S6125-F-4.0A
S6125-F-4.0A
    SART(萨特)
    SMD
S6125-F-4.0A 数据手册
Surface Mount Fuses File No.: JS-S6125-F-00 Revision: K Page: 1/ 6 6125 Size >Fast Acting>S6125-F Series General • Fast acting,Inrush withstand capability • Wire-In-Air performance • Wide range of current rating available • 6.1mm× 2.5mm square shape surface mount • Higher temperature profiles • -55℃~125℃ operating temperature • Excellent environmental integrity • RoHS compliant • Halogen-free Application Agency / Certificate Information Agency File Number Ampere Range E319512 1A~20A PSE18021410 1A~5A PSE18021408 6.3A~10A • Battery pack •Storage system • Power supply • PC & PC peripherals • Game console • PC server • Cooling fan system • Wireless basestation • Industrial equipment • Telecom system • LCD monitor and modules • Medical equipment Electrical Specifications Part Number Current Rating (A) Voltage Rating (V) S6125-F-1.0A S6125-F-1.25A S6125-F-1.6A S6125-F-2.0A S6125-F-2.5A S6125-F-3.0A S6125-F-3.15A S6125-F-4.0A S6125-F-5.0A S6125-F-6.3A S6125-F-7.0A S6125-F-8.0A S6125-F-10.0A S6125-F-12.0A S6125-F-15.0A S6125-F-20.0A 1 1.25 1.6 2 2.5 3 3.15 4 5 6.3 7 8 10 12 15 20 125 125 125 125 125 125 125 125 125 125 125 125 125 65 65 65 Interrupting Rating (V) CQC/PSE: 100A 100V AC UL: 50A 125V AC 50A 160V DC / CQC/PSE: 100A 100V AC UL: 50A 65V AC 50A 65V DC Typical Cold DCR* (mΩ) 80.0 60.0 38.0 30.0 27.0 22.0 21.0 16.0 14.0 10.0 9.4 7.4 5.9 4.8 3.7 3 Typical I2T** (A2s) 0.56 0.84 1.23 1.34 1.43 1.88 2.05 3.44 4.84 10.55 10.58 17.62 30.30 42.22 69.75 132.04 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8105 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S6125-F-00 Revision: K Page: 2/ 6 6125 Size >Fast Acting>S6125-F Series * ** Measured at≤10% rated current and 25℃ Melting I2T at 10 times of rated current Catalo Part Number Information S 6125—F—1.0A “1.0A” Ampere Rating: 1A “ F” Electrical Characteristic: F = Fast acting “6125” Size Number “ S” Symbol of SART Shape & Dimensions: (mm) Dimensions Type L (mm) W/ T (mm) D (mm) S6125 6.10±0.20 2.50±0.10 1.40±0.10 W/T Recommended Land Patterns D Materials A C Components Material Body Ceramic Terminations Au Plated Brass Cap Element Nickel alloy or Copper Alloy B Dimensions Spec A(mm) 3.00±0.30 B(mm) 8.00±0.30 C(mm) 3.00±0.30 D(mm) 2.50±0.30 Dimensions of Standard Test Board Type Ampere Rating 1A~6.3A S6125 7A~10A 12A~20A Board Thickness (mm) 1.6 1.6 1.6 Copper Layer Thickness (mm) 0.035 0.070 0.080 Copper Trace Width (mm) 5 7.5 10 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8105 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S6125-F-00 Revision: K Page: 3/ 6 6125 Size >Fast Acting>S6125-F Series I2T VS Time Curve 20 A 6 .3 A 7 .0 A 8 .0 A 10 A 12 A 15 A 100 3 .1 5 A 4 .0 A 5 .0 A 1 .0 A 1 .2 5 A 1 .6 A 2 .0 A 2 .5 A Time Current Current Curve Time Curve: 1E7 20.0A 15.0A 12.0A 10.0A 8.0A 7.0A 6.3A 5.0A 4.0A 3.15A 2.5A 2.0A 1.6A 1.25A 1.0A 1000000 100000 10000 1 I2 T (A 2 S) T im e (s ) 10 0.1 1000 100 10 1 0.01 0.1 0.01 1E-3 1 10 100 1000 1E-3 0.01 0.1 1 10 100 1000 10000 Time(s) Current(A) Electrical Characteristics Type S6125 Ampere Rating % of Current Rating Opening Time 1A~20A 100 4hours Min. 1A~10A 200 5sec Max. 1A~10A 125 1hour Min. 12A~20A 200 20sec Max. Temperature Derating Curve Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8105 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses 6125 Size >Fast Acting>S6125-F Series File No.: JS-S6125-F-00 Revision: K Page: 4/ 6 Product Characteristics Item Test condition/ Methods Performance Standard 100% of current rating No Fusing, 4hours Min. UL248-14 200% of current rating 1A~10A:
S6125-F-4.0A 价格&库存
很抱歉,暂时无法提供与“S6125-F-4.0A”相匹配的价格&库存,您可以联系我们找货
