OPA340/2340/4340
SINGLE-SUPPLY, RAIL-TO-RAIL
OPERATIONAL AMPLIFIERS
FEATURES
APPLICATIONS
● DRIVING A/D CONVERTERS
● PCMCIA CARDS
● DATA ACQUISITION
● PROCESS CONTROL
● AUDIO PROCESSING
● COMMUNICATIONS
● ACTIVE FILTERS
● TEST EQUIPMENT
RAIL-TO-RAIL INPUT
RAIL-TO-RAIL OUTPUT (within 1mV)
MicroSIZE PACKAGES
WIDE BANDWIDTH: 5.5MHz
HIGH SLEW RATE: 6V/µs
LOW THD+NOISE: 0.0007% (f = 1kHz)
LOW QUIESCENT CURRENT: 750µA/channel
SINGLE, DUAL, AND QUAD
of the supply rails with a 100kΩ load. They offer excellent dynamic response (BW = 5.5MHz, SR = 6V/µs), yet
quiescent current is only 750µA. Dual and quad designs
feature completely independent circuitry for lowest
crosstalk and freedom from interaction.
The single (OPA340) packages are the tiny 5-lead
SOT-23-5 surface mount, SO-8 surface mount, and
8-pin DIP. The dual (OPA2340) comes in the miniature MSOP-8 surface mount, SO-8 surface mount,
and 8-pin DIP packages. The quad (OPA4340) packages are the space-saving SSOP-16 surface mount,
SO-14 surface mount, and the 14-pin DIP. All are
specified from –40°C to +85°C and operate from
–55°C to +125°C. A SPICE macromodel is available
for design analysis.
DESCRIPTION
OPA340 series rail-to-rail CMOS operational amplifiers are optimized for low voltage, single supply operation. Rail-to-rail input/output and high speed operation
make them ideal for driving sampling analog-to-digital
converters. They are also well suited for general purpose and audio applications as well as providing I/V
conversion at the output of D/A converters. Single,
dual, and quad versions have identical specifications
for design flexibility.
The OPA340 series operates on a single supply as low as
2.5V with an input common-mode voltage range that
extends 500mV below ground and 500mV above the
positive supply. Output voltage swing is to within 1mV
PIN CONFIGURATIONS
OPA340
NC
1
8
NC
–In
2
7
V+
+In
3
6
Output
V–
4
5
NC
OPA4340
Out A
1
OPA2340
OPA340
Out 1
5
V+
V– 2
+In 3
4
–In
SOT-23-5
http://www.hgsemi.com.cn
Out A
1
–In A
2
+In A
3
V–
4
A
B
8
V+
7
Out B
6
–In B
5
+In B
8-Pin DIP, SO-8, MSOP-8
1
Out D
–In A
2
15
–In D
+In A
3
14
+In D
+V
4
13
–V
+In B
5
12
+In C
–In B
6
11
–In C
Out B
7
10
Out C
NC
8
9
NC
A
8-Pin DIP, SO-8
16
D
B
C
SSOP-16
2020 MAR
OPA340/2340/4340
ELECTROSTATIC
DISCHARGE SENSITIVITY
PIN CONFIGURATIONS
Top View
SOIC/DIP
OPA4340
Out A
1
14
Out D
–In A
2
13
–In D
A
This integrated circuit can be damaged by ESD. Burr-Brown
recommends that all integrated circuits be handled with
appropriate precautions. Failure to observe proper handling
and installation procedures can cause damage.
D
+In A
3
12
+In D
V+
4
11
V–
+In B
5
10
+In C
B
ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits
may be more susceptible to damage because very small
parametric changes could cause the device not to meet its
published specifications.
C
–In B
6
9
–In C
Out B
7
8
Out C
ABSOLUTE MAXIMUM RATINGS(1)
Supply Voltage ................................................................................... 5.5V
Signal Input Terminals, Voltage (2) .................... (V–) –0.5V to (V+) +0.5V
Current(2) .................................................... 10mA
Output Short-Circuit(3) .............................................................. Continuous
Operating Temperature ................................................. –55°C to +125°C
Storage Temperature ..................................................... –55°C to +125°C
Junction Temperature ...................................................................... 150°C
Lead Temperature (soldering, 10s) ................................................. 300°C
NOTES: (1) Stresses above these ratings may cause permanent damage.
