FT800Q-R
FT800Q-R
    BRIDGETEK
    VQFN48_7X7MM
    嵌入式视频引擎
FT800Q-R 数据手册
FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Bridgetek Pte Ltd FT800 (Embedded Video Engine) The FT800 is an easy to use graphic controller targeted for embedded applications to generate high-quality Human Machine Interfaces (HMIs). It has the following features:  Support for LCD display in WQVGA (480x272) and QVGA (320x240) formats with data enable (DE) support mode and VSYNC/HSYNC mode  FT800 functionality includes graphic controller, audio processing, and resistive touch controller.  The FT800 calculates for 8-bit colour despite only providing pins for 6-bit (RGB-6,6,6); this improves the half tone appearance  Embedded Video Engine (EVE) with widget support can offload the system MPU and provide a variety of graphic features  Display enable control output to LCD panel  Mono audio channel output with PWM output  64 voice polyphonic sound synthesizer  Audio wave playback for mono 8-bit linear PCM, 4-bit ADPCM and µ-Law coding format at sampling frequency from 8 kHz to 48 kHz. Built-in digital filter reduces the system design complexity of external filtering  PWM output for backlight dimming control for LED  Low power consumption for portable application, 24mA active (typical) and 10-25 uA sleep (typical)  No frame buffer RAM required     Built-in graphics operations allow users with little expertise to create high-quality display Integrated with 4-wire touch-screen controller incorporating median filtering and touch force sensing. Hardware engine can recognize touch tags and track touch movement. It provides notification for up to 255 touch tags. Standard serial interface to host MPU/MCU with SPI up to 30MHz or I²C clocking up to 3.4MHz Programmable interrupt controller provides interrupts to host MPU/MCU  Built-in 12MHz crystal oscillator with PLL providing 48MHz or 36MHz system clock   Video RGB parallel output (default RGB data width of 6-6-6) with 2 bit dithering; configurable to support resolution up to 512x512 and LCD R/G/B data width of 1 to 6 Advanced object oriented architecture enables low cost MPU/MCU as system host using I2C and SPI interfaces  Power mode control allows chip to be put in power down, sleep and standby states  Supports host interface I/O voltage from 1.8V to 3.3V  Internal voltage regulator supplies 1.2V to the digital core  -40°C to 85°C temperature range  Available in a compact Pb-free, VQFN-48, 7mm X 7mm X 0.9mm package, RoHS compliant  Programmable timing to adjust HSYNC and VSYNC timing, enabling interface to numerous displays extended operating Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Bridgetek Pte Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H Copyright © Bridgetek Pte Ltd 1 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 1 Typical Applications  Point of Sales Machines  Power meter  Multi-function Printers  Home appliance devices  Instrumentation  Set-top box  Home Security Systems  Thermostats  Graphic touch pad – remote, dial pad  Sprinkler system displays  Tele / Video Conference Systems  Medical Appliances  Phones and Switchboards  GPS / SatNav  Medical Appliances  Vending Machine Control Panels  Blood Pressure displays  Elevator Controls  Heart monitors  ……and many more  Glucose level displays  Breathalyzers  Gas chromatographs 1.1 Part Numbers Part Number FT800Q-x Package 48 Pin VQFN, pitch 0.5mm, body 7mm x 7mm x 0.9mm Table 1- Video Controller Part Numbers Note: Packaging codes for x is: -R: Taped and Reel, (VQFN in 3000 pieces per reel) -T: Tray packing, (VQFN in 260 pieces per tray) For example: FT800Q-R is 3000 VQFN pieces in taped and reel packaging Copyright © Bridgetek Pte Ltd 2 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 2 FT800 Block Diagram Figure 2-1 FT800 Block Diagram For a description of each function please refer to Section 4. Figure 2-2 FT800 System Design Diagram FT800 or EVE (Embedded Video Engine) simplifies the system architecture for advanced human machine interfaces (HMIs) by providing functionality for display, audio, and touch as well as an object oriented architecture approach that extends from display creation to the rendering of the graphics. Copyright © Bridgetek Pte Ltd 3 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Table of Contents 1 Typical Applications................................................. 2 1.1 Part Numbers ......................................................................2 2 FT800 Block Diagram .............................................. 3 3 Device Pin Out and Signal Description ..................... 6 3.1 VQFN-48 Package Pin Out ...................................................6 3.2 Pin Description ....................................................................7 4 Function Description ............................................. 10 4.1 Serial Host Interface ......................................................... 10 4.1.1 SPI Interface .................................................................................... 12 4.1.2 I²C Interface .................................................................................... 12 4.1.3 Serial Data Protocol........................................................................... 12 4.1.4 Host Memory Read ............................................................................ 12 4.1.5 Host Memory Write ........................................................................... 13 4.1.6 Host Command ................................................................................. 13 4.1.7 Interrupts ........................................................................................ 14 4.2 System Clock .....................................................................15 4.2.1 Clock Source .................................................................................... 15 4.2.2 Phase Locked Loop ............................................................................ 16 4.2.3 Clock Enable .................................................................................... 16 4.2.4 Clock Frequency ............................................................................... 16 4.3 Graphics Engine ................................................................ 16 4.3.1 Introduction ..................................................................................... 