KUSBX-SMT-AS1N-W
KUSBX-SMT-AS1N-W
    KYCON
    SMD
    USB连接器 SMD
KUSBX-SMT-AS1N-W 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBX-SMT-AS1N-B Part Number Builder LR78160 KUSBX-SMT UNIVERSAL SERIAL BUS: KUSBX-SMT Series Surface Mount USB Series Surface Mount Compatible with Many Computer Peripherals A and B Types Available Supports Hot Plugging Contact Area with Gold Plating CSA/NRTL Certified File No. LR78160 UL File No. E134345 Plating Option Packaging Type AS1N - A Type BS1N - B Type Insulator Color Option B - Black W - White Performance Specifications Materials and Finish Insulator High Temperature Thermoplastic, UL94V-0 Rated, White or Black Color Contacts Phosphor Bronze Contact Plating Gold over Nickel on Contacts Tin over Nickel on Termination End Shell Copper Alloy, Nickel Plated over Copper Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Packaging Blank - Bulk TR - Tape and Reel Contact Kycon for more options KUSBX-SMT Dimensions in mm KUSBX-SMT-AS1N 12.5 5.12 7.0 7.05 pos. 4 7.05 14.6 7.1 pos. 1 2.50 10.3 14.5 4.3 2.50 2.00 13.35 KUSBX-SMT-BS1N Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013 7.0 13.1 14.0 Rated Voltage 30V AC Rated Current 1A Contact Resistance 30 milliohms Max. Insulation Resistance 1000 Megohms Min. Dielectric Withstanding Voltage 500V AC For 1 Minute Operating Temperature See Drawing Insulator Color Type Series KUSBX-SMT - Surface Mount Universal Serial Bus Product Features Electrical Characteristics B AS1N
KUSBX-SMT-AS1N-W 价格&库存
很抱歉,暂时无法提供与“KUSBX-SMT-AS1N-W”相匹配的价格&库存,您可以联系我们找货
KUSBX-SMT-AS1N-W
    • 1+16.992721+2.19220
    • 10+11.2992810+1.45770
    • 50+7.3576750+0.94920
    • 100+6.48176100+0.83620
    • 500+6.30658500+0.81360
    • 1000+6.306581000+0.81360
    • 2000+6.306582000+0.81360
    库存:2
    KUSBX-SMT-AS1N-W
    • 1+10.259911+1.32362
    • 10+8.7407110+1.12763
    • 25+8.1891025+1.05646
    • 50+7.7979650+1.00600
    • 100+7.42554100+0.95796
    • 300+6.87139300+0.88647
    • 500+6.62801500+0.85507
    • 1000+6.311551000+0.81424
    • 2500+5.916422500+0.76327
    库存:5103
