SS82CG THRU SS820CG
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V Forward Current - 8.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS82 ~ SS820
Simplified outline SMC and symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS82CG
SS84CG
SS86CG
SS88CG SS810CG SS812CG SS815CG SS820CG
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
8.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 8 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.55
0.45
V
mA
400
600
pF
RθJA
35
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
0.85
1.0
50
IR
Cj
0.70
1 of 3
SS82CG THRU SS820CG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
9.6
8.0
6.4
4.8
3.2
1.6
0.0
25
50
75
100
125
150
10 4
T J =100°C
10 3
10 1
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS82CG
SS84CG
SS86CG/SS88CG
SS810CG/SS820CG
0.1
1.0
1.5
100
SS82CG/SS84CG
SS54F
/SS520F
SS86CG~SS820CG
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
175
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
180
25
1000
2.0
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
10
100
Number of Cycles at 60Hz
REV.08
T J =75°C
10 2
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2 of 3
100
SS82CG THRU SS820CG
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
REV.08
3 of 3
Type number
Marking code
SS82CG
SS 8 2
SS 8 4CG
SS 8 4
SS 8 6CG
SS 8 6
SS 8 8CG
SS 8 8
SS 8 10CG
SS 8 10
SS 8 12CG
SS 8 12
SS 8 15CG
SS 8 15
SS 8 20CG
SS 8 20
很抱歉,暂时无法提供与“SS88CG”相匹配的价格&库存,您可以联系我们找货
