TP-POE+10G
DATA SHEET
53V 30W 10G 802.3at PoE Inserter
Features
10/100/1000/10000Mb Data Rate
CAT6 (or higher) for 10G
Compact Size, Shielded RJ45 Jacks
I.T.E. Power Supply, UL Listed
Applications
• 802.3af/at PoE Wireless Devices
• 802.3af/at PoE Security Cameras
Description
The TP-POE+10G is a compact 10/100/1000/10000MB (10G) desktop 802.3at PoE+ inserter with
120/240VAC auto-ranging input. The reliable UL Listed inserter has an output that is Mode A (1,2+ 3,6-)
802.3at PoE at up to 31.8W. It comes with a 3 prong 2’ North American power cord with IEC C5 plug.
Specifications
TP-POE+10G
100-240VAC 50/60Hz
53VDC +/-2V, 802.3af/at PoE, Mode A (Pins 1,2+ 3,6-)
0.6A (31.8W) Max
Short Circuit, Overcurrent, Surge/ESD (8kV)
78% Minimum
200mV p-p max
10/100/1000/10000Mbps (10Gb)
1W Max
-20 to +50°C
-30 to +80°C
10% to 90% non condensing
5.5 x 2.5 x 1.4” (138.5 x 62.5 x 35.3mm)
7.4oz (210g)
50,000 Hrs
UL, CE, FCC | IEC 60065, IEC60950, UL60950-1, UL/CUL62368, EN55022, EN55013,
EN55024, EN55020, FCC Part 15 Class B, EN61000-4-4, EN61000-4-5
RJ45 Shielded Jacks
CAT6a 10G to 55m; CAT6e 10G to 80m, 5G to 100m
3 Years
AC Input Voltage
Output PoE Voltage
Maximum Load
Protections
Efficiency
Ripple and Noise
Data Rate
No Load Consumption
Operating Temperature
Storage Temperature
Operating Humidity
Size (L x W x H)
Weight
MTBF
Certifications
Connectors
Ethernet Cable Compatibility
Warranty
System Ordering:
TP-POE+10G
802.3at 10G Desktop Active PoE Inserter
For further information contact:
Tyconsystems.com
TP-POE+10G Spec Rev 1 9/9/2019
Specifications Subject to Change Without Notice
14641 S 800 W Bluffdale, UT 84065
PH: 801-432-0003 FAX: 801-618-4220
很抱歉,暂时无法提供与“TP-POE+10G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+726.623271+93.99982
