1206FA-10A
1206FA-10A
    PROSEMI(普罗森美)
1206FA-10A 数据手册
Circuit Protection 1206FA Series Fast Acting | 0.126x0.064 inch Thick Film Chip Fuses 1206FA Series are the fuses set the industry standard for performance, reliability and quality. The solder-free design provides excellent on-off and temperature cycling characteristics during use and also makes our SMD fuses more heat and shock tolerant than typical subminiature fuses. Appications Features Compatible with reflow and wave solder Flat panel displays and televisions Ceramic and glass construction Automotive infotainment and ECU Halogen free, lead free and RoHS compliant Computer servers Excellent environmental integrity Portable electronics One time positive disconnect Mobile device chargers AEC-Q200 Automotive Grade Certified Power Battery Packs 30 P Electrical Characteristics Amp Rating % of Amp Rating 0.25~40A 0.25~5A 6~40A 100% 250% 350% Opening Time 4 Hours Min. 5 Seconds Max. 5 Seconds Max. Specification Part Number Ampere Rating (A) 1206FA-R250 Voltage Rating Interrupting Rating Typical Cold Resistance (Ohms) Typical Melting I 2 t (A 2 Sec) Typical Voltage Drop (V) Marking Code 0.250 3.610 0.0004 1.402 .25 1206FA-R375 0.375 1.891 0.0008 0.716 E 1206FA-R500 0.500 1.026 0.0020 0.652 0.5 1206FA-R750 1206FA-1A 1206FA-1.5A 1206FA-2A 1206FA-2.5A 1206FA-3A 1206FA-3.5A 1206FA-4A 1206FA-4.5A 1206FA-5A 1206FA-6A 1206FA-7A 1206FA-8A 1206FA-10A 1206FA-12A 1206FA-15A 1206FA-20A 1206FA-25A 1206FA-30A 1206FA-40A 0.750 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 6.00 7.00 8.00 10.0 12.0 15.0 20.0 25.0 30.0 40.0 0.605 0.484 0.249 0.131 0.077 0.048 0.039 0.035 0.031 0.026 0.016 0.012 0.008 0.0065 0.0048 0.0039 0.0018 0.0016 0.0012 0.0086 0.0056 0.105 0.151 0.427 0.675 1.396 1.683 1.745 2.666 2.923 11.20 12.62 14.00 20.55 12.00 16.32 48.02 33.03 44.10 160.3 0.620 0.511 0.365 0.313 0.240 0.185 0.181 0.175 0.168 0.142 0.140 0.141 0.099 0.100 0.086 0.077 0.061 0.058 0.070 0.097 .75 H K N O P R S X T F 7 M U 12 15 20 25 30 XL 72Vdc @ 50A 32Vdc @ 150A 24Vdc @ 300A 32Vdc @ 150A 24Vdc @ 300A 32Vdc @ 150A 24Vdc @ 300A 32Vdc @ 200A DC Interrupting Rating - Measured at designated voltage, time constant < 50 microseconds. DC Cold Resistance are measured at
1206FA-10A
1. 物料型号:1206FA系列 2. 器件简介:这些保险丝以其性能、可靠性和质量设定了行业标准。无焊接设计在使用寿命期间提供了出色的开关和温度循环特性,并且比典型的小型保险丝更耐热和冲击。 3. 引脚分配:文档中未明确提供引脚分配图,但通常1206封装有2个引脚。 4. 参数特性: - 兼容回流焊和波峰焊 - 陶瓷和玻璃构造 - 无卤素、无铅且符合RoHS标准 - 出色的环境完整性 - 一次性正断开 - 通过AEC-Q200汽车级认证 5. 功能详解:电气特性表提供了不同额定电流下的参数,包括额定电流、额定电流百分比和开路时间。 6. 应用信息:适用于平板显示器、电视、汽车信息娱乐和ECU、计算机服务器、便携式电子设备、移动设备充电器和电源电池组。 7. 封装信息:尺寸为3.2±0.2mm(0.126±0.008inch),采用8mm宽胶带在178mm(7英寸)直径的卷轴上,符合EIA标准481,数量为3000pcs。 8. 焊接参数:提供了IR回流焊和波峰焊的参数,包括预热、液态和峰值温度以及时间。 9. 温度降额曲线:展示了在不同环境温度下额定电流的百分比。 10. 平均时间-电流曲线:展示了不同电流下的熔断时间。
1206FA-10A 价格&库存
很抱歉,暂时无法提供与“1206FA-10A”相匹配的价格&库存,您可以联系我们找货
