FX2B-80PA-1.27DS(71) 数据手册
1.27mm Pitch Multi-function Two Piece Connector
FX2 Series
Stacking connection (Stack height: 12~16mm)
12mm~16mm
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Horizontal Connection
Vertical Connection
25mm
■Features
1. Various connection with various product line
2. Easy One-Touch Operation
The ribbon cable connection type allows easy one-touch operation
with either single hand.
Stacking connection
Vertical type
Cable connection
Through hole type SMT type Through hole type SMT type
Insersion and Extraction
(1) Pick internal locks with thumb and the index finger.
Through hole type
Cable only
Horizontal type
SMT type
(2) With unique and preferable click feeling, the cable and
connector can be inserted or withdrawed.
Vertical type
Cable only
Cable connection
(For insertion, the operation proceeds from procedure (2) to (1).)
A85
FX2 Series●1.27mm Pitch Multi-function Two Piece Connector
3. Board to board type
q Flux swell prevention
4. Board to cable type
q Complete lock with easy operation
The straight through hole type takes the complete flux
tight action from the board back side at solder dipping.
The type is prepared, corresponding to whether or not
cleaning is required.
Employing the inner lock system, complete lock and eject
actions can be performed with easy operation.
w Applicable cable
The applicable cable is the AWG#28 flat cable
(7/0.127mm), and the jacket size is 0.9±0.1mm.
w Stack height 12mm to 16mm
The board stack height can be set to every 1 mm unit up
to 12 to 16mm.
5. SMT type
Strength security with metaltab
e Mis-insertion preventive mechanism
The right angle type is equipped with metaltab to secure
soldering strength, and constructed so as to fix by
screws. The straight type can choose whether or not
metaltab are required.
The mating area is designed in a mechanism so as to
prevent mis-insertion, and complete countermeasures
have been taken against wrenching.
■Applications
Computers, peripheral equipments, various machines etc.
■Product Specifications
Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç (Note 2)
Current rating 0.5A
Rating
Voltage rating 125V AC Operating Humidity Range 40 to 80%
Item
Storage Humidity Range 40 to 70%
Specification
(Note 2)
Condition
1. Insulation Resistance
1000M ohms min
250V DC
2. Withstanding Voltage
No flashover or insulation breakdown.
300V AC/1 minute
3. Contact Resistance
45m ohms max.
100mA
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Contact resistance: 55m ohms max. Insulation resistance: 100M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
(-55ç: 30 minutes→15 to 35ç: 2 to 3 minutes →
(-85ç: 30 minutes→15 to 35ç: 2 to 3 minutes) 5 cycles
No damage, cracks, or parts looseness.
7. Durability (Mating/un-mating) Contact resistance: 55 m ohms max.
500 cycles
SMT Type
8. Resistance to soldering heat No deformation of components affecting performance.
DIP Type
Reflow: At the recommended temperature profile
Manual soldering: 360ç for 5 seconds
Solder bath: 260ç for 10 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series.Contact us for the drawings and specifications for
a specific part number shown.
■Material
Parts
Insulator
Contact
Material
Finish
Dip type
Polyamid
Socket
PBT/Polyamid
SMT type
PPS
Receptacle
Black
UL94V-0
Light brown
Phosphor bronze
Socket
Header
________
Selective gold plated
Phosphor bronze or brass
■Stacking Variation
Receptacle
Header
Dip type
SMT type
A86
Remark
FX2C-*P-1.27DSA(L)
FX2CA-*P-1.27DSA(L)
FX2CA1-*P-1.27DSA(L)
FX2CA2-*P-1.27DSA(L)
FX2-*P-1.27SV(L)
Unit:mm
Dip type
SMT type
FX2C-*S-1.27DSA(L) FX2C2-*S-1.27DSA(L) FX2-*S-1.27SV(L)
FX2CA-*S-1.27DSA(L) FX2CA2-*S-1.27DSA(L)
12.0
14.0
12.2
13.0
14.0
12.1
15.0
16.0
14.1
13.2
14.2
12.3
■Ordering Information
●Board to Board Receptacle
FX2 CA 2 - * S - 1.27 DSA L
q
w
e
r
t
y
u
i
q Series Name :FX2
r Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100, 120
w Blank: Right angle type
t Connector type: S: Receptacle
C
: Straight non-cleaning type
y Contact pitch: 1.27mm
CA
: Straight cleaning type
u Contact type
e Product height variation (DSA only)
DS
Blank : Standard product
2
: Right angle type
DSA : Straight type
i L: Board prefixed pin
: +2mm
●Board to Board Header
FX2 CA 1 - * P - 1.27 DSA L
q
w
e
r
t
y
u
i
q Series Name :FX2
w None : Right angle type
t Connector type: P: header
C
CA
u Contact type:
DS
1
: Right angle type
DSA : Straight type
: +1mm
2
: +2mm
Note 1. C and CA take complete countermeasures against flux.
Note 2. Cleaning type: the liquid escape hole is added at dip cleaning.
Note 3. No-cleaning type: no liquid escape hole is added at dip cleaning.
●Board to Cable Socket
FX2 BA - * S A - 1.27 R
q
w
e
r
t
y
u
q Series Name : FX2
r S: Socket
wB
: Lock cable type
t A: Contact material: phosphor bronze
: No lock cable type
BA
e Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100
u R: Insulation displacement
A87
●Board to Cable Header
FX2 BA - * P A - 1.27 DSA L
q
w
e
r
q Series Name : FX2
wB
BA
t
y
u
i
t None : Contact material: phosphor bronze
: Lock straight no cleaning type
A
: Contact material: brass
: Lock right angle type
: Lock straight cleaning type
u Contact type:
DS
r Connector type: P: header
DSA : Straight type
: Right angle type
Note 1. Cleaning type: The liquid escape hole is added at dip cleaning.
