DC-DC Converters PCB Mount Type
10:1
Low Profile Isolated
Safety
Approvals
OCP
OVP
Remote
ON/OFF
Wide 4 :1
input
Ultra wide
10 : 1 input
MG-series
Feature
Industry Standard SIP6 (MG1R5/MG3), SIP8 (MG6/MG10), 1"X1" (MG15/MG40), 1"X2" (MG30/MG80)
Wide input range DC4.5-13V/DC9-36V/DC18-76V (MGFS/MGFW)
Ultra wide input range DC6-60V (MGXS/MGXW)
High efficiency by synchronized rectification circuit (MGS10/MGFS10/MGS15/MGFS15/MGS30/MGFS30/MGFS40/MGFW40/MGFS80/MGFW80)
6 sided shield (MG15/MG30/MG40/MG80)
I/O isolation voltage DC1,500V (1 minute)
Built-in overcurrent protection circuits (recovers automatically)
Built-in overvoltage protection circuits (MG30/MG40/MG80)
Built-in remote ON/OFF (MG6/MG10/MG15/MG30/MG40/MG80)
Output voltage adjustability by external variable resistor (MGS15/MGFS15/MGS30/MGFS30/MGFS40/MGFS80)
High reliability : not built-in aluminum and tantalum electrolytic capacitor
CE marking
Low Voltage Directive
RoHS Directive
Safety agency approvals
UL60950-1, C-UL, EN62368-1 (MG1R5/MG3/MG6/MG10/MG15/MG30)
UL62368-1, C-UL, EN62368-1 (MG40/MG80)
10-year warranty
Refer to the instruction manual
January 31, 2022
MG-1
Ordering information
MGS15
MG
1
S
2
15
3
24
4
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
G : Capacitor between
Input and Output is removed.
R : with Remote ON/OFF
(Positive logic control)
R
MODEL
MAX OUTPUT WATTAGE[W]
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
05
5
*1
MGS15123R3
13.2
3.3
4
MGS151205
15
5
3
MGS151212
15.6
12
1.3
MGS151215
15
15
1
MGS15243R3
13.2
3.3
4
MGS152405
15
5
3
MGS152412
15.6
12
1.3
MGS152415
15
15
1
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
TEMPERATURE REGULATION[mV]
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OUTPUT VOLTAGE ADJUSTMENT RANGE
OUTPUT VOLTAGE SETTING[V]*5
PROTECTION OVERCURRENT PROTECTION
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MGS15123R3 MGS151205 MGS151212 MGS151215 MGS15243R3 MGS152405
DC9 - 18
DC18 - 36
1.28typ
1.44typ
1.49typ
1.42typ
0.63typ
0.70typ
86typ
87typ
87typ
88typ
87typ
89typ
3.3
5
12
15
3.3
5
4
3
1.3
1
4
3
13.2max
20max
48max
60max
13.2max
20max
13.2max
20max
48max
60max
13.2max
20max
75max
75max
100max
100max
75max
75max
100max
100max
120max
120max
100max
100max
75max
75max
100max
100max
75max
75max
150max
150max
150max
150max
150max
150max
50max
50max
150max
180max
50max
50max
80max
80max
240max
290max
80max
80max
20max
20max
48max
60max
20max
20max
30max (Minimum input, Io=100%)
Fixed (TRM pin open) Available to adjust ±10% by external variable resister
3.296 - 3.404
4.975 - 5.137
11.857 - 12.243 14.839 - 15.321 3.296 - 3.404
4.975 - 5.137
Works over 105% of rating and recovers automatically
Provided (Negative logic L:ON, H:OFF)
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGS15483R3
13.2
3.3
4
*1
MGS154805
15
5
3
MGS154812
15.6
12
1.3
MGS154815
15
15
1
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MG-53
MGS15483R3 MGS154805 MGS154812 MGS154815
DC36 - 76
0.32typ
0.35typ
0.36typ
0.35typ
87typ
89typ
90typ
90typ
3.3
5
12
15
4
3
1.3
1
13.2max
20max
48max
60max
13.2max
20max
48max
60max
75max
75max
100max
100max
100max
100max
120max
120max
75max
75max
100max
100max
150max
150max
150max
150max
50max
50max
150max
180max
80max
80max
240max
290max
20max
20max
48max
60max
Fixed (TRM pin open) ±10% adjustable by external VR
3.296 - 3.404
4.975 - 5.137
January 31, 2022
MGS152412 MGS152415
0.73typ
89typ
12
1.3
48max
48max
100max
120max
100max
150max
150max
240max
48max
0.70typ
89typ
15
1
60max
60max
100max
120max
100max
150max
180max
290max
60max
MGS15
GENERAL SPECIFICATIONS
ISOLATION
INPUT-OUTPUT
DC1,500V 1minute, Cutoff current = 10mA, DC500V 1,000MW min (20±15C)
INPUT-CASE
DC1,000V 1minute, Cutoff current = 10mA, DC500V 1,000MW min (20±15C)
OUTPUT-CASE
OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 to 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max
ENVIRONMENT
SAFETY
OTHERS
STORAGE TEMP.,HUMID.AND ALTITUDE
-40 to +100C, 20 to 95%RH (Non condensing), 9,000m (30,000feet) max
VIBRATION
10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis
IMPACT
490.3m/s2 (50G), 11ms, once each along X, Y and Z axis
AGENCY APPROVALS
CASE SIZE/WEIGHT
25.4X9.9X25.4mm [1X0.39X1 inches] (WXHXD) / 20g max
COOLING METHOD
Convection/Forced air
*1 MGW15xx05/MGW15xx12/MGW15xx15 is available as single output, +10V/+24V/+30V
*2 Rated input 12V, 24V or 48V DC lo=100%
*3 Ripple and Ripple Noise is measured by using test board with ceramic capacitor 22 F at 50mm from output pins. (20MHz Osilloscope)
*4 Drift is the DC output accuracy for eight hours period after a half-hour warm-up at 25C.
