R411802119
R411802119
    RADIALL
    SMA(DO-214AC)
    SMA连接器,2 dB衰减,12.4 GHz频率范围,2W平均功率
R411802119 数据手册
Technical Data Sheet SMA ATTENUATOR 2 DB 12.4 GHZ 2W PAGE 1/2 ISSUE 24-08-15D SERIES ATTENUATOR PART NUMBER R411802119 All dimensions are in mm. . pn . ao COMPONENTS Body Male center contact Female center contact Outer contact Insulator Gasket Substrate Resistor Others parts MATERIALS STAINLESS STEEL BERYLLIUM COPPER BERYLLIUM COPPER PTFE SILICONE RUBBER ALUMINA THIN FILM - PLATING (m) PASSIVATED GOLD 2 OVER NICKEL 2 GOLD 1.3 OVER NICKEL2 - - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet SMA ATTENUATOR 2 DB 12.4 GHZ 2W PAGE 2/2 ISSUE 24-08-15D SERIES ATTENUATOR PART NUMBER R411802119 ELECTRICAL CHARACTERISTICS DC - 4 4-8 8 - 12.4 V.S.W.R () 1.20 1.25 1.30 Deviation(dB) 0.30 0.40 0.50 Frequency (GHz) DC - 12.4 Operating Frequency Range GHz Impedance 50  Nominal Attenuation 2 dB 100 W Peak power at 25°C (1µs, 1%0) 2 Average power at 25°C W (Free Air Cooled) W (Conduction Cooled) MECHANICAL CHARACTERISTICS Connectors SMA Weight 4,7300 Male Female MIL-C 39012 g ENVIRONMENTAL CHARACTERISTICS Operating temperature range -55 /+125 °C Storage temperature range -55 /+125 °C Power (% ) Power derating Versus temperature 10 0 90 80 70 60 50 40 30 20 10 0 -5 5 -1 5 25 75 12 5 Temperature (°C) SPECIFICATION OTHER CHARACTERISTICS This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R411802119 价格&库存
很抱歉,暂时无法提供与“R411802119”相匹配的价格&库存,您可以联系我们找货
