XT25F128BSSIGU
XT25F128BSSIGU
    XTX(芯天下)
    SOP8_208MIL
    XT25F128BSSIGU
XT25F128BSSIGU 数据手册
3.3V QUAD IO Serial Flash XT25F128B XT25F128B Quad IO Serial NOR Flash Datasheet 深圳市芯天下技术有限公司 XTX Technology Limited Tel: (86 755) 28229862 Fax: (86 755) 28229847 Website: http://www.xtxtech.com/ Technical Contact: fae@xtxtech.com * Information furnished is believed to be accurate and reliable. However, XTX Technology Limited assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of XTX Technology Limited. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. XTX Technology Limited products are not authorized for use as critical components in life support devices or systems without express written approval of XTX Technology Limited. The XTX logo is a registered trademark of XTX Technology Limited. All other names are the property of their respective own. Rev 1.2 Mar/20/2020 Page 0 XT25F128B 3.3V QUAD IO Serial Flash Serial NOR Flash Memory 128 Megabits 3.3V Quad I/O Serial Flash Memory with 4KB Uniform Sector   16, 384K-byte  256 bytes per programmable page  Support SFDP & Unique ID  Standard, Dual, Quad SPI    Temperature Range & Moisture Sensitivity Level    Standard SPI: SCLK, CS#, SI, SO, WP#, HOLD#  Dual SPI: SCLK, CS#, IO0, IO1, WP#, HOLD#  Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3  QPI: SCLK, CS#, IO0, IO1, IO2, IO3 Flexible Architecture Industrial Level Temperature. (-40℃ to +85℃), MSL3 Low Power Consumption  30mA maximum active current  0.1uA typical power down current  Single Power Supply Voltage: Full voltage range: 2.70~3.60V  Typical 100,000 Program/Erase Cycle  High Speed Clock Frequency  Sector of 4K-byte  108MHz for fast read with 30PF load  Block of 32/64k-byte  Dual Output Data transfer up to 216Mbits/s  Quad I/O Data transfer up to 432Mbits/s  QPI Mode Data transfer up to 288Mbits/s  Continuous Read With 8/16/32/64-byte Wrap Advanced security Features    128M -bit Serial Flash 4*256-Byte Security Registers With OTP Lock Software/Hardware Write Protection  Write protect all/portion of memory via software   Program/Erase Speed  Page Program time: 0.3ms typical Enable/Disable protection with WP# Pin  Sector Erase time: 80ms typical Top or Bottom, Sector or Block selection  Block Erase time: 0.15/0.2s typical  Chip Erase time: 35s typical Package Options  See 1.1 Available Ordering OPN  All Pb-free packages are compliant RoHS, Halogen-Free and REACH. Rev 1.2  Mar/20/2020 Page 1 3.0V QUAD IO Serial Flash XT25F128B CONTENTS 1. GENERAL DESCRIPTION ..............................................................................................................................................3 1.1. 1.2. 1.3. 1.4. AVAILABLE ORDERING OPN ....................................................................................................................................... 3 CONNECTION DIAGRAM ............................................................................................................................................ 3 PIN DESCRIPTION .................................................................................................................................................... 5 BLOCK DIAGRAM ..................................................................................................................................................... 6 2. MEMORY ORGANIZATION ..........................................................................................................................................7 3. DEVICE OPERATION ....................................................................................................................................................8 4. DATA PROTECTION ................................................................................................................................................... 10 5. STATUS REGISTER ..................................................................................................................................................... 13 6. COMMANDS DESCRIPTION ....................................................................................................................................... 15 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. 6.8. 6.9. 6.10. 6.11. 6.12. 6.13. 6.14. 6.15. 6.16. 6.17. 6.18. 6.19. 6.20. 6.21. 6.22. 6.23. 6.24. 6.25. 6.26. 6.27. 6.28. 6.29. 6.30. 6.31. 6.32. 6.33. 6.34. 6.35. 6.36. 6.37. 7. WRITE ENABLE (WREN) (06H) ............................................................................................................................... 19 WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) .................................................................................................. 19 WRITE DISABLE (WRDI) (04H) ................................................................................................................................ 20 READ STATUS REGISTER (RDSR) (05H OR 35H) ........................................................................................................... 21 WRITE STATUS REGISTER (WRSR) (01H) ................................................................................................................... 22 READ DATA BYTES (READ) (03H) ............................................................................................................................ 23 READ DATA BYTES AT HIGHER SPEED (FAST READ) (0BH) ............................................................................................... 24 DUAL OUTPUT FAST READ (3BH) .............................................................................................................................. 25 QUAD OUTPUT FAST READ (6BH) ............................................................................................................................. 26 DUAL I/O FAST READ (BBH) ................................................................................................................................... 26 QUAD I/O FAST READ (EBH) ................................................................................................................................... 28 QUAD I/O WORD FAST READ (E7H) ......................................................................................................................... 30 SET BURST WITH WRAP (77H) ................................................................................................................................. 31 PAGE PROGRAM (PP) (02H) ................................................................................................................................... 32 QUAD PAGE PROGRAM (QPP) (32H) ........................................................................................................................ 33 SECTOR ERASE (SE) (20H) ...................................................................................................................................... 35 32KB BLOCK ERASE (BE) (52H) ............................................................................................................................... 36 64KB BLOCK ERASE (BE) (D8H) .............................................................................................................................. 37 CHIP ERASE (CE) (60/C7H) .................................................................................................................................... 38 DEEP POWER-DOWN (DP) (B9H)............................................................................................................................. 39 RELEASE FROM DEEP POWER-DOWN AND READ DEVICE ID (RDI) (ABH) ........................................................................... 40 READ MANUFACTURE ID/ DEVICE ID (REMS) (90H) .................................................................................................... 41 READ MANUFACTURE ID/ DEVICE ID DUAL I/O (92H) .................................................................................................. 43 READ MANUFACTURE ID/ DEVICE ID QUAD I/O (94H) .................................................................................................. 44 READ IDENTIFICATION (RDID) (9FH) ......................................................................................................................... 44 GLOBAL BLOCK/SECTOR LOCK (7EH) OR UNLOCK (98H) ................................................................................................ 45 INDIVIDUAL BLOCK/SECTOR LOCK (36H)/UNLOCK (39H)/READ (3DH) ............................................................................. 47 ERASE SECURITY REGISTERS (44H) ............................................................................................................................ 49 PROGRAM SECURITY REGISTERS (42H) ....................................................................................................................... 49 READ SECURITY REGISTERS (48H) ............................................................................................................................. 50 SET READ PARAMETERS (C0H) ................................................................................................................................. 51 BURST READ WITH WRAP (0CH)............................................................................................................................... 52 ENABLE QPI (38H) ............................................................................................................................................... 52 CONTINUOUS READ MODE RESET (CRMR) (FFH)/ DISABLE QPI (FFH) ............................................................................. 53 ENABLE RESET (66H) AND RESET (99H) ..................................................................................................................... 54 READ SERIAL FLASH DISCOVERABLE PARAMETER (5AH) .................................................................................................. 55 READ UNIQUE ID (5AH) ......................................................................................................................................... 56 ELECTRICAL CHARACTERISTICS ................................................................................................................................. 61 7.1. Rev 1.2 POWER-ON TIMING ................................................................................................................................................ 61 Mar/20/2020 Page 1 3.0V QUAD IO Serial Flash 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. 7.8. XT25F128B INITIAL DELIVERY STATE .......................................................................................................................................... 61 DATA RETENTION AND ENDURANCE ........................................................................................................................... 61 LATCH UP CHARACTERISTICS ..................................................................................................................................... 