Note 2. No cleaning type: No liquid escape hole is added at dip cleaning.
Note 3. Straight 20 and 32 contact types use phosphor bronze for contact material.
●Straight SMT Type
FX2 - * P - 1.27 SV L
q
w
e
q Series Name :FX2
r
t
y
r Contact pitch: 1.27mm
w Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100, 120 t Contact type:
e Connector type: P: Header
SV: Straight SMT type
y L: Board prefixed pin
S: Receptacle
●Header Right Angle SMT Type
FX2 A - * P - 0.635 SH
q
e
r
t
y
q Series Name :FX2
r Connector type: P: Header
w Blank: With boss
t Mounting area pitch: 0.635mm
A
: Without boss
e Number of contacts: 20, 40, 52, 60, 80
A88
w
y Contact type
SH: Right angle SMT type
BFX2 Functional Flow Chart
Board to Board Cable Type
Header Side
Receptacle and Socket Side
FX2-*P-1.27DS (L)
Right angle type
FX2-*S-1.27DS (L)
Right angle type
FX2(A)-*P-0.635SH
Right angle type
SMT type
FX2C-*S-1.27DS (L)
Straight type
No cleaning type, flux tight
FX2C-*P-1.27DSA (L)
Straight type
FX2C-*S-1.27DS (L)
Straight type
Cleaning type, flux tight
FX2CA-*P-1.27DSA (L)
Straight type
FX2CA-*S-1.27DSV (L)
Straight type
SMT type
FX2-*P-1.27DSA (L)
Straight type
SMT type
FX2BA-*SA-1.27R
No lock cable type
A89
Header Side
FX2B-*PA-1.27DS (L)
FX2B-*PA-1.27DSA(L)
Lock straight type
FX2BA-*PA-1.27DSA(L)
Lock straight type
A90
FX2BA-*SA-1.27R
Lock cable type
BThrough hole Type Application Pattern
FX2-*P-1.27DS(L)
Header
Stacking height
B
12
14
Receptacle
FX2C(A) -*S
A
FX2CA-*P
18.5
12
FX2CA1-*P
13
15
FX2C(A)2-*S
20.5
14
FX2CA2-*P
14
16
Header
Receptacle
FX2CA-*S FX2CA2-*S
Receptacle
Receptacle
FX2-*P-1.27DS(L)
FX2-*S-1.27DS(L)
Header
A
B
FX2C(A) -*P
18.5
12
FX2C(A)1-*P
19.5
13
FX2C(A)2-*P
20.5
14
Header
FX2-*P-1.27DS(L)
FX2B(A)-*SA-1.27R
FX2B(A)-*SA-1.27R
FX2B(A)-*P(A)-1.27DSA(L)
FX2B-*PA-1.27DS(L)
A91
BSMT Type Application Pattern
A92
FX2-*P-1.27SV(L)
FX2-*S-1.27SV(L)
FX2-*S-1.27SV(L)
FX2C(A)-*P-1.27DSA(L)
FX2-*P-1.27SV(L)
FX2-*S-1.27SV(L)
FX2C(A)-*S-1.27-DSA(L)
FX2C(A)1-*P-1.27DSA(L)
FX2-*P-1.27SV(L)
FX2-*S-1.27SV(L)
FX2C(A)2-*S-1.27DSA(L)
FX2C(A)2-*P-1.27DSA(L)
FX2-*P-1.27SV(L)
FX2-*S-1.27SV(L)
FX2-*S-1.27DS(L)
FX2-*P-1.27DS(L)
FX2(A)-*P-0.635SH
Receptacle
FX2(A)-*P-0.635SH
A
FX2C(A)
14.7
FX2C(A)2
16.7
FX2C(A•2)-*S-1.27DSA(L)
FX2-*S-1.27SV(L)
FX2(A)-*P-0.635SH
FX2(A)-*P-0.635SH
FX2-*S-1.27DS(L)
FX2BA-*SA-1.27R
A93
■Receptacle No Cleaning Type
●Straight Type
BPCB mounting pattern
Unit:mm
A94
Part Number
CL No.
FX2C-020S-1.27DSA(71)
572-2401-7-71
FX2C-020S-1.27DSAL(71)
572-2451-5-71
FX2C-032S-1.27DSA(71)
572-2402-0-71
FX2C-032S-1.27DSAL(71)
572-2452-8-71
FX2C-040S-1.27DSA(71)
572-2403-2-71
FX2C-040S-1.27DSAL(71)
572-2453-0-71
FX2C-052S-1.27DSA(71)
572-2404-5-71
FX2C-052S-1.27DSAL(71)
572-2454-3-71
FX2C-060S-1.27DSA(71)
572-2405-8-71
FX2C-060S-1.27DSAL(71)
572-2455-6-71
FX2C-068S-1.27DSA(71)
572-2406-0-71
FX2C-068S-1.27DSAL(71)
572-2456-9-71
FX2C-080S-1.27DSA(71)
572-2407-3-71
FX2C-080S-1.27DSAL(71)
572-2457-1-71
FX2C-100S-1.27DSA(71)
572-2408-6-71
FX2C-100S-1.27DSAL(71)
572-2458-4-71
FX2C-120S-1.27DSA(71)
572-2409-9-71
FX2C-120S-1.27DSAL(71)
572-2459-7-71
Number of Contacts
A
B
C
11.43
17.63
32
30.37
19.05
25.25
40
35.45
24.13
30.33
52
43.07
31.75
37.95
60
48.15
36.83
43.03
68
53.23
41.91
48.11
80
60.85
49.53
55.73
100
73.55
62.23
68.43
120
86.25
74.93
81.13
D
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
________
82.55
YES
■Receptacle Cleaning Type
●Straight Type
Unit:mm
Part Number
CL No.