(2) Input terminals are diode-clamped to the power supply rails. Input signals
that can swing more than 0.5V beyond the supply rails should be currentlimited to 10mA or less. (3) Short-circuit to ground, one amplifier per
package.
PACKAGE/ORDERING INFORMATION
PRODUCT
PACKAGE
PACKAGE
DRAWING
NUMBER(1)
Single
OPA340NA
5-Lead SOT-23-5
331
–40°C to +85°C
A40
OPA340PA
OPA340UA
8-Pin DIP
SO-8 Surface-Mount
006
182
–40°C to +85°C
–40°C to +85°C
OPA340PA
OPA340UA
OPA340NA-250
OPA340NA-3K
OPA340PA
OPA340UA
Dual
OPA2340EA
OPA2340PA
OPA2340UA
MSOP-8 Surface-Mount
8-Pin DIP
SO-8 Surface-Mount
337
006
182
–40°C to +85°C
–40°C to +85°C
–40°C to +85°C
A40A
OPA2340PA
OPA2340UA
OPA2340EA-250
OPA2340EA-2500
OPA2340PA
OPA2340UA
Tape and Reel
Tape and Reel
Rails
Rails (3)
Quad
OPA4340EA
OPA4340PA
OPA4340UA
SSOP-16 Surface-Mount
14-Pin DIP
SO-14 Surface Mount
322
010
235
–40°C to +85°C
–40°C to +85°C
–40°C to +85°C
OPA4340EA
OPA4340PA
OPA4340UA
OPA4340EA-250
OPA4340EA-2500
OPA4340PA
OPA4340UA
Tape and Reel
Tape and Reel
Rails
Rails (3)
SPECIFIED
TEMPERATURE
RANGE
PACKAGE
MARKING
ORDERING
NUMBER(2)
TRANSPORT
MEDIA
Tape and Reel
Tape and Reel
Rails
Rails (3)
NOTES: (1) For detailed drawing and dimension table, please see end of data sheet.
2
2020 MAR
OPA340/2340/4340
SPECIFICATIONS: VS = 2.7V to 5V
At TA = +25°C, RL = 10kΩ connected to VS/2 and VOUT = VS/2, unless otherwise noted.
Boldface limits apply over the specified temperature range, TA = –40°C to +85°C. VS = 5V.
OPA340NA, PA, UA
OPA2340EA, PA, UA
OPA4340EA, PA, UA
PARAMETER
OFFSET VOLTAGE
Input Offset Voltage
vs Temperature
vs Power Supply
T A = –40°C to +85°C
Channel Separation, dc
INPUT BIAS CURRENT
Input Bias Current
TA = –40°C to +85°C
Input Offset Current
NOISE
Input Voltage Noise, f = 0.1 to 50kHz
Input Voltage Noise Density, f = 1kHz
Current Noise Density, f = 1kHz
INPUT VOLTAGE RANGE
Common-Mode Voltage Range
Common-Mode Rejection Ratio
CONDITION
VOS
dVOS/dT
PSRR
MIN
VS = 5V
VS = 2.7V to 5.5V, VCM = 0V
µV
µV/°C
µV/V
µV/V
µV/V
±0.2
en
in
8
25
3
VCM
CMRR
AOL
GBW
SR
THD+N
TA = –40°C to +85°C
TEMPERATURE RANGE
Specified Range
Operating Range
Storage Range
Thermal Resistance
SOT-23-5 Surface Mount
MSOP-8 Surface Mount
SO-8 Surface Mount
8-Pin DIP
SSOP-16 Surface Mount
SO-14 Surface Mount
14-Pin DIP
±500
IOS
OUTPUT
Voltage Output Swing from Rail(3)
TA = –40°C to +85°C
POWER SUPPLY
Specified Voltage Range