61 ABSOLUTE MAXIMUM RATINGS ................................................................................................................................ 62 CAPACITANCE MEASUREMENT CONDITION .................................................................................................................. 62 DC CHARACTERISTICS ............................................................................................................................................. 63 AC CHARACTERISTICS ............................................................................................................................................. 64 8. ORDERING INFORMATION ...................................................................................................................................... 67 9. PACKAGE INFORMATION ......................................................................................................................................... 68 9.1. 9.2. 9.3. 9.4. 9.5. 10. Rev 1.2 PACKAGE SOP8 208MIL ........................................................................................................................................ 68 PACKAGE SOP16 300MIL ....................................................................................................................................... 69 PACKAGE DFN8 (4X4X0.85) MM ............................................................................................................................. 70 PACKAGE WSON (6X5) MM .................................................................................................................................... 71 PACKAGE BGA (8X6) MM ....................................................................................................................................... 72 REVISION HISTORY................................................................................................................................................ 73 Mar/20/2020 Page 2 3.0V QUAD IO Serial Flash XT25F128B 1. GENERAL DESCRIPTION The XT25F128B (128M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), Dual and Quad SPI. The Dual Output data is transferred with speed up to 216Mbits/s and the Quad I/O & Quad output data is transferred with speed up to 432Mbits/s. 1.1. 1.2. Available Ordering OPN OPN Package Type Package Carrier XT25F128BSSIGU XT25F128BSSIGT XT25F128BWOIGT XT25F128BDHIGT XT25F128BBGIGA XT25F128BSFIGU XT25F128BSFIGT SOP8 208mil SOP8 208mil WSON8 6x5mm DFN8 4x4mm 24-ball TFBGA SOP16 300mil SOP16 300mil Tube Tape & Reel Tape & Reel Tape & Reel Tray Tube Tape & Reel Connection Diagram CS# 1 8 VCC SO(IO1) 2 7 HOLD#(IO3) Top View WP#(IO2) 3 6 SCLK VSS 4 5 SI(IO0) 8 – LEAD SOP/DFN8/WSON8 Rev 1.2 Mar/20/2020 Page 3 3.0V QUAD IO Serial Flash A1 A2 A3 A4 NC NC NC NC B1 B2 B3 B4 NC SCLK VSS VCC C1 C2 C3 C4 NC CS# NC WP#(IO2) D1 D2 D3 D4 NC XT25F128B DO(IO1) DI(IO0) HOLD#(IO3) E1 E2 E3 E4 NC NC NC NC F1 F2 F3 F4 NC NC NC NC 24-ball TFBGA HOLD# 1 16 SCLK VCC 2 15 SI NC 3 14 NC NC 4 13 NC Top View NC 5 12 NC NC 6 11 NC CS# 7 10 VSS SO 8 9 WP# 16-PIN SOP Note: Only for 16-PIN SOP special order, Pin 3 is RESET# pin. Please contact XTX-tech for detail. Rev 1.2 Mar/20/2020 Page 4 3.0V QUAD IO Serial Flash 1.3. Pin Description Pin Name I/O CS# I SO(IO1) I/O Data Output(Data Input Output1) WP#(IO2) I/O Write Protect Input(Data Input Output2) SI(IO0) I/O SCLK I HOLD# (IO3) I/O VCC Description Chip Select Input Ground VSS Rev 1.2 XT25F128B Data Input(DataInputOutput0) Serial Clock Input Hold Input(Data Input Output3) Power Supply Mar/20/2020 Page 5 3.0V QUAD IO Serial Flash Block Diagram WP#(IO2) Write Control Logic Status Register High Voltage Generators HOLD#(IO3) SCLK CS# SPI Command & Control Logic Page Address Latch/Counter Flash Memory Column Decode And 256-Byte Page Buffer SI(IO0) SO(IO1) Rev 1.2 Write Protect Logic And Row Decode 1.4. XT25F128B Byte Address Latch/Counter Mar/20/2020 Page 6 3.0V QUAD IO Serial Flash XT25F128B 2. MEMORY ORGANIZATION XT25F128B Each Device has Each block has Each sector has Each page has Remark 16M 64K/32K 4K 256 bytes 64K 256/128 16 - pages 4K 16/8 - - sectors 256/512 - - - blocks UNIFORM BLOCK SECTOR ARCHITECTURE XT25F128B 64Kbytes Block Sector Architecture Block 255 254 …… …… 2 1 0 Rev 1.2 Sector Address range 4095 FFF000H FFFFFFH …… …… …… 4080 FF0000H FF0FFFH 4079 FEF000H FEFFFFH …… …… …… 4064 FE0000H FE0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH Mar/20/2020 Page 7 3.0V QUAD IO Serial Flash XT25F128B 3. DEVICE OPERATION SPI Mode Standard SPI The XT25F128B features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Note: “WP#” & “HOLD#” pin require external pull-up. Dual SPI The XT25F128B supports Dual SPI operation when using the “Dual Output Fast Read” and “Dual I/O Fast Read” (3BH and BBH) commands. These commands allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Note: “WP#” & “HOLD#” pin require external pull-up. Quad SPI The XT25F128B supports Quad SPI operation when using the “Quad Output Fast Read”,” Quad I/O Fast Read”, “Quad I/O Word Fast Read” (6BH, EBH, E7H) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and WP# and HOLD# pins become IO2 and IO3. Quad SPI commands require the non-volatile Quad Enable bit (QE) in Status Register to be set. QPI The XT25F128B supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enable the QPI (38H)” command. The QPI mode utilizes all four IO pins to input the command code. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given times. “Enable the QPI (38H)” and “Disable the QPI (FFH)” commands are used to switch between these two modes. Upon power-up and after software reset using “Reset (99H)” command, the default state of the device is Standard/Dual/Quad SPI mode. The QPI mode requires the non-volatile Quad Enable bit (QE) in Status Register to be set. Hold The HOLD# signal goes low to stop any serial communications with the device, but doesn’t stop the on going operation of writing status register, programming, or erasing which was in progress. The operation of HOLD, need CS# keep low, and starts on falling edge of the HOLD# signal, with SCLK signal being low (if SCLK is not being low, HOLD operation will not start until SCLK being low). The HOLD condition ends on rising edge of HOLD# signal with SCLK being low (If SCLK is not being low, HOLD operation will not end until SCLK being low). Both SI and SCLK don’t care during the HOLD operation, if CS# drives high during HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be at high and then CS# must be at low. Rev 1.2 Mar/20/2020 Page 8 3.0V QUAD IO Serial Flash XT25F128B Figure1.Hold Condition CS# SCLK HOLD# HOLD HOLD RESET The RESET# pin allows the device to be reset by the control. Only available on the SOP16 package, a dedicated RESET# pin is provided and it is independent of QE bit setting. The RESET# pin goes low for a period of tRLRH or longer will reset the flash. After the reset cycle, the flash will be at the following states: - Standby mode - All the volatile bits will return to the default status as power on. Figure1a.Reset Condition CS# RESET# RESET Rev 1.2 Mar/20/2020 Page 9 3.0V QUAD IO Serial Flash XT25F128B 4. DATA PROTECTION The XT25F128B provide the following data protection methods:  Write Enable (WREN) command: The WREN command sets the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation:  POWER-UP  WRITE DISABLE (WRDI)  WRITE STATUS REGISTER (WRSR)  PAGE PROGRAM (PP)  SECTOR ERASE (SE) / BLOCK ERASE (BE) / CHIP ERASE (CE)    Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, BP0) bits define the section of the memory array that can be read only. Hardware Protection Mode: WP# goes low protect the BP0~BP4 bits and SRP bit. Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command. Table1.0 XT25F128B Protected area size (CMP=0) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 252 to 255 FC0000H-FFFFFFH 256KB Upper 1/64 0 0 0 1 0 248 to 255 F80000H-FFFFFFH 512KB Upper 1/32 0 0 0 1 1 240 to 255 F00000H-FFFFFFH 1MB Upper 1/16 0 0 1 0 0 224 to 255 E00000H-FFFFFFH 2MB Upper 1/8 0 0 1 0 1 192 to 255 C00000H-FFFFFFH 4MB Upper 1/4 0 0 1 1 0 128 to 255 800000H-FFFFFFH 8MB Upper 1/2 0 1 0 0 1 0 to 3 000000H-03FFFFH 256KB Lower 1/64 0 1 0 1 0 0 to 7 000000H-07FFFFH 512KB Lower 1/32 0 1 0 1 1 0 to 15 000000H-0FFFFFH 1MB Lower 1/16 0 1 1 0 0 0 to 31 000000H-1FFFFFH 2MB Lower 1/8 0 1 1 0 1 0 to 63 000000H-3FFFFFH 4MB Lower 1/4 0 1 1 1 0 0 to 127 000000H-7FFFFFH 8MB Lower 1/2 X X 1 1 1 0 to 255 000000H-FFFFFFH 16MB ALL 1 0 0 0 1 255 FFF000H-FFFFFFH 4KB Top Block 1 0 0 1 0 255 FFE000H-FFFFFFH 8KB Top Block 1 0 0 1 1 255 FFC000H-FFFFFFH 16KB Top Block 1 0 1 0 X 255 FF8000H-FFFFFFH 32KB Top Block 1 0 1 1 0 255 FF8000H-FFFFFFH 32KB Top Block 1 1 0 0 1 0 000000H-000FFFH 4KB Bottom Block 1 1 0 1 0 0 000000H-001FFFH 8KB Bottom Block 1 1 0 1 1 0 000000H-003FFFH 16KB Bottom Block 1 1 1 0 X 0 000000H-007FFFH 32KB Bottom Block 1 1 1 1 0 0 000000H-007FFFH 32KB Bottom Block Rev 1.2 Mar/20/2020 Page 10 3.0V QUAD IO Serial Flash XT25F128B Table1.1 XT25F128B Protected area size (CMP=1) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 0 to 255 000000H-FFFFFFH ALL ALL 0 0 0 0 1 0 to 251 000000H-FBFFFFH 16128KB Lower 63/64 0 0 0 1 0 0 to 247 000000H-F7FFFFH 15872KB Lower 31/32 0 0 0 1 1 0 to 239 000000H-EFFFFFH 15MB Lower 15/16 0 0 1 0 0 0 to 223 000000H-DFFFFFH 14MB Lower 7/8 0 0 1 0 1 0 to 191 000000H-BFFFFFH 12MB Lower 3/4 0 0 1 1 0 0 to 127 000000H-7FFFFFH 8MB Lower 1/2 0 1 0 0 1 4 to 255 040000H-FFFFFFH 16128KB Upper 63/64 0 1 0 1 0 8 to 255 080000H-FFFFFFH 15872KB Upper 31/32 0 1 0 1 1 16 to 255 100000H-FFFFFFH 15MB Upper 15/16 0 1 1 0 0 32 to 255 200000H-FFFFFFH 14MB Upper 7/8 0 1 1 0 1 64 to 255 400000H-FFFFFFH 12MB Upper 3/4 0 1 1 1 0 128 to 255 800000H-FFFFFFH 8MB Upper 1/2 X X 1 1 1 NONE NONE NONE NONE 1 0 0 0 1 0 to 255 000000H-FFEFFFH 16380KB L-4095/4096 1 0 0 1 0 0 to 255 000000H-FFDFFFH 16376KB L-2047/2048 1 0 0 1 1 0 to 255 000000H-FFBFFFH 16368KB L-1023/1024 1 0 1 0 X 0 to 255 000000H-FF7FFFH 16352KB L-511/512 1 0 1 1 0 0 to 255 000000H-FF7FFFH 16352KB L-511/512 1 1 0 0 1 0 to 255 001000H-FFFFFFH 16380KB U-4095/4096 1 1 0 1 0 0 to 255 002000H-FFFFFFH 16376KB U-2047/2048 1 1 0 1 1 0 to 255 004000H-FFFFFFH 16368KB U-1023/1024 1 1 1 0 X 0 to 255 008000H-FFFFFFH 16352KB U-511/512 1 1 1 1 0 0 to 255 008000H-FFFFFFH 16352KB U-511/512 Rev 1.2 Mar/20/2020 Page 11 3.0V QUAD IO Serial Flash XT25F128B Table1.2 XT25F128B Individual Block Protection (WPS=1) Block 255 254 …… …… 2 1 0 Rev 1.2 Sector Individual Block Lock Operation Address range 4095 FFF000H FFFFFFH …… …… …… 4080 FF0000H FF0FFFH 4079 FEF000H FEFFFFH …… …… …… 4064 FE0000H FE0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH Mar/20/2020 32 Sectors(Top/Bottom)/254 Blocks Block Lock: 36H+Address Block Unlock: 39H+Address Read Block Lock: 3DH+Address Global Block Lock: 7EH Global Block Unlock: 98H Page 12 3.0V QUAD IO Serial Flash XT25F128B 5. STATUS REGISTER S15 S14 S13 S12 S11 S10 S9 S8 Reserved CMP Reserved WPS LB1 LB0 QE SRP1 S7 S6 S5 S4 S3 S2 S1 S0 SRP0 BP4 BP3 BP2 BP1 BP0 WEL WIP The status and control bits of the Status Register are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy in programing/erasing/writing status register progress. When WIP bit sets to 1, that means the device is busy in programing/erasing/writing status register progress, when WIP bit sets to 0, that means the device is not in programing/erasing/writing status register progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, then Write Status Register, Program or Erase command will be accepted. when set to 0 the internal Write Enable Latch is reset, then no Write Status Register, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits are non-volatile. They define the size and location of the flash memory to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table1) becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits can be written when the Hardware Protected mode has not been set. The Chip Erase (CE) command will be executed if the Block Protect (BP2, BP1, BP0) bits are 0 and CMP=0 or the Block Protect (BP2, BP1, BP0) bits are 1 and CMP=1. SRP1, SRP0 bits. The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the type of write protection: software protection, hardware protection, power supply lockdown or one-time programmable protection. SRP1 SRP0 WP# 0 0 X Software Protected The Status Register can be written to after a Write Enable command, WEL=1.