FX2CA-020S-1.27DSA(71)
572-2501-1-71
FX2CA-020S-1.27DSAL(71)
572-2551-0-71
FX2CA-032S-1.27DSA(71)
572-2502-4-71
FX2CA-032S-1.27DSAL(71)
572-2552-2-71
FX2CA-040S-1.27DSA(71)
572-2503-7-71
FX2CA-040S-1.27DSAL(71)
572-2553-5-71
FX2CA-052S-1.27DSA(71)
572-2504-0-71
FX2CA-052S-1.27DSAL(71)
572-2554-8-71
FX2CA-060S-1.27DSA(71)
572-2505-2-71
FX2CA-060S-1.27DSAL(71)
572-2555-0-71
FX2CA-068S-1.27DSA(71)
572-2506-5-71
FX2CA-068S-1.27DSAL(71)
572-2556-3-71
FX2CA-080S-1.27DSA(71)
572-2507-8-71
FX2CA-080S-1.27DSAL(71)
572-2557-6-71
FX2CA-100S-1.27DSA(71)
572-2508-0-71
FX2CA-100S-1.27DSAL(71)
572-2558-9-71
FX2CA-120S-1.27DSA(71)
572-2509-3-71
FX2CA-120S-1.27DSAL(71)
572-2559-1-71
Number of Contacts
A
B
C
11.43
17.63
32
30.37
19.05
25.25
40
35.45
24.13
30.33
52
43.07
31.75
37.95
60
48.15
36.83
43.03
68
53.23
41.91
48.11
80
60.85
49.53
55.73
100
73.55
62.23
68.43
120
86.25
74.93
81.13
D
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
YES
44.45
________
49.53
________
57.15
________
69.85
________
82.55
A95
●Straight Type
Unit:mm
A96
Part Number
CL No.
FX2C2-020S-1.27DSA(71)
572-2421-4-71
FX2C2-020S-1.27DSAL(71)
572-2471-2-71
FX2C2-032S-1.27DSA(71)
572-2422-7-71
FX2C2-032S-1.27DSAL(71)
572-2472-5-71
FX2C2-040S-1.27DSA(71)
572-2423-0-71
FX2C2-040S-1.27DSAL(71)
572-2473-8-71
FX2C2-052S-1.27DSA(71)
572-2424-2-71
FX2C2-052S-1.27DSAL(71)
572-2474-0-71
FX2C2-060S-1.27DSA(71)
572-2425-5-71
FX2C2-060S-1.27DSAL(71)
572-2475-3-71
FX2C2-068S-1.27DSA(71)
572-2426-8-71
FX2C2-068S-1.27DSAL(71)
572-2476-6-71
FX2C2-080S-1.27DSA(71)
572-2427-0-71
FX2C2-080S-1.27DSAL(71)
572-2477-9-71
FX2C2-100S-1.27DSA(71)
572-2428-3-71
FX2C2-100S-1.27DSAL(71)
572-2478-1-71
FX2C2-120S-1.27DSA(71)
572-2429-6-71
FX2C2-120S-1.27DSAL(71)
572-2479-4-71
Number of Contacts
A
B
C
11.43
17.63
32
30.37
19.05
25.25
40
35.45
24.13
30.33
52
43.07
31.75
37.95
60
48.15
36.83
43.03
68
53.23
41.91
48.11
80
60.85
49.53
55.73
100
73.55
62.23
68.43
120
86.25
74.93
81.13
D
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
________
82.55
YES
●Straight Type
Unit:mm
Part Number
CL No.
FX2CA2-020S-1.27DSA(71)
572-2521-9-71
FX2CA2-020S-1.27DSAL(71)
572-2571-7-71
FX2CA2-032S-1.27DSA(71)
572-2522-1-71
FX2CA2-032S-1.27DSAL(71)
572-2572-0-71
FX2CA2-040S-1.27DSA(71)
572-2523-4-71
FX2CA2-040S-1.27DSAL(71)
572-2573-2-71
FX2CA2-052S-1.27DSA(71)
572-2524-7-71
FX2CA2-052S-1.27DSAL(71)
572-2574-5-71
FX2CA2-060S-1.27DSA(71)
572-2525-0-71
FX2CA2-060S-1.27DSAL(71)
572-2575-8-71
FX2CA2-068S-1.27DSA(71)
572-2526-2-71
FX2CA2-068S-1.27DSAL(71)
572-2576-0-71
FX2CA2-080S-1.27DSA(71)
572-2527-5-71
FX2CA2-080S-1.27DSAL(71)
572-2577-3-71
FX2CA2-100S-1.27DSA(71)
572-2528-8-71
FX2CA2-100S-1.27DSAL(71)
572-2578-6-71
FX2CA2-120S-1.27DSA(71)
572-2529-0-71
FX2CA2-120S-1.27DSAL(71)
572-2579-9-71
Number of Contacts
A
B
C
11.43
17.63
32
30.37
19.05
25.25
40
35.45
24.13
30.33
52
43.07
31.75
37.95
60
48.15
36.83
43.03
68
53.23
41.91
48.11
80
60.85
49.53
55.73
100
73.55
62.23
68.43
120
86.25
74.93
81.13
D
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
YES
44.45
________
49.53
________
57.15
________
69.85
________
82.55
A97
■Receptacle
●Right Angle Type
Unit:mm
A98
Part Number
CL No.
