PELB5VB1
PELB5VB1
    PRISEMI(上海芯导电子)
    SMB(DO-214AA)
    PELB5VB1接入设备和用户端设备,使其免受电信线路及其他线路上的静电放电(ESD)和雷击影响。DO - 214AA固态保护器件可保护调制解调器、线卡、传真机等电信设备及其他用户端设备(CPE)。该...
PELB5VB1 数据手册
PELB5VB1 ESD & Lightning Protector Description Prisemi’s PELB5VB1 protects central office access and customer premise equipment against ESD and lightning on the telecom line and others. DO-214AA solid state protection devices protect telecommunications equipment such as modems, line cards, fax machines, and other CPE. The device is used to enable equipment to meet various regulatory requirements including IEC61000-4-2, IEC62000-4-5, GR 1089, ITU K.20, K.21 and K.45, IEC 60950, UL 60950, and TIA-968 (formerly known as FCC Part 68). Feature Compared to surge suppression using other technologies, PELB5VB1 offer absolute surge protection regardless of the surge +I current available and the rate of applied voltage (dv/dt). PELB5VB1: ¾ Cannot be damaged by ESD and lightning ¾ Eliminate hysteresis and heat dissipation typically found with IT IS IH clamping devices ¾ Eliminate voltage overshoot caused by fast-rising transients ¾ Have low capacitance, making them ideal for high-speed IDRM -V VDRM VS VT transmission equipment +V -I Electrical Parameters Parameter Symbol Conditions Reverse Stand-off Voltage VRWM Reverse Breakdown Voltage VBR It = 1mA Reverse Leakage Current IR VRWM = 5V T=25℃ Junction Capacitance Cj VR=2V Hold Current IH Min. Typ. Max. Units 5 V 6.2 V 1 f = 1MHz 80 μA pF 30 50 mA Surge Ratings Series IPP 2x10 µs Amps IPP 8x20 µs Amps IPP 10x160 µs Amps IPP 10x560 µs Amps IPP 10x1000 µs Amps ITSM 60 Hz Amps di/dt Amps/µs B 250 250 150 100 80 30 500 Rev.06.2 1 www.prisemi.com ESD & Lightning Protector PELB5VB1 Thermal Considerations Package DO-214AA Symbol Parameter Operating Junction Temperature Storage Temperature Range Thermal Resistance: Junction to Ambient TJ TS 2.4 10 2.2 8 2.0 IH / IH(TC=℃) 12 6 4 2 25℃ 0 Ratio of Percent VS Change - % RBJA -2 -4 -6 Value Unit - 40 to +150 °C - 65 to +150 °C 90 °C/W 1.8 1.6 1.4 25℃ 1.2 1.0 0.8 0.6 -8 0.4 -40 -20 0 20 40 60 80 100 120 140 160 -40 -20 0 20 40 60 80 100 120 140 160 Case Temperature (TC) - ℃ Junction Temperature (TJ) - ℃ Fig 1.Normalized VS Change vs. Junction Temperature Fig 2. Normalized DC Holding Current versus IPP – Peak Pulse Current - % of IPP Case Temperature Peal Value 100 tr =rise time to peak value td =decay time to half value Waveform =tr× td Half Value 50 0 tr td t-Time(μs) Fig 3. tr × td Pulse Wave-form Rev.06.2 2 www.prisemi.com ESD & Lightning Protector PELB5VB1 Product dimension(DO-214AA/SMB) B D C A H F L E J K G 0.071 (1.8) 0.090 (2.3) 0.098 (2.5) INCHES DIMENSIONS ARE : (Millimeters) Dimension Inches Millimeters MIN MAX MIN MAX A 0.134 0.155 3.40 3.94 B 0.205 0.220 5.21 5.59 C 0.075 0.083 1.90 2.11 D 0.166 0.185 4.22 4.70 E 0.036 0.056 0.91 1.42 F 0.073 0.087 1.85 2.10 G 0.002 0.008 0.05 0.20 H 0.077 0.094 1.95 2.40 J 0.043 0.053 1.09 1.35 K 0.008 0.014 0.20 0.35 L 0.039 0.049 0.99 1.24 Ordering information Rev.06.2 Device Package Shipping PELB5VB1 SMB(Pb-Free) 3000 / Tape & Reel 3 www.prisemi.com ESD & Lightning Protector PELB5VB1 IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 4 www.prisemi.com
PELB5VB1 价格&库存
很抱歉,暂时无法提供与“PELB5VB1”相匹配的价格&库存,您可以联系我们找货