(Default) 0 1 0 Hardware Protected WP#=0, the Status Register locked and cannot be written until the next power-up. 0 1 1 Hardware Unprotected WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. 1 0 X Power Supply LockDown(1)(2) Status Register is protected and cannot be written to again until the next Power-Down, Power-Up cycle. 1 1 X One-Time Program(2) Status Register is permanently protected and cannot be written to. Rev 1.2 Status Register Description Mar/20/2020 Page 13 3.0V QUAD IO Serial Flash XT25F128B NOTE: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order (XT25F128BxxSx). Please contact XTX for details. QE bit. The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the WP# pin and HOLD# pin are enable. When the QE pin is set to 1, IO2 and IO3 pins will be enabled. (The QE bit should never be set to 1 during standard SPI or Dual SPI operation if the WP# or HOLD# pins are tied directly to the power supply or ground). LB1, LB0, bits. The LB1, LB0, bits are non-volatile One Time Program (OTP) bits in Status Register (S11-S10) that provide the write protect control and status to the Security Registers. The default state of LB1-LB0 are 0, the security registers are unlocked. The LB1-LB0 bits can be set to 1 individually using the Write Register instruction. The LB1-LB0 bits are One Time Programmable. Once LB0 or LB1 is set to 1, the corresponding Security Register page 1 or page 2 will become permanently lock for read-only and non-erasable, while if Any of the LB bits are is set to 1, then all 4 pages of the Security Register will become permanently lock for read-only non-erasable. CMP bit. The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction the BP4BP0 bits to provide more flexibility for the array protection. Please see the Status register Memory Protection table for details. The default setting is CMP=0. WPS The WPS Bit is used to select which Write Protect scheme should be used. When WPS=0, the device will use the combination of CMP, BP (4:0) bits to protect a specific area of the memory array. When WPS=1, the device will utilize the Individual Block Locks to protect any individual sector or block. The default value for all Individual Block Lock bits is 1 upon device power on or after reset. Rev 1.2 Mar/20/2020 Page 14 3.0V QUAD IO Serial Flash XT25F128B 6. COMMANDS DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted in to the device, the most significant bit will be the first bit on SI, each bit will be latched on the following rising edge of SCLK. See Table2, every command sequence starts with a one-byte command code. Depending on the command, this might be followed by address bytes, or by data bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been shifted in. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. CS# can be driven high after any bit of the data-out sequence is being shifted out. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Table2. Commands Command Name Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 n-Bytes Write Enable 06H Write Enable for Volatile Status Register 50H Write Disable 04H Read Status Register 05H (S7-S0) (continuous) Read Status Register-1 35H (S15-S8) (continuous) Write Status Register 01H (S7-S0) (S15-S8) Read Data 03H A23-A16 A15-A8 A7-A0 (D7-D0) Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy (D7-D0)(1) (continuous) Dual I/O Fast Read BBH A23A8(2) A7-A0 M7-M0(2) (D7-D0)(1) Quad Output Fast Read 6BH A23-A16 A15-A8 A7-A0 Quad I/O Fast Read EBH A23-A0 M7M0(4) dummy(5) (D7-D0)(3) (continuous) Quad I/O Word Fast Read E7H A23-A0 M7M0(4) dummy(6) (D7-D0)(3) (continuous) Continuous Read Reset FFH Page Program 02H A23-A16 A15-A8 A7-A0 (D7-D0) Quad Page Program 32H A23-A16 A15-A8 A7-A0 (D7D0)(3) Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase(32KB) 52H A23-A16 A15-A8 A7-A0 Block Erase(64KB) D8H A23-A16 A15-A8 A7-A0 Rev 1.2 Mar/20/2020 (continuous) (continuous) (continuous) dummy (D7-D0)(3) (continuous) (Next byte) Page 15 3.0V QUAD IO Serial Flash Command Name Byte1 XT25F128B Byte2 Byte3 Byte4 Byte5 dummy dummy dummy W6-W4 dummy dummy dummy (ID7DID0) (MID7MID0) Byte6 n-Bytes Chip Erase C7/60H Enable QPI 38H Set Burst with Wrap 77H Deep Power-Down B9H Release From Deep Power-Down, And Read Device ID ABH Release From Deep Power-Down ABH Manufacturer/Device ID 90H A23-A16 A15-A8 A7-A0 Manufacturer/Device ID by Dual I/O 92H A23-A8 A7-A0, M[7:0] (M7-M0) (ID7-ID0) Manufacturer/Device ID by Quad I/O 94H A23-A0, M[7:0] dummy (M7-M0) (ID7-ID0) Read Serial Flash Discoverable Parameters 5AH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Read Unique ID 5AH 00h 00h 94h dummy (D7-D0) (continuous) Read Identification 9FH (M7-M0) (ID15-ID8) (ID7-ID0) Erase Security Register(8) 44H A23-A16 A15-A8 A7-A0 Program Security Register(8) 42H A23-A16 A15-A8 A7-A0 (D7-D0) (Next byte) Read Security Register(8) 48H A23-A16 A15-A8 A7-A0 dummy (D7-D0) Enable Reset 66H Reset 99H Individual Block Lock 36H A23-A16 A15-A8 A7-A0 A23-A16 A15-A8 A7-A0 A23-A16 A15-A8 A7-A0 Individual Block Unlock (continuous) (DID7DID0) (continuous) (continuous) (continuous) 39H Read Block Lock 3DH Global Block Lock 7EH Global Block Unlock 98H Rev 1.2 Mar/20/2020 Page 16 3.0V QUAD IO Serial Flash XT25F128B Table2a. Commands (QPI) Command Name Byte1 Byte2 Byte3 Byte4 Byte5 Clock Number (0,1) (2,3) (4,5) (6,7) (8,9) Byte6 (10,11 ) (D7-D0) (Next byte) Write Enable 06H Write Enable for Volatile Status Register 50H Write Disable 04H Read Status Register 05H (S7-S0) Read Status Register-1 35H (S15-S8) Write Status Register 01H (S7-S0) (S15-S8) Page Program 02H A23-A16 A15-A8 A7-A0 Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase(32KB) 52H A23-A16 A15-A8 A7-A0 Block Erase(64KB) D8H A23-A16 A15-A8 A7-A0 Chip Erase C7/60H Deep Power-Down B9H Set Read Parameters C0H P7-P0 Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) Burst Read with Wrap 0CH A23-A16 A15-A8 A7-A0 dummy (D7-D0) Quad I/O Fast Read EBH A23-A0 M7-M0(4) dummy(5) (D7-D0)(3) Release from Deep PowerDown, And Read Device ID(10) ABH dummy dummy dummy * N (ID7-ID0) Manufacturer/Device ID(11) 90H dummyx2 00H dummy * N MID7~MID0 Disable QPI FFH Enable Reset 66H Reset 99H Individual Block Lock 36H A23-A16 A15-A8 A7-A0 Individual Block Unlock 39H A23-A16 A15-A8 A7-A0 Read Block Lock 3DH A23-A16 A15-A8 A7-A0 Global Block Lock 7EH Global Block Unlock 98H Read Serial Flash Discoverable Parameter 5AH (ID7ID0) NOTE: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8,A6, A4, A2, A0, M6, M4, M2, M0 Rev 1.2 Mar/20/2020 Page 17 3.0V QUAD IO Serial Flash XT25F128B IO1 = A23, A21, A19, A17, A15, A13, A11, A9,A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. Quad I/O Fast Read Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Quad I/O Word Fast Read Data IO0 = (x, x, D4, D0,…) IO1 = (x, x, D5, D1,…) IO2 = (x, x, D6, D2,…) IO3 = (x, x, D7, D3,…) 7. Quad I/O Word Fast Read Data: the lowest address bit must be 0. 8. Security Registers Address: Security Register0: A23-A16=00H, A15-A8=00H, A7-A0= Byte Address; Security Register1: A23-A16=00H, A15-A8=01H, A7-A0= Byte Address; Security Register2: A23-A16=00H, A15-A8=02H, A7-A0= Byte Address; Security Register3: A23-A16=00H, A15-A8=03H, A7-A0= Byte Address. 9. QPI Command, Address, Data input/output format: CLK# = 0 1 2 3 4 5 6 7 8 9 10 11 IO0 = C4, C0, A20, A16, A12, A8, A4, A0, D4, D0, D4, D0 IO1 = C5, C1, A21, A17, A13, A9, A5, A1, D5, D1, D5, D1 IO2 = C6, C2, A22, A18, A14, A10, A6, A2, D6, D2, D6, D2 IO3 = C7, C3, A23, A19, A15, A11, A7, A3, D7, D3, D7, D4 10. QPI mode: Release from Deep Power-Down, And Read Device ID (ABH) N dummy cycles should be inserted before ID read cycle, refer to C0H command 11. QPI mode: Manufacturer/Device ID (90H) N dummy cycles should be inserted before ID read cycle, refer to C0H command Table of ID Definitions: XT25F128B Operation Code M7-M0 ID15-ID8 ID7-ID0 9FH 0B 40 18 90H 0B 17 ABH Rev 1.2 17 Mar/20/2020 Page 18 3.0V QUAD IO Serial Flash 6.1. XT25F128B Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE) and Write Status Register (WRSR) command. The Write Enable (WREN) command sequence: CS# goes lowSending the Write Enable commandCS# goes high. Figure2.Write Enable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO 06H High-Z Figure2a. Write Enable Sequence Diagram (QPI) CS# 0 1 SCLK 06H SI(IO0) 0 SO(IO1) 0 1 WP#(IO2) 0 1 HOLD#(IO3) 6.2. 0 0 0 Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical nonvolatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command and any other commands can't be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Rev 1.2 Mar/20/2020 Page 19 3.0V QUAD IO Serial Flash XT25F128B Figure3.Write Enable for Volatile Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 50H High-Z SO Figure3a. Write Enable for Volatile Status Register Sequence Diagram (QPI) CS# 0 1 SCLK 50H 6.3. SI(IO0) 1 0 SO(IO1) 0 0 WP#(IO2) 1 HOLD#(IO3) 0 0 0 Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes lowSending the Write Disable commandCS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase commands. Figure4.Write Disable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO Rev 1.2 04H High-Z Mar/20/2020 Page 20 3.0V QUAD IO Serial Flash XT25F128B Figure4a. Write Disable Sequence Diagram (QPI) CS# 0 1 SCLK 04H 6.4. SI(IO0) 0 0 SO(IO1) 0 0 WP#(IO2) 0 HOLD#(IO3) 0 1 0 Read Status Register (RDSR) (05H or 35H) The Read Status Register (RDSR) command is for reading the Status Register. The Status Register can be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. The command code “35H”, the SO will output Status Register bits S15~S8. Figure5. Read Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI 05H or 35H S7~S0 or S15~S8 out SO High-Z 7 6 5 4 3 2 1 MSB Rev 1.2 Mar/20/2020 S7~S0 or S15~S8 out 0 7 6 5 4 3 2 1 0 7 MSB Page 21 3.0V QUAD IO Serial Flash XT25F128B Figure5a. Read Status Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 SCLK 05H SI(IO0) 0 1 4 0 4 0 SO(IO1) 0 0 5 1 5 1 WP#(IO2) 0 1 6 2 6 2 HOLD#(IO3) 0 0 7 3 7 3 S7~S0 S7~S0 CS# 0 1 2 3 4 5 SCLK 35H SI(IO0) 1 1 4 0 4 0 SO(IO1) 1 0 5 1 5 1 WP#(IO2) 0 1 6 2 6 2 HOLD#(IO3) 0 0 7 3 7 3 S15~S8 6.5. S15~S8 Write Status Register (WRSR) (01H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on S15, S1 and S0 of the Status Register. CS# must be driven high after the eighth or sixteen bit of the data byte has been latched in. If not, the Write Status Register (WRSR) command is not executed. If CS# is driven high after eighth bit of the data byte, the CMP and QE bit will be cleared to 0. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. Rev 1.2 Mar/20/2020 Page 22 3.0V QUAD IO Serial Flash XT25F128B Figure6.Write Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI Status Register in 7 6 5 4 3 2 1 0 15 14 13 12 11 10 9 8 01H MSB MSB High-Z SO Figure6a. Write Status Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 SCLK 01H SI(IO0) 0 1 4 0 12 8 SO(IO1) 0 0 5 1 13 9 WP#(IO2) 0 0 6 2 14 10 HOLD#(IO3) 0 0 7 3 15 11 S7~S0 6.6. S15~S8 Read Data Bytes (READ) (03H) The Read Data Bytes (READ) command is followed by a 3-byte address (A23-A0), each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The first byte can be addressed at any location and the address is automatically incremented to the next address after each byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure7.Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI 03H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB SO Rev 1.2 Data Out1 High-Z MSB Mar/20/2020 7 6 5 4 3 2 1 Data Out2 0 Page 23 3.0V QUAD IO Serial Flash 6.7. XT25F128B Read Data Bytes At Higher Speed (Fast Read) (0BH) The Read Data Bytes at Higher Speed (Fast Read) command is for quickly reading data out. It is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte can be addressed at any location and the address is automatically incremented to the next address after each byte of data is shifted out. Figure8.Read Data By test Higher Speed Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 0BH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO Data Out2 Data Out3 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB Fast Read (0BH) in QPI mode The Fast Read command is also supported in QPI mode. In QPI mode, the number of dummy clocks is configured by the “Set Read Parameters (C0H)” command to accommodate a wide range application with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 4/6/8. When the dummy cycle is configured to 4, addr [0] input must be 0. Rev 1.2 Mar/20/2020 Page 24 3.0V QUAD IO Serial Flash XT25F128B Figure8a. Read Data Bytes at Higher Speed Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK 0BH SI(IO0) 0 1 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 0 0 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 0 1 7 3 7 3 7 3 7 3 7 3 7 3 A15-8 A23-16 A7-0 dummy* Byte2 Byte1 Byte3 *Set Read Parameters Command (C0H) can set the number of dummy cycles 6.8. Dual Output Fast Read (3BH) The Dual Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure9. The first byte can be addressed at any location and the address is automatically incremented to the next address after each byte of data is shifted out. Figure9.Dual Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 3BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 Data Out1 SO Rev 1.2 Data Out2 Data Out3 Data Out4 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 MSB MSB MSB MSB Mar/20/2020 6 7 Page 25 3.0V QUAD IO Serial Flash 6.9. XT25F128B Quad Output Fast Read (6BH) The Quad Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The command sequence is shown in Figure10. The first byte addressed can be at any location and the address is automatically incremented to the next address after each byte of data is shifted out. Figure 10.Quad Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 6BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO(IO1) High-Z WP#(IO2) High-Z HOLD#(IO3) CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 HOLD#(IO3) Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Byte8 6.10. Dual I/O Fast Read (BBH) The Dual I/O Fast Read command is similar to the Dual Output Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte 2-bit per clock by SI and SO, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure11. The first byte can be addressed at any location and the address is automatically incremented to the next address after each byte of data is shifted out. Dual I/O Fast Read with “Continuous Read Mode” The Dual I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. The command sequence is shown in Figure12. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Rev 1.2 Mar/20/2020 Page 26 3.0V QUAD IO Serial Flash XT25F128B Figure11.Dual I/O Fast Read Sequence Diagram (M5-4≠(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 BBH SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Byte5 Byte4 Byte3 Byte2 Byte6 Figure12.Dual I/O Fast Read Sequence Diagram (M5-4=(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Rev 1.2 Byte2 Mar/20/2020 Byte3 Byte4 Page 27 3.0V QUAD IO Serial Flash XT25F128B 6.11. Quad I/O Fast Read (EBH) The Quad I/O Fast Read command is similar to the Dual I/O Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte and 4-dummy clock 4-bit per clock by IO0, IO1, IO3, IO4, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The command sequence is shown in Figure13. The first byte can be addressed at any location and the address is automatically incremented to the next address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Fast read command. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) =(1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH command code. The command sequence is shown in Figure14. If the “Continuous Read Mode” (M5- 4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure13.Quad I/O Fast Read Sequence Diagram (M5-4≠(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 EBH HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Figure14.Quad I/O Fast Read Sequence Diagram (M5-4=(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Rev 1.2 Mar/20/2020 Dummy Byte1 Byte2 Page 28 3.0V QUAD IO Serial Flash XT25F128B Quad I/O Fast Read with “8/16/32/64-Byte Wrap Around” in Standard SPI mode The Quad I/O Fast Read command can be used to access a specific portion within a page by issuing “Set Burst with Wrap” (77H) commands prior to EBH. The “Set Burst with Wrap” (77H) command can either enable or disable the “Wrap Around” feature for the following EBH commands. When “Wrap Around” is enabled, the data being accessed can be limited to an 8/16/32/64-byte section within a 256-byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around to the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” command allows three “Wrap Bits” W6-W4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-W5 is used to specify the length of the wrap around section within a page. Quad I/O Fast Read (EBH) in QPI mode The Quad I/O Fast Read command is also supported in QPI mode. See Figure 14a. In QPI mode, the number of dummy clocks is configured by the “Set Read Parameters (C0H)” command to accommodate a wide range application with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 4/6/8. When the dummy cycle is configured to 4, addr*0+ input must be 0. In QPI mode, the “Continuous Read Mode” bits M7-M0 are also considered as dummy clocks. “Continuous Read Mode” feature is also available in QPI mode for Quad I/O Fast Read command. “Wrap Around” feature is not available in QPI mode for Quad I/O Fast Read command. To perform a read operation with fixed data length wrap around in QPI mode, a dedicated “Burst Read with Wrap” (0CH) command must be used. Figure14a. Quad I/O Fast Read Sequence Diagram (M5-4= (1, 0) QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK EBH SI(IO0) 0 1 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 1 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 1 0 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 1 1 7 3 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 M7~M0 * dummy* Byte1 Byte2 Byte3 *Set Read Parameters Command (C0H) can set the number of dummy cycles Rev 1.2 Mar/20/2020 Page 29 3.0V QUAD IO Serial Flash XT25F128B 6.12. Quad I/O Word Fast Read (E7H) The Quad I/O Word Fast Read command is similar to the Quad I/O Fast Read command except that the lowest address bit (A0) must equal 0 and only 2-dummy clock. The command sequence is shown in followed Figure15. The first byte can be addressed at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Word Fast read command. Quad I/O Word Fast Read with “Continuous Read Mode” The Quad I/O Word Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) = (1, 0), then the next Quad I/O Word Fast Read command (after CS# is raised and then lowered) does not require the E7H command code. The command sequence is shown in Figure15. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first E7H command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M7-0) before issuing normal command. Figure15.Quad I/O Word Fast Read Sequence Diagram (M5-4≠(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 E7H HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Byte3 Figure15a.Quad I/O Word Fast Read Sequence Diagram (M5-4=(1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte1 Byte2 Rev 1.2 Mar/20/2020 Page 30 3.0V QUAD IO Serial Flash XT25F128B Quad I/O Word Fast Read with “8/16/32/64-Byte Wrap Around” in Standard SPI mode The Quad I/O Word Fast Read command can be used to access a specific portion within a page by issuing “Set Burst with Wrap” (77H) commands prior to E7H. The “Set Burst with Wrap” (77H) command can either enable or disable the “Wrap Around” feature for the following E7H commands. When “Wrap Around” is enabled, the data being accessed can be limited to either an 8/16/32/64-byte section within a 256-byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around to the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” command allows three “Wrap Bits” W6W4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-W5 is used to specify the length of the wrap around section within a page. 6.13. Set Burst with Wrap (77H) The Set Burst with Wrap command is used in conjunction with “Quad I/O Fast Read” and “Quad I/O Word Fast Read” command to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap command sequence: CS# goes low Send Set Burst with Wrap command Send 24 dummy bits Send 8 bits “Wrap bits”CS# goes high If the W6-W4 bits are set by the Set Burst with Wrap command, all the following “Quad I/O Fast Read” and “Quad I/O Word Fast Read” command will use the W6-W4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap command should be issued to set W4=1. In QPI mode, the “Burst Read with Wrap (0CH)” command should be used to perform the Read Operation with “Wrap Around” feature. The Wrap Length set by W5-W6 in Standard SPI mode is still valid in QPI mode and can also be re-configured by “Set Read Parameters (C0H) command. Figure16. Set Burst with Wrap Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 SCLK Command SI(IO0) 77H X X X X X X 4 X SO(IO1) X X X X X X 5 X WP#(IO2) X X X X X X 6 X HOLD#(IO3) X X X X X X X X W6-W4 Rev 1.2 Mar/20/2020 Page 31 3.0V QUAD IO Serial Flash XT25F128B 6.14. Page Program (PP) (02H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three address bytes and at least one data byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes lowsending Page Program command3-byte address on SIat least 1 byte data on SI CS# goes high. The command sequence is shown in Figure17. