MMCXV-P-C-GF-RA-CA1
MMCXV-P-C-GF-RA-CA1
    SAMTEC(申泰)
    内针
MMCXV-P-C-GF-RA-CA1 数据手册
F-221 WEB MMCXV–P–C–GF–ST–CA1 MMCXV–J–C–HF–ST–CA1 MMCXV–P–C–HF–RA–CA1 MMCXV–J–P–GF–ST–TH1 MMCXV SERIES 50 W HIGH VIBRATION MMCX Mates with: RF174, RF316 MMCXV GENDER TYPE PLATING ORIENTATION –HF = Straight TERMINATION SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MMCXV-EM, www.samtec.com?MMCXV-TH Contact Material: BeCu Insulator Material: PTFE Pin and Shell Material: Brass Operating Temp Range: -65 °C to +125 °C Insulation Resistance: 1000 MW min Contact Resistance: Center: 5 mW Outer: 2.5 mW Impedance: 50 W Dielectric Withstanding Voltage: 500 Vrms, 50 Hz Dielectric Working Voltage: 170 Vrms, 50 Hz V.S.W.R.: 1.3 max Frequency Range: 0~6 GHz RoHS Compliant: Yes Processing: –P –J = PCB Mount = Jack –P = Plug SPECIFICATIONS For complete specifications and assembly instructions see www.samtec.com?MMCXV-CA Shell Material: Brass Insulator Material: PTFE Lead, Contact Socket and Outer Conductor Material: BeCu with Au plating Center Contact: Soldered Outer Ferrule: Crimped Operating Temp Range: -65 °C to +125 °C Insulation Resistance: 1000 MW min Contact Resistance: Center: 5 mW Outer: 2.5 mW Impedance: 50 W Dielectric Withstanding Voltage: 500 Vrms, 50 Hz Dielectric Working Voltage: 170 Vrms, 50 Hz Frequency Range: 0~6 GHz (Cable dependent) –EM1 = Edge Mount (–J only) –GF = 10 µ" (0.25 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact (3.50) .138 SQ (3.50) .138 DIA (7.40) .291 (4.50) .177 DIA (0.35) .014 (7.40) .291 (0.90) .035 (3.40) .134 (4.35) .171 (7.40) .291 (3.50) .138 –J–TH1 (4.40) .173 –J–EM1 (0.70) .028 DIA (0.50) .020 –P–TH1 MMCXV GENDER TYPE PLATING ORIENTATION –HF = Right Angle (–P only) –C –J = Cable = 30 µ" (0.76 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact = Jack –P = Plug –RA TERMINATION –CA1 = RG 174 / 316 Cable –ST = Straight –GF (8.80) .346 (4.48) .176 DIA = 10 µ" (0.25 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact (13.60) .535 (7.00) .276 –J–ST (2.70) .106 DIA (9.60) .378 (4.48) .176 DIA –P–ST (4.00) .157 (9.00) .354 –P–RA (14.41) .567 Note: The MMCX and MMCXV connectors are not inter-mateable. –TH1 = Through-hole = 30 µ" (0.76 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact Lead-Free Solderable Yes Note: The MMCX and MMCXV connectors are not inter-mateable. –ST –J –P Supplied with pins and ferrules. See website for dimensions. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MMCXV-P-C-GF-RA-CA1 价格&库存
很抱歉,暂时无法提供与“MMCXV-P-C-GF-RA-CA1”相匹配的价格&库存,您可以联系我们找货
MMCXV-P-C-GF-RA-CA1
    • 1+64.99440
    • 10+63.50400
    • 30+62.51040
    库存:10