FX2-020S-1.27DS(71)
572-2701-0-71
FX2-020S-1.27DSL(71)
572-2751-9-71
FX2-032S-1.27DS(71)
572-2702-3-71
FX2-032S-1.27DSL(71)
572-2752-1-71
FX2-040S-1.27DS(71)
572-2703-6-71
FX2-040S-1.27DSL(71)
572-2753-4-71
FX2-052S-1.27DS(71)
572-2704-9-71
FX2-052S-1.27DSL(71)
572-2754-7-71
FX2-060S-1.27DS(71)
572-2705-1-71
FX2-060S-1.27DSL(71)
572-2755-0-71
FX2-068S-1.27DS(71)
572-2706-4-71
FX2-068S-1.27DSL(71)
572-2756-2-71
FX2-080S-1.27DS(71)
572-2707-7-71
FX2-080S-1.27DSL(71)
572-2757-5-71
FX2-100S-1.27DS(71)
572-2708-0-71
FX2-100S-1.27DSL(71)
572-2758-8-71
FX2-120S-1.27DS(71)
572-2709-2-71
FX2-120S-1.27DSL(71)
572-2759-0-71
Number of Contacts
A
B
C
D
11.43
17.63
18.05
32
30.37
19.05
25.25
25.67
40
35.45
24.13
30.33
30.75
52
43.07
31.75
37.95
38.37
60
48.15
36.83
43.03
43.45
68
53.23
41.91
48.11
48.53
80
60.85
49.53
55.73
56.15
100
73.55
62.23
68.43
68.85
120
86.25
74.93
81.13
81.55
D
YES
■Header
●Right Angle Type
Unit:mm
Part Number
CL No.
FX2-020P-1.27DS(71)
572-2601-6-71
FX2-020P-1.27DSL(71)
572-2651-4-71
FX2-032P-1.27DS(71)
572-2602-9-71
FX2-032P-1.27DSL(71)
572-2652-7-71
FX2-040P-1.27DS(71)
572-2603-1-71
FX2-040P-1.27DSL(71)
572-2653-0-71
FX2-052P-1.27DS(71)
572-2604-4-71
FX2-052P-1.27DSL(71)
572-2654-2-71
FX2-060P-1.27DS(71)
572-2605-7-71
FX2-060P-1.27DSL(71)
572-2655-5-71
FX2-068P-1.27DS(71)
572-2606-0-71
FX2-068P-1.27DSL(71)
572-2656-8-71
FX2-080P-1.27DS(71)
572-2607-2-71
FX2-080P-1.27DSL(71)
572-2657-0-71
FX2-100P-1.27DS(71)
572-2608-5-71
FX2-100P-1.27DSL(71)
572-2658-3-71
FX2-120P-1.27DS(71)
572-2609-8-71
FX2-120P-1.27DSL(71)
572-2659-6-71
Number of Contacts
A
B
C
11.43
18.05
32
30.37
19.05
25.67
40
35.45
24.13
30.75
52
43.07
31.75
38.37
60
48.15
36.83
43.45
68
53.23
41.91
48.53
80
60.85
49.53
56.15
100
73.55
62.23
68.85
120
86.25
74.93
81.55
RoHS
YES
A99
■Header No Cleaning Type
●Straight Type
A100
Unit:mm
Part Number
CL No.
FX2C-020P-1.27DSA(71)
572-2201-8-71
FX2C-020P-1.27DSAL(71)
572-2251-6-71
FX2C-032P-1.27DSA(71)
572-2202-0-71
FX2C-032P-1.27DSAL(71)
572-2252-9-71
FX2C-040P-1.27DSA(71)
572-2203-3-71
FX2C-040P-1.27DSAL(71)
572-2253-1-71
FX2C-052P-1.27DSA(71)
572-2204-6-71
FX2C-052P-1.27DSAL(71)
572-2254-4-71
FX2C-060P-1.27DSA(71)
572-2205-9-71
FX2C-060P-1.27DSAL(71)
572-2255-7-71
FX2C-068P-1.27DSA(71)
572-2206-1-71
FX2C-068P-1.27DSAL(71)
572-2256-0-71
FX2C-080P-1.27DSA(71)
572-2207-4-71
FX2C-080P-1.27DSAL(71)
572-2257-2-71
FX2C-100P-1.27DSA(71)
572-2208-7-71
FX2C-100P-1.27DSAL(71)
572-2258-5-71
FX2C-120P-1.27DSA(71)
572-2209-0-71
FX2C-120P-1.27DSAL(71)
572-2259-8-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
________
82.55
YES
■Header Cleaning Type
●Straight Type
Unit:mm
Part Number
CL No.
FX2CA-020P-1.27DSA(71)
572-2301-2-71
FX2CA-020P-1.27DSAL(71)
572-2351-0-71
FX2CA-032P-1.27DSA(71)
572-2302-5-71
FX2CA-032P-1.27DSAL(71)
572-2352-3-71
FX2CA-040P-1.27DSA(71)
572-2303-8-71
FX2CA-040P-1.27DSAL(71)
572-2353-6-71
FX2CA-052P-1.27DSA(71)
572-2304-0-71
FX2CA-052P-1.27DSAL(71)
572-2354-9-71
FX2CA-060P-1.27DSA(71)
572-2305-3-71
FX2CA-060P-1.27DSAL(71)
572-2355-1-71
FX2CA-068P-1.27DSA(71)
572-2306-6-71
FX2CA-068P-1.27DSAL(71)
572-2356-4-71
FX2CA-080P-1.27DSA(71)
572-2307-9-71
FX2CA-080P-1.27DSAL(71)
572-2357-7-71
FX2CA-100P-1.27DSA(71)
572-2308-1-71
FX2CA-100P-1.27DSAL(71)
572-2358-0-71
FX2CA-120P-1.27DSA(71)
572-2309-4-71
FX2CA-120P-1.27DSAL(71)
572-2359-2-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
YES
44.45
________
49.53
________
57.15
________
69.85
________
82.55
A101
●Straight Type
A102
Unit: mm
Part Number
CL No.