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) will not be executed. Figure17.PageProgramSequenceDiagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 02H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI Data Byte4 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB Rev 1.2 Data Byte3 MSB MSB Mar/20/2020 Data Byte256 7 6 5 4 3 2 1 0 MSB Page 32 3.0V QUAD IO Serial Flash XT25F128B Figure17a. Page Program Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK 02H SI(IO0) 0 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 0 0 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 0 0 7 3 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 Byte1 Byte2 Byte3 Byte4 6.15. Quad Page Program (QPP) (32H) The Quad Page Program command is for programming the memory, while the data bytes are transfered via 4 pins: IO0, IO1, IO2, and IO3. To use Quad Page Program, the Quad enable in status register Bit9 must be set (QE=1). A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Quad Page Program command is entered by driving CS# Low, followed by the command code (32H), three address bytes and at least one data byte on IO pins. The command sequence is shown in Figure18. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Quad Page Program command will not be executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset A Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) will not be executed. Rev 1.2 Mar/20/2020 Page 33 3.0V QUAD IO Serial Flash XT25F128B Figure18.Quad Page Program Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 32H 23 22 21 20 19 7 6 5 4 3 2 1 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MSB Byte1 Byte2 Byte3 Byte4 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 536 537 538 539 540 541 542 543 CS# SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 Byte5 Rev 1.2 Byte6 Byte7 Byte8 Byte9 Byte10 Byte11 Byte12 Byte13 Byte14 Byte15 Byte16 Mar/20/2020 Byte253 Byte254 Byte255 Byte256 Page 34 3.0V QUAD IO Serial Flash XT25F128B 6.16. Sector Erase (SE) (20H) The Sector Erase (SE) command is for erasing all the data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit, before sending the Sector Erase command.. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3-address byte on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. The Sector Erase command sequence: CS# goes lowsending Sector Erase command3-byte address on SICS# goes high. The command sequence is shown in Figure20. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the Sector Erase (SE) command will not be executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) command applied to a sector which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bit(see Table1.0&1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus it is recommend to perform a re-erase once power resume. Figure19. Sector Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 20H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Figure20. Sector Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK 20H SI(IO0) 0 0 4 0 4 0 4 0 SO(IO1) 1 0 5 1 5 1 5 1 WP#(IO2) 0 0 6 2 6 2 6 2 HOLD#(IO3) 0 0 7 3 7 3 7 3 A23~A16 Rev 1.2 Mar/20/2020 A15~A8 A7~A0 Page 35 3.0V QUAD IO Serial Flash XT25F128B 6.17. 32KB Block Erase (BE) (52H) The 32KB Block Erase (BE) command is for erasing all the data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit, before sending the 32KB Block Erase command. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI, driving CS# high.. Any address inside the block is a valid address for the 32KB Block Erase (BE) command. The 32KB Block Erase command sequence: CS# goes lowsending 32KB Block Erase command3-byte address on SICS# goes high. The command sequence is shown in Figure21. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 32KB Block Erase (BE) command will not be executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table1.0&1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus it is recommend to perform a re-erase once power resume. Figure21. 32KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 52H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Figure21a. 32KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK 52H SI(IO0) 1 0 4 0 4 0 4 0 SO(IO1) 0 1 5 1 5 1 5 1 WP#(IO2) 1 0 6 2 6 2 6 2 HOLD#(IO3) 0 0 7 3 7 3 7 3 A23~A16 Rev 1.2 Mar/20/2020 A15~A8 A7~A0 Page 36 3.0V QUAD IO Serial Flash XT25F128B 6.18. 64KB Block Erase (BE) (D8H) The 64KB Block Erase (BE) command is for erasing all the data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit, before sending the 64KB Block Erase command. The 64KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI, driving CS# high.. Any address inside the block is a valid address for the 64KB Block Erase (BE) command. The 64KB Block Erase command sequence: CS# goes lowsending 64KB Block Erase command3-byte address on SICS# goes high. The command sequence is shown in Figure22. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 64KB Block Erase (BE) command will not be executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus it is recommend to perform a re-erase once power resume. Figure22. 64KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) D8H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Figure22a. 64KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK D8H SI(IO0) 1 0 4 0 4 0 4 0 SO(IO1) 0 0 5 1 5 1 5 1 WP#(IO2) 1 0 6 2 6 2 6 2 HOLD#(IO3) 1 1 7 3 7 3 7 3 A23~A16 Rev 1.2 Mar/20/2020 A15~A8 A7~A0 Page 37 3.0V QUAD IO Serial Flash XT25F128B 6.19. Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is for erasing all the data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit, before sending the Chip Erase command .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). The Chip Erase command sequence: CS# goes lowsending Chip Erase commandCS# goes high. The command sequence is shown in Figure23. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Chip Erase command will not be executed. As soon as CS# is driven high, the self-timed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, BP0) bits are 0 and CMP=0 or the Block Protect (BP2, BP1, and BP0)bits are 1 and CMP=1. The Chip Erase (CE) command is ignored if one or more sectors are protected. Note: Power disruption during erase operation will cause incomplete erase, thus it is recommend to perform a re-erase once power resume. Figure23. Chip Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 60H or C7H Figure23a. Chip Erase Sequence Diagram (QPI) CS# 0 1 SCLK C7H SI(IO0) 0 1 SO(IO1) 0 1 WP#(IO2) HOLD#(IO3) 1 1 0 1 CS# 0 1 SCLK 60H SI(IO0) 0 0 SO(IO1) 1 0 WP#(IO2) 1 0 HOLD#(IO3) Rev 1.2 0 Mar/20/2020 0 Page 38 3.0V QUAD IO Serial Flash XT25F128B 6.20. Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest power consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and that puts the flash memory in the Standby Mode (if there is no internal cycle currently in progress). But the Standby Mode is different from the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the flash memory has entered the Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down and Read Device ID (RDI) command. This command release the flash memory from the Deep Power-Down Mode. The Deep Power-Down Mode automatically stops at Power-Off, and the flash memory always Power-Up in the Standby Mode. The Deep Power-Down (DP) command is entered by driving CS# low, followed by the command code on SI, driving CS# high. The Deep Power-Down command sequence: CS# goes lowsending Deep Power-Down commandCS# goes high. The command sequence is shown in Figure24. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command will not be executed. As soon as CS# is driven high, it requires a time duration of tDP before the supply current is reduced to ICC2 and the Deep Power-Down Mode is entered. Any input of Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, will be rejected without having any effects on the cycle that is in progress. Figure24. Deep Power-Down Sequence Diagram CS# tDP 0 1 2 3 4 5 6 7 SCLK Stand-by mode Command SI Deep Power-down mode B9H Figure24a. Deep Power-Down Sequence Diagram (QPI) tPD CS# 0 1 SCLK B9H SI(IO0) 1 1 SO(IO1) 1 0 WP#(IO2) 0 0 1 1 HOLD#(IO3) Standby Mode Rev 1.2 Mar/20/2020 Deep Power Down Mode Page 39 3.0V QUAD IO Serial Flash XT25F128B 6.21. Release from Deep Power-Down And Read Device ID (RDI) (ABH) Release from Power-Down and Read Device ID command is a multi-purpose command. It can be used to release the flash memory from the Power-Down state or obtain the flash memory electronic identification (ID) number. To release the device from the Deep Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high as shown in Figure25. Release from Deep Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must remain high during the tRES1 time duration. When the command is used only to obtain the Device ID while the flash memory is not in the Deep PowerDown mode. The command is initiated by driving the CS# pin low and shifting the instruction code “ABH” followed by 3-dummy byte. The Device ID bits are then shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure26. The Device ID value for the XT25F128B flash memory is listed in Manufacturer and Device Identification table. The Device ID can be read continuously. The command is completed by driving CS# high. In QPI mode the dummy cycles can be configured by C0H command. When the dummy cycle is configured to 4, addr[0] input must be 0. When the command is used to release the device from the Deep Power-Down state and obtain the Device ID, the command is the same as previously described, and shown in Figure26 and Figure26a, except that after CS# is driven high it must remain high for a time duration of tRES2 (See AC Characteristics). After this time duration the device will resume normal operation and other command will be accepted. If the Release from Deep Power-Down and Read Device ID command is issued while an Erasing, Programming or Writing cycle is in process (when WIP equal 1) the command will be ignored and will not have