Operating Voltage Range
Quiescent Current (per amplifier)
TA = –40°C to +85°C
±150
±2.5
30
±0.2
TA = –40°C to +85°C
TA = –40°C to +85°C
Short-Circuit Current
Capacitive Load Drive
UNITS
IB
TA = –40°C to +85°C
FREQUENCY RESPONSE
Gain-Bandwidth Product
Slew Rate
Settling Time, 0.1%
0.01%
Overload Recovery Time
Total Harmonic Distortion + Noise
MAX
120
120
0.2
–0.3V < VCM < (V+) –1.8V
VS = 5V, –0.3V < VCM < 5.3V
VS = 2.7V, –0.3V < VCM < 3V
–0.3
80
70
66
INPUT IMPEDANCE
Differential
Common-Mode
OPEN-LOOP GAIN
Open-Loop Voltage Gain
TA = –40°C to +85°C
TYP(1)
RL = 100kΩ, 5mV < VO < (V+) –5mV
RL = 10kΩ, 50mV < VO < (V+) –50mV
RL = 2kΩ, 200mV < VO < (V+) –200mV
106
106
100
100
94
94
IQ
µVrms
nV/√Hz
fA/√Hz
(V+) +0.3
V
dB
dB
dB
1013 || 3
1013 || 6
Ω || pF
Ω || pF
124
dB
dB
dB
dB
dB
dB
120
114
5.5
6
1
1.6
0.2
0.0007
RL = 100kΩ, AOL ≥ 106dB
RL = 10kΩ, AOL ≥ 100dB
RL = 2kΩ, AOL ≥ 94dB
1
10
40
MHz
V/µs
µs
µs
µs
5
5
50
50
200
200
mV
mV
mV
mV
mV
mV
mA
5
950
1100
V
V
µA
µA
+85
+125
+125
°C
°C
°C
±50
See Typical Curve
ISC
CLOAD
2.7
2.5 to 5.5
750
IO = 0, VS = +5V
IO = 0, VS = +5V
pA
pA
pA
92
84
80
G=1
VS = 5V, G = 1, CL = 100pF
VS = 5V, 2V Step, CL = 100pF
VIN • G = VS
VS = 5V, VO = 3Vp-p(2), G = 1, f = 1kHz
VS
±10
±60
±10
–40
–55
–55
θJA
200
150
150
100
100
100
80
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
NOTES: (1) VS = +5V. (2) V OUT = 0.25V to 3.25V. (3) Output voltage swings are measured between the output and power supply rails.
3
2020 MAR
OPA340/2340/4340
TYPICAL PERFORMANCE CURVES
At TA = +25°C, VS = +5V, and RL = 10kΩ connected to VS/2, unless otherwise noted.
POWER SUPPLY and COMMON-MODE
REJECTION vs FREQUENCY
OPEN-LOOP GAIN/PHASE vs FREQUENCY
160
PSRR
140
80
–45
80
–90
60
40
Phase (°)
100
–135
PSRR, CMRR (dB)
Voltage Gain (dB)
120
60
40
CMRR
–180
–20
10
1
100
1k
10k
100k
1M
10M
1
10
100
Frequency (Hz)
1k
10k
100k
1M
Frequency (Hz)
INPUT VOLTAGE AND CURRENT NOISE
SPECTRAL DENSITY vs FREQUENCY
CHANNEL SEPARATION vs FREQUENCY
1k
10k
140
100
10
10
1
Channel Separation (dB)
100
Voltage Noise
Current Noise (fA√Hz)
Voltage Noise (nV√Hz)
Current Noise
1k
130
120
110
G = 1, All Channels
0.1
1
1
10
100
1k
10k
100k
100
1M
10
100
1k
100k
Frequency (Hz)
TOTAL HARMONIC DISTORTION + NOISE
vs FREQUENCY
CLOSED-LOOP OUTPUT IMPEDANCE
vs FREQUENCY
0.1
5k
G = 100
RL = 600
4k
0.01
Output Resistance (Ω)
RL = 2k
THD+N (%)
10k
Frequency (Hz)
G = 10
RL = 10k
RL = 600
0.001