FX2C1-020P-1.27DSA(71)
572-2211-1-71
FX2C1-020P-1.27DSAL(71)
572-2261-0-71
FX2C1-032P-1.27DSA(71)
572-2212-4-71
FX2C1-032P-1.27DSAL(71)
572-2262-2-71
FX2C1-040P-1.27DSA(71)
572-2213-7-71
FX2C1-040P-1.27DSAL(71)
572-2263-5-71
FX2C1-052P-1.27DSA(71)
572-2214-0-71
FX2C1-052P-1.27DSAL(71)
572-2264-8-71
FX2C1-060P-1.27DSA(71)
572-2215-2-71
FX2C1-060P-1.27DSAL(71)
572-2265-0-71
FX2C1-068P-1.27DSA(71)
572-2216-5-71
FX2C1-068P-1.27DSAL(71)
572-2266-3-71
FX2C1-080P-1.27DSA(71)
572-2217-8-71
FX2C1-080P-1.27DSAL(71)
572-2267-6-71
FX2C1-100P-1.27DSA(71)
572-2218-0-71
FX2C1-100P-1.27DSAL(71)
572-2268-9-71
FX2C1-120P-1.27DSA(71)
572-2219-3-71
FX2C1-120P-1.27DSAL(71)
572-2269-1-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
________
82.55
YES
●Straight Type
Unit: mm
Part Number
CL No.
FX2CA1-020P-1.27DSA(71)
572-2311-6-71
FX2CA1-020P-1.27DSAL(71)
572-2361-4-71
FX2CA1-032P-1.27DSA(71)
572-2312-9-71
FX2CA1-032P-1.27DSAL(71)
572-2362-7-71
FX2CA1-040P-1.27DSA(71)
572-2313-1-71
FX2CA1-040P-1.27DSAL(71)
572-2363-0-71
FX2CA1-052P-1.27DSA(71)
572-2314-4-71
FX2CA1-052P-1.27DSAL(71)
572-2364-2-71
FX2CA1-060P-1.27DSA(71)
572-2315-7-71
FX2CA1-060P-1.27DSAL(71)
572-2365-5-71
FX2CA1-068P-1.27DSA(71)
572-2316-0-71
FX2CA1-068P-1.27DSAL(71)
572-2366-8-71
FX2CA1-080P-1.27DSA(71)
572-2317-2-71
FX2CA1-080P-1.27DSAL(71)
572-2367-0-71
FX2CA1-100P-1.27DSA(71)
572-2318-5-71
FX2CA1-100P-1.27DSAL(71)
572-2368-3-71
FX2CA1-120P-1.27DSA(71)
572-2319-8-71
FX2CA1-120P-1.27DSAL(71)
572-2369-6-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
YES
49.53
________
57.15
________
69.85
________
82.55
A103
●Straight Type
A104
Unit: mm
Part Number
CL No.
FX2C2-020P-1.27DSA(71)
572-2221-5-71
FX2C2-020P-1.27DSAL(71)
572-2271-3-71
FX2C2-032P-1.27DSA(71)
572-2222-8-71
FX2C2-032P-1.27DSAL(71)
572-2272-6-71
FX2C2-040P-1.27DSA(71)
572-2223-0-71
FX2C2-040P-1.27DSAL(71)
572-2273-9-71
FX2C2-052P-1.27DSA(71)
572-2224-3-71
FX2C2-052P-1.27DSAL(71)
572-2274-1-71
FX2C2-060P-1.27DSA(71)
572-2225-6-71
FX2C2-060P-1.27DSAL(71)
572-2275-4-71
FX2C2-068P-1.27DSA(71)
572-2226-9-71
FX2C2-068P-1.27DSAL(71)
572-2276-7-71
FX2C2-080P-1.27DSA(71)
572-2227-1-71
FX2C2-080P-1.27DSAL(71)
572-2277-0-71
FX2C2-100P-1.27DSA(71)
572-2228-4-71
FX2C2-100P-1.27DSAL(71)
572-2278-2-71
FX2C2-120P-1.27DSA(71)
572-2229-7-71
FX2C2-120P-1.27DSAL(71)
572-2279-5-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
________
82.55
YES
●Straight Type
Unit: mm
Part Number
CL No.
FX2CA2-020P-1.27DSA(71)
572-2321-0-71
FX2CA2-020P-1.27DSAL(71)
572-2371-8-71
FX2CA2-032P-1.27DSA(71)
572-2322-2-71
FX2CA2-032P-1.27DSAL(71)
572-2372-0-71
FX2CA2-040P-1.27DSA(71)
572-2323-5-71
FX2CA2-040P-1.27DSAL(71)
572-2373-3-71
FX2CA2-052P-1.27DSA(71)
572-2324-8-71
FX2CA2-052P-1.27DSAL(71)
572-2374-6-71
FX2CA2-060P-1.27DSA(71)
572-2325-0-71
FX2CA2-060P-1.27DSAL(71)
572-2375-9-71
FX2CA2-068P-1.27DSA(71)
572-2326-3-71
FX2CA2-068P-1.27DSAL(71)
572-2376-1-71
FX2CA2-080P-1.27DSA(71)
572-2327-6-71
FX2CA2-080P-1.27DSAL(71)
572-2377-4-71
FX2CA2-100P-1.27DSA(71)
572-2328-9-71
FX2CA2-100P-1.27DSAL(71)
572-2378-7-71
FX2CA2-120P-1.27DSA(71)
572-2329-1-71
FX2CA2-120P-1.27DSAL(71)
572-2379-0-71
Number of Contacts
A
B
11.43
32
30.37
19.05
40
35.45
24.13
52
43.07
31.75
60
48.15
36.83
68
53.23
41.91
80
60.85
49.53
100
73.55
62.23
120
86.25
74.93
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
YES
49.53
________
57.15
________
69.85
________
82.55
A105
■Receptacle SMT Type
1.75±0.05
ot
e
2
5)
87
2.1±0.05
0.
