DB307S
DB307S
    LGE(鲁光)
    DBS_8.5X6.5MM_SM
    DBS_8.5X6.5MM_SM
DB307S 数据手册
DB301S thru DB307S 3.0A Single-Phase GLass Passivated Bridge Rectifiers Recifiter Reverse Voltage 50V to 1000V DBS Features ●Glass passivated junction ●The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 ●Suge overload ratings to 85 amperes peak ●Ideal for printed circuit board application ●High temperature soldering guaranteed 265℃/10 seconds at 5 lbs(2.3kg)tension Mechanical Data Case:Molded plastic Terminals:Platde leads solderable per MIL-STD-750, Method 2026 Polarity:Polarity symbols molded or Marked on body Mounting Position:Any Weight:0.01ounce,0.3 grams(approx) SPACING Maximum Ratings & Thermal Characteristics Rating at 25℃ ambient temperature unless otherwise specified,Resistive or inductive load,60HZ. For Capacitive load derate current by 20% Parameter Symbol DB301S DB302S DB303S DB304S DB305S DB306S DB307S Maximum repetitive peak reverse voltage VRRM Maximum RMS bridge input voltage VRMS VDC Maximum DC blocking voltage Maximum average forward rectified unit 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V 50 100 200 400 600 800 1000 V IF(AV) 3.0 A IFSM 85 A 10 Typical thermal resistance per element(1) I2 t ReJA 110 Typical thermal resistance per element(2) Cj 25.0 A2sec ℃/w PF Operating junction and stroage temperature TJ, -55to+150 ℃ output current at TA=40℃ Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) Rating for fusing(t
DB307S 价格&库存
很抱歉,暂时无法提供与“DB307S”相匹配的价格&库存,您可以联系我们找货