*5 Rated input voltage (DC12V, DC24V, DC48V), rated output wattage, ambient temperature at 25C.
* Parallel operation with other model is not possible.
External view
Name Plate
¶Recommended Pad and Hole dia.
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
TRM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Tolerance ±0.5 [±0.02]
¶ Dimensions in mm, [ ]=inches
¶ Pin terminal material : Copper
¶ Plating treatment of terminal : Lead free plating
¶ Case material : Brass
¶ Plating treatment of case : Nickel plating
¶ Bottom Cover : FR4 (t=0.6) [t=0.024]
¶ Please keep enough creepage distance with the
pattern on PCB and other components.
¶ Weight 20g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-54
MGW15
MG
1
W
2
15
24
3
05
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGW151205 MGW151212 MGW151215 MGW152405 MGW152412 MGW152415 MGW154805 MGW154812 MGW154815
15
15.6
±5 or +10
±12 or +24 ±15 or +30 ±5 or +10
1.5
0.65
0.65
0.65
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
15
0.5
15
1.5
15.6
15
0.5
15
1.5
15.6
15
0.5
SPECIFICATIONS
INPUT
MODEL
VOLTAGE[V]
DC9 - 18
1.48typ
1.49typ
1.42typ
0.74typ
0.74typ
0.70typ
0.37typ
0.37typ
EFFICIENCY[%]
*2
84typ
87typ
88typ
84typ
88typ
89typ
84typ
89typ
89typ
VOLTAGE[V]
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
CURRENT[A]
1.5
0.65
0.5
1.5
0.65
0.5
1.5
0.65
0.5
LINE REGULATION[mV]
40max
60max
75max
40max
60max
75max
40max
60max
75max
RIPPLE[mVp-p]
*6
RIPPLE NOISE[mVp-p]
*6
0.35typ
*3
500max *5
600max
750max
500max *5
600max
750max
500max *5
600max
750max
*4
250max
480max
600max
250max
480max
600max
250max
480max
600max
-20 to +60C 100max
100max
100max
100max
100max
100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
120max
120max
120max
120max
120max
-20 to +60C 100max
100max
100max
100max
100max
100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
150max
150max
150max
150max
150max
-20 to +60C 50max
150max
180max
50max
150max
180max
50max
150max
180max
-40 to +60C 80max
240max
290max
80max
240max
290max
80max
240max
290max
50max
60max
50max
50max
60max
50max
50max
60max
DRIFT[mV]
*7
START-UP TIME[ms]
50max
OUTPUT VOLTAGE SETTING[V]*8 4.935 - 5.240
CIRCUIT AND
REMOTE ON/OFF
OTHERS
ISOLATION
DC36 - 76
*2
LOAD REGULATION[mV]
OUTPUT
DC18 - 36
CURRENT[A]
11.765 - 12.492 14.602 - 15.505 4.935 - 5.240
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
*1 Single output +10V, +24V, +30V with no use of COM.
*2 Rated input 12V, 24V or 48V lo=100%
*3 An output load is 100%, the other load is 5% to 100%.
*4 An output load is 100%, the other load is 20% to 100%.
*5 Refer to the instruction manual 11.
*6 Ripple and Ripple Noise is measured by using test board with ceramic capacitor 22 F at
*7 Drift is the DC output accuracy for eight hours period after a half-hour warm-up at 25C.
MG-55
*8 Rated input voltage (DC12V, DC24V, DC48V), rated output wattage, ambient temperature
at 25C.
