HHEI252010A-1R0M-Q8
HHEI252010A-1R0M-Q8
    CHILISIN(奇力新)
    功率电感 SMD
HHEI252010A-1R0M-Q8 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL Customer: Customer P/N: Drawing No: Quantity: X Pcs. DATE: 2016/08/17 HHEI252010A-1R0M-Q8 Chilisin P/N: SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com.tw http://www.chilisin.com.tw Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com.tw 奇力新電子(河南)有限公司 蘇州奇益新電子有限公司 Chilisin Electronics (Henan) Co., Ltd. XiuWu Xian, industry gathering area JiaoZuo, Henan China Postal Code:454350 TEL:+86-391-717-0682 FAX:+86-391-717-0666 Drawn by 張鈺雯 chang.yuwen SUZHOU QI YIXIN Electronics Co., Ltd. No.143,Song Shan Rd., Suzhou New District, Suzhou,China Postal Code:215129 TEL:+86-512-6841-2350 FAX:+86-512-6841-2356 E-mail suzhou@chilisin.com.tw Checked by 張鈺雯 chang.yuwen Approved by 鍾瑞民 jacky.chung HHEI252010A Series Specification 1 Scope: This specification applies to Molding power inductors 2 Part Numbering: 3 Rating: Operating Temperature: -40℃~125℃(Including self - temperature rise) Storage Temperature: -40℃~125℃(after PCB) -5℃~35℃,Humidity 45%~85%(before PCB) 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35℃) Ordinary Humidity(25 to 85% RH) In case of doubt 20 to 30℃ 50 to 80 %RH HHEI252010A Series Specification 6 Configuration and Dimensions: Dimensions in mm TYPE HHEI252010A A 2.5±0.3 B 2.0±0.3 C 1.0max D 0.6±0.3 7 ELECTRICAL CHARACTERISTICS: Part No. HHEI252010A-1R0M-Q8 Inductance (uH ) Tolerance (±%) Test Freq. Irms(A) Max.(Typ) Isat(A) Max.(Typ) RDC(mΩ) Max.(Typ) 1.0 20 2MHz,0.2V 4.2(4.4) 4.7(5.0) 30(25) NOTE: 1.Operating temperature range -40℃~125℃(Including self - temperature rise) 2.Idc: DC current (A) that will cause an approximate ΔT of 40°C. 3.Isat: DC current (A) that will cause Lo to drop approximately 30% 4.All test data is referenced to 25℃ ambient 5.Absolute maximum voltage 25VDC HHEI252010A Series Specification 8 HHEI252010A Series 8.1 Construction: 8.2 Material List: HHEI252010A Series Specification 9 Reliability Of Molding power inductors 1-1.Mechanical Performance No Item 1-1-1 Flexure Strength 1-1-2 Vibration Test Method Specification Test device shall be soldered on the substrate conditions must not damage Substrate Dimension: 100x40x1.6mm the terminal electrode and the Deflection: 2.0mm metal body Keeping Time: 30sec The forces applied on the right Test device shall be soldered on the substrate Appearance:No damage (for microscope of CASTOR MZ-45 20X) Oscillation Frequency: 10 to 55 to 10Hz for 1min Amplitude: 1.5mm Time: 2hrs for each axis (X, Y & Z), total 6hrs 1-1-3 Resistance to Soldering Heat Appearance: No damage Pre-heating: 150℃, 1min More than 75% of the terminal. Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) electrode should be covered Solder Temperature: 260±5℃ with solder. Immersion Time: 10±1sec Inductance: within ±20% of initial value 1-1-4 Solder ability The electrodes shall be at Pre-heating: 150℃, 1min least 95% covered with new Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) solder coating Solder Temperature: 245±5℃ Immersion Time: 4±1sec Inductance change shall be within ±20% 1-1-5 Terminal Strength Test No split termination Chip F Test device shall be soldered on the substrate, then apply a force in the direction of the arrow. Force : 5N Keeping Time: 10±1sec Mounting Pad 1-2.Environmental Performance No Item 1-2-1 Temperature Cycle 1-2-2 Humidity Resistance 1-2-3 High Temperature Resistance 1-2-4 Low Temperature Resistance Specification Appearance: No damage Inductance:within±20% of initial value Test Method One cycle: Step Time (min) Temperature (℃) 1 -40±3 30 2 25±2 3 3 125±3 30 4 25±2 3 Total: 100cycles Measured after exposure in the room condition for 24hrs Temperature: 60±2℃ Relative Humidity: 90 ~ 95% / Time: 500hrs Measured after exposure in the room condition for 24hrs Temperature: 85±3℃ Relative Humidity: 0% / Time: 500hrs Measured after exposure in the room condition for 24hrs Temperature: -40±3℃ Relative Humidity: 0% / Time: 500hrs Measured after exposure in the room condition for 24hrs HHEI252010A Series Specification HHEI252010A Series Specification 10 Packaging 10.1 Packaging -Cover tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. 10.2 Packaging Quantity TYPE PCS/REEL HHEI252010A 3000 10.3 Reel Dimensions Dimensions in mm TYPE A HHEI252010A 178 B C D 60 12 1.5 HHEI252010A Series Specification 10 Packaging 10.4 Tape Dimensions in mm TYPE A B T W P F K HHEI252010A 2.25 2.80 0.22 8 4 3.5 1.15 TYPE A B C HHEI252010A 1.2 2.8 2.3 11 Recommended Pattern Dimensions in mm 12 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5.After manufacturing process, there might be slight irregular shape on the edge of the products, and it's a normal phenomenon that can be neglected 6.The moisture sensitivity level (MSL) of products is classified as level 1. HHEI252010A Series Specification 13 Graph: HHEI252010A-1R0M-Q8 2.00 50 1.80 1.60 40 L(uH) 1.20 30 1.00 0.80 20 0.60 0.40 L(uH) 0.20 ΔT(℃) 0.00 10 0 0 0.4 0.8 1.2 1.6 2 2.4 2.8 3.2 3.6 DC Current(A) 4 4.4 4.8 5.2 △T(℃) 1.40
HHEI252010A-1R0M-Q8 价格&库存
很抱歉,暂时无法提供与“HHEI252010A-1R0M-Q8”相匹配的价格&库存,您可以联系我们找货
HHEI252010A-1R0M-Q8
    • 5+0.56478
    • 50+0.45680
    • 150+0.40277
    • 500+0.36229
    • 3000+0.28756
    • 6000+0.27140
    库存:640
