
0.006 REF.
Suggested Solder
Pad Layout
0.50
(mm)
TE
0.30
0.45 1.52
2.15 0.89
0.63
1.30
4
WWW.TECHPUBLIC.COM.TW
很抱歉,暂时无法提供与“TPESD0514PA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44410
- 100+0.35792
- 300+0.31482
- 3000+0.25326
- 6000+0.22734
- 9000+0.21438