RL = 2k
G=1
RL = 10k
0.0001
G = 10
3k
2k
G=1
1k
1k
10k
10
20k
100
1k
10k
100k
1M
10M
Frequency (Hz)
Frequency (Hz)
4
2020 MAR
OPA340/2340/4340
TYPICAL PERFORMANCE CURVES (CONT)
OPEN-LOOP GAIN AND POWER SUPPLY REJECTION
vs TEMPERATURE
130
120
COMMON-MODE REJECTION vs TEMPERATURE
100
RL = 100kΩ
AOL
90
AOL, PSRR (dB)
RL = 10kΩ
CMRR (dB)
80
110
RL = 2kΩ
100
PSRR
90
70
60
VS = 2.7V to 5V, VCM = –0.3V to (V+) –1.8V
VS = 5V, VCM = –0.3V to 5.3V
VS = 2.7V, VCM = –0.3V to 3V
50
80
40
–75
–50
–25
50
75
100
125
–75
–50
–25
Temperature (°C)
50
75
100
125
800
Per Amplifier
Per Amplifier
Quiescent Current (µA)
900
25
QUIESCENT CURRENT vs SUPPLY VOLTAGE
QUIESCENT CURRENT vs TEMPERATURE
1000
800
700
600
500
750
700
650
600
–75
–50
–25
50
75
100
125
2.0
2.5
3.0
Temperature (°C)
4.5
5.0
5.5
6.0
60
Short-Circuit Current (mA)
–ISC
80
70
60
50
4.0
SHORT-CIRCUIT CURRENT vs SUPPLY VOLTAGE
SHORT-CIRCUIT CURRENT vs TEMPERATURE
90
3.5
Supply Voltage (V)
100
Temperature (°C)
+ISC
40
30
–ISC
50
+ISC
40
10
–75
–50
–25
50
75
100
125
2.0
Temperature (°C)
2.5
3.0
3.5
4.0
4.5
5.0
5.5
6.0
Supply Voltage (V)
5
2020 MAR
OPA340/2340/4340
INPUT BIAS CURRENT
vs INPUT COMMON-MODE VOLTAGE
INPUT BIAS CURRENT vs TEMPERATURE
1.0
1k
0.6
100
Input Bias Current (pA)
0.8
10
1
0.4
0.2
–0.2
–0.4
–0.6
–0.8
–1.0
0.1
–75
–50
–25
50
Temperature (°C)
75
100
125
–1
OUTPUT VOLTAGE SWING vs OUTPUT CURRENT
+25°C
–55°C
Output Voltage (Vp-p)
Output Voltage (V)
3
2
+125°C
–55°C
+25°C
±10 ±20
±30 ±40
±50 ±60
5
6
Maximum output
voltage without
slew rate-induced
distortion.
4
VS = 2.7V
3
2
1M
10M
Output Current (mA)
Frequency (Hz)
OFFSET VOLTAGE
PRODUCTION DISTRIBUTION
OFFSET VOLTAGE DRIFT MAGNITUDE
25
Typical production
distribution of
packaged units.
Percent of Amplifiers (%)
14
VS = 5.5V
100k
±70 ±80 ±90 ±100
18
16
4
1
5
4
1
2
MAXIMUM OUTPUT VOLTAGE vs FREQUENCY
6
5
+125°C
1
Common-Mode Voltage (V)
12
10
8
6
4
Typical production
distribution of
packaged units.
10
5
2
400
300
200
100
–100
–200
–300
–400
–500
2
3
4
5
6
7
8
9
10 11 12 13 15
Offset Voltage Drift (µV/°C)
Offset Voltage (µV)
6
2020 MAR
OPA340/2340/4340
LARGE-SIGNAL STEP RESPONSE
CL = 100pF
1V/div
50mV/div
SMALL-SIGNAL STEP RESPONSE
CL = 100pF
1µs/div
1µs/div
SETTLING TIME vs CLOSED-LOOP GAIN
SMALL-SIGNAL OVERSHOOT vs LOAD CAPACITANCE
100
60
G = –1
0.01%
Settling Time (µs)
Overshoot (%)
50
G = +1
40
30
G = –5
10
0.1%
1
See text for
reducing overshoot.
