LM324A
Quadruple Operational Amplifiers
DESCRIPTION
The LM324A consists of four independent, high gain, internally frequency compensated operational amplifiers which were
designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power
supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply
voltage.
Application areas include transducer amplifiers, DC gain blocks and all the conventional op amp circuits.
FEATURES
Wide range of supply voltages
Low supply current drain independent of supply voltage
Low input biasing current
Low input offset voltage and offset current
Input common-mode voltage range includes ground
Differential input voltage range equal to the power supply voltage
DC voltage gain 100 V/ mV Typ
Internally frequency compensation
PIN1
SOP14
PIN1
DIP14
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing Qty
LM324AN
DIP14
LM324A
TUBE
1000/box
LM324AM/TR
SOP14
LM324A
REEL
2500/reel
PACKAGE INFORMATION
DIP14/SOP14
http://www.hgsemi.com.cn
1
2019 OCT V1.0
LM324A
ELECTRICAL CHARACTERISTICS
at specified free-air temperature, VCC = 5V (unless otherwise noted)
PARAMETER
TEST CONDITIONS*
VIO
Vcc =5V to MAX,
25 С
Input offset voltage
VIC = VICR min,
VO=1.4V
Full temperature
range
αVIO
Average temperature coefficient of input offset
voltage
IIO
Vo=1.4V
MIN
LM324A
TYP
3
Full temperature
range
7
25 С
2
Full temperature
range
αIIO
current
IIB
Input bias current
Full temperature
range
10
-20
Vcc = 5V to MAX
25 С
Full temperature
range
25 С
0 to Vcc - 2
VOH
RL = 2 k
Full temperature
range
25 С
High-level output voltage
Vcc = MAX, RL =2k
Full temperature
range
26
Vcc = MAX,
Full temperature
range
27
VICR
Common-mode input voltage range
VOL
Low-level output voltage
AVD
RL = 10 k
RL = 10 k
7
mV
9
Input offset current
Vo=1.4V
UNIT
MAX
µV/C
50
nA
150
pA/C
-250
-500
0 to Vcc-1.5
V
Vcc-1.5
Full temperature
range
nA
V
28
5
mV
Vcc = 15 V,
25 С
25
Large-signal differential voltage amplification
Vo=1V to 11 V,
RL 2 k
Full temperature
range
15
CMRR
Common-mode rejection ratio
Vcc = 5V to MAX,
VIC = VICR min
25 С
kSVR Supply voltage rejection ratio (Vcc/VIO)
Vcc = 5V to MAX
25 С
Vo1/Vo2 Crosstalk attenuation
f=1kHz to 20 kHz
25 С
IO
Vcc = 15 V,
25 С
-20
Output current
VID=1V,Vo= 0
Full temperature
range
25 С
-10
Full temperature
range
5
VID= -1V, Vo = 200 mV
25 C
12
los
Short-circuit output current
Icc
Vcc at 5 V,
GND at -5V,Vo=0
Vo = 2.5 V, No load
25 С
±40
±60
mA
Full temperature
range
1.5
2.4
mA
Supply current (four amplifiers)
Vcc = MAX, Vo = 0.5Vcc, No
load
Full temperature
range
1.1
3
Vcc = 15 V,
VID= -1V, Vo=15V
100
V/mV
65
80
dB
65
100
dB
120
dB
-30
mA
10
µA
30
* All characteristics are measured under open loop conditions with zero common-mode input voltage unless otherwise specified.
"MAX" Vcc for testing purposes is 30 V. Operating temperature -40 ÷ 85° C, MAX Junction temperature + 125°C.
1
2
2019 OCT V1.0
LM324A
PACKAGE
SOP14
Q
A
C1
C
B
D
A1
a
0.25
b
UNIT:mm
DIM.
A
A1
B
C
C1
D
MIN
4.520
0.100
8.500
5.800
3.800
0.400
TYP
4.570
8.750
6.100
3.900
MAX
4.620
0.250
9.000
6.250
4.000
0.950
DIM.
a
b
Q
MIN
0.400
1.260
0°
TYP
0.420
1.270
MAX
0.440
1.280
8°
DIP14
3
2019 OCT V1.0
LM324A
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
4
2019 OCT V1.0
很抱歉,暂时无法提供与“LM324AM/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71874
- 50+0.57348
- 150+0.50091
- 500+0.44648
- 2500+0.41505
- 5000+0.39323