any effects on the current cycle. Figure25. Release Power-Down Sequence Diagram CS tRES1 0 1 2 3 4 5 6 7 SCLK Command SI ABH Deep Power-down mode Stand-by mode Figure25a. Release Power-Down Sequence Diagram (QPI) CS# tRES1 0 1 SCLK ABH SI(IO0) SO(IO1) WP#(IO2) HOLD#(IO3) 0 1 0 1 1 1 0 1 Deep Power Down Mode Rev 1.2 Mar/20/2020 Standby Mode Page 40 3.0V QUAD IO Serial Flash XT25F128B Figure26. Release Power-Down/Read Device ID Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI tRES2 3 Dummy Bytes ABH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Device ID High-Z SO MSB 7 6 5 4 3 2 1 0 Stand-by Mode Figure26a. Release Power-Down/Read Device ID Sequence Diagram (QPI) CS# tRES2 0 1 2 3 4 5 6 7 8 9 SCLK ABH SI(IO0) 0 1 4 0 4 0 4 0 4 0 SO(IO1) 1 1 5 1 5 1 5 1 5 1 WP#(IO2) 0 0 6 2 6 2 6 2 6 2 HOLD#(IO3) 1 1 7 3 7 3 7 3 7 3 Deep Power Down Mode dummy dummy dummy* Standby Mode Device ID *Set Read Parameters Command (C0H) can set the number of dummy cycles 6.22. Read Manufacture ID/ Device ID (REMS) (90H) The Read Manufacturer/Device ID command is an alternative to the Release from Deep Power-Down and Read Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The command is initiated by driving the CS# pin low and shifting the command code “90H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure27. If the 24-bit address is initially set to 000001H, the Device ID will be read first. In QPI mode the dummy cycles can be configured by C0H command. When the dummy cycle is configured to 4, addr [0] input must be 0. Rev 1.2 Mar/20/2020 Page 41 3.0V QUAD IO Serial Flash XT25F128B Figure27. Read Manufacture ID/ Device ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 90H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK SI Manufacturer ID SO Manufacturer ID Device ID 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB Figure27a. Read Manufacture ID/ Device ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 SCLK 90H SI(IO0) 1 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 0 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 0 0 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 1 0 7 3 7 3 7 3 7 3 7 3 dummy dummy dummy* MID Device ID *Set Read Parameters Command (C0H) can set the number of dummy cycles Rev 1.2 Mar/20/2020 Page 42 3.0V QUAD IO Serial Flash XT25F128B 6.23. Read Manufacture ID/ Device ID Dual I/O (92H) The Read Manufacturer/Device ID Dual I/O command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by dual I/O. The command is initiated by driving the CS# pin low and shifting the command code “92H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure28. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure28. Read Manufacture ID/ Device ID Dual I/O Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 92H SO(IO1) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 MFR ID Rev 1.2 Device ID MFR ID (Repeat) Mar/20/2020 Device ID (Repeat) MFR ID (Repeat) Device ID (Repeat) Page 43 3.0V QUAD IO Serial Flash XT25F128B 6.24. Read Manufacture ID/ Device ID Quad I/O (94H) The Read Manufacturer/Device ID Quad I/O command is an alternative to the Release from Deep Power Down and Read Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by quad I/O. The command is initiated by driving the CS# pin low and shifting the command code “94H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure 29. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure29. Read Manufacture ID/ Device ID Quad I/O Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 94H HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Dummy MID DID MID DID MID DID 6.25. Read Identification (RDID) (9FH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte, and the memory capacity of the device in the second byte. Any Read Identification (RDID) command while an Erase or Program cycle is in progress, will not be decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# to low. Then, the 8-bit command code for the command is shifted in. This is followed by the 24-bit manufacture identification and device identification, stored in the memory, being shifted out on Serial Data Output, each bit being shifted out during the falling edge of Serial Clock. The command sequence is shown in Figure30. The Read Identification (RDID) command is terminated by driving CS# to high at any time during data output. When CS# is driven high, the device is put in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. Figure30. Read Identification ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI 9FH Manufacturer ID SO High-Z 7 6 5 4 3 2 1 Memory Type JDID15-JDID8 0 7 6 5 4 3 2 1 Capacity JDID7-JDID0 0 7 6 5 4 3 2 1 0 High-Z MSB Rev 1.2 Mar/20/2020 Page 44 3.0V QUAD IO Serial Flash XT25F128B 6.26. Global Block/Sector Lock (7EH) or Unlock (98H) All Block/Sector Lock bits can be set to 1 by the Global Block/Sector Lock command, or can set to 0 by the Global Block/Sector Unlock command. The Global Block/Sector Lock command (7EH) sequence: CS# goes low –> SI: Sending Global Block/Sector Lock command –> CS# goes high. The command sequence is shown in Figure 31. The Global Block/Sector Unlock command (98H) sequence: CS# goes low –> SI: Sending Global Block/Sector Unlock command –> CS# goes high. The command sequence is shown in Figure 32. Figure 31. The Global Block/Sector Lock Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7EH High-Z SO Figure31a. The Global Block/Sector Lock Sequence Diagram (QPI) CS# 0 1 SCLK 7EH SI(IO0) 0 0 SO(IO1) 1 1 WP#(IO2) 1 1 HOLD#(IO3) Rev 1.2 1 Mar/20/2020 1 Page 45 3.0V QUAD IO Serial Flash XT25F128B Figure 32. The Global Block/Sector Unlock Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 98H High-Z SO Figure 32a. The Global Block/Sector Unlock Sequence Diagram (QPI) CS# 0 1 SCLK 98H SI(IO0) 1 0 SO(IO1) 0 0 WP#(IO2) 0 0 HOLD#(IO3) Rev 1.2 1 Mar/20/2020 1 Page 46 3.0V QUAD IO Serial Flash XT25F128B 6.27. Individual Block/Sector Lock (36H)/Unlock (39H)/Read (3DH) The individual block/sector lock provides an alternative way to protect the memory array from adverse Erase/Program. In order to use the Individual Block/Sector Locks, the WPS bit in Status Register-3 must be set to 1. If WPS=0, the write protection will be determined by the combination of CMP, BP (4:0) bits in the Status Register. The Individual Block/Sector Lock bits are volatile bits. The default values after device power up or after a Reset are 1, so the entire memory array is being protected. The individual Block/Sector Lock command (36H) sequence: CS# goes low –> SI: Sending individual Block/Sector Lock command –> SI: Sending 24bits individual Block/Sector Lock Address –> CS# goes high. The command sequence is shown in Figure 33. The individual Block/Sector Unlock command (39H) sequence: CS# goes low –> SI: Sending individual Block/Sector Unlock command –> SI: Sending 24bits individual Block/Sector Lock Address –> CS# goes high. The command sequence is shown in Figure 33a. The Read individual Block/Sector lock command (3DH) sequence: CS# goes low –> SI: Sending Read individual Block/Sector Lock command –> SI: Sending 24bits individual Block/Sector Lock Address –> SO: The Block/Sector Lock Bit will out –> CS# goes high. If the least significant bit(LSB) is1, the corresponding block/sector is locked, if the LSB is 0, the corresponding block/sector is unlocked, Erase/Program operation can be performed. The command sequence is shown in Figure 33c. Figure33. Individual Block/Sector Lock command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 36H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Figure33a. Individual Block/Sector Lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK 36H SI(IO0) 0 0 20 16 12 8 4 0 SO(IO1) 0 1 21 17 13 9 5 1 WP#(IO2) 1 1 22 18 14 10 6 2 HOLD#(IO3) 1 0 23 19 15 11 7 A23~A16 A15~A8 3 A7~A0 Figure33b. Individual Block/Sector Unlock command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 39H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Rev 1.2 Mar/20/2020 Page 47 3.0V QUAD IO Serial Flash XT25F128B Figure 33c. Individual Block/Sector Unlock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK 39H SI(IO0) 0 1 20 16 12 8 4 0 SO(IO1) 0 0 21 17 13 9 5 1 WP#(IO2) 1 0 22 18 14 10 6 2 HOLD#(IO3) 1 1 23 19 15 11 7 A23~A16 3 A7~A0 A15~A8 Figure 33d. Read Individual Block/Sector lock command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 SCLK Command SI 3DH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Lock Value Out High Z SO X X X X X X X 0 MSB Figure 33e. Read Individual Block/Sector lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 SCLK 3DH SI(IO0) 0 1 4 0 4 0 4 0 4 0 SO(IO1) 0 0 5 1 5 1 5 1 5 1 WP#(IO2) 1 1 6 2 6 2 6 2 6 2 HOLD#(IO3) 1 1 7 3 7 3 7 3 7 3 A23-A16 Rev 1.2 Mar/20/2020 A15-A8 A7-A0 Page 48 3.0V QUAD IO Serial Flash XT25F128B 6.28. Erase Security Registers (44H) The XT25F128B flash memory provides four 256-byte Security Registers which can be erased all at once but can be programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes lowsending Erase Security Registers commandCS# goes high. The command sequence is shown in Figure34. CS# must be driven high after the last address bit has been latched in, otherwise the Erase Security Registers command will not be executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit (LB1, LB0) in the Status Register can be used as OTP to protect the security registers. Any of the LB bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address Security Registers A23-A16 00000000 A15-A10 000000 A9-A0 Don’t Care Figure34. Erase Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 44H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.29. Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. It allows from 1 to 256 byte of Security Registers data to be programmed. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address bytes and at least one data byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register can be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit 0 (LB0) is set to 1, the Security Registers 1 will be permanently locked. Program Security Registers 1command will be ignored.If the Security Registers Lock Bit 1 (LB1) is set to 1, the Security Registers 2 will be permanently locked. Program Security Registers 2command will be ignored. Rev 1.2 Address A23-A16 A15-A8 A7-A0 Security Registers 0 00H 00H Byte Address Security Registers 1 00H 01H Byte Address Security Registers 2 00H 02H Byte Address Security Registers 3 00H 03H Byte Address Mar/20/2020 Page 49 3.0V QUAD IO Serial Flash XT25F128B Figure 35. Program Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 42H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI Data Byte3 Data Byte4 Data Byte256 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB 7 6 5 4 3 2 1 0 MSB 6.30. Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Once the A9-A0 address reaches the last byte of the register (Byte 3FFH), it will reset to 000H, the command is completed by driving CS# high. Address A23-A16 A15-A10 A9-A0 Security Registers 00000000 000000 Address Figure 36. Read Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 48H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 5 4 3 2 1 MSB Rev 1.2 Mar/20/2020 Data Out2 0 7 6 5 4 3 2 1 Data Out3 0 MSB Page 50 3.0V QUAD IO Serial Flash XT25F128B 6.31. Set Read Parameters (C0H) In QPI mode the “Set Read Parameters (C0H)” command can be used to configure the number of dummy clocks for “Fast Read (0BH)”, “Quad I/O Fast Read (EBH)” and “Burst Read with Wrap (0CH)” command, and to configure the number of bytes of “Wrap Length” for the “Burst Read with Wrap (0CH)” command. The “Wrap Length” is set by W5-6 bit in the “Set Burst with Wrap (77H)” command. This setting will remain unchanged when the device is switched from Standard SPI mode to QPI mode. P5-P4 Dummy Clocks 00 4 01 Maximum Read Freq. P1-P0 Wrap Length 48MHz 00 8-byte 4 48MHz 01 16-byte 10 6 48MHz 10 32-byte 11 8 48MHz 11 64-byte Figure 37. Set Read Parameters command Sequence Diagram CS# 0 1 2 3 SCLK C0H SI(IO0) 0 0 P4 P0 SO(IO1) 0 0 P5 P1 WP#(IO2) 1 0 P6 P2 HOLD#(IO3) 1 0 P7 P3 Read Parameter Rev 1.2 Mar/20/2020 Page 51 3.0V QUAD IO Serial Flash XT25F128B 6.32. Burst Read with Wrap (0CH) The “Burst Read with Wrap (0CH)” command provides an alternative way to perform the read operation with “Wrap Around” in QPI mode. This command is similar to the “Fast Read (0BH)” command in QPI mode, except the addressing of the read operation will “Wrap Around” to the beginning boundary of the “Wrap Around” once the ending boundary is reached. The “Wrap Length” and the number of dummy clocks can be configured by the “Set Read Parameters (C0H)” command. When the dummy cycle is configured to 4, addr*0+ input must be 0. Figure 38. Burst Read with Wrap command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK 0CH SI(IO0) 0 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 0 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 0 1 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 0 1 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 dummy* Byte1 Byte2 Byte3 *Set Read Parameters Command (C0H) can set the number of dummy cycles 6.33. Enable QPI (38H) The device support both Standard/Dual/Quad SPI and QPI mode. The “Enable QPI (38H)” command can switch the device from SPI mode to QPI mode. See the command Table 2a for all supported QPI commands. In order to switch the device to QPI mode, the Quad Enable (QE) bit in Status Register-1 must be set to 1 first, and “Enable QPI (38H)” command must be issued. If the QE bit is 0, the “Enable QPI (38H)” command will be ignored and the device will remain in SPI mode. When the device is switched from SPI mode to QPI mode, the existing Write Enable Latch and the Wrap Length setting will remain unchanged. Figure 39. Enable QPI mode command Sequence Diagram CS 0 1 2 3 4 5 6 7 SCLK Command SI SO Rev 1.2 38H High-Z Mar/20/2020 Page 52 3.0V QUAD IO Serial Flash XT25F128B 6.34. Continuous Read Mode Reset (CRMR) (FFH)/ Disable QPI (FFH) In the Dual/Quad I/O Fast Read operations, “Continuous Read Mode” bits (M7-0) are implemented to further reduce command overhead. By setting the (M7-0) to AXH, the next Dual/Quad I/O Fast Read operations do not require the BBH/EBH/E7H command code. Because the XT25F128B flash memory has no hardware reset pin, so if Continuous Read Mode bits are set to “AXH”, the XT25F128B flash memory will not recognize any standard SPI commands. So Continuous Read Mode Reset command will release from the Continuous Read Mode and allow standard SPI command to be recognized. The command sequence is show in Figure 40. Figure40. Continuous Read Mode Reset Sequence Diagram CS# Mode Bit Reset for Quad/ Dual I/O 0 1 2 3 4 5 6 7 SCLK SI(IO0) FFH SO(IO1) Don’t care WP#(IO2) Don’t care HOLD#(IO3) Don’t care Disable QPI (FFH) To exit the QPI mode and return to Standard/Dual/Quad SPI mode, the “Disable QPI (FFH)” command must be issued. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch and the Wrap Length setting will remain unchanged. When the device is in QPI Continuous Read Mode, the first FFH command will exit continuous read mode and the second FFH command will exit QPI mode. Figure 40a. Disable QPI mode command Sequence Diagram CS# 0 1 SCLK FFH Rev 1.2 SI(IO0) 1 1 SO(IO1) 1 1 WP#(IO2) WP#(IO2) 1 1 HOLD#(IO3) HOLD#(IO3) 1 1 Mar/20/2020 Page 53 3.0V QUAD IO Serial Flash XT25F128B 6.35. Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Read Parameter setting (P7-P0)and Wrap Bit Setting (W6-W4). The “Reset (99H)” command sequence as follow: CS# goes low  Sending Enable Reset command  CS# goes high  CS# goes low  Sending Reset command  CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST_R to reset. During this period, no command will be accepted. Data corruption may happen if there is an on-going internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the BUSY bit in Status Register before issuing the Reset command sequence. Figure41a. Enable Reset and Reset command Sequence Diagram CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command SI High-Z 66H Command 99H Figure41b. Enable Reset and Reset command Sequence Diagram (QPI) CS# 0 1 0 1 SCLK 66H SI(IO0) 0 SO(IO1) 1 1 WP#(IO2) 1 1 HOLD#(IO3) Rev 1.2 0 99H 0 1 0 0 0 0 0 1 Mar/20/2020 1 1 Page 54 3.0V QUAD IO Serial Flash XT25F128B 6.36. Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216. Figure42a. Read Serial Flash Discoverable Parameter command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 5AH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO Data Out2 Data Out3 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB Figure42b. Read Serial Flash Discoverable Parameter command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK 5AH SI(IO0) 1 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 1 0 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 0 1 7 3 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 dummy* Byte1 Byte2 Byte3 *Set Read Parameters Command (C0H) can set the number of dummy cycles Rev 1.2 Mar/20/2020 Page 55 3.0V QUAD IO Serial Flash XT25F128B 6.37. Read Unique ID (5AH) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each XT25F128B device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low → sending Read Unique ID command →00H →00H →94H → Dummy byte 128bit Unique ID Out → CS# goes high. The command sequence is show below. Figure 43 Read Unique ID (RUID) Sequence ( Command 5AH ) CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 5AH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 160 161 162 163 164 165 166 167 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 128 bit unique serial number 12 12 12 12 12 12 12 12 7 6 5 4 3 2 1 0 SO 7 6 5 4 3 2 1 0 MSB Figure 43b. Read Unique ID (RUID) Sequence (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK 5AH SI(IO0) 1 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 0 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 1 0 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 0 1 7 3 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 dummy* Byte1 Byte2 Byte3 *Set Read Parameters Command (C0H) can set the number of dummy cycles Rev 1.2 Mar/20/2020 Page 56 3.0V QUAD IO Serial Flash Table3. Signature and Parameter Identification Data Values Add(H) DW Add Description Comment (Byte) (Bit) 00H 07:00 01H 15:08 SFDP Signature Fixed:50444653H 02H 23:16 03H 31:24 SFDP Minor Revision Number Start from 00H 04H 07:00 SFDP Major Revision Number Start from 01H 05H 15:08 Number of Parameters Headers Start from 00H 06H 23:16 Contains 0xFFH and can never be Unused 07H 31:24 changed 00H: It indicates a JEDEC specified ID number (JEDEC) 08H 07:00 header Parameter Table Minor Revision Start from 0x00H 09H 15:08 Number Parameter Table Major Revision Start from 0x01H 0AH 23:16 Number Parameter Table Length How many DWORDs in the 0BH 31:24 (in double word) Parameter table 0CH 07:00 First address of JEDEC Flash Parameter Table Pointer (PTP) 0DH 15:08 Parameter table 0EH 23:16 Contains 0xFFH and can never be Unused 0FH 31:24 changed ID Number(XTX Manufacturer ID) It is indicates XTX manufacturer ID 10H 07:00 Parameter Table Minor Revision Start from 0x00H 11H 15:08 Number Parameter Table Major Revision Start from 0x01H 12H 23:16 Number Parameter Table Length How many DWORDs in the Param13H 31:24 (in double word) eter table 14H 07:00 First address of XT-series Flash Parameter Table Pointer (PTP) 15H 15:08 Parameter table 16H 23:16 Contains 0xFFH and can never be Unused 17H 31:24 changed Rev 1.2 Mar/20/2020 XT25F128B Data Data 53H 46H 44H 50H 00H 01H 01H 53H 46H 44H 50H 00H 01H 01H FFH FFH 00H 00H 00H 00H 01H 01H 09H 09H 30H 00H 00H 30H 00H 00H FFH FFH 0BH 0BH 00H 00H 01H 01H 03H 03H 60H 00H 00H 60H 00H 00H FFH FFH Page 57 3.0V QUAD IO Serial Flash Description Table4. Parameter Table (0): JEDEC Flash Parameter Tables Add(H) DW Add Comment (Byte) (Bit) Block/Sector Erase Size Write Granularity Write Enable Instruction Requested for Writing to Volatile Status Registers Write Enable Opcode Select for Writing to Volatile Status Registers Unused 4KB Erase Opcode (1-1-2) Fast Read Address Bytes Number used in addressing flash array Double Transfer Rate (DTR) clocking (1-2-2) Fast Read (1-4-4) Fast Read (1-1-4) Fast Read Unused Unused Flash Memory Density (1-4-4) Fast Read Number of Wait states (1-4-4) Fast Read Number of Mode Bits (1-4-4) Fast Read Opcode (1-1-4) Fast Read Number of Wait states (1-1-4) Fast Read Number of Mode Bits (1-1-4) Fast Read Opcode Rev 1.2 XT25F128B 00: Reserved; 01: 4KB erase; 10: Reserved; 11: not support 4KB erase 0: 1Byte, 1: 64Byte or larger 0: Nonvolatile status bit 1: Volatile status bit (BP status register bit) 0: Use 50H Opcode, 1: Use 06H Opcode, Note:If target flash status register is Nonvolatile, then bits 3 and 4 must be set to 00b. Contains 111b and can never be changed 31H 32H 0=Not support, 1=Support 0=Not support, 1=Support 0=Not support, 1=Support 33H 37H:34H 0 0000b: Wait states (Dummy Clocks) not support 02 1b 03 0b 04 0b 07:05 111b 15:08 16 20H 1b 18:17 00b 19 0b 20 21 22 23 31:24 31:00 3BH 20H F1H 1b 1b 1b 1b FFH FFH 00FFFFFFH 00100b 44H 07:05 010b 15:08 EBH 20:16 01000b 23:21 000b 31:24 6BH 3AH 000b:Mode Bits not support Data E5H 04:00 39H Mar/20/2020 01b 38H 000b:Mode Bits not support 0 0000b: Wait states (Dummy Clocks) not support 01:00 30H 0=Not support, 1=Support 00: 3Byte only, 01: 3 or 4Byte, 10: 4Byte only, 11: Reserved 0=Not support, 1=Support Data EBH 08H 6BH Page 58 3.0V QUAD IO Serial Flash Add(H) (Byte) Description Comment (1-1-2) Fast Read Number of Wait states 0 0000b: Wait states (Dummy Clocks) not support (1-1-2) Fast Read Number of Mode Bits (1-1-2) Fast Read Opcode (1-2-2) Fast Read Number of Wait states (1-2-2) Fast Read Number of Mode Bits (1-2-2) Fast Read Opcode (2-2-2) Fast Read Unused (4-4-4) Fast Read Unused Unused Unused (2-2-2) Fast Read Number of Wait states (2-2-2) Fast Read Number of Mode Bits (2-2-2) Fast Read Opcode Unused (4-4-4) Fast Read Number of Wait states (4-4-4) Fast Read Number