LC86LIAMD
LC86LIAMD
    QUECTEL(移远)
    SMD-12P
    LC86LIAMD
LC86LIAMD 数据手册
10.1 mm Quectel LC79D Ultra-Small Dual-Band Multi-Constellation GNSS Module 9.7mm 2.4mm Featuring a concurrent multi-constellation GNSS receiver on dual GNSS bands, LC79D can work on L1 and L5 bands for GPS, Galileo and QZSS satellites, L1 band for GLONASS and BeiDou satellites as well as L5 band for IRNSS satellite. Compared with the GNSS modules working on L1 band only, LC79D greatly increases the number of satellites involved in tracking and positioning, thereby significantly reducing the multipath effect caused by tall buildings in urban environments, reducing signal acquisition time and improving positioning accuracy. LC79D is AIS-140 compliant, and its on-board LNAs and SAW filters serve to ensure better positioning in weak signal areas and other harsh environments. The GNSS chipset using 28nm process technology, coupled with the advanced low-power management solution, enables low-power GNSS sensing and positioning determination and makes the module an ideal solution for power-sensitive and battery-powered systems. Due to its excellent performance in improving position drift and enhancing positioning accuracy in rough urban canyons, LC79D has become a popular selection for real-time tracking systems, sharing economy applications and so on. Key Benefits Ultra-compact size: 10.1mm × 9.7mm ×2.4mm Multi-GNSS engine for GPS, GLONASS, IRNSS, BeiDou, Galileo and QZSS Support dual GNSS bands (L1, L5) L1+L5 Dual Bands Multi-constellation System Ultra-compact Size Wide Operation Temperature: -40°C to +85°C Low Power Consumption Support AGNSS Built-in LNA for better sensitivity Support SPI, UART and I2C interfaces Support SDK command developed by Quectel Support UDR (Untethered Dead Reckoning) in host mode RoHS Compliant Rev.: V1.0 | Status: Released EMAIL US: info@quectel.com VISIT US: www.quectel.com Quectel LC79D Dual-Band GNSS Module LC79D (A) LC79D (B) Region Global Global Dimensions (mm) 10.1mm × 9.7mm × 2.4mm 10.1mm × 9.7mm × 2.4mm Weight Approx. 0.42g Approx. 0.42g Working Mode Standalone Mode Host Embedded Flash ● / Operation Temperature -40°C ~ +85°C -40°C ~ +85°C Storage Temperature -40°C ~ +90°C -40°C ~ +90°C Supported Bands GPS L1 C/A, Galileo E1, QZSS L1: 1575.42MHz GPS L5, Galileo E5a, QZSS L5: 1176.45MHz IRNSS L5: 1176.45MHz GLONASS L1: 1602.5625MHz BeiDou B1: 1561.098MHz GPS L1 C/A, Galileo E1, QZSS L1: 1575.42MHz GPS L5, Galileo E5a, QZSS L5: 1176.45MHz IRNSS L5: 1176.45MHz GLONASS L1: 1602.5625MHz BeiDou B1: 1561.098MHz Default GNSS Constellation GPS+BeiDou+GLONASS+Galileo+QZSS+IRNSS GPS+BeiDou+GLONASS+Galileo+QZSS+IRNSS Channels 32 Channels 32 Channels Horizontal Position Accuracy Autonomous:
LC86LIAMD 价格&库存
很抱歉,暂时无法提供与“LC86LIAMD”相匹配的价格&库存,您可以联系我们找货