January 31, 2022
MGW15
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
COM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Weight 20g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-56
MGS30
MG
1
S
2
30
3
24
4
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
05
5
MGS301215
30
15
2
MGS30243R3
26.4
3.3
8
MGS302405
30
5
6
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND OVERVOLTAGE PROTECTION
OTHERS
REMOTE ON/OFF
MGS30123R3 MGS301205 MGS301212 MGS301215
DC9 - 18
2.45typ
2.75typ
2.78typ
2.78typ
90typ
91typ
90typ
90typ
3.3
5
12
15
8
6
2.5
2
13.2max
20max
48max
60max
13.2max
20max
48max
60max
75max
75max
100max
100max
100max
100max
120max
120max
75max
75max
100max
100max
150max
150max
150max
150max
50max
50max
150max
180max
80max
80max
240max
290max
20max
20max
48max
60max
3.296 - 3.404
4.975 - 5.137
Works over 120 to 160% of rating
MGS30243R3
DC18 - 36
1.21typ
91typ
3.3
8
13.2max
13.2max
75max
100max
75max
150max
50max
80max
20max
MGS302405 MGS302412 MGS302415
1.36typ
92typ
5
6
20max
20max
75max
100max
75max
150max
50max
80max
20max
1.36typ
92typ
12
2.5
48max
48max
100max
120max
100max
150max
150max
240max
48max
3.296 - 3.404
4.975 - 5.137
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGS30483R3
26.4
3.3
8
*1
MGS30123R3
26.4
3.3
8
MGS301205
30
5
6
MGS301212
30
12
2.5
MGS302412
30
12
2.5
MGS302415
30
15
2
SPECIFICATIONS
*1
MGS304805
30
5
6
MGS304812
30
12
2.5
MGS304815
30
15
2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MG-57
MGS30483R3 MGS304805 MGS304812 MGS304815
DC36 - 76
0.61typ
0.68typ
0.68typ
0.68typ
91typ
92typ
92typ
92typ
3.3
5
12
15
8
6
2.5
2
13.2max
20max
48max
60max
13.2max
20max
48max
60max
75max
75max
100max
100max
100max
100max
120max
120max
75max
75max
100max
100max
150max
150max
150max
150max
50max
50max
150max
180max
80max
80max
240max
290max
20max
20max
48max
60max
3.296 - 3.404
4.975 - 5.137
January 31, 2022
1.36typ
92typ
15
2
60max
60max
100max
120max
100max
150max
180max
290max
60max
MGS30
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
25.4X9.9X50.8mm [1X0.39X2 inches] (WXHXD) / 40g max
COOLING METHOD
*1 MGW30xx05/MGW30xx12/MGW30xx15 is available as single output, +10V/+24V/+30V
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
-Vout
RC
5.08
[0.2]
TRM
¶ Weight 40g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-58
MGW30
MG
1
W
2
30
24
3
05
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGW301205 MGW301212 MGW301215 MGW302405 MGW302412 MGW302415 MGW304805 MGW304812 MGW304815
25
30
±5 or +10
2.5
1.25
1.25
1.25
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
30
1
25
2.5
30
30
1
25
2.5
30
30
1
SPECIFICATIONS
INPUT
MODEL
VOLTAGE[V]
DC9 - 18
DC36 - 76
*2
2.42typ
2.78typ
2.78typ
1.20typ
1.38typ
1.38typ
0.60typ
0.70typ
EFFICIENCY[%]
*2
86typ
90typ
90typ
87typ
91typ
91typ
87typ
90typ
90typ
VOLTAGE[V]
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
CURRENT[A]
2.5
1.25
1
2.5
1.25
1
2.5
1.25
1
LINE REGULATION[mV]
40max
60max
75max
40max
60max
75max
40max
60max
75max
*3
500max *5
600max
750max
500max *5
600max
750max
500max *5
600max
750max
*4
250max
480max
600max
250max
480max
600max
250max
480max
600max
-20 to +60C 100max
100max
100max
100max
100max
100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
120max
120max
120max
120max
120max
-20 to +60C 100max
100max
100max
100max
100max
100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
150max
150max
150max
150max
150max
-20 to +60C 50max
150max
180max
50max
150max
180max
50max
150max
180max
-40 to +60C 80max
240max
290max
80max
240max
290max
80max
240max
290max
50max
60max
50max
50max
60max
50max
50max
60max
LOAD REGULATION[mV]
RIPPLE[mVp-p]
OUTPUT
DC18 - 36
CURRENT[A]
*6
RIPPLE NOISE[mVp-p]
*6
DRIFT[mV]
*7
START-UP TIME[ms]
50max
0.70typ
PROTECTION OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically
CIRCUIT AND OVERVOLTAGE PROTECTION Works over 120 to 160% of rating (Total of +V and -V)
OTHERS
REMOTE ON/OFF
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
*3 Symmetrical loading from 5% to 100%.
*4 Symmetrical loading from 20% to 100%.
MG-59
at 25C.