G = +5
0.1
1000
10k
1
10
100
1000
Closed-Loop Gain (V/V)
Load Capacitance (pF)
7
2020 MAR
OPA340/2340/4340
APPLICATIONS INFORMATION
Power supply pins should be bypassed with 0.01µF ceramic
capacitors.
OPA340 series op amps are fabricated on a state-of-the-art
0.6 micron CMOS process. They are unity-gain stable and
suitable for a wide range of general purpose applications.
Rail-to-rail input/output make them ideal for driving sampling A/D converters. In addition, excellent ac performance
makes them well-suited for audio applications. The class AB
output stage is capable of driving 600Ω loads connected to
any point between V+ and ground.
OPERATING VOLTAGE
OPA340 series op amps are fully specified from +2.7V to
+5V. However, supply voltage may range from +2.5V to
+5.5V. Parameters are guaranteed over the specified supply
range—a unique feature of the OPA340 series. In addition,
many specifications apply from –40°C to +85°C. Most
behavior remains virtually unchanged throughout the full
operating voltage range. Parameters which vary significantly with operating voltages or temperature are shown in
the typical performance curves.
Rail-to-rail input and output swing significantly increases
dynamic range, especially in low supply applications.
Figure 1 shows the input and output waveforms for the
OPA340 in unity-gain configuration. Operation is from a
single +5V supply with a 10kΩ load connected to VS /2.
The input is a 5Vp-p sinusoid. Output voltage is approximately 4.98Vp-p.
RAIL-TO-RAIL INPUT
The input common-mode voltage range of the OPA340
series extends 500mV beyond the supply rails. This is
achieved with a complementary input stage—an N-channel
input differential pair in parallel with a P-channel differential pair (see Figure 2). The N-channel pair is active for input
voltages close to the positive rail, typically
(V+) –1.3V to 500mV above the positive supply, while the
P-channel pair is on for inputs from 500mV below the
negative supply to approximately (V+) –1.3V. There is a
small transition region, typically (V+) –1.5V to (V+) –1.1V,
in which both pairs are on. This 400mV transition region
can vary ±300mV with process variation. Thus, the transition region (both stages on) can range from (V+) –1.8V to
(V+) –1.4V on the low end, up to (V+) –1.2V to (V+) –0.8V
on the high end.
VS = +5, G = +1, RL = 10kΩ
5
2V/div
VIN
5
VOUT
FIGURE 1. Rail-to-Rail Input and Output.
V+
Reference
Current
VIN+
VIN–
VBIAS1
Class AB
Control
Circuitry
VO
VBIAS2
V–
(Ground)
FIGURE 2. Simplified Schematic.
8
2020 MAR
OPA340/2340/4340
OPA340 series op amps are laser-trimmed to the reduce
offset voltage difference between the N-channel and
P-channel input stages, resulting in improved commonmode rejection and a smooth transition between the
N-channel pair and the P-channel pair. However, within the
400mV transition region PSRR, CMRR, offset voltage,
offset drift, and THD may be degraded compared to operation outside this region.
CAPACITIVE LOAD AND STABILITY
OPA340 series op amps can drive a wide range of capacitive
loads. However, all op amps under certain conditions may
become unstable. Op amp configuration, gain, and load
value are just a few of the factors to consider when determining stability. An op amp in unity gain configuration is the
most susceptible to the effects of capacitive load. The
capacitive load reacts with the op amp’s output resistance,
along with any additional load resistance, to create a pole in
the small-signal response which degrades the phase margin.
In unity gain, OPA340 series op amps perform well, with a
pure capacitive load up to approximately 1000pF. Increasing
gain enhances the amplifier’s ability to drive more capacitance. See the typical performance curve “Small-Signal
Overshoot vs Capacitive Load.”
