FN351H-25-33
FN351H-25-33
    SCHAFFNER(夏弗纳)
    FN351H-25-33
FN351H-25-33 数据手册
DATA SHEET 3-Phase Filters FN351 General Purpose EMC Filter EMC solution for industrial inverters and motor drives Approvals & Compliances Rated currents from 8 to 280 A Selectable voltage level of 440 V and 520 V High differential and common-mode attenuation Approvals up to 110 A Features and Benefits Performance indicators Broad range of power ratings for fast and convenient filter selection Available as 440 VAC (FN 351) and 520 VAC (FN 351 H) versions for network-specific applications FN 351 filters provide a broadband common and differential-mode attenuation performance, which remains available also when high interference levels are present Solid, touch-safe filter terminals contribute to overall equipment safety Introduced as one of the very first motor drive EMC filters in the market, FN 351 has been widely imitated and has success- fully proven its function over more than 10 years Technical Specifications Typical Applications Maximum continuous operating voltage 3x 520/300 VAC (FN 351 H) 3x 440/250 VAC (FN 351) Operating frequency DC to 60 Hz Rated currents 8 to 280 A @ 40°C High potential test voltage P –> P 2250 VDC for 2 sec (FN 351 H) P –> E 2600 VDC for 2 sec (FN 351) P –> P 1900 VDC for 2 sec (FN 351) P –> E 2750 VDC for 2 sec (FN 351 H) Protection category IP 20 Overload capability 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour Temperature range (operation and storage) -25°C to +100°C (25/100/21) (FN 351 H) -25°C to +85°C (25/085/21) (FN 351) Flammability corresponding to UL 94 V-2 or better Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 MTBF @ 45°C/480 V (Mil-HB-217F) 135,000 hours Three-phase motor drives Inverters and converters Industrial automation equipment UPS SMPS General purpose three-phase filtering Typical electrical schematic 2 3-Phase Filters Schaffner Group DATA SHEET 05. Jul 2022 Filter Selection Table Filter* Rated current Typical drive Leakage current*** Power loss @ 40°C (25°C) power rating** @ 440/520 VAC/50 Hz @ 25°C/50 Hz [A] [kW] [mA] [W] 8 (9.2) 3 0.3 7 FN 351-16-29 16 (18.5) 5.5 0.3 FN 351-25-33 25 (28.9) 11 3.2 FN 351-36-33 36 (41.6) 15 FN 351-50-.. 50 (57.7) 22 FN 351-64-.. 64 (73.9) FN 351-80-34 FN 351-110-35 FN 351-8-29 Input/Output connections Weight [kg] -29 0.8 8 -29 1.3 8 -33 1.4 3.2 9 -33 1.5 3.5 11 -33 30 3.5 15 -33 80 (92.3) 37 3.7 23 -34 110 (127) 55 3.7 25 -35 5.8 FN 351-180-36 180 (208) 90 3.7 49 -36 13.0 FN 351-280-37 280 (323) 132 4.3 70 -37 28.0 FN 351 H-8-29 1.6 -34 1.7 5.6 8 (9.2) 4 0.3 7 -29 1.1 FN 351 H-16-29 16 (18.5) 7.5 0.3 8 -29 1.3 FN 351 H-25-33 25 (28.9) 15 3.8 8 -33 1.4 FN 351 H-36-33 36 (41.6) 18.5 3.8 9 -33 1.5 FN 351 H-50-.. 50 (57.7) 30 3.8 11 -33 1.6 FN 351 H-64-33 64 (73.9) 37 3.8 15 -33 1.7 FN 351 H-80-34 80 (92.3) 45 4.4 23 -34 5.6 FN 351 H-110-35 110 (127) 75 4.4 25 -35 5.8 FN 351 H-180-36 180 (208) 110 4.4 49 -36 13.0 * To compile a complete part number, please replace the -.. with the required I/O connection style. ** Calculated at rated current, 400 VAC (FN 351)/480 VAC (FN 351 H) and cos phi=0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application. *** Standardized calculated leakage current acc. IEC60939 under normal operating conditions (FN 351 at 440 VAC and FN 351H at 520 VAC). Typical Filter Attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 8 A types 16 A types 25 A types 36 and 50 A types 64 A types 80 and 110 A types 180 A types 280 A types 3 3-Phase Filters Schaffner Group Mechanical Data 8 and 16 A types 80 and 110 A types 25 to 64 A types 180 and 280 A types DATA SHEET 05. Jul 2022 4 3-Phase Filters Schaffner Group DATA SHEET 05. Jul 2022 80 A 110 A 180 A 280 A Dimensions 8A 8A 16 A 25 A 36 A (-H) 50 A 50 A 64 A 64 A (-33) (-34) (-33) (-34) A 180 200 200 200 200 200 200 200 200 400 400 510 700 B 115 150 150 150 150 150 150 150 150 170 170 180 260 C 60 65 65 65 65 65 65 65 80 90 90 133 155 D 85 120 120 120 120 120 120 120 120 350 350 360 530 E 115 115 115 115 115 115 115 115 115 373 373 470 660 F 100 136 136 136 136 136 136 136 136 130 130 156 220 G 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 15 x 6.5 15 x 6.5 16 x 9 16 x 9 H 1 1 1 1 1 1 1 1 1 1 1 4 4 I 17 17 17 25 25 25 39 25 39 39 45 83 110 J M6 M6 M6 M6 M6 M6 M6 M6 M6 M10 M10 M10 M10 K 13 19.25 19.25 19.25 19.25 19.25 18.75 19.25 18.75 40 40 25 30 L 17 17 17 18.4 18.4 18.4 17 18.4 17 70 70 85 100 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m Filter Input/Output Connector Cross Sections -29 -33 -34 -35 -36 -37 Solid wire 6 mm2 16 mm2 35 mm2 50 mm2 95 mm2 150 mm2 Flex wire 4 mm2 10 mm2 25 mm2 50 mm2 95 mm2 150 mm2 AWG type wire AWG 10 AWG 6 AWG 2 AWG 1/0 AWG 4/0 AWG 6/0 Recommended torque 0.6-0.8 Nm 1.5-1.8 Nm 4.0-4.5 Nm 7-8 Nm 17-20 Nm 27-30 Nm Please visit www.schaffner.com to find more details on filter connectors. 5 3-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 05. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN351H-25-33
物料型号:3-Phase Filters FN351
器件简介:该产品是用于工业变频器和电机驱动的通用EMC(电磁兼容性)滤波器,提供8至280A的额定电流。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 工作电压:三相520/300 VAC (FN 351 H) 或 440/250 VAC (FN 351) - 操作频率:直流至60 Hz - 高电位测试电压:不同型号有不同电压等级 - 保护类别:IP 20 - 过载能力:开机时4倍额定电流,每小时一次1.5倍额定电流持续1分钟 - 温度范围:-25°C至+100°C 或 -25°C至+85°C - 阻燃等级:符合UL 94 V-2或更好
功能详解:FN 351滤波器提供了宽带共模和差模衰减性能,在高干扰水平下仍能保持有效。
应用信息: - 三相电机驱动 - 变频器和转换器 - 工业自动化设备 - UPS(不间断电源) - SMPS(开关电源)
封装信息:提供了不同额定电流下的典型电气原理图和滤波器选择表,包括额定电流、典型驱动功率等级、漏电流、功率损耗、输入/输出连接方式和重量。
FN351H-25-33 价格&库存
很抱歉,暂时无法提供与“FN351H-25-33”相匹配的价格&库存,您可以联系我们找货
FN351H-25-33
  • 1+3693.882311+478.79748
  • 10+3067.1743510+397.56420
库存:1