January 31, 2022
MGW30
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
COM
RC
5.08
[0.2]
-Vout
¶ Weight 40g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-60
MGFS15
MGF
1
S
2
15
3
05
5
*1
MGFS15243R3
13.2
3.3
4
MGFS152405
15
5
3
MGFS152412
15.6
12
1.3
MGFS152415
15
15
1
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MGFS15243R3
MGFS152405
DC9 - 36
0.63typ
0.71typ
87typ
88typ
3.3
5
4
3
13.2max
20max
13.2max
20max
75max
75max
100max
100max
75max
75max
150max
150max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
MGFS152412
MGFS152415
0.73typ
89typ
12
1.3
48max
48max
100max
120max
100max
150max
150max
240max
48max
0.70typ
89typ
15
1
60max
60max
100max
120max
100max
150max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGFS15483R3
13.2
3.3
4
MGFS154812
15.6
12
1.3
MGFS154815
15
15
1
MGFS154812
MGFS154815
0.37typ
88typ
12
1.3
48max
48max
100max
120max
100max
150max
150max
240max
48max
0.35typ
89typ
15
1
60max
60max
100max
120max
100max
150max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
*1
MGFS154805
15
5
3
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MG-61
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
24
4
MGFS15483R3
MGFS154805
DC18 - 76
0.32typ
0.36typ
87typ
88typ
3.3
5
4
3
13.2max
20max
13.2max
20max
75max
75max
100max
100max
75max
75max
150max
150max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
January 31, 2022
MGFS15
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
*1 MGFW15xx05/MGFW15xx12/MGFW15xx15 is available as single output, +10V/+24V/+30V
*5 Rated input voltage (DC24V, DC48V), rated output wattage, ambient temperature at 25C.
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
TRM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Weight 20g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-62
MGFW15
MGF
1
W
2
15
24
3
05
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGFW152405
MGFW152412
MGFW152415
MGFW154805
MGFW154812
MGFW154815
15
15.6
15
15
15.6
15
±5 or +10
±12 or +24
±15 or +30
±5 or +10
±12 or +24
±15 or +30
1.5
0.65
0.5
1.5
0.65
0.5
MODEL
MGFW152405
MGFW152412
MGFW152415
MGFW154805
MGFW154812
MGFW154815
VOLTAGE[V]
DC9 - 36
0.36typ
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
SPECIFICATIONS
INPUT
CURRENT[A]
*2
0.74typ
0.74typ
0.70typ
0.37typ
0.37typ
EFFICIENCY[%]
*2
84typ
88typ
89typ
84typ
87typ
88typ
VOLTAGE[V]
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
CURRENT[A]
1.5
0.65
0.5
1.5
0.65
0.5
LINE REGULATION[mV]
40max
60max
75max
40max
60max
75max
*3
500max *5
600max
750max
500max *5
600max
750max
*4
250max
480max
600max
250max
480max
600max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
120max
120max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
150max
150max
-20 to +60C 50max
150max
180max
50max
150max
180max
-40 to +60C 80max
240max
290max
80max
240max
290max
50max
60max
50max
50max
60max
14.602 - 15.505
4.935 - 5.240
11.765 - 12.492
14.602 - 15.505
LOAD REGULATION[mV]
RIPPLE[mVp-p]
OUTPUT
*6
RIPPLE NOISE[mVp-p]
*6
DRIFT[mV]
*7
START-UP TIME[ms]
50max
CIRCUIT AND
REMOTE ON/OFF
OTHERS
ISOLATION
DC18 - 76
11.765 - 12.492
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
MG-63
*8 Rated input voltage (DC24V, DC48V), rated output wattage, ambient temperature at 25C.
January 31, 2022
MGFW15
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
COM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Weight 20g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-64
MGFS30
MGF
1
S
2
30
3
05
5
*1
MGFS30243R3
24.75
3.3
7.5
MGFS302405
30
5
6
MGFS302412
30
12
2.5
MGFS302415
30
15
2
MGFS302412
MGFS302415
1.40typ
89typ
12
2.5
48max
48max
100max
120max
100max
150max
150max
240max
48max
1.40typ
89typ
15
2
60max
60max
100max
120max
100max
150max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
MGFS304812
30
12
2.5
MGFS304815
30
15
2
MGFS304812
MGFS304815
0.70typ
89typ
12
2.5
48max
48max
100max
120max
100max
150max
150max
240max
48max
0.70typ
89typ
15
2
60max
60max
100max
120max
100max
150max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MGFS30243R3
MGFS302405
DC9 - 36
1.16typ
1.39typ
89typ
90typ
3.3
5
7.5
6