(R
4-
A106
Note 1 : The 120 contacts type differs in the style.
Note 2 : The connector positioning bosses are constructed to press fit
into the board with light force. When mounting on the board,
press the connector lightly from the top and check that the
positioning bosses are securely inserted in the board holes
and that the connector leads are engaged in the board.
The recommended boss hole for use with automatic mounting
is illustrated in fig. 1.
N
●Straight Type
FIG.1
Unit: mm
Part Number
CL No.
FX2-020S-1.27SV(71)
572-2101-3-71
FX2-020S-1.27SVL(71)
572-2151-1-71
FX2-032S-1.27SV(71)
572-2102-6-71
FX2-032S-1.27SVL(71)
572-2152-4-71
FX2-040S-1.27SV(71)
572-2103-9-71
FX2-040S-1.27SVL(71)
572-2153-7-71
FX2-052S-1.27SV(71)
572-2104-1-71
FX2-052S-1.27SVL(71)
572-2154-0-71
FX2-060S-1.27SV(71)
572-2105-4-71
FX2-060S-1.27SVL(71)
572-2155-2-71
FX2-068S-1.27SV(71)
572-2106-7-71
FX2-068S-1.27SVL(71)
572-2156-5-71
FX2-080S-1.27SV(71)
572-2107-0-71
FX2-080S-1.27SVL(71)
572-2157-8-71
FX2-100S-1.27SV(71)
572-2108-2-71
FX2-100S-1.27SVL(71)
572-2158-0-71
FX2-120S-1.27SV(71)
572-2109-5-71
FX2-120S-1.27SVL(71)
572-2159-3-71
Number of Contacts
A
B
C
D
11.43
17.63
16.51
32
30.37
19.05
25.25
24.13
40
35.45
24.13
30.33
29.21
52
43.07
31.75
37.95
36.83
60
48.15
36.83
43.03
41.91
68
53.23
41.91
48.11
46.99
80
60.85
49.53
55.73
54.61
100
73.55
62.23
68.43
67.31
120
86.25
74.93
81.13
80.01
E
________
F
________
25.75
________
21.15
________
33.37
________
28.77
________
38.45
________
33.85
________
46.07
________
41.47
________
51.15
________
46.55
________
56.23
________
51.63
________
63.85
________
59.25
________
76.55
________
71.95
________
89.25
84.65
RoHS
YES
■Header SMT Type
Note : The connector positioning bosses are constructed to press fit
The recommended boss hole for use with automatic mounting is
1.75±0.05
N
ot
e
2.1±0.05
5)
87
0.
(R
4-
●Straight Type
FIG.1
Unit: mm
Part Number
CL No.
FX2-020P-1.27SV(71)
572-2001-9-71
FX2-020P-1.27SVL(71)
572-2051-7-71
FX2-032P-1.27SV(71)
572-2002-1-71
FX2-032P-1.27SVL(71)
572-2052-0-71
FX2-040P-1.27SV(71)
572-2003-4-71
FX2-040P-1.27SVL(71)
572-2053-2-71
FX2-052P-1.27SV(71)
572-2004-7-71
FX2-052P-1.27SVL(71)
572-2054-5-71
FX2-060P-1.27SV(71)
572-2005-0-71
FX2-060P-1.27SVL(71)
572-2055-8-71
FX2-068P-1.27SV(71)
572-2006-2-71
FX2-068P-1.27SVL(71)
572-2056-0-71
FX2-080P-1.27SV(71)
572-2007-5-71
FX2-080P-1.27SVL(71)
572-2057-3-71
FX2-100P-1.27SV(71)
572-2008-8-71
FX2-100P-1.27SVL(71)
572-2058-6-71
FX2-120P-1.27SV(71)
572-2009-0-71
FX2-120P-1.27SVL(71)
572-2059-9-71
Number of Contacts
A
B
C
11.43
16.51
32
30.37
19.05
24.13
40
35.45
24.13
29.21
52
43.07
31.75
36.83
60
48.15
36.83
41.91
68
53.23
41.91
46.99
80
60.85
49.53
54.61
100
73.55
62.23
67.31
120
86.25
74.93
80.01
D
________
E
________
25.75
________
21.15
________
33.37
________
28.77
________
38.45
________
33.85
________
46.07
________
41.47
________
51.15
________
46.55
________
56.23
________
51.63
________
63.85
________
59.25
________
76.55
________
71.95
________
89.25
84.65
RoHS
YES
A107
■Header SMT Type
●Right Angle Type
Note: The FX2A type does not have bosses as shown in the
illustration.
BPCB mounting Pattern
BRecommended Screw Clamp
Use M2 screw for fixture.
Recommended torque is 0.15(N•m).
Unit: mm
A108
Part Number
CL No.
FX2-20P-0.635SH (71)
572-2761-2-71
FX2A-20P-0.635SH (71)
572-2771-6-71
FX2-40P-0.635SH (71)
572-2763-8-71
FX2A-40P-0.635SH (71)
572-2773-1-71
FX2-52P-0.635SH (71)
572-2764-0-71
FX2A-52P-0.635SH (71)
572-2774-4-71
FX2-60P-0.635SH (71)
572-2765-3-71
FX2A-60P-0.635SH (71)
572-2775-7-71
FX2-80P-0.635SH (71)
572-2767-9-71
FX2A-80P-0.635SH (71)
572-2777-2-71
Number of Contacts
A
B
C
D
E
F
G
12.065
18.05
6.85
________
8.85
________
15.7
________
21.15
40
35.45
24.765
30.75
13.2
________
15.2
________
28.4
________
33.85
52
43.07
32.385
38.37
17.01
________
19.01
________
36.02
________
41.47
60
48.15
37.465
43.45
19.55
________
21.55
________
41.1
________
46.55
80
60.85
50.165
56.15
25.9
________
27.9
________
53.8
________
59.25
RoHS
YES
■Socket Type
●Lock Cable Type
Combination View
Unit: mm
Part Number
CL No.
