1N4004
1N4004
    YONGYUTAI(永裕泰)
    SMA(DO-214AC)
    400V 1A
1N4004 数据手册
1N4001 THRU 1N4007 FEATURES Glass passivated chip junction Ideal for surface mounted applications Low leakage High forward surge current capability. High temperature soldering guaranteed: 260/10 seconds at terminals. MECHANICAL DATA Case: Transfer molded plastic Epoxy: UL94V - 0 rate flame retardant. Polarity: Color band denotes cathode end Lead: Plated terminals solderable per MIL - STD - 202E method 208C Weight: 0.002 ounce, 0.057 gram MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load derate current by 20% CatalogNumber Maximum Repetitive Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current, at TA = 75 Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum Instantaneous Forward Voltage Drop at 1.0A TC = 25 Maximum DC Reverse Current at rated TA = 125 DC blocking voltage Maximum Full Load Reverse Current, full cycle average at TA = 75 Typical Junction Capacitance (Note 1) Typical Thermal Resistane (Note 2) Operating and Storage Temperature Range SYMBOLS VRRM VRMS VDC 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007 I(AV)   Amp IFSM  Amps VF   Volts IR    A IR(AV)  A CJ R TJ,TSTG   (-65 to +175) pF /w                        UNITS Volts Volts Volts NOTES: 1. Measured at 1.0 MHz and applied aberage voltage of 4.0 volts. 2. 6.0 X 6.0mm2 copper pads to each terminal. www.yongyutai.com PAGE 1 1N4001 THRU 1N4007 FIG.2-MAXIMUM NON-REPETITIVE PEAK FIG.1-TYPICAL FORWARD CURRENT FORWARD SURGE CURRENT 1.0 0.8 0.6 Single Phase Half Wave 60Hz 0.4 Resistive or Inductive Load 0.2 0.375''(9.5mm) Lead Length 30 8.3ms Single Half Sine-Wave =TTj j max (JEDEC Method) 20 (A) PEAK FORWARD SURGE CURRENT 1.2 (A) AVERAGE FORWARD CURRENT, DERATING CURVE 10 1 Cycle 0 0 0 75 50 25 125 100 150 1 175 2 4 8 20 10 60 40 100 NUMBER OF CYCLES AT 60 Hz AMBIENT TEMPERATURE, ( ° C) FIG.3-TYPICAL INSTANTANEOUS FIG.4-TYPICAL REVERSE FORWARD CHARACTERISTICS CHARACTERISTICS 10 (A) 1.0 0.1 T j =25 ° C PULSE WIDTH=300uS 1%DUTY CYCLE 0.01 0.4 0.8 0.6 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE,(V) T =100 ° C j 1.0 (A) INSTANTANEOUS REVERSE CURRENT, 10 INSTANTANEOUS FORWARD CURRENT, 6 0.1 T =25 ° C j 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) FIG.5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 100 10 T =25 ° C j f=1MHz V sig =50mV p-p 1 0.1 1.0 10 100 REVRESE VOLTAGE,(V) www.yongyutai.com PAGE 2
1N4004 价格&库存
很抱歉,暂时无法提供与“1N4004”相匹配的价格&库存,您可以联系我们找货
1N4004
    库存:11642
    1N4004
    • 1+0.07546
    • 50+0.03784
    • 2000+0.02860
    库存:3239
    1N4004
      • 50+0.05160
      • 500+0.04280
      • 2000+0.03600
      • 4000+0.03110
      • 10000+0.02930
      库存:11642