13.2max
20max
13.2max
20max
75max
75max
100max
100max
75max
75max
150max
150max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGFS30483R3
24.75
3.3
7.5
*1
MGFS304805
30
5
6
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MG-65
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
24
4
MGFS30483R3
MGFS304805
DC18 - 76
0.58typ
0.70typ
89typ
90typ
3.3
5
7.5
6
13.2max
20max
13.2max
20max
75max
75max
100max
100max
75max
75max
150max
150max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
January 31, 2022
MGFS30
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
*1 MGFW30xx05/MGFW30xx12/MGFW30xx15 is available as single output, +10V/+24V/+30V
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
-Vout
RC
5.08
[0.2]
TRM
¶ Weight 40g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-66
MGFW30
MGF
1
W
2
30
24
3
05
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGFW302405
MGFW302412
MGFW302415
MGFW304805
MGFW304812
MGFW304815
30
30
±5 or +10
±12 or +24
±15 or +30
±5 or +10
±12 or +24
±15 or +30
2
1.25
1
2
1.25
1
MODEL
MGFW302405
MGFW302412
MGFW302415
MGFW304805
MGFW304812
MGFW304815
VOLTAGE[V]
DC9 - 36
0.72typ
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
SPECIFICATIONS
INPUT
CURRENT[A]
*2
0.98typ
1.42typ
1.44typ
0.49typ
0.71typ
EFFICIENCY[%]
*2
85typ
88typ
87typ
85typ
88typ
87typ
VOLTAGE[V]
±5(+10)
±12(+24)
±15(+30)
±5(+10)
±12(+24)
±15(+30)
CURRENT[A]
2
1.25
1
2
1.25
1
LINE REGULATION[mV]
40max
60max
75max
40max
60max
75max
*3
500max *5
600max
750max
500max *5
600max
750max
*4
250max
480max
600max
250max
480max
600max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
120max
120max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
150max
150max
-20 to +60C 50max
150max
180max
50max
150max
180max
-40 to +60C 80max
240max
290max
80max
240max
290max
50max
60max
50max
50max
60max
14.602 - 15.505
4.935 - 5.240
11.765 - 12.492
14.602 - 15.505
LOAD REGULATION[mV]
RIPPLE[mVp-p]
OUTPUT
DC18 - 76
*6
RIPPLE NOISE[mVp-p]
*6
DRIFT[mV]
*7
START-UP TIME[ms]
50max
11.765 - 12.492
OTHERS
REMOTE ON/OFF
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
MG-67
January 31, 2022
MGFW30
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
COM
RC
5.08
[0.2]
-Vout
¶ Weight 40g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-68
MGFS40
MGF
1
S
2
40
3
24
4
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
05
5
*1
MGFS40053R3
26.4
3.3
8
MGFS400505
30
5
6
MGFS400512
30
12
2.5
MGFS400515
30
15
2
MGFS40243R3
33
3.3
10
MGFS402405
40
5
8
MGFS402412
40.8
12
3.4
MGFS402415
40.5
15
2.7
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MGFS40053R3 MGFS400505 MGFS400512 MGFS400515
DC4.5 - 13 (Surge Voltage 15V, 100ms max)
6.21typ
6.90typ
6.90typ
6.82typ
85typ
87typ
87typ
88typ
3.3
5
12
15
8
6
2.5
2
13.2max
20max
48max
60max
13.2max
20max
48max
60max
75max
75max
100max
100max
100max
100max
120max
120max
75max
75max
100max
100max
150max
150max
150max
150max
50max
50max
150max
180max
80max
80max
240max
290max
20max
20max
48max
60max
30max (Minimum input, Rated load)
3.296 - 3.404
4.975 - 5.137
Work over 115 to 140% of rating
MGFS40243R3 MGFS402405 MGFS402412
DC9 - 36 (Surge Voltage 50V, 100ms max)
1.54typ
1.83typ
1.85typ
89typ
91typ
92typ
3.3
5
12
10
8
3.4
13.2max
20max
48max
13.2max
20max
48max
75max
75max
100max
100max
100max
120max
75max
75max
100max
150max
150max
150max
50max
50max
150max
80max
80max
240max
20max
20max
48max
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGFS40483R3
33
3.3
10
MGFS404812
40.8
12
3.4
MGFS404815
40.5
15
2.7
MGFS404812
MGFS404815
0.92typ
92typ
12
3.4
48max
48max
100max
120max
100max
150max
150max
240max
48max
0.92typ
92typ
15
2.7
60max
60max
100max
120max
100max
150max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
*1
MGFS404805
40
5
8
3.296 - 3.404
4.975 - 5.137
MGFS402415
1.83typ
92typ
15
2.7
60max
60max
100max
120max
100max
150max
180max
290max
60max
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
*3 -40 to -20C
-20 to +60C
RIPPLE NOISE[mVp-p]
OUTPUT
*3 -40 to -20C
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MG-69
MGFS40483R3
MGFS404805
DC18 - 76 (Surge Voltage 100V, 100ms max)
