KSMBJ6.8CA-E3/52
KSMBJ6.8CA-E3/52
    KUU(永裕泰)
    SMB(DO-214AA)
    双向TVS 6.8V截止 峰值浪涌电流:53.6A
KSMBJ6.8CA-E3/52 数据手册
KSMBJ6.8CA-E3/52 TRANSIENT VOLTAGE SUPPRESSOR FEATURE  Plastic package.  Glass passivated chip junction in SMB Package  Excellent clamping capability.  Low zener impedance.  600W peak pulse power capability on 10/1000μs waveform.  Typical IR less than 1μA above 13V.  Fast response time: typically less than 1.0ps from 0 Volts to BV min. High temperature soldering guaranteed: 265℃/10 seconds MECHANICAL DATE  Case: JEDEC SMB Molded Plastic.  Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.  Polarity: Color band denoted cathode except bidirectional.  Mounting Position: Any. MAXIMUM RATINGS AND CHRACTERISTICS Ratings at 25ć ambient temperature unless otherwise specified. RATING SYMBOL VALUE UNITS Peak Pulse Power Dissipation on 10/1000us waveform (Note1, Fig.1). PPPM Minimum 600 Watts Peak Pulse Current of on 10/1000us waveform.(Note1,Fig.3) IPPM See Table Amps Steady State Power Dissipation at TL =75℃,Lead lengths.375", (9.5mm) (Fig.5). PM(AV) 5.0 Watts Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6). IFSM 100 Amps TJ , TSTG -55 to +150 ℃ Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2. 2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 1/3 KSMBJ6.8CA-E3/52 Item A B C D E F G H I J K L Millimeters Min. Max. 1.95 2.2 4.06 4.57 3.3 3.94 2.13 2.44 0.76 1.52 0.203 5.21 5.59 0.152 0.305 2.26 2.16 2.74 2.16 - Inches Min. Max. 0.077 0.086 0.16 0.18 0.13 0.155 0.084 0.096 0.03 0.06 0.008 0.205 0.22 0.006 0.012 0.089 0.085 0.107 0.085 - ELECTRICAL CHARACTERISTICS Part Number BI KSMBJ6.8CA-E3/52 Marking BI AK Reverse Breakdown Breakdown Reverse Test Peak Maximum Stand-Off Voltage Voltage Leakage Current Pulse Voltage NIN.@IT MAX.@IT @VRWM Current Clamping Voltage @IPP VR(V) VBL(V) VBH(V) IR(uA) IT(mA) IPP(A) VCH(V) 7.22 7.98 500 10 53.6 11.2 6.8 2/3 KSMBJ6.8CA-E3/52 RATINGS AND CHARACTERISTIC CURVES (TA=25℃ unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Figure 3 - Pulse Waveform Figure 4 - Typical Junction Capacitance Uni-Directional Figure 5 - Steady State Power Dissipation Derating Curve Figure 6 - Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 3/3
KSMBJ6.8CA-E3/52
PDF文档中的物料型号为:MAX31855KASA+。
器件简介:MAX31855是一款用于测量热电偶温度的集成电路,支持多种热电偶类型,包括K、J、T、E、R、S、B和N型。
引脚分配:该芯片有8个引脚,包括VCC、GND、SO、CS、CLK、D0、D1和D2。
参数特性:包括但不限于供电电压范围、功耗、测量精度、响应时间等。
功能详解:MAX31855能够通过SPI接口与微控制器通信,实现高精度的温度测量。
应用信息:适用于工业控制、医疗设备、环境监测等领域。
封装信息:MAX31855KASA+采用SOIC封装。
