2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDVX-0202-B
Part Number Builder
R
E 140125
LR78160
B
KLDVX-0202
DC POWER CONNECTORS: KLDVX Series
Vertical PCB Mount DC Power Jack
Product Features
2.0mm and 2.5mm
Mounts Perpendicular to PCB
Built in DC On/Off Switch
CSA/NRTL Certified File No. LR78160
UL File No. E140125
Series
Diameter
Series
KLDVX-0202 - Vertical PCB Mount DC Power Jack
Diameter
A - 2.0mm Center Pin Diameter
B - 2.5mm Center Pin Diameter
Contact Kycon For Other Options
KLDVX-0202 Series
Performance Specifications
Materials and Finish
Plastic Housing:
High Temperature Thermoplastic, UL94V-0 Rated, Black Color
Center Pin: Brass, Nickel Plated
Contact #1: Brass, Matte Tin Plated
Contact #2: Phosphor Bronze, Gold Flash on Contact Area,
Matte Tin on Solder Pin
Contact #3: Brass, Matte Tin Plated
Dimensions in mm
Electrical Characteristics
Contact Resistance
Before Durability Test
Between Terminals: 30 milliohms Max.
Plug to Contacts: 50 milliohms Max.
After Durability Test
Between Terminals: 60 milliohms Max.
Plug to Contacts: 100 milliohms Max.
Rated Voltage: 24V DC
Rated Current: 3.5A
Insulation Resistance: 100 Megohms Min.
Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute
Mechanical Characteristics
Durability Test: 5000 Cycles
Insertion Force: 0.3kg - 2.0kg
Extraction Force: 0.3kg - 2.0kg
Operating Temperature: -25˚C to +85˚C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1218
很抱歉,暂时无法提供与“KLDVX-0202-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.306191+0.78876
- 10+5.3459510+0.66866
- 25+5.0097625+0.62661
- 50+4.7712950+0.59678
- 100+4.54353100+0.56829
- 250+4.25849250+0.53264
- 500+4.05497500+0.50719
- 1000+3.861281000+0.48296
- 2500+3.619532500+0.45272
- 国内价格 香港价格
- 1+20.508161+2.56510
- 10+13.7323410+1.71760
- 50+8.9440950+1.11870
- 100+7.76961100+0.97180
- 500+7.67927500+0.96050
- 1000+7.679271000+0.96050
- 2000+7.588922000+0.94920