A double-folded cascode adds the signal from the two input
pairs and presents a differential signal to the class AB output
stage. Normally, input bias current is approximately 200fA,
however, input voltages exceeding the power supplies by
more than 500mV can cause excessive current to flow in or
out of the input pins. Momentary voltages greater than
500mV beyond the power supply can be tolerated if the
current on the input pins is limited to 10mA. This is easily
accomplished with an input resistor as shown in Figure 3.
Many input signals are inherently current-limited to less
than 10mA, therefore, a limiting resistor is not required.
One method of improving capacitive load drive in the unity
gain configuration is to insert a 10Ω to 20Ω resistor in series
with the output, as shown in Figure 4. This significantly
reduces ringing with large capacitive loads. However, if
there is a resistive load in parallel with the capacitive load,
it creates a voltage divider introducing a dc error at the
output and slightly reduces output swing. This error may be
insignificant. For instance, with RL = 10kΩ and RS = 20Ω,
there is only about a 0.2% error at the output.
V+
IOVERLOAD
10mA max
VOUT
OPAx340
VIN
OPA340 series op amps are optimized for driving medium
speed (up to 100kHz) sampling A/D converters. However,
they also offer excellent performance for higher speed
converters. The OPA340 series provides an effective means
of buffering the A/D’s input capacitance and resulting
charge injection while providing signal gain.
5kΩ
FIGURE 3. Input Current Protection for Voltages Exceeding
the Supply Voltage.
Figures 5 and 6 show the OPA340 driving an ADS7816.
The ADS7816 is a 12-bit, micro-power sampling converter
in the tiny MSOP-8 package. When used with the miniature package options of the OPA340 series, the combination is ideal for space-limited and low power applications.
For further information consult the ADS7816 data sheet.
RAIL-TO-RAIL OUTPUT
A class AB output stage with common-source transistors is
used to achieve rail-to-rail output. For light resistive loads
(>50kΩ), the output voltage is typically a few millivolts
from the supply rails. With moderate resistive loads (2kΩ to
50kΩ), the output can swing to within a few tens of millivolts from the supply rails and maintain high open-loop
gain. See the typical performanc curve “Output Voltage
Swing vs Output Current.”
With the OPA340 in a noninverting configuration, an RC
network at the amplifier’s output can be used to filter high
frequency noise in the signal (Figure 5). In the inverting
configuration, filtering may be accomplished with a capacitor across the feedback resistor (Figure 6).
V+
RS
VOUT
OPAx340
VIN
10Ω to
20Ω
RL
CL
FIGURE 4. Series Resistor in Unity-Gain Configuration Improves Capacitive Load Drive.
9
2020 MAR
OPA340/2340/4340
+5V
0.1µF
0.1µF
1 VREF
8 V+
500Ω
DCLOCK
+In
OPA340
ADS7816
12-Bit A/D
2
VIN
–In
CS/SHDN
3
3300pF
DOUT
7
6
5
Serial
Interface
GND 4
VIN = 0V to 5V for
0V to 5V output.
NOTE: A/D Input = 0 to VREF
RC network filters high frequency noise.
FIGURE 5. OPA340 in Noninverting Configuration Driving ADS7816.
+5V
330pF
0.1µF
5kΩ
0.1µF
5kΩ
VIN
8 V+
1 VREF
DCLOCK
+In
OPA340
ADS7816
12-Bit A/D
2
–In
DOUT
CS/SHDN
3
7
6
5
Serial
Interface
GND 4
VIN = 0V to –5V for 0V to 5V output.
FIGURE 6. OPA340 in Inverting Configuration Driving ADS7816.
Filters 160Hz to 2.4kHz
+5V
10MΩ
VIN
200pF
10MΩ
1/2
OPA2340
243kΩ
1.74MΩ
47pF
1/2
OPA2340
RL
220pF
FIGURE 7. Speech Bandpass Filter.
10
2020 MAR
OPA340/2340/4340
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
11
2020 MAR
