O3250000153025D3JB
O3250000153025D3JB
    JGHC(晶光华)
    SMD3225_4P
    有源晶振 50MHz 3.3V -40℃~+85℃ CMOS
O3250000153025D3JB 数据手册
承 认 书 SPECIFICATION FOR APPROVAL 客户名称:Customer 货 SMD 3225 XO CMOS 石英晶体振荡器 名:Description 客户料号: Part No 物料编号: Code No O3250000153025D3 频 率:Frequency 50.000MHz 日 期:Date 2020-05-25 备 注:RoHS compliance with Directive (EU) 2015/863 制作(Prepare by) 检查(Check by) 批准(Approve by) 江丹娜 甘瑛 张刚 客户批准 Approve by customer 批准日期 Approval date Add:广东省深圳市华发北路桑达工业区桑达雅苑 7P 7 P Sangda Yayuan Huafa North Road, Futian District, Shenzhen, Guangdong Tel: 86-755-83048260 86-755-83048290 Fax: 86-755-83048280 www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd.  ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature Relative humidity : 25±5℃ : 40%~70% If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature Relative humidity : 25±3℃ : 40%~70% Measure equipment Electrical characteristics measured by MD 37WX-05M or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode).  Electrical characteristicsFrequency Frequency Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units 1 Nominal Frequency - 50.000 MHz - 2 Frequency Stability - ±30 ppm - 3 Operating Temperature Topr -20 25 70 ℃ - 4 Storage Temperature Tstg -55 ~ 125 ℃ - 5 Supply Voltage VDD V - mA - Icc 6 Input Current 7 Enable Control 8 Output Load : CMOS 2.5 ±10% - - 3 - Yes - CL 15 pF - Pad 1 9 Output Voltage High VoH 90%Vdd - - V - 10 Output Voltage Low VoL - - 10%Vdd V - 11 Rise Time Tr - - 10 ns 10%→90%VDD Level 12 Fall Time Tf - - 10 ns 90%→10%VDD Level 13 Symmetry (Duty ratio) TH/T 45 ~ 55 % - 14 Start-up Time Tosc - - 10 ms - 15 Enable Voltage High Vhi 70%Vdd - - V - 16 Disable Voltage Low Vlo - - 30%Vdd V - - 17 Aging ppm/yr. 1st. Year at 25℃ ±3 18 Output Disable Delay Time T off - - 150 μS - 19 Output Enable Delay Time T on - - 150 μS - www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd. ■ TEST DIAGRAM Control input (output enable/disable) Logic 1 or open on pad 1: Oscillator output Logic 0 on pad 1 : Disable output to high impedance ■ WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd. ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ ■ PRODUCT DIMENSIONS (Unit:mm) www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd. ■ STRUCTURE ILLUSTRATION COMPONENTS NO MATERIA FINISH/SPECIFICATIONS LS 1 Lid Kovar (Fe/Co/Ni) 2 Base (Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad (Au) - 3 IC chip - - 4 Crystal blank SiO2 - 5 Conductive adhesive Ag Silicon resin 6 Electrode Noble Metal - 7 Die attached Conductive (Ag) Epoxy resin Bonding wire Au 8 - Pad 1 options : NC is 5 wires , www.jghcorp.com EN is 6 wires. ShenZhen JingGuangHua Electronic Co.,Ltd. ■ PACKAGE INFORMATION TAPE (CARRIER) DIMENSIONS THE DIRECTION OF PACKING REEL DIMENSIONS www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd. ■ RELIABILITY SPECIFICATIONS 1. Mechanical Endurance Test Item No. 1 1 Test Methods Drop Test 75 cm height,3 times on concrete floor . Device are shocked to half sine wave ( 1000 G ) three mutually Mechanical Shock perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes perpendicular axes each test time 4 Hrs 1 Vibration REF. DOC JIS C6701 MIL-STD-202 MIL-STD-883 (Total test time 12 Hrs) 1 2 Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg Gross Leak / cm2 Fine Leak Helium Bomging 4.5 kgf / cm 2 for 2 Hrs 2 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883 MIL-STD-883 MIL-STD-883 solvent ( 1 : 4 ) 2. Environmental Endurance Test Item No. Test Methods Pre-heat temperature 2 125 ℃ Resistance To Soldering Pre-heat time 60 ~ 120 sec. Heat Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs REF. DOC MIL-STD-202 MIL-STD-883 Total 100 cycles of the following temperature cycle 2 Thermal Shock MIL-STD-883 3 High Temp&Humidity 85℃ ± 3℃, RH 85% , 1000 Hrs 3 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240 Hrs www.jghcorp.com ShenZhen JingGuangHua Electronic Co.,Ltd. EIA-JESD22 EIA-JESD22
O3250000153025D3JB 价格&库存
很抱歉,暂时无法提供与“O3250000153025D3JB”相匹配的价格&库存,您可以联系我们找货
O3250000153025D3JB
  • 1+1.74312
  • 10+1.38024
  • 30+1.22472
  • 100+1.03680
  • 500+0.94608
  • 1000+0.89424
库存:325
