TL431 SOT-23
Adjustable Accurate Reference Source
Features
3
The output voltage can be adjusted to 36V
Low dynamic output impedance, its typical value is 0.2
Trapping current capability is 1 to 100mA
2
The typical value of the equivalent temperature factor in the
whole temperature scope is 50 ppm/
1.Reference
2.Cathode
3.Anode
1
The effective temperature compensation in the working
■ Simplified outline(SOT-23)
range of full temperature
Low output noise voltage
Fast on-state response
Classification Of VREF
Rank
0.3﹪
0.5﹪
1﹪
2﹪
Rangfe
2.493~2.508
2.487~2.512
2.475~2.525
2.450~2.550
Absolute Maximum Ratings (Operating temperature range applies unless otherwise specified)
Parameter
Symbol
Rating
Cathode Voltage
VKA
37
Cathode Current Range (Continuous)
IKA
-100
+150
mA
Reference Input Current Range
IREF
0.05
+10
mA
Power Dissipation
PD
TOPR
Storage Temperature Range
TSTG
-65
Parameter
Reference Input Voltage
Over Temperature
Ratio of Change in Reference Input Voltage
to the Change in Cathode Voltage
Deviation of Reference Input Current
Over Full Temperature Range
mW
70
+150
Symbol
Deviation of Reference Input Voltage
V
350
Operating Temperature
Electrical Characteristics (Ta = 25
Unit
Testconditons
VKA = VREF , IKA = 10mA
VREF
VREF/
VREF/
T
VKA
IREF
IREF/
T
Tmin
Ta
Tmax
Min
Typ
Max
Unit
2.45
2.5
2.55
V
4.5
17
mV
IKA = 10mA ,
VKA = 10V
VREF
-1.0
-2.7
mV/V
IKA = 10mA ,
VKA = 36V
10V
-0.5
-2.0
mV/V
1.5
4
A
0.4
1.2
A
IKA = 10mA , R1 = 10K
, R2 =
, R2 =
TA = Full Temperature
Minimum Cathode Current for Regulation
IKA(min)
VKA = VREF
0.45
1.0
mA
Off-state Cathode Current
IKA(OFF)
VKA = 36V, VREF = 0
0.05
1.0
A
VKA = VREF, IKA = 1 to 100mA,
f
1.0KHz
0.15
0.5
Dynamic Impedance
* TMIN = 0
ZKA
, TMAX = +70
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
TL431 SOT-23
Typical Characteristics
800
V KA = V REF
T A = 25
100
Cathode Current ( A)
Cathode Current (mA)
125
75
50
25
-50
V KA = V REF
T A = 25
600
I KA (MIN)
400
200
-100
-2
1
-200
3
2
I KA = 10mA
T A = 25
40
-10
10
7
-20
-25
-30
T A = 25
I KA = 1mA to 100mA
4
2
1
0.7
0.4
-35
-40
0.2
10
15
30
35
0.1
40
10K
1K
Cathode Voltage (V)
10M
1M
Dynamic Impedance Frequency
70
6
I KA = 10mA
T A = 25
60
T A = 25
I n p u t a n d O u t p u t Vo l t a g e ( V )
Vo l t a g e A m p l i f i c a t i o n ( d B )
100K
Frequency (Hz)
Change in Reference Input Voltage vs.
Cathode Voltage
50
40
30
3
2
Cathode Current vs. Cathode Voltage
100
70
Impedance ( )
Change in Reference Input voltage (mV)
1
Cathode Voltage (V)
Cathode Voltage (V)
1K
10K
100K
1M
3
OUTPUT
2
1
2
3
Time (
Frequency (Hz)
Small Signal Voltage Amplification
vs. Frequency
www.yfwdiode.com
4
10M
INPUT
8
4
5
6
7
s)
Pulse Response
2/3
TL431 SOT-23
SOT-23
Package Outline
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
c
bp
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
Summary of Packing Options
Package
SOT-23
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“TL431”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34536
- 100+0.27673
- 300+0.24242
- 3000+0.19878
- 6000+0.17827
- 9000+0.16797
