F0603SB7000V032TM
F0603SB7000V032TM
    AEM
    一次性保险丝(熔断) 7A 32V
F0603SB7000V032TM 数据手册
Revision of March 2018 SolidMatrix® Surface Mount Fuses SB Series (Slow Blow), 0603 Size Features: • • • • • Clearing Time Characteristics: % of Current Rating 100% 200% 300% 800% (1 A - 1.5 A) 800% (2 A - 8 A) High inrush current withstanding capability Ceramic Monolithic structure Silver fusing element and silver termination with nickel and tin plating Symmetrical design with marking on both sides (optional) Operating temperature range: -55°C to +150°C (with derating) Shape and Dimensions: Clearing time at 25°C 4 hours min. 1 second min. 0.1 seconds min. 0.0005 seconds min. 0.001 seconds min. 120 seconds max. 3 seconds max. 0.05 seconds max. 0.05 seconds max. Unit Inch mm L 0.063 ± 0.006 1.60 ± 0.15 W 0.031 ± 0.006 0.80 ± 0.15 T 0.031 ± 0.006 0.80 ± 0.15 B 0.014 ± 0.006 0.36 ± 0.15 L W Agency Approval: Recognized Under the Components Program of UL. File Number: E232989. T Patents: B Patent numbers “US6,034,589”, “US6,602,766”, “US7,268,661 B2” “ZL00134544.3”, “ZL02114719.1”, “ZL200410104280.7”, “ZL201020551352.3”, “ZL201020551360.8”, “ZL201010299185.2”, “ZL201220030614.0”, “ZL201210020693.1. Ordering Information: Part Number F0603SB1000V032TM F0603SB1500V032TM F0603SB2000V032TM F0603SB2500V032TM F0603SB3000V032TM F0603SB3500V032TM F0603SB4000V032TM F0603SB4500V032TM F0603SB5000V032TM F0603SB6000V032TM F0603SB7000V032TM F0603SB8000V032TM Current Rating (A) 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 6.0 7.0 8.0 1. Measured at ≤ 10% rated current and 25 oC ambient. Voltage Rating (VDC) 32 32 32 32 32 32 32 32 32 32 32 32 Interrupting Ratings 50 A at rated voltage 80 A at rated voltage 2. Melting I2t at 0.001 second pre-arcing time. Nominal Cold DCR(Ω)1 Nominal I2t (A2s)2 Marking (Optional)3 0.200 0.100 0.052 0.041 0.031 0.021 0.017 0.015 0.013 0.010 0.008 0.006 0.093 0.18 0.32 0.63 0.87 1.20 2.30 2.70 3.20 4.00 5.00 7.00 E G I J K L M T N O P R 3. Red Marking Character Code. Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses SB Series (Slow Blow), 0603 Size 8.0 A 7.0 A 6.0 A 5.0 A 4.5 A 4.0 A 3.5 A 3.0 A 2.5 A 2.0 A 1.5 A 1.0 A Average Pre-arcing Time Curves: 100 Time(s)(s) Pre-arcing Clearing Time 10 1 0.1 0.01 0.001 1 10 Current (A) Website: www.aemchina.com & www.aemcomponents.com 100 Revision of March 2018 SolidMatrix® Surface Mount Fuses SB Series (Slow Blow), 0603 Size Average I2t vs. t Curves: 10000 8.0 A 7.0 A 6.0 A 5.0 A 4.5 A 1000 4.0 A 3.5 A 3.0 A 2.5 A 2.0 A 100 I2t (A2s) 1.5 A 1.0 A 10 1 0.1 0.01 0.001 0.01 0.1 1 10 Time (s) Website: www.aemchina.com & www.aemcomponents.com 100 Revision of March 2018 SolidMatrix® Surface Mount Fuses Product Identification: F 0603 FA 1000 V032 T M F 1206 HC 20A0 T M (1) (1) (2) (3) (4) (5) (6) (7) (2) (3) (4) (5) (6) (1) Product Code: F-Chip Fuse (1) Product Code: F-Chip Fuse (2) Size Code: Standard EIA Chip Sizes (2) Size Code: L x W (inch), the first two digits-L (length), (3) Series Code: FA - Fast Acting, SB - Slow Blow, HI - High Inrush, FF - Very Fast Acting, HB - High Current the last two digits-W (width) (4) Current Rating Code: 1000 - 1000 mA (For HB, 10 - 10A) (3) Series Code: HC Series (5) Voltage Rating Code: V032 - 32 VDC (4) Current Rating Code: 20A0—20.0A (6) Package Code: T - Tape & Reel, B - Bulk (5) Package Code: T - Tape & Reel, B - Bulk (7) Marking Code: M - With Marking Recommended Land Pattern: 0.016 (0.40) 0.028 (0.70) 0.063 (1.60) Inch (mm) 0402 Size 0.059 (1.50) 0.031 (0.80) 0.087 (2.20) 0.039 (1.00) 0.173 (4.40) Inch (mm) Inch (mm) 0603 Size 0.071 (1.80) 1206 Size Environmental Tests: No. Test Requirement Test condition 1 Soldering heat resistance DCR change  10% No mechanical damage One dip at 260C for 60 seconds 2 Solderability Minimum 95% coverage One dip at 245C for 5 seconds 3 Thermal shock 4 Moisture resistance 5 Salt spray 6 Mechanical vibration 7 Mechanical shock 8 Life DCR change  10% No mechanical damage DCR change  15% No excessive corrosion DCR change  10% No excessive corrosion DCR change  10% No mechanical damage DCR change  10% No mechanical damage 100 cycles between -65C and +125C 10 cycles 48 hour exposure 0.4 ” D.A. or 30 G between 5 – 3000 Hz 1500 G, 0.5 ms, half-sine shocks Test reference MIL-STD-202 Method 210 MIL-STD-202 Method 208 MIL-STD-202 Method 107 MIL-STD-202 Method 106 MIL-STD-202 Method 101 MIL-STD-202 Method 204 MIL-STD-202 Method 213 No electrical “opens” during 80% rated current (75% for < 1 A fuses) testing Refer to AEM for 2000 hours at ambient temperature