0.77typ
0.92typ
89typ
91typ
3.3
5
10
8
13.2max
20max
13.2max
20max
75max
75max
100max
100max
75max
75max
150max
150max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
January 31, 2022
MGFS40
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 to 95%RH (Non condensing) (Refer to “Derating”), 5,000m (16,400feet) max
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
UL62368-1, C-UL(CSA62368-1), EN62368-1
CASE SIZE/WEIGHT
25.4X9.9X25.4mm (WXHXD) / 30g max
COOLING METHOD
*1 MGFW40xx12/MGFW40xx15 is available as single output +24V/+30V
*2 Rated input voltage (DC5V, DC24V, DC48V) Io=100%
*3 Riple and Ripple Noise is measured by using test board with ceramic capacitor 22μF and Recommended Capacitance at 50mm from output pins. (20MHz Oscilloscope)
*4 Drift is the DC output accuracy for eight hour period after a half-hour warm-up at 25C
*5 Rated input voltage (DC5V, DC24V, DC48V), rated output wattage, ambient temperature at 25C
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
TRM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Weight 30g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-70
MGFW40
MGF
1
W
2
40
24
3
12
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGFW400512
MGFW400515
MGFW402412
MGFW402415
MGFW404812
MGFW404815
31.2
30
40.8
42
40.8
42
±12 or +24
±15 or +30
±12 or +24
±15 or +30
±12 or +24
±15 or +30
1.3
1
1.7
1.4
1.7
1.4
MODEL
MGFW400512
MGFW400515
MGFW402412
MGFW402415
MGFW404812
MGFW404815
VOLTAGE[V]
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
SPECIFICATIONS
INPUT
CURRENT[A]
*2
7.26typ
6.90typ
1.87typ
1.92typ
0.93typ
EFFICIENCY[%]
*2
86typ
87typ
91typ
91typ
91typ
91typ
VOLTAGE[V]
±12(+24)
±15(+30)
±12(+24)
±15(+30)
±12(+24)
±15(+30)
CURRENT[A]
1.3
1
1.7
1.4
1.7
1.4
LINE REGULATION[mV]
60max
75max
60max
75max
60max
75max
*3
600max
750max
600max
750max
600max
750max
*4
LOAD REGULATION[mV]
RIPPLE[mVp-p]
OUTPUT
*5
RIPPLE NOISE[mVp-p]
*5
0.96typ
480max
600max
480max
600max
480max
600max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
120max
120max
-20 to +60C 100max
100max
100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
150max
150max
-20 to +60C 150max
180max
150max
180max
150max
180max
-40 to +60C 240max
290max
240max
290max
240max
290max
60max
50max
60max
50max
60max
11.765 - 12.492
14.602 - 15.505
11.765 - 12.492
14.602 - 15.505
DRIFT[mV]
*6
START-UP TIME[ms]
50max
OUTPUT VOLTAGE SETTING[V]*7 11.765 - 12.492
14.602 - 15.505
CIRCUIT AND OVERVOLTAGE PROTECTION Work over 115 to 140% of rating (Total of +Vo and -Vo)
OTHERS
REMOTE ON/OFF
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
UL62368-1, C-UL (CSA62368-1), EN62368-1
CASE SIZE/WEIGHT
COOLING METHOD
*1 Single output +24V/+30V with no use of COM
*2 Rated input voltage(DC5V , DC24V, DC48V) Io=100%
*3 Symmetrical loading from 0% to 100%
*5 Riple and Ripple Noise is measured by using test board with ceramic capacitor 22μF and
*6 Drift is the DC output accuracy for eight hour period after a half-hour warm-up at 25C
MG-71
*7 Rated input voltage (DC5V, DC24V, DC48V), rated output wattage, ambient temperature
at 25C
January 31, 2022
MGFW40
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
10.16
[0.4]
+Vout
2.54
[0.1]
25.4
[1.0]
COM
-Vin
10.16
[0.4]
7.62
[0.3]
5.08
[0.2]
+Vin
RC
-Vout
¶ Weight 30g max
20.32
[0.8]
25.4
[1.0]
January 31, 2022
MG-72
MGFS80
MGF
1
S
2
80
3
05
5
*1
MGFS80243R3
59.4
3.3
18
MGFS802405
80
5
16
MGFS802412
80.4
12
6.7
MGFS802415
81
15
5.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
-40 to -20C
*3
Io=0 to 10%
-20 to +60C
OUTPUT
RIPPLE NOISE[mVp-p]
-40 to -20C
*3
Io=0 to 10%
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MGFS80243R3
MGFS802405
2.69typ
3.60typ
92typ
93typ
3.3
5
18
16
13.2max
20max
20max
20max
75max
75max
100max
100max
200max
200max
75max
75max
150max
150max
250max
250max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
MGFS802412
MGFS802415
3.56typ
94typ
12
6.7
48max
48max
100max
120max
240max
100max
150max
270max
150max
240max
48max
3.59typ
94typ
15
5.4
60max
60max
100max
120max
240max
100max
150max
270max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
