RD035M331LO10*16H-8A2C
    BERYL(绿宝石)
    插件,D10xL16mm
    直插铝电解电容 AEC_D10X16MM_TM
RD035M331LO10*16H-8A2C 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RD Series ● ● High ripple current,for input filtering,105℃ 6000~8000hours RoHS2.0 Compliant ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperture Range -40~ +105℃(160~400V.DC) 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 Capacitance Tolerance 漏电流 Leakage Current 损耗角正切值tanδ Dissipation Factor -25~+105℃(450~500V.DC) 160 ~ 500V.DC ±20%(M) (at 20℃,120Hz) I≤0.02CV +10μA Note: I=Max.leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(Vdc) Rated voltage(Vdc) 160 200 250 350 400 420 450 500 tanδ(Max.) 0.15 0.15 0.2 0.20 0.24 0.24 0.24 0.24 (at 20℃ after 2 minute ) 标称容量超过1000uF,则每增加1000uF,损耗角正切值增加0.02 When nominal capacitance exceeds 1000μF,add 0.02 to the value above for each 1000μF increase. (at 20℃,120Hz) 低温特性 LOW Temperature Characteristics (Max.Impedance Ratio) 阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table Rated voltage(Vdc) 160 200 250 350 400 450 500 Z(-25℃)/Z(+20℃) 3 3 3 5 5 6 6 Z(-40℃)/Z(+20℃) 6 6 6 6 6 - (at 120Hz) 在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流,连续加载右表时间,经恢复到20℃后电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored to 20℃ after applied within maximum allowable ripple current and not over rated voltage range for the time in the table at 105℃. 耐久性 Endurance Capacitance change D.F.(tanδ) Leakage current ≦±20% of the initial value ≦200% of the initial specified value ≦The initial specified value ΦD Φ6.3 >Φ8 时间(hrs) 6000 8,000 在105℃环境中,不施加电压条件下储存1000小时,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. Rated voltage capacitance change D.F.(tanδ) Leakage current 高温储存特性 Shelf Life ≦±20% of the initial value ≦200% of the initial specified value ≦The initial specified value ≦±20% of the initial value ≦200% of the initial specified value ≦200% of the initial specified value ◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm) L± α. Safety Vent (Φ8up) 15min. 5min. 5 6.3 8 10 13 16 18 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 Φd 0.5 0.5 0.5/0.6 0.6 0.6 0.8 0.8 F±0.5 Vinyl sleeve Rubber end seal Φd±0.05 Tinned copper-ply wire α D±0.5 ◆ 纹波电流补正系数 Rated Ripple Current Coefficient ● ΦD 频率系数 Frequency Coefficient Capacitance(μF) 120 1K 10K 100K 2.2~4.7 0.20 0.40 0.80 1.00 5.6~15 0.30 0.60 0.90 1.00 22~100 0.50 0.80 0.90 1.00 Frequency(Hz) -48- (L
RD035M331LO10*16H-8A2C 价格&库存
很抱歉,暂时无法提供与“RD035M331LO10*16H-8A2C”相匹配的价格&库存,您可以联系我们找货