Number of Contacts
A
FX2B-020SA-1.27R
572-0621-2
FX2B-032SA-1.27R
572-0622-5
32
35.45
FX2B-040SA-1.27R
572-0623-8
40
40.53
FX2B-052SA-1.27R
572-0624-0
52
48.15
FX2B-060SA-1.27R
572-0625-3
60
53.23
FX2B-068SA-1.27R
572-0629-4
68
58.31
FX2B-080SA-1.27R
572-0630-3
80
65.93
FX2B-100SA-1.27R
572-0628-1
100
78.63
CL No.
Number of Contacts
A
FX2BA-020SA-1.27R
572-0671-0
FX2BA-032SA-1.27R
572-0672-3
32
25.67
FX2BA-040SA-1.27R
572-0673-6
40
30.75
FX2BA-052SA-1.27R
572-0674-9
52
38.37
FX2BA-060SA-1.27R
572-0675-1
60
43.45
FX2BA-068SA-1.27R
572-0676-4
68
48.53
FX2BA-080SA-1.27R
572-0677-7
80
56.15
FX2BA-100SA-1.27R
572-0678-0
100
68.85
RoHS
YES
●Unlock Cable Type
Combination View
Part Number
BConnection Tool
Type
Part Number
Unit: mm
RoHS
YES
CL No.
Guide plate
FX2B(A)-GPA
550-0212-6
Connection press
Hi-Flex connection press
550-0082-2
Note:HRS6 cable cutter FC601 isn't required for FX2B(A) connection.
(Connected without convex-concave cutting.)
A109
■Header
●Right Angle Type for Lock
A110
Unit: mm
Part Number
CL No.
FX2B-020PA-1.27DS(71)
572-0721-7-71
FX2B-020PA-1.27DSL(71)
572-0771-5-71
FX2B-032PA-1.27DS(71)
572-0722-0-71
FX2B-032PA-1.27DSL(71)
572-0772-8-71
FX2B-040PA-1.27DS(71)
572-0723-2-71
FX2B-040PA-1.27DSL(71)
572-0773-0-71
FX2B-052PA-1.27DS(71)
572-0724-5-71
FX2B-052PA-1.27DSL(71)
572-0774-3-71
FX2B-060PA-1.27DS(71)
572-0725-8-71
FX2B-060PA-1.27DSL(71)
572-0775-6-71
FX2B-068PA-1.27DS(71)
572-0726-0-71
FX2B-068PA-1.27DSL(71)
572-0776-9-71
FX2B-080PA-1.27DS(71)
572-0727-3-71
FX2B-080PA-1.27DSL(71)
572-0777-1-71
FX2B-100PA-1.27DS(71)
572-0728-6-71
FX2B-100PA-1.27DSL(71)
572-0778-4-71
Number of Contacts
A
B
C
11.43
18.05
32
37.95
19.05
25.67
40
43.03
24.13
30.75
52
50.65
31.75
38.37
60
55.73
36.83
43.45
68
60.81
41.91
48.53
80
68.43
49.53
56.15
100
81.13
62.23
68.85
RoHS
YES
●Straight Type for Lock
Unit: mm
Part Number
CL No.
FX2B-020P-1.27DSA(71)
572-0801-4-71
FX2B-020P-1.27DSAL(71)
572-0851-2-71
FX2B-032P-1.27DSA(71)
572-0802-7-71
FX2B-032P-1.27DSAL(71)
572-0852-5-71
FX2B-040PA-1.27DSA(71)
572-0823-7-71
FX2B-040PA-1.27DSAL(71)
572-0873-5-71
FX2B-052PA-1.27DSA(71)
572-0824-0-71
FX2B-052PA-1.27DSAL(71)
572-0874-8-71
FX2B-060PA-1.27DSA(71)
572-0825-2-71
FX2B-060PA-1.27DSAL(71)
572-0875-0-71
FX2B-068PA-1.27DSA(71)
572-0826-5-71
FX2B-068PA-1.27DSAL(71)
572-0876-3-71
FX2B-080PA-1.27DSA(71)
572-0827-8-71
FX2B-080PA-1.27DSAL(71)
572-0877-6-71
FX2B-100PA-1.27DSA(71)
572-0828-0-71
FX2B-100PA-1.27DSAL(71)
572-0878-9-71
Number of Contacts
A
B
11.43
32
37.95
19.05
40
43.03
24.13
52
50.65
31.75
60
55.73
36.83
68
60.81
41.91
80
68.43
49.53
100
81.13
62.23
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
YES
44.45
________
49.53
________
57.15
________
69.85
A111
A112
Unit: mm
Part Number
CL No.
