Technical Data Sheet
STRAIGHT JACK FLANGE, SOLDER CABLE .141
PAGE 1/3
ISSUE 28-06-17B
SERIES NEX10
PART NUMBER R180252007
All dimensions are in mm. Tolerances according ISO 2768 m-H
pn
ao
COMPONENTS
Body
Center contact
Outer contact
Insulator
Gasket
Others parts
MATERIALS
BRASS.
BERYLLIUM COPPER
PLATING (m)
BBR
SILVER
PTFE
This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written
agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
PAGE 2/3
ISSUE 28-06-17B
SERIES NEX10
PACKAGING
Standard
50
Unit
Contact us
Other
Contact us
ELECTRICAL CHARACTERISTICS
Impedance
Frequency
1.02* +
VSWR
Insertion loss
RF leakage
Voltage rating
Dielectric withstanding voltage
Insulation resistance
50
0-20
0.0200
0.05
NA
500
1500
5000
ENVIRONMENTAL
GHz
x F(GHz) Maxi
F(GHz) dB Maxi
- F(GHz)) dB Maxi
Veff Maxi
Veff mini
M mini
NA
NA
NA
°C
Atm.cm3/s
SPECIFICATION
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating End
Axial force – Opposite end
Torque
-55/+125
NA
NA
Operating temperature
Hermetic seal
Panel leakage
CABLE ASSEMBLY
N mini
N mini
N.cm mini
Stripping
mm
a
3.2
b
c
d
e
0.85
f
Assembly instruction:
Recommended torque
Mating
Panel nut
Clamp nut
A/F clamp nut
NA
NA
NA
0.0000
100
9.8000
Mating life
Weight
N.cm
N.cm
N.cm
mm
Cycles mini
g
Recommended cable(s)
RG 402
Characteristics indicated on this data sheet are those that can be achieved with the highest
performance cable. Intrinsic limitations of the cable may diminish the performance of the
assembly
Cable retention
200
NA
- pull off
- torque
N mini
N.cm
TOOLING
Part Number
Description
Hexagon
OTHER CHARACTERISTICS
PIM3
很抱歉,暂时无法提供与“R180252007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+249.383434+32.17110
- 15+215.4841015+27.79800
- 61+206.8121861+26.67930
- 国内价格
- 4+231.24727
- 15+199.79304
- 61+191.74382
- 国内价格
- 6+78.50980
- 15+75.38953
- 61+72.35311
