TP-ESP-1000-POE
TP-ESP-1000-POE
    TYCON(泰康)
    TP-ESP-1000-POE
TP-ESP-1000-POE 数据手册
TP-ESP-1000-POE DATA SHEET Ethernet Surge Protector Features • • • • • 10/100/1000Mb Data Rate (24 or 48V POE Model) CAT5/6 Compatible. All 8 pins protected. Shielded jacks and full metal housing Complies with IEC 61643-21 Standard UL497B Listed (TP-ESP-1000-POE) Applications • Wireless Access Points and Client Devices • IP Phone and Security Camera Systems • Industrial Control Systems Description The ESP-POE are a low cost Ethernet surge protector to help protect sensitive equipment from surges caused by lightning and grid power fluctuations. They have a full metal body for improved EMI suppression and have integral mounting feet and separate ground wire. They are designed for indoor or outdoor use inside a weatherproof enclosure. The ESP-1000-POE is compatible with 10/100/1000M PoE systems up to 57V. The ESP-1000-POE24 is compatible with 10/100/1000M PoE systems up to 30V. The ESP-100-POE24 is for 10/100M passive PoE systems up to 30V. Protection is provided on all 8 CAT5/6 wires. Specifications Operating Voltage Clamping Voltage Max Surge Discharge Current Peak Pulse Current Protection Mode Insulation Resistance Shunt Capacitance Data Rate Response Time Operating Temperature Storage Temperature Operating Humidity Size (L x W x H) Weight Ground Wire Connectors IEC Standard UL Standard Shock and Vibration IEEE/ ANSI Standard MTBF (Mean Time Between Failure) Warranty TP-ESP-1000-POE TP-ESP-1000-POE24 TP-ESP-100-POE24 Data 5V ; PoE 48V Data 5V ; PoE 24V Data 5V ; PoE 24V 7.5V Data (Pins 1,2,3,6) 70V POE (All 8 Pins) 40V POE (All 8 Pins) 40V POE (Pins 4,5,7,8) 5KA (8/20us) 5KA (8/20us) 5KA (8/20us) 100A (10/1000us) 100A (10/1000us) 100A (10/1000us) Differential & Common Mode Differential & Common Mode Differential & Common Mode >1000 MOhm >1000 MOhm >1000 MOhm < 25 pF < 50 pF < 25 pF 10/100/1000 Mbps 10/100/1000 Mbps 10/100 Mbps
TP-ESP-1000-POE 价格&库存
很抱歉,暂时无法提供与“TP-ESP-1000-POE”相匹配的价格&库存,您可以联系我们找货
TP-ESP-1000-POE
  • 1+523.981421+67.75807