of Mode Bits (4-4-4) Fast Read Opcode Sector Type 1 Size 3FH 0=not support 1=support 0=not support 1=support 40H 43H:41H 45H:44H 0 0000b: Wait states (Dummy Clocks) not support 47H 49H:48H 0 0000b: Wait states (Dummy Clocks) not support 08H 07:05 000b 15:08 3BH 20:16 00010b 23:21 010b 31:24 00 03:01 04 07:05 31:08 15:00 BBH 0b 111b 1b 111b 0xFFH 0xFFH 20:16 00000b 23:21 000b 31:24 15:00 FFH 0xFFH 20:16 00000b Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector/block size=2^N bytes 0x00b: this sector type don’t exist Mar/20/2020 3BH 42H BBH EEH 0xFFH 0xFFH 00H 4AH 000b: Mode Bits not support Data 01000b 46H 000b: Mode Bits not support Sector Type 4 erase Opcode Rev 1.2 Data 3EH Sector Type 3 erase Opcode Sector Type 4 Size 04:00 3DH Sector Type 2 erase Opcode Sector Type 3 Size DW Add (Bit) 3CH 000b: Mode Bits not support Sector Type 1 erase Opcode Sector Type 2 Size XT25F128B FFH 0xFFH 00H 23:21 000b 4BH 31:24 FFH FFH 4CH 07:00 0CH 0CH 4DH 15:08 20H 20H 4EH 23:16 0FH 0FH 4FH 31:24 52H 52H 50H 07:00 10H 10H 51H 15:08 D8H D8H 52H 23:16 00H 00H 53H 31:24 FFH FFH Page 59 3.0V QUAD IO Serial Flash Description XT25F128B Table5. Parameter Table (1): XT-series Flash Parameter Tables Add(H) DW Add Comment (Byte) (Bit) Data Data Vcc Supply Maximum Voltage 2000H=2.000V 2700H=2.700V 3600H=3.600V 61H:60H 15:00 3600H 3600H Vcc Supply Minimum Voltage 1650H=1.650V 2250H=2.250V 2300H=2.300V 2700H=2.700V 63H:62H 31:16 2700H 2700H 00 01 02 03 0b 1b 1b 1b 65H:64H 11:04 99H F99FH 66H 12 13 14 15 23:16 0b 0b 1b 1b 77H 77H 67H 31:24 64H 64H 00 1b 01 0b 09:02 36H 10 0b E8D9H 11 12 13 15:14 31:16 1b 0b 1b 11b FFH FFH HW Reset# pin HW Hold# pin Deep Power Down Mode SW Reset SW Reset Opcode Program Suspend/Resume Erase Suspend/Resume Unused Wrap-Around Read mode Wrap-Around Read mode Opcode Wrap-Around Read data length Individual block lock Individual block lock bit (Volatile/Nonvolatile) Individual block lock Opcode Individual block lock Volatile protect bit default protect status Secured OTP Read Lock Permanent Lock Unused Unused Rev 1.2 0=not support 1=support 0=not support 1=support 0=not support 1=support 0=not support 1=support Should be issue Reset Enable(66H) before Reset cmd 0=not support 1=support 0=not support 1=support 0=not support 1=support 08H:support 8B wrap-around read 16H:8B&16B 32H:8B&16B&32B 64H:8B&16B&32B&64B 0=not support 1=support 0=Volatile 1=Nonvolatile 0=protect 1=unprotect 0=not support 1=support 0=not support 1=support 0=not support 1=support Mar/20/2020 6BH:68H Page 60 3.0V QUAD IO Serial Flash XT25F128B 7. ELECTRICAL CHARACTERISTICS 7.1. Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) Reset State tVSL Device is fully accessible VWI tPUW Time Table3. Power-Up Timing and Write Inhibit Threshold Note: At power-down, need to ensure VCC drop to 0.5V before the next power-on in order for the device to have a proper power-on reset. Symbol Parameter Min Max Unit tVSL VCC(min) To CS# Low 10 us tPUW Time Delay Before Write Instruction 1 - ms VWI Write Inhibit Voltage 1.5 2.5 V 7.2. Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH).The Status Register contains 00H (all Status Register bits are 0). 7.3. Data Retention and Endurance Parameter Typical Unit Pattern Data Retention Time 20 Years Erase/Program Endurance 100K Cycles Parameter Min Max Input Voltage Respect To VSS On I/O Pins -1.0V VCC+1.0V VCC Current -100mA 100mA 7.4. Latch up Characteristics Rev 1.2 Mar/20/2020 Page 61 3.0V QUAD IO Serial Flash XT25F128B 7.5. Absolute Maximum Ratings Parameter Value Unit Ambient Operating Temperature -40 to 85 ℃ Storage Temperature -65 to 150 ℃ Output Short Circuit Current 200 mA Applied Input/Output Voltage -0.5 to 4.0 V VCC -0.5 to 4.0 V 7.6. Capacitance Measurement Condition Symbol Parameter Min Typ Max Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 30 Input Rise And Fall time pF 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to .8 0.7VCC V Output Timing Reference Voltage VCC 0.5VCC V Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns 20ns VSS VSS-2.0V 20ns Maximum Positive Overshoot Waveform 20ns VCC+2.0V VCC 20ns Rev 1.2 Mar/20/2020 20ns Page 62 3.0V QUAD IO Serial Flash XT25F128B 7.7. DC Characteristics (T=-40℃~85℃,VCC=2.70~3.60V) Symbol Parameter ILI Input Leakage Current ILO Output Leakage Current ICC1 Standby Current ICC2 Deep Power-Down Current ICC3 Operating Current(Read) Test Condition Min. Max. Unit ±2 μA ±2 μA 20 40 μA 0.1 4 μA CLK=0.1VCC/0.9VCC at 108MHz, Q=Open(*1 I/O) 15 20 mA CLK=0.1VCC/0.9VCC at 80MHz, Q=Open(*1,*2,*4 I/O) 13 18 mA CLK=0.1VCC/0.9VCC at 50MHZ,Q=Open(*1 I/O) 7 10 mA CS#=VCC VIN=VCC or VSS CS#=VCC VIN=VCC or VSS Typ ICC4 Operating Current(PP) CS#=VCC 30 mA ICC5 Operating Current(WRSR) CS#=VCC 30 mA ICC6 Operating Current(SE) CS#=VCC 30 mA ICC7 Operating Current(BE) CS#=VCC 30 mA VIL Input Low Voltage -0.5 0.2VCC V VIH Input High Voltage 0.7VCC VCC+0.4 V VOL Output Low Voltage IOL=1.6mA 0.4 V VOH Output High Voltage IOH=-100uA VCC-0.2 V Note: 1. Typical values given for TA=25°C. 2. Value guaranteed by design and/or characterization, are not 100% tested in production. Rev 1.2 Mar/20/2020 Page 63 3.0V QUAD IO Serial Flash XT25F128B 7.8. AC Characteristics (T=-40℃~85℃,VCC=2.70~3.60V,CL=30pF) Symbol Parameter fC fC1 Min. Typ Serial Clock Frequency For:Fast Read (0BH), Dual Output(3BH) Serial Clock Frequency For:Dual I/O (BBH), Quad I/O(EBH),Quad Output(6BH) Max. Unit 108 MHz 108 MHz fC2 Serial Clock Frequency For QPI (0BH, EBH) 72 MHz fR1 Serial Clock Frequency For: Read (03H) 60 MHz fR2 Serial Clock Frequency For: Read Identification (9FH) 108 MHz tCLH (1) Serial Clock High Time 45% PC ns tCLL (1) Serial Clock Low Time 45% PC ns tCLCH Serial Clock Rise Time(Slew Rate) 0.2 V/ns tCHCL Serial Clock Fall Time(Slew Rate) 0.2 V/ns tSLCH CS# Active Setup Time 5 ns tCHSH CS# Active Hold Time 5 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns tSHSL CS# High Time (read/write) 20 ns tSHQZ Output Disable Time tCLQX Output Hold Time 1 ns tDVCH Data In Setup Time 2 ns tCHDX Data In Hold Time 2 ns tHLCH Hold# Low Setup Time(relative to Clock) 5 ns tHHCH Hold# High Setup Time(relative to Clock) 5 ns tCHHL Hold# High Hold Time(relative to Clock) 5 ns tCHHH Hold# Low Hold Time(relative to Clock) 5 ns tCLQV Clock Low To Output Valid tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns 6 6.5 ns ns tDP CS# High To Deep Power-Down Mode 0.1 µs tRES1 CS# High To Standby Mode Without Electronic Signature Read 20 µs tRES2 CS# High To Standby Mode With Electronic Signature Read 20 µs tRST_R CS# High To Next Command After Reset (from read) 20 µs tRST_P CS# High To Next Command After Reset (from program) 20 µs tRST_E CS# High To Next Command After Reset (from erase) 12 ms tW Write Status Register Cycle Time 80 800 ms tPP Page Programming Time 0.3 0.75 ms tSE Sector Erase Time 80 800 ms tBE Block Erase Time(32K Bytes/64K Bytes) 0.15/0.2 1.2/1.6 s tCE Chip Erase Time 35 120 s Note: 1. Clock high or Clock low must be more than or equal to 45%Pc. Pc=1/fC(MAX) 2. Value guaranteed by design and/or characterization, are not 100% tested in production. 3. Maximum Serial Clock Frequencies are measured results picked at the falling edge. For the result picked at the rising edge, please refer to the bellowing diagram. Rev 1.2 Mar/20/2020 Page 64 3.0V QUAD IO Serial Flash Serial Clock Frequency Result Picked At The Rising Edge Parameter Min. Typ Symbol fC fC1 XT25F128B Serial Clock Frequency For:Fast Read (0BH), Dual Output(3BH) Serial Clock Frequency For:Dual I/O (BBH), Quad I/O(EBH),Quad Output(6BH) Max. Unit 96 MHz 72 MHz fC2 Serial Clock Frequency For QPI (0BH, EBH) 60 MHz fR1 Serial Clock Frequency For: Read (03H) 60 MHz fR2 Serial Clock Frequency For: Read Identification (9FH) 60 MHz tSHSL Serial Input Timing CS# tCHSL tCHSH tSLCH tSHCH SCLK tDVCH SI tCHCL tCLCH tCHDX MSB LSB High-Z SO Output Timing CS# tCLH tSHQZ SCLK tCLQV tCLQX tCLL tCLQV tCLQX LSB SO SI Least significant address bit (LSB) in Hold Timing CS# tCHHL tHLCH tHHCH SCLK tHLQZ SO tCHHH tHHQX HOLD# SI do not care during HOLD operation Rev 1.2 Mar/20/2020 Page 65 3.0V QUAD IO Serial Flash XT25F128B RESET Timing Rev 1.2 Mar/20/2020 Page 66 3.0V QUAD IO Serial Flash XT25F128B 8. ORDERING INFORMATION The ordering part number is formed by a valid combination of the following: XT 25F 128B SS I G U Company Prefix XT = XTX Product Family 25F=2.70~3.60V Serial Flash Memory with 4KB Uniform-Sector Product Density 128B = 128M bit Product Package SS = 8-pin SOP8(208mil) SF = 16-pin SOP16(300mil) DH = 8-pin DFN8(4x4x0.85mm) WO = WSON 6x5 BG = BGA 8x6 WL = WLCSP Temperature & Moisture Sensitivity Level I = Industrial Level Temp. (-40℃ to +85℃), MSL3 Green Code G = Green/Reach Package Product Carrier U = Tube; T = Tape & Reel; A = Tray NOTE: Standard bulk shipment is in Tube. Any alternation of packing method (for Tape, Reel and Tray etc.), please advise in advance. Rev 1.2 Mar/20/2020 Page 67 3.0V QUAD IO Serial Flash XT25F128B 9. PACKAGE INFORMATION E E1 9.1. Package SOP8 208MIL 0.8 0.8 C b Symbol A A1 A2 b c D E E1 e L θ Min 1.750 0.050 1.700 0.350 0.190 5.130 7.700 5.180 0.500 0° A L 0.25 e 0° GAGE PLANE SEATING PLANE A2 A1 D Dimensions in Millimeters Norm 1.950 0.150 1.800 0.420 0.20 5.230 7.900 5.280 1.270 BSC 0.650 ---- Max 2.160 0.250 1.910 0.480 0.250 5.330 8.100 5.380 0.800 8° Note: 1. JEDEC Outline : N/A 2. Coplanarity: 0.1mm 3. Max allowable mold flash is 0.15mm at the package ends. 0.25mm between leads. Rev 1.2 Mar/20/2020 Page 68 3.0V QUAD IO Serial Flash XT25F128B 9.2. Package SOP16 300mil D A3 h A2 A 0.25 θ° A1 C L L1 b b1 C E1 e With Plating Base Metal b SYMBOL A A1 A2 A3 b b1 C C1 D E E1 e L L1 θ Rev 1.2 E C1 MIN — 0.10 2.25 0.97 0.35 0.34 0.25 0.24 10.20 10.10 7.40 0.55 0 Mar/20/2020 MILLIMETER NOM — — 2.30 1.02 — 0.37 — 0.25 10.30 10.30 7.50 1.27 BSC — 1.40 REF — MAX 2.65 0.30 2.35 1.07 0.43 0.40 0.29 0.26 10.40 10.50 7.60 0.85 8 Page 69 3.0V QUAD IO Serial Flash XT25F128B 9.3. Package DFN8 (4x4x0.85) mm D A2 △ E A1 A Top View y Side View L D1 b E1 e Bottom View Symbol Unit Min milli- Norm mete Max A 0.80 0.85 0.90 A1 0.05 A2 b D D1 E E1 0.15 0.25 0.30 0.35 3.90 4.00 4.10 2.20 2.30 2.40 3.90 4.00 4.10 2.60 2.70 2.80 e L 0.80 0.35 0.40 0.45 Note: Both package length and width do not include mold flash. Rev 1.2 Mar/20/2020 Page 70 3.0V QUAD IO Serial Flash XT25F128B 9.4. Package WSON (6x5) mm A D PIN #1 CORNER E A2 A1 L b E2 e D2 PIN #1 CORNER Symbol A A1 A2 D E D2 E2 e b L Dimensions in Millimeters Min Norm Max 0.70 0.00 --5.90 4.90 3.30 3.90 --0.35 0.55 0.75 0.02 0.20 6.00 5.00 3.40 4.00 1.27 0.40 0.60 0.80 0.04 --6.10 5.10 3.50 4.10 --0.45 0.65 Note: 1. Coplanarity: 0.1mm Rev 1.2 Mar/20/2020 Page 71 3.0V QUAD IO Serial Flash XT25F128B 9.5. Package BGA (8x6) mm // 0.10 C A 3 2 1 1 A A B B C C D D E E F F 2 3 4 A D1 c 4 PIN A1 INDEX A1 PIN A1 INDEX ob M 0.15 C A B 0.08 M C 0.10 C e B C E1 E 0.10(4X) SEATING PLANE BALL LAND Note: Ball land:0.45mm. 1 Ball Opening:0.35mm. PCB ball land suggested
XT25F128BSSIGU 价格&库存
很抱歉,暂时无法提供与“XT25F128BSSIGU”相匹配的价格&库存,您可以联系我们找货
