SLIM, DIRECT ATTACH
CABLE ASSEMBLIES
(0.635 mm) .025" PITCH
FEATURES & BENEFITS
• Slimmest cable assembly in the industry – 7.6 mm width
• High-density 2-row design
• 8, 16 and 24 differential pair configurations
• 34 AWG, 100 Ω Eye Speed® ultra low skew twinax cable
• Multiple wiring options including reverse polarity
• Mating board level socket (ARF6 Series) features standard rugged
weld tabs for increased stability on the PCB
• Rugged metal latching and shielding
• Supports 56 Gbps PAM4 (28 Gbps NRZ) applications
• Utilizes Samtec’s Flyover® Technology to simplify board layout
and extend signal reach
Right-angle available.
Visit samtec.com?ARF6-RA
for specifications.
Two rows of high-density
contacts directly
soldered to the cable
KEY SPECIFICATIONS
PITCH
CABLE
SIGNAL
ROUTING
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
(0.635 mm) .025"
34 AWG Eye Speed®
100 Ω Differential
Black LCP
Copper Alloy
Au or Sn over 50 µ"
(1.27 µm) Ni
-40 °C to +125 °C
F-221 (Rev 20JUN22)
samtec.com/AcceleRate-Cable
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.635 mm) .025" • SLIM CABLE & SOCKET
ARC6
NO OF
PAIRS
–08
CABLE
LENGTH
–“XX.X”
–24
–LU
= Length in Inches
03.0" (76.2 mm)
minimum
–16
END 1
END 2
–LU
= Latch Up
WIRING
OPTION
CABLE
TYPE
–2
= Latch Up
–1
= Pin 1 to Pin 2
(End 2 -LD option only)
–LD
= 34 AWG 100 Ω
Eye Speed ®
–3
= Latch Down
= Pin 1 to Pin N-1
(End 2 -LU option only)
–2R
ARC6
= Pin 1 to Pin 2
Reversed Polarity
0.60" (152.4 mm) min.
cable length
Board Mates:
ARF6
–3R
= Pin 1 to Pin N-1
Reversed Polarity
cable length
LENGTH = (CABLE LENGTH + (8.1) .319) ±1%
CABLE LENGTH ±1%
A
(15.00)
.591
(5.65)
.222
ARC6–08–XX.X-LU–LU–3–X SHOWN
Notes:
Cable lengths longer than
40.00" (1 meter) are not
supported with S.I. test data.
ARF6
NO. OF
PAIRS
A
N
N-1
–08
(10.90) .429
26
25
–16
(18.52) .729
50
49
–24
(26.14) 1.029
74
73
View complete specifications at: samtec.com?ARC6
NO. OF
PAIRS
–08
–16
–24
PLATING
–S
ROW
–D
= 30 µ" (0.76 µm)
Gold on contact area,
Matte Tin on tail
= Double
Row
A
–A
= Alignment
Pin
K
“X”R
–K
= Polyimide
film Pick &
Place Pad
ARF6
Cable Mates:
ARC6
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order
maximum quantity
per reel; contact
Samtec for
quantity breaks)
A
(12.51)
.493
(7.21)
.284
B
Notes:
Tape & Reel packaging
and K-Dot are standard.
Some sizes, styles and
options are non-standard,
non-returnable.
NO. OF
PAIRS
A
B
C
–08
(12.46)
.491
(7.62)
.300
(9.59)
.378
–16
(20.08)
.791
(15.24)
.600
(17.21)
.678
–24
(27.70)
1.091
(22.86)
.900
(24.83)
.978
C
ARF6–16–L–D–A SHOWN
View complete specifications at: samtec.com?ARF6
F-221 (Rev 20JUN22)
很抱歉,暂时无法提供与“ARF6-08-S-D-A-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+54.46440
- 10+47.47680
- 30+43.22160
- 100+34.89869
