PESDNC2FD5VBH
Bi-directional 5V Normal Capacitance ESD Protector
Description
The PESDNC2FD5VBH protects sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD) and other voltage
induced transient events. They feature large cross-sectional area junctions
for
conducting
high
transient
currents,
offer
desirable
electrical
characteristics for board level protection, such as fast response time, low
operating voltage. It gives designer the flexibility to protect one bi-directional
DFN1006-2L(Bottom View)
line in applications where arrays are not practical.
Feature
100W peak pulse power per line (tP = 8/20μs)
DFN1006-2L package
Replacement for MLV(0402)
Bidirectional configurations
Response time is typically < 1ns
Low clamping voltage
RoHS compliant
Transient protection for data lines to
QB
Marking (Top View)
IEC61000-4-2(ESD) ±30KV(air), ±30KV(contact);
IEC61000-4-4 (EFT) 40A (5/50ns)
Applications
Cellular phones
Portable devices
Digital cameras
Power supplies
Pin 1
Pin 2
Circuit Diagram
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 1 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Rev.06.7
1
www.prisemi.com
ESD Protector
PESDNC2FD5VBH
Electronics Parameter
Symbol
VRWM
IR
VBR
Parameter
Peak Reverse Working Voltage
Reverse Leakage Current @ VRWM
IPP
I
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
Junction Capacitance
IF
Forward Current
VF
Forward Voltage @ IF
VC VBR VRWM
IT
IR
V
IR
IT
VRWM VBR VC
IPP
Electrical characteristics per line@25℃ (unless otherwise specified)
Parameter
Breakdown Voltage
Symbol
Conditions
Min.
Typ.
Max.
Units
5
V
7.6
V
1.0
μA
VRWM
VBR
It = 1mA
IR
VRWM = 5V T=25℃
IPP=16A
5.5
Clamping Voltage
VCL
Clamping Voltage
VC
IPP=3A
7.5
V
Clamping Voltage
VC
IPP=5A
8.0
V
Clamping Voltage
VC
IPP=10A
10.0
V
Cj
VR=0V
tp=100ns
6.4
f = 1MHz
8.5
V
35
pF
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Peak Pulse Power (tp=8/20μs)
Ppp
100
W
Peak Pulse Current (tp=8/20μs)
IPP
10
A
Operating Temperature
TJ
-55 to 150
TSTG
-55 to 150
Storage Temperature
Rev.06.7
2
www.prisemi.com
ESD Protector
PESDNC2FD5VBH
tf=8μs
100
100
80
60
80
% Of Rated Power
IPP – Peak Pulse Current - % of
IPP
Typical Characteristics
tP =20μs(IPP /2)
40
60
40
10
15
50
75
100
125
150
TL – Lead Temperature - ℃
t - Time -μs
Fig 1.Pulse Waveform
Fig 2.Power Derating Curve
16
5
12
IR(nA)
Current (A)
10
-10
8
4
-15
-20
-10
-8
-6
-4
-2
Voltage
2
4
6
8
50
(V)
75
100
125
150
Temperature (ºC)
Fig 3.TLP Measurement
Fig 4.Typical Leakage Current vs. Temperature
12
1000
Pulse waveform: tp=8/20us
8
Peak Pulse Power (W)
VC-Clamping Voltage (V)
10
6
4
100
10
2
4
6
8
10
1
12
10
100
1000
Pulse Duration(us)
IPP-Peak pulse current (A)
Fig 5. Clamping voltage vs. Peak pulse current
Rev.06.7
1
Fig 6. Non-Repetitive Peak Pulse Power vs. Pulse time
3
www.prisemi.com
ESD Protector
Clamping Voltage
PESDNC2FD5VBH
ESD clamping
Fig 7. (8kV contact discharge per IEC61000-4-2)
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
210
240
270
300
330
360
390
420
450
480
Time (sec)
PCB Design
For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD
protection. Novices in the area of ESD protection should take following suggestions to heart:
Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.
Do not make false economies and save copper for the ground connection.
Place via holes to ground as close as possible to the anode of the TVS diode.
Use as many via holes as possible for the ground connection.
Keep the length of via holes in mind! The longer the more inductance they will have.
Rev.06.7
4
www.prisemi.com
ESD Protector
PESDNC2FD5VBH
Product dimension (DFN1006-2L)
A
Dim
B
C
R
D
E
Millimeters
MIN
MAX
MIN
MAX
A
0.013
0.020
0.34
0.50
B
0.000
0.002
0.00
0.05
C
0.037
0.043
0.95
1.080
D
0.022
0.027
0.55
0.680
E
0.016
0.024
0.40
0.60
F
0.008
0.012
0.20
0.30
H
R
F
Inches
0.015Typ.
0.001
0.005
0.40Typ.
0.05
0.15
H
1.10
0.60
0.40
Unit:mm
Suggested PCB Layout
Ordering information
Device
Package
Reel
Shipping
PESDNC2FD5VBH
DFN1006-2L (Pb-Free)
7"
10000 / Tape & Reel
Rev.06.7
5
www.prisemi.com
ESD Protector
PESDNC2FD5VBH
Load with information
USER DIRECTION OF FEED
Φ1.50 ± 0.10
2.00 ± 0.05
2.00 ± 0.05
1.75 ± 0.10
4.00 ± 0.10
3.50 ± 0.05
8.00 ± 0.10
Φ0.50 ± 0.05
Unit:mm
Rev.06.7
6
www.prisemi.com
ESD Protector
PESDNC2FD5VBH
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi
assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.7
7
www.prisemi.com
很抱歉,暂时无法提供与“PESDNC2FD5VBH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39270
- 500+0.13090
- 5000+0.08723
- 10000+0.07161
