www.msksemi.com
SMF15CT1G
Semiconductor
Compiance
Applications
Cellular handsets and accessories
Portable electronics
Computers and peripherals
Communications systems
Audio and video equipment.
SOT-363
Features
Uni-directional ESD protection of up to five lines
Bi-directional ESD protection of up to four lines
Low diode capacitance
Low clamping voltage
low leakage current
IEC 61000-4-2; level 4 (ESD)
IEC61000-4-5 (surge)
S- Prefix for Automotive and Other Applications
Requiring Unique Site and Control Change
Requirements; AEC-Q101 Qualified and PPAP Capable.
Electrical Characteristics
VBR
P/N
SMF15CT1G
IPP
VRM
IR
Min.
Max.
v
v
v
μA
17
19
15
1
8/20 s pulse;
notes1and2
A
5
C
f=1MHz;
VR = 0 V;
seeFig.4
VCL (Max)
@ IPP =1A
@ IPP =5A
v
v
pF
23
29
15
Value
Units
Notes
1. Non-repetitive current pulse 8/20 s exponentially decaying waveform; see Fig.1.
2. Measured from any of pins 1, 3, 4, 5 or 6 to pin 2.
Absolute Ratings (Tamb=25°C )
Symbol
Parameter
PPP
Peak Pulse Power (tp = 8/20μs)
150
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-60 to +150
°C
Top
Operating Temperature Range
-60 to +150
°C
Tj
Maximum junction temperature
150
°C
8
kV
15
kV
Electrostatic discharge
VPP
IEC61000-4-2 (contact discharge)
IEC61000-4-2 (air discharge)
www.msksemi.com
SMF15CT1G
Semiconductor
Compiance
Electrical Parameter
Symbol
Parameter
VRM
Stand-off voltage
VBR
Breakdown voltage
VCL
Clamping voltage
IR
Leakage current
IPP
Peak pulse current
C
Capacitance
Ipp
120
Ipp
100 %
100 % Ipp; 8 s
80
90 %
et
50 % Ipp; 20 s
40
10 %
Fig.1
t (s)
8/20 s pulse waveform according to
IEC 61000-4-5.
t
tr 0.7 to 1 ns
40
30 ns
60 ns
Fig.2
Electrostatic Discharge (ESD) pulse
waveform according to IEC61000-4-2.
www.msksemi.com
SMF15CT1G
Semiconductor
Compiance
GRAPHICAL DATA
102
Ppp(Tj)
Ppp(Tj=25C)
1.0
Ppp
(W)
0.8
0.6
10
0.4
0.2
1
1
102
10
103
tp (s)
100
Tj (C)
150
Tamb = 25 C.
Ipp = 8/20 s exponentially decaying waveform; see Fig.1.
Fig.3
Peak pulse power dissipation as a function
of pulse time; typical values.
Fig.4
25
Relative variation of peak pulse power as a
function of junction temperature; typical
values.
10
Cd
(pF)
IR(Tj)
IR(Tj=25C)
15
1
10
5
2
3
4
VR (V)
5
101
75
25
25
75
125
175
Tj ( C)
f = 1 MHz; Tamb = 25 C.
Fig.5
Diode capacitance as af unction of reverse
voltage; typical values.
Fig.6
Relative variation of reverse leakage
current as a function of junction
temperature; typical values.
www.msksemi.com
SMF15CT1G
Semiconductor
Compiance
PACKAGE DIMENSIONS
SOT-363
NOTES:
1. DIMENSIONINGANDTOLERANCINGPERANSI
Y14.5M, 1982.
2.CONTROLLINGDIMENSION:INCH.
INCHES
MILLIMETERS
DIM
MIN
MAX
MIN
MAX
A
0.071
0.087
1.80
2.20
B
C
D
G
H
J
K
N
S
V
0.045
0.053
0.031
0.043
0.004
0.012
0.026BSC
0.004
0.004
0.010
0.004
0.012
0.008 REF
0.079
0.087
0.012
0.016
1.15
1.35
0.80
1.10
0.10
0.30
0.65BSC
0.10
0.10
0.25
0.10
0.30
0.20 REF
2.00
2.20
0.30
0.40
REEL SPECIFICATION
P/N
SMF15CT1G
PKG
SOT-363
QTY
3000
www.msksemi.com
SMF15CT1G
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“SMF15CT1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87270
- 50+0.71790
- 150+0.59060
- 500+0.53170
- 3000+0.48470
- 5000+0.45640
- 国内价格
- 5+2.06954
- 50+1.65084
- 150+1.47140
- 500+1.24752
- 3000+1.06068
- 6000+1.00087
