1N5408GHR0G
1N5408GHR0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    1N5408GHR0G
1N5408GHR0G 数据手册
1N5400G – 1N5408G Taiwan Semiconductor 3A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High current capability, Low VF High reliability High surge current capability Low power loss, high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 50 - 1000 V IFSM 125 A TJ MAX 150 °C Package DO-201AD Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.20g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL 1N 1N 1N 1N 1N 1N 1N UNIT 5400G 5401G 5402G 5404G 5406G 5407G 5408G 1N 1N 1N 1N 1N 1N 1N 5400G 5401G 5402G 5404G 5406G 5407G 5408G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IF 3 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: K2105 1N5400G – 1N5408G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 45 °C/W Junction-to-case thermal resistance RӨJC 15 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) CONDITIONS 1N5400G 1N5401G 1N5402G 1N5404G I = 3A, TJ = 25°C 1N5405G F 1N5406G 1N5407G 1N5408G TJ = 25°C Junction capacitance TJ = 125°C 1MHz, VR = 4.0V SYMBOL TYP MAX UNIT - 1.1 V - 1.0 V - 5 µA - 100 µA 25 - pF VF IR CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 1N54xG DO-201AD 1,250 / Tape & Reel 1N54xG A0G DO-201AD 500 / Ammo box 1N54xGH DO-201AD 1,250 / Tape & Reel 1N54xGHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 50V (1N5400G) to 1000V (1N5408G) 2. “H” means AEC-Q101 qualified 2 Version: K2105 1N5400G – 1N5408G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 3 CAPACITANCE (pF) 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 ANBIENT TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 10 TJ=125°C 0.1 TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1N5402G-1N5408G 1 TJ=125°C TJ=25°C 10.1 1N5400G-1N5401G 0.01 0.1 0.001 0.60.3 0.7 0.4 0.8 0.5 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.9 0.6 1 0.7 1.1 0.8 1.2 0.9 11.3 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 1 100 (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2105 1.2 1N5400G – 1N5408G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 1N5400G – 1N5408G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: K2105
1N5408GHR0G 价格&库存
很抱歉,暂时无法提供与“1N5408GHR0G”相匹配的价格&库存,您可以联系我们找货