MGFS80483R3
59.4
3.3
18
MGFS804812
80.4
12
6.7
MGFS804815
81
15
5.4
MGFS804812
MGFS804815
1.78typ
94typ
12
6.7
48max
48max
100max
120max
240max
100max
150max
270max
150max
240max
48max
1.80typ
94typ
15
5.4
60max
60max
100max
120max
240max
100max
150max
270max
180max
290max
60max
11.857 - 12.243
14.839 - 15.321
*1
MGFS804805
80
5
16
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +60C
RIPPLE[mVp-p]
-40 to -20C
*3
Io=0 to 10%
-20 to +60C
OUTPUT
RIPPLE NOISE[mVp-p]
-40 to -20C
*3
Io=0 to 10%
-20 to +60C
-40 to +60C
*4
DRIFT[mV]
START-UP TIME[ms]
OTHERS
REMOTE ON/OFF
MG-73
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
VOLTAGE[V]
DC OUTPUT
CURRENT[A]
24
4
MGFS80483R3
MGFS804805
1.35typ
1.80typ
92typ
93typ
3.3
5
18
16
13.2max
20max
20max
20max
75max
75max
100max
100max
200max
200max
75max
75max
150max
150max
250max
250max
50max
50max
80max
80max
20max
20max
3.296 - 3.404
4.975 - 5.137
January 31, 2022
MGFS80
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
25.4X9.9X50.8mm (WXHXD) / 50g max
COOLING METHOD
*1 MGFW80xx12/MGFW80xx15 is available as single output +24V/+30V
*2 Rated input voltage (DC24V, DC48V) Io=100%
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
-Vout
RC
5.08
[0.2]
TRM
¶ Weight 50g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-74
MGFW80
MGF
1
W
2
80
3
24
12
4
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MGFW802412
MGFW802415
MGFW804812
MGFW804815
81.6
81
81.6
81
±12 or +24
±15 or +30
±12 or +24
±15 or +30
3.4
2.7
3.4
2.7
MODEL
MGFW802412
MGFW802415
MGFW804812
MGFW804815
VOLTAGE[V]
VOLTAGE[V]
DC OUTPUT
*1
CURRENT[A]
SPECIFICATIONS
INPUT
CURRENT[A]
*2
3.62typ
3.59typ
1.81typ
1.80typ
EFFICIENCY[%]
*2
94typ
94typ
94typ
94typ
VOLTAGE[V]
±12 or +24
±15 or +30
±12 or +24
±15 or +30
CURRENT[A]
3.4
2.7
3.4
2.7
LINE REGULATION[mV]
60max
75max
60max
75max
*3
600max
750max
600max
750max
*4
480max
600max
480max
600max
-20 to +60C 100max
100max
100max
100max
-40 to -20C 120max
120max
120max
120max
Io=0 to 10% 240max
240max
240max
240max
-20 to +60C 100max
100max
100max
100max
-40 to -20C 150max
150max
150max
150max
Io=0 to 10% 270max
270max
270max
270max
-20 to +60C 150max
180max
150max
180max
-40 to +60C 240max
290max
240max
290max
60max
50max
60max
11.765 - 12.492
14.602 - 15.505
LOAD REGULATION[mV]
RIPPLE[mVp-p]
*5
OUTPUT
RIPPLE NOISE[mVp-p]
*5
DRIFT[mV]
*6
START-UP TIME[ms]
50max
14.602 - 15.505
OTHERS
REMOTE ON/OFF
ISOLATION
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
SAFETY
OTHERS
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
*2 Rated input voltage(DC24V, DC48V) Io=100%
MG-75
*7 Rated input voltage (DC24V, DC48V), rated output wattage, ambient temperature at 25C
January 31, 2022
MGFW80
External view
Name Plate
(TOP VIEW)
6-f1.5
9.9
[0.39]
Case
3.5
[0.14]
Bottom Cover
f 1 ±0.1
¶ Unit : 0.1inch
¶ Dimension : mm
+Vout
10.16
[0.4]
5.08
[0.2]
+Vin
-Vin
25.4
[1.0]
10.16
[0.4]
10.16
[0.4]
COM
RC
5.08
[0.2]
-Vout
¶ Weight 50g max
45.72
[1.8]
50.8
[2.0]
January 31, 2022
MG-76
MG15,MG30,MG40,MG80-series
Pin configuration
¿MG15/MG40 Single Output and Dual (±) Output
3
Input
2
1
-Vout
RC
-Vin
TRM
Pin No.
1
2
3
4
6
Load
5
+Vin
+Vout
4
5
(a) Single Output
3
Input
2
1
RC
-Vin
-Vout
6
6
Pin Name
+Vin
-Vin
RC
+Vout
TRM
COM
-Vout
Function
+DC Input
-DC Input
Remote ON/OFF
+DC Output
Output Voltage Adjustment (Refer to
instruction manual 1.5)
GND of Output Voltage (for Dual Output)
-DC Output
Load
COM
+Vin
+Vout
5
Load
Load
4
(b) Dual (±) Output
¿MG30/MG80 Single Output and Dual (±) Output
3
Input
2
1
RC
-Vin
+Vin
TRM
6
-Vout
5
+Vout
Pin No.
1
2
3
4
Load
4
5
6
6
(a) Single Output
3
Input
2
1
-Vout
RC
Pin Name
+Vin
-Vin
RC
+Vout
-Vout
COM
TRM
-Vout
Function
+DC Input
-DC Input
Remote ON/OFF
+DC Output
-DC Output (for Single Output)
-DC Output (for Dual Output)
Load
-Vin
COM
+Vin
+Vout
5
Load
Load
4
(b) Dual (±) Output
Assembling and Installation Method
Installation
¡When two or more power supplies are used side by side, position them with proper intervals to allow enough air ventilation. Ambient temperature around each power supply should not exceed the temperature range shown in “Derating”.