FX2BA-020P-1.27DSA(71)
572-0901-9-71
FX2BA-020P-1.27DSAL(71)
572-0951-7-71
FX2BA-032P-1.27DSA(71)
572-0902-1-71
FX2BA-032P-1.27DSAL(71)
572-0952-0-71
FX2BA-040PA-1.27DSA(71)
572-0923-1-71
FX2BA-040PA-1.27DSAL(71)
572-0973-0-71
FX2BA-052PA-1.27DSA(71)
572-0924-4-71
FX2BA-052PA-1.27DSAL(71)
572-0974-2-71
FX2BA-060PA-1.27DSA(71)
572-0925-7-71
FX2BA-060PA-1.27DSAL(71)
572-0975-5-71
FX2BA-068PA-1.27DSA(71)
572-0926-0-71
FX2BA-068PA-1.27DSAL(71)
572-0976-8-71
FX2BA-080PA-1.27DSA(71)
572-0927-2-71
FX2BA-080PA-1.27DSAL(71)
572-0977-0-71
FX2BA-100PA-1.27DSA(71)
572-0928-5-71
FX2BA-100PA-1.27DSAL(71)
572-0978-3-71
Number of Contacts
A
B
11.43
32
37.95
19.05
40
43.03
24.13
52
50.65
31.75
60
55.73
36.83
68
60.81
41.91
80
68.43
49.53
100
81.13
62.23
C
________
RoHS
19.05
________
26.67
________
31.75
________
39.37
________
44.45
________
49.53
________
57.15
________
69.85
YES
FX2M6 Series
■Ordering Imformation
FX2M6
A - 60 P - 1.27 DSA L
1
2
3
4
5
6
7
1 Series Name : FX2M6
2 Type No.
:A
3 Number of contacts
4 Contact Style
P
:Header
S
:Receptacle
: 60
5 Contact pitch : 1.27mm
6 DSA :Straight type
7 L
:Board prefixed pin
BStacking Variation
Unit: mm
Receptacle FX2C-60S
Header
-1.27DSA
FX2C2-60S FX2M6B-60S FX2M6A-60S
-1.27DSA
-1.27DSAL
-1.27DSAL
FX2C-60P
-1.27DSA
12
14
28.2
44.2
FX2C1-60P
-1.27DSA
13
15
29.2 *2
45.2 *2
FX2C2-60P
-1.27DSA
14
16
30.2 *2
46.2 *2
FX2M6B-60P
-1.27DSAL
28.4 *1
30.4 *1
44
60
FX2M6A-60P
-1.27DSAL
34.4 *1
36.4 *1
50
66
Note 1. Mate the male and female connectors to meet the allowable clearance within 1.0mm. However, set it within 0.4mm in
combination *1.
Note 2. In case of combination *2, 0.6mm clearance occurs
on the mating side, but no problem.
Note 3. After the board is mounted, fix the board by screws.
A113
■Header
Unit: mm
A114
Part Number
CL No.
A
FX2M6A-60P-1.27DSAL(71)
572-1036-8-71
30.9
FX2M6B-60P-1.27DSAL(71)
572-1041-8-71
24.9
RoHS
YES
■Receptacle
Unit: mm
Part Number
CL No.
A
FX2M6A-60S-1.27DSAL(71)
572-1037-0-71
35.1
FX2M6B-60S-1.27DSAL(71)
572-1042-0-71
19.1
RoHS
YES
A115
BConnection Circuit Diagram
Connection to Cable 1
A1
1
B2
bn
1
An
a1
Bn
b1
Type A, A
A116
bn
B1
an
an
A2
Connection to Cable 2
Type A, B
A2
b2
B2
a2
a1
B1
b1
A1
An
bn
Bn
an
n=
Number of Contacts
2
BConnecter Use Hand book
1. Selecting connector
1 The FX2 series is the perfect flux tight connector for the straight type in the soldering process, but it depends on the soldering
process whether non-cleaning type (FX2C-*, FX2B-*) or cleaning type (FX2CA-*, FX2BA-*) should be selected. Please be
sure to clean the right angle type (FX2-*, FX2B-*) connector. To clean the connector, please be sure to use detergent,
containing no contaminant.
2 To use the socket cable type, if a vibration or shock load is applied to the cable, select the lock type. In addition, if a load is
applied to the cable, please be sure to use the cable clamp.
2. Prefixed Process to Board
If the prefixed process is required for mounting the board, please use the prefixed pin type. (Applicable board thickness t = 1.6±0.1)
Note: In order to prevent the dip post breakage in the connector installation to the board, please insert the board in parallel to the
connector so that the prefixed pin may be forcibly pushed in, after the dip post is guided to the board through-hole.
3. Mating Side Tolerance Clearance
(Example) FX2C-*P-1.27DSA and FX2C-*S-1.27DSA
Set the tolerance clearance within 1mm to
mate the male and female connectors.
(Except for the lock cable type)
4. Cautions: for Using Lock Cable Type
1 When the connector is mated,
insert the connector by the end so
as not to make a clearance.
2 When the connector is inserted or
extracted, please insert or extract
the connector after the both lock
levers are laid inside. If the
connector is inserted or extracted
with either lock lever laid, the
connector may be broken.
3 please do not open the lock lever
outside.
A117
5. SMT Type Connector Mounting Temperature Profile (Reference)
●IR Reflow
HRS test conditions
Test boardGlass epoxy 110mm∞40mm∞1.6mm thick
Solder method
(MAX 250ç)
260
96.5%Sn/ 3%Ag/ 0.5%Cu
240
220ç
220
Temperature (ç)
A118
Metal mask
: 0.2mm thick (Straight)
Reflow cycles
: 2 cycles
200ç
200
0.15mm thick(Right angle)
180
160
140
: Reflow
Solder composition : Paste,
The temperature profile is based on the above conditions.
150ç
In individual applications the actual temperature may vary, depending
on solder paste type, volume/thickness and board size/thickness.
Consult your solder paste and equipment manufacturer for specific
recommendations.
(90 to 120 sec.)
Preheating(150 to 200ç)
(MAX 60sec.)
Soldering Time
(220çmin)
Time (sec.)
* In regard to the straight type, please contact Hirose Electric about
the recommended open area ratio when using a 0.15mm metal
mask.
6. SMT Type Connector mated height
As shown in the application pattern, the mated height of the male/female connector doesn't contain the solder paste thickness. Thus,
after the connector installation in the board, consider that the mated height will be widened in proportion to the solder paste
thickness.
