TECHNICAL DATA SHEET
1/2
R125.073.000
STRAIGHT PLUG CRIMP OR SOLDER TYPE
Series : SMA
CABLE 2.6/50 S
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
MATERIALS
STAINLESS STEEL
BRASS
PTFE
SILICONE RUBBER
STAINLESS STEEL
PLATINGS (µm)
GOLD 0.5 OVER NICKEL 2
GOLD 1.3 OVER NICKEL 2
Issue : 0220 J
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R125.073.000
Series : SMA
CABLE 2.6/50 S
PACKAGING
SPECIFICATION
Standard
100
Unit
‘W’ option
Other
Contact us
CABLE ASSEMBLY
ELECTRICAL CHARACTERISTICS
Impedance
50 Ω
Frequency
0-12.4 GHz
VSWR
1.15 + 0.020 x F(GHz) Maxi
Insertion loss
0.06 √F(GHz) dB Maxi
RF leakage
60 - F(GHz)) dB Maxi
Voltage rating
250 Veff Maxi
Dielectric withstanding voltage
750 Veff mini
Insulation resistance
5000 MΩ mini
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
27 N mini
27 N mini
NA N.cm mini
Stripping
a
b
c
d
e
f
mm
3.50
7.00
13.5
0.00
10.0
0.00
Assembly instruction :
Crimp 10
Recommended cable(s)
KX 22A
RG 188
RG 316
RG 174
KX 3B
RG 174 FTX
SHF 2.7T U
Cable retention
- pull off
- torque
90 N mini
NA N.cm
TOOLING
Recommended torque
Mating
Panel nut
Clamp nut
A/F clamp nut
100
NA
115
7.000
Mating life
Weight
500 Cycles mini
4.700 g
N.cm
N.cm
N.cm
mm
Part Number
R282.271.000
R282.293.000
R282.235.003
Description
CRIMPING TOOL
CRIMPING TOOL
CRIMPING DIES
Hexagon
3.25
3.25
OTHERS CHARACTERISTICS
ENVIRONMENTAL
Operating temperature
Hermetic seal
Panel leakage
-65/+165 ° C
NA Atm.cm3/s
NA
Issue : 0220 J
necessary.
很抱歉,暂时无法提供与“R125073000”相匹配的价格&库存,您可以联系我们找货
