FM25Q08B-SO-T-G
FM25Q08B-SO-T-G
    FUDANMICRO(复旦微电子)
    SOP8
    FM25Q08B-SO-T-G
FM25Q08B-SO-T-G 数据手册
FM25Q08B 8M-BIT SERIAL FLASH MEMORY Datasheet Nov. 2019 FM25Q08B 8M-BIT SERIAL FLASH MEMORY Preliminary Datasheet 1 INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE CUSTOMER'S APPLICATION; THEY DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS, BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY. WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND PRODUCTS. PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN. UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/). PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS. Trademarks Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China. Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved. FM25Q08B 8M-BIT SERIAL FLASH MEMORY Preliminary Datasheet 2 1. Description The FM25Q08B is a 8M-bit (1M-byte) Serial Flash memory, with advanced write protection mechanisms. The FM25Q08B supports the standard Serial Peripheral Interface (SPI), Dual/Quad I/O as well as 2clock instruction cycle Quad Peripheral Interface (QPI). They are ideal for code shadowing to RAM, executing code directly from Dual/Quad SPI (XIP) and storing voice, text and data. The FM25Q08B can be programmed 1 to 256 bytes at a time, using the Page Program instruction. It is designed to allow either single Sector/Block at a time or full chip erase operation. The FM25Q08B can be configured to protect part of the memory as the software protected mode. The device can sustain a minimum of 100K program/erase cycles on each sector or block. 2. Features  8Mbit of Flash memory – 256 uniform sectors with 4K-byte each – 16 uniform blocks with 64K-byte each or – 32 uniform blocks with 32K-byte each – 256 bytes per programmable page  Wide Operation Range – 2.3V~3.6V single voltage supply – Industrial temperature range  Serial Interface – Standard SPI: CLK, CS#, DI, DO, WP# – Dual SPI: CLK, CS#, DQ0, DQ1, WP# – Quad SPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – QPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – Continuous READ mode support – Program/Erase Suspend & Resume support – Allow true XIP (execute in place) operation  High Performance – Max FAST_READ clock frequency: 100MHz – Max READ clock frequency: 50MHz – Typical page program time: 0.5ms – Typical sector erase time: 60ms – Typical block erase time: 250/400ms – Typical chip erase time: 6s  Low Power Consumption – Typical Deep Power Down current:
FM25Q08B-SO-T-G
物料型号:FM25Q08B
器件简介: FM25Q08B是上海复旦微电子集团有限公司生产的一款8M位串行闪存存储器,具备高级写保护机制。支持标准的串行外设接口(SPI)、双/四线I/O以及2个时钟指令周期的四线外设接口(QPI)。适用于代码到RAM的影子复制、直接从双/四SPI执行代码以及存储声音、文本和数据。
引脚分配: - SOP 8 (150mil):包含VCC、CS#、DO(DQ1)、HOLD#(DQ3)、WP#(DQ2)、VSS、CLK、DI(DQ0)等引脚。 - USON8 (2x3mm):包含VCC、DO(DQ WP# CS# VSS)、VCC、HOLD# CLK DI(DQ0)等引脚。
参数特性: - 存储容量:8Mbit的闪存。 - 操作电压范围:2.3V~3.6V单电压供电。 - 工作温度范围:工业级温度范围。 - 接口:标准SPI、双SPI、四SPI、QPI。 - 读写性能:最大FAST_READ时钟频率100MHz,典型页编程时间0.5ms,典型扇区擦除时间60ms。
功能详解: - 支持1到256字节的页编程。 - 设计允许单扇区/块擦除或全芯片擦除操作。 - 可配置为保护内存的一部分作为软件保护模式。 - 每个扇区或块可承受至少100K次编程/擦除周期。
应用信息: 适用于需要数据存储和代码执行的应用,如工业控制、消费电子、汽车电子等领域。
封装信息: - SOP 8 (150mil):8引脚小外形封装。 - USON8 (2x3mm):8引脚超小型封装。
