FH28D-68S-0.5SH(05)
FH28D-68S-0.5SH(05)
    HRS(广濑)
    SMD,P=0.5mm,卧贴
    FPC/FFC连接器 间距:0.50mm 68Pin 卧贴
FH28D-68S-0.5SH(05) 数据手册
For Question Please Contact with SGS www.sgs.com.tw Test Report Page: 1 of 5 HIROSE ELECTRIC CO., LTD. 6-3, NAKAGAWA CHUOH 2-CHOME, TSUZUKI-KU, YOKOHAMA-SHI 224-8540, JAPAN The following sample(s) was/were submitted and identified by/on behalf of the applicant as: Sample Submitted By : HIROSE ELECTRIC CO., LTD. Sample Name : METAL Not to declare Supplier : Product Name : Copper alloy =============================================================================== Sample Receiving Date : 23-Feb-2021 Testing Period : 23-Feb-2021 to 02-Mar-2021 Test Requested Test Results : : (1) As specified by client, with reference to RoHS Directive 2011/65/EU Annex II to determine Cadmium, Lead, Mercury, Cr(VI) contents in the submitted sample(s). (2) Please refer to next pages for the other item(s). Please refer to following pages. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 25 t+886(02)2299 3939 f+886(02)2299 3237 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group Group Test Report Page: 2 of 5 HIROSE ELECTRIC CO., LTD. 6-3, NAKAGAWA CHUOH 2-CHOME, TSUZUKI-KU, YOKOHAMA-SHI 224-8540, JAPAN Test Part Description No.1 : COPPER COLORED METAL Test Result(s) Test Item(s) Cadmium (Cd) (CAS No.: 7440-43-9) Lead (Pb) (CAS No.: 7439-92-1) Mercury (Hg) (CAS No.: 7439-97-6) Method Unit MDL With reference to IEC 62321-5: 2013, analysis was performed by ICP-OES. With reference to IEC 62321-5: 2013, analysis was performed by ICP-OES. With reference to IEC 62321-4: 2013+ AMD1: 2017, analysis was performed by ICP-OES. mg/kg 2 Result No.1 n.d. mg/kg 2 n.d. mg/kg 2 n.d. 0.1 n.d. 2 n.d. Hexavalent Chromium Cr(VI) (CAS No.: With reference to IEC 62321-7-1: 18540-29-9) (#2) 2015, analysis was performed by UVVIS. Beryllium (Be) (CAS No.: 7440-41-7) With reference to US EPA 3050B: 1996, analysis was performed by ICPOES. mg/kg 1. 2. MDL = Method Detection Limit 3. n.d. = Not Detected ( Less than MDL) 4. (#2) = coating is considered to contain Cr(VI). considered a non-Cr(VI) based coating coating variations may influence the determination. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 25 t+886(02)2299 3939 f+886(02)2299 3237 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group Group Test Report Page: 3 of 5 HIROSE ELECTRIC CO., LTD. 6-3, NAKAGAWA CHUOH 2-CHOME, TSUZUKI-KU, YOKOHAMA-SHI 224-8540, JAPAN #FLOW Analytical flow chart of Heavy Metal These samples were dissolved totally by pre-conditioning method according to below flow chart. Cr6+ test method excluded Cutting Preparation Sample Measurement Cr6+ Pb/Cd/Hg Acid digestion with microwave / hotplate ABS / PC / PVC Filtration (1) Alkali fusion (2) HCl to dissolve ICP-OES Metal Others Boiling water extraction Residue Solution Non-metal Dissolving by ultrasonication Digesting at 60 by ltrasonication Digesting at 150~160 Separating to get aqueous phase pH adjustment Add diphenyl-carbazide for color development Cool, filter digestate through filter Add diphenylcarbazide for color development Measure the absorbance at 540 nm by UV-VIS Measure the absorbance at 540 nm by UV-VIS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 25 t+886(02)2299 3939 f+886(02)2299 3237 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group Group Test Report Page: 4 of 5 HIROSE ELECTRIC CO., LTD. 6-3, NAKAGAWA CHUOH 2-CHOME, TSUZUKI-KU, YOKOHAMA-SHI 224-8540, JAPAN Flow Chart of digestion for the elements analysis performed by ICP-OES These samples were dissolved totally by pre-conditioning method according to below flow chart. Cutting / Preparation Sample Measurement Acid digestion by suitable acid depended on different sample material (as below table) Filtration Residue Solution 1) Alkali Fusion 2) HCl to dissolve ICP-OES Steel, copper, aluminum, solder Glass Gold, platinum, palladium, ceramic Silver Plastic Others Aqua regia, HNO3, HCl, HF, H2O2 HNO3/HF Aqua regia HNO3 H2SO4, H2O2, HNO3, HCl Added appropriate reagent to total digestion This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 25 t+886(02)2299 3939 f+886(02)2299 3237 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group Group Test Report Page: 5 of 5 HIROSE ELECTRIC CO., LTD. 6-3, NAKAGAWA CHUOH 2-CHOME, TSUZUKI-KU, YOKOHAMA-SHI 224-8540, JAPAN #PIC * The tested sample / part is marked by an arrow if it's shown on the photo. * ** End of Report ** This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 25 t+886(02)2299 3939 f+886(02)2299 3237 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group Group
FH28D-68S-0.5SH(05) 价格&库存
很抱歉,暂时无法提供与“FH28D-68S-0.5SH(05)”相匹配的价格&库存,您可以联系我们找货
FH28D-68S-0.5SH(05)
  • 2000+15.475462000+2.00844
  • 4000+14.737554000+1.91267
  • 6000+14.322486000+1.85880
库存:10243
FH28D-68S-0.5SH(05)
    • 1+9.49850
    • 10+7.96180
    • 30+7.12690
    • 100+6.17100
    • 500+5.74750
    • 1000+5.55390
    库存:1315
    FH28D-68S-0.5SH(05)
      库存:4000
      FH28D-68S-0.5SH(05)
      • 1+22.002491+2.85552
      • 10+17.9575210+2.33056
      • 25+16.5562625+2.14870
      • 50+15.5667350+2.02028
      • 100+14.63884100+1.89986
      • 250+13.49627250+1.75157
      • 500+12.69189500+1.64718
      • 1000+11.935921000+1.54907
      库存:10253
      FH28D-68S-0.5SH(05)
        FH28D-68S-0.5SH(05)
          • 1+8.47800
          • 10+7.10640
          • 30+6.36120
          • 100+5.50800
          • 500+5.13000
          • 1000+4.95720
          库存:1250
          FH28D-68S-0.5SH(05)
          • 1+26.476051+3.43611
          • 10+22.4945010+2.91938
          • 25+21.0843725+2.73637
          • 50+20.0765550+2.60557
          • 100+19.11729100+2.48108
          • 250+17.92005250+2.32570
          • 500+17.06477500+2.21470
          • 1000+16.607461000+2.15535
          库存:10243
          FH28D-68S-0.5SH(05)
          • 1+7.77150
          • 10+6.51420
          • 400+4.70250
          • 800+4.54410
          • 2000+4.49866