voltage drop change shall be QIQ106 between +20C and +30C less than 20% of initial value Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses Electrical Specification: Clearing Time Characteristics: Same as specified on the Short Form Data Sheet Insulation Resistance after Opening: 20,000 ohms typical when cleared with rated voltage applied. Fuse clearing under low voltage conditions may result in lower after clearing insulation resistance values. (Note: Under normal fault conditions (low or rated voltage conditions), AEM SolidMatrix fuses provide sufficient after clearing insulation resistance values for circuit protection.) Current Carrying Capacity: 100% rated current at +25°C ambient for 4 hours minimum when evaluated per MIL-PRF-23419 Interrupt Ratings: Fuse Selection and Temperature De-rating Guideline: The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25°C, the fuse shall be “de-rated”. To select a fuse from the catalog, the following rule may be followed: Catalog Fuse Current Rating = Nominal Operating Current / 0.75 / % De-rating at the maximum operating temperature. Example: At maximum operating temperature of 65°C, % De-rating is 90%. The nominal operating current is 4 A. The current rating for fuse selected from the catalog shall be: 4 / 0.75 / 90% = 5.9 or 6 A. Specifications and descriptions in this literature are as accurate as known at the time of publish, but are subject to change without notice. Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses Soldering Temperature Profile: * Recommended Temperature Profile for Reflow Soldering Profile Feature * Recommended Temperature Profile for Wave Soldering Pb-Free Assembly Preheat/Soak Temperature Min (Tsmin) Temperature Max(Tsmax) Time(ts) from (Tsmin to Tsmax) 150°C 200°C 60~120 seconds Ramp-uprate (TL to Tp) 3°C/second max. Liquidous temperature(TL) Time(tL) maintained above TL 217°C 60~150 seconds Peak package body temperature (Tp) 260°C Time (tp)*within 5°C of the specified classification temperature (Tc) 30 seconds * Ramp-down rate (Tp to TL) 6°C/second max. Time 25°C to peak temperature 8 minutes max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum Notice: Wave Soldering is suitable for 1206 and 0603 size. Packaging: Chip Size Parts on 7 inch (178 mm) Reel 0402 (1005) 10,000 0603 (1608) 4,000 0603FF (1608) 6,000 1206 (3216) 3,000 Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 Disclaimer Specifications are subject to change without notice. AEM products are designed for specific applications and should not be used for any purpose (including, without limitation, automotive, aerospace, medical, life-saving applications, or any other application which requires especially high reliability for the prevention of such defect as may directly cause damage to the third party’s life, body or property) not expressly set forth in applicable AEM product documentation. It is the customer’s responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Warranties granted by AEM shall be deemed void for products used for any purpose not expressly set forth in applicable AEM product documentation. AEM shall not be liable for any claims or damages arising out of products used in applications not expressly intended by AEM as set forth in applicable AEM product documentation. The sale and use of AEM products is subject to AEM terms and conditions of sale. Please refer Website: www.aemchina.com & www.aemcomponents.com
F0603SB7000V032TM
1. 物料型号:文档中提供了多个型号,例如F0603SB1000V032TM、F0603SB1500V032TM等,这些型号属于SB系列(慢速熔断)的0603尺寸表面贴装保险丝。
2. 器件简介:这些保险丝具有高浪涌电流承受能力、陶瓷单体结构、银熔断元件和银镀镍锡端子、对称设计(可选双面标记)、工作温度范围为-55°C至+150°C(需降额)。
3. 引脚分配:文档中未明确指出具体的引脚分配,但通常这类保险丝为表面贴装元件,具有对称设计。
4. 参数特性: - 额定电流范围从1.0A至8.0A。 - 直流电压额定值为32V。 - 断路额定值从50A至80A不等。 - 标称冷态直流电阻(Nominal Cold DCR)和标称12t(Nominal 12t)值随不同型号而变化。
5. 功能详解:保险丝具有慢速熔断特性,提供了在不同电流下的清除时间特性表,并附有预电弧时间曲线图和I2t vs. t曲线图。
6. 应用信息:文档提到这些保险丝适用于需要电路保护的应用场合,并附有推荐焊盘图案和环境测试要求。
7. 封装信息:保险丝采用0603尺寸封装,文档中提供了详细的尺寸数据,包括长度(L)、宽度(W)、厚度(T)和间隙(B)。
8. 环境测试:包括耐焊接热性、可焊性、热冲击、耐湿性、盐雾、机械振动、机械冲击和寿命测试。
9. 电气规格:包括清除时间特性、开路后的绝缘电阻、电流承载能力和中断额定值。
10. 焊接温度曲线:提供了无铅组装和波峰焊接的推荐温度曲线。
F0603SB7000V032TM 价格&库存
很抱歉,暂时无法提供与“F0603SB7000V032TM”相匹配的价格&库存,您可以联系我们找货
F0603SB7000V032TM
  • 4000+3.614504000+0.46972
  • 8000+3.326688000+0.43231
  • 12000+3.1679412000+0.41169
  • 20000+3.1146120000+0.40476
库存:3706
F0603SB7000V032TM
  • 1+9.543391+1.24019
  • 5+7.899165+1.02652
  • 10+7.2785710+0.94587
  • 50+6.0403850+0.78497
  • 100+5.57292100+0.72422
  • 250+5.00931250+0.65098
  • 500+4.61992500+0.60037
  • 1000+4.259051000+0.55348
库存:3706