Soldering Conditions
(1) Flow Soldering : 260ª 15 seconds or less
(2) Soldering Iron : maximum 360ª 5 seconds or less
Stress to Pin
¡Applying excessive stress to the input or output pins of the power module may damage internal
connections. Avoid applying stress in excess of that shown in right figure.
¡Input/output pin are soldered to the PCB internally. Do not pull or bend a lead powerfully.
¡If it is expected that stress is applied to the input/output pin due to vibration or impact, reduce
the stress to the pin by taking such measures as fixing the unit to the PCB by silicone rubber,
etc.
¡Due to prevent failure, PS should not be pulled after soldering with PCB.
MG-77
January 31, 2022
19.6N (2kgf)
or less
19.6N (2kgf)
or less
Derating
Derating curve for input voltage
¿MGF O 4005 O
¿MGFO4024O, MGFO4048O, MGFO8024O and MGFO8048O
Load factor [%]
100
Load factor [%]
100
70
9
80
18
Input Voltage [V]
12
24
36
76
18
36
Input Voltage [V]
Ambient temperature derating curve
¡It is necessary to note thermal fatigue life by power cycle. Please reduce the temperature fluctuation range as much as possible when the
up and down of temperature are frequently generated.
¡In case of forced air, ventilation must keep the temperature of point below the temperatures shown in Instruction Manual 7.
¿MG15/MGF15 (Rated Input Voltage)
(2) In the case of Forced Air Cooling (1.0m/s)
(Excluding MGW15O05/MGFW15O05)
(1) In the case of Convection Cooling
100
Load factor [%]
Load factor [%]
100
2
1
Natural Convection
1 MGW15O05 / MGFW15O05
2 others
50
- 20
(55) 60
80 (85)
Forced air (1.0m/s)
50
100
- 20
60
80 (85)
100
80 (85)
100
Ambient temperature Ta [C]
(3) In the case of Forced Air Cooling (1.0m/s, 2.5m/s)
(MGW15O05/MGFW15O05)
Load factor [%]
100
1
Forced air
1 1.0 m/s
2 2.5 m/s
50
- 20
60
2
80 (85)
100
¿MG30/MGF30 (Rated Input Voltage)
(Excluding MGW30O05 and MGFW30O12/15)
100
3
2
1
Natural Convection
1 MGFS302412
MGFW302415 / 4815
2 MGFS302415 / 4812 / 4815
3 others
50
- 20
Load factor [%]
Load factor [%]
100
(55) 60
80 (85)
100
Forced air (1.0m/s)
50
- 20
60
(3) In the case of Forced Air Cooling (1.0m/s, 1.5m/s)
(MGW30O05 and MGFW30O12/15)
Load factor [%]
100
50
1
Forced air
1 1.0 m/s
2 1.5 m/s
- 20
60
2
80 (85)
100
January 31, 2022
MG-78
Derating
¿MGF40 (Rated Input Voltage)
100
Load factor [%]
100
Load factor [%]
A B C D E F
50
- 20
80 (85)
Forced air (1.0m/s)
50
100
- 20
Input Voltage[V]
5
24
48
3.3
B
E
F
5
A
D
D
60
80 (85)
100
80 (85)
100
Output Voltage[V]
12
15
±12
B
C
B
E
F
E
F
E
E
±15
B
E
E
¿MGF80 (Rated Input Voltage)
100
Load factor [%]
100
Load factor [%]
A B C D
50
- 20
(55) 60 (65)
80 (85)
Forced air (1.0m/s)
50
100
- 20
Input Voltage[V]
24
48
3.3
B
C
5
A
B
60
Output Voltage[V]
12
15
±12
C
C
C
C
D
C
±15
C
C
Instruction Manual
◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product.
Instruction Manual
https://en.cosel.co.jp/product/powersupply/MGS/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/MGW/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/MGFS/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/MGFW/
https://en.cosel.co.jp/technical/caution/index.html
MGS
MGW
MGFS
MGFW
NOTICE
Basic Characteristics Data
Model
Circuit method
Switching
frequency
[kHz]
(reference)
Input
current
[A]
Inrush
current
protection
Material
Series/Parallel
operation availability
PCB/Pattern
Single
sided
Double
sided
Series
operation
Parallel
operation
MG15
Flyback converter
445-495
*1
glass fabric base,epoxy resin
Yes
Yes
*2
MGF15
Flyback converter
445-495
*1
Yes
Yes
*2
MG30
Forward converter
380-460
*1
Yes
Yes
*2
MGF30
Forward converter
380-460
*1
Yes
Yes
*2
MGF40
Flyback converter
100-1500 *3
*1
Yes
Yes
*2
MGF80
Flyback converter
100-1500 *3
*1
Yes
Yes
*2
*1 R
efer to Specification.
*2 Refer
to Instruction Manual.
*3 The value changes depending on input and load.
MG-79
January 31, 2022