16 4.3.2 ROM and RAM Fonts .......................................................................... 17 4.4 Parallel RGB Interface ....................................................... 20 4.5 Miscellaneous Control ....................................................... 21 4.5.1 Backlight Control Pin ......................................................................... 21 4.5.2 DISP Control Pin ............................................................................... 21 4.5.3 General Purpose IO pins .................................................................... 21 4.5.4 Pins Drive Current Control.................................................................. 22 4.6 Audio Engine .....................................................................22 4.6.1 Sound Synthesizer ............................................................................ 22 4.6.2 Audio Playback ................................................................................. 24 4.7 Touch-Screen Engine ......................................................... 24 4.8 Power Management ........................................................... 26 Copyright © Bridgetek Pte Ltd 4 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 4.8.1 Power supply .................................................................................... 26 4.8.2 Internal Regulator and POR ................................................................ 26 4.8.3 Power Modes .................................................................................... 27 5 FT800 Memory Map ............................................... 30 5.1 6 FT800 Registers ................................................................ 30 Devices Characteristics and Ratings ...................... 33 6.1 Absolute Maximum Ratings ...............................................33 6.2 DC Characteristics ............................................................. 33 6.3 Touch Sense Characteristics ..............................................34 6.4 AC Characteristics ............................................................. 35 6.4.1 System clock .................................................................................... 35 6.4.2 Host Interface SPI Mode 0 ................................................................. 35 6.4.3 Host Interface I2C Mode Timing .......................................................... 36 6.4.4 RGB Video Timing ............................................................................. 36 7 Application Examples ............................................ 38 7.1 Examples of LCD Interface connection .............................. 38 7.2 Examples of PWM Audio Circuits .......................................38 8 Package Parameters .............................................. 39 8.1 VQFN-48 Package Dimensions ...........................................39 8.1.1 Top Side ............................................................................................... 39 8.1.2 Bottom Side .......................................................................................... 39 8.2 VQFN-48 Package Dimensions ...........................................40 8.3 Solder Reflow Profile ......................................................... 41 9 Contact Information .............................................. 42 Appendix A – References ............................................. 43 Document References ................................................................ 43 Acronyms and Abbreviations ..................................................... 43 Appendix B - List of Figures and Tables ....................... 44 List of Figures ............................................................................44 List of Tables .............................................................................44 Appendix C - Revision History ...................................... 46 Copyright © Bridgetek Pte Ltd 5 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 3 Device Pin Out and Signal Description 3.1 VQFN-48 Package Pin Out Figure 3-1 Pin Configuration VQFN-48 (top view) Copyright © Bridgetek Pte Ltd 6 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 3.2 Pin Description 1 Pin No. Name AUDIO_L O 2 3 GND SPI_SCLK/ I2C_SCL P I 4 MISO/ I2C_SDA I/O 5 MOSI/ I2C_SA0 I 6 CS_N/ I2C_SA1 I 7 GPIO0/ I2C_SA2 I/O 8 GPIO1 I/O 9 VCCIO P 10 MODE I 11 INT_N OD 12 PD_N I 13 X1/ CLK I 14 X2 O 15 16 17 GND VCC VCC1V2 P P O 18 19 VCC X+ P AI/O Copyright © Bridgetek Pte Ltd Type Description Audio PWM out, push-pull output, 16mA sink/source current. Pad powered from pin VCC. Ground In SPI mode: SPI SCLK input. In I2C mode: SCL input, need external 1kΩ ~ 4.7kΩ pull up to VCCIO. Input pad with Schmitt trigger, 3.3V tolerant. Pad powered from pin VCCIO. In SPI mode: SPI MISO output. In I2C mode: SDA input/Open Drain Output, need external1kΩ ~ 4.7kΩ pull up to VCCIO. Input with Schmitt trigger, 3.3V tolerant, 4/8/12/16mA sink/source current. Pad powered from pin VCCIO. In SPI mode: SPI MOSI input. In I2C mode: Input, bit 0 of I2C device address. Input pad, 3.3V tolerant. Pad powered from pin VCCIO. In SPI mode: SPI CS_N input, active low. In I2C mode: Input, bit 1 of I2C device address. Input pad, 3.3V tolerant. Pad powered from pin VCCIO. In SPI mode: General purpose input, output port. In I2C mode: Input, bit 2 of I2C device address. Push-pull, three-state output. 3.3V tolerant, 4/8/12/16mA sink/source current. Pad powered from pin VCCIO. General purpose input, output port. Push-pull, three-state output. 3.3V tolerant, 4/8/12/16mA sink/source current. Pad powered from pin VCCIO. I/O power supply, connect a 0.1uF decoupling capacitor. Support 1.8V, 2.5V or 3.3V. Note: VCCIO supply to IO pads from pin 3 to 12 only. Host interface SPI(pull low) or I2C(pull up) mode select input, 3.3V tolerant Pad powered from pin VCCIO. Host Interrupt, open drain output, active low, pull up to VCCIO through a 1kΩ ~10kΩ resistor. Power down input, active low, 3.3V tolerant, pull up to VCCIO through 47kΩ resistor and 100nF to ground. Pad powered from pin VCCIO. Crystal oscillator or clock input; Connect to GND if not used. 3.3V peak input allowed. Pad powered from pin VCC. Crystal oscillator output; leave open if not used. Pad powered from pin VCC. Ground 3.3V power supply input. 1.2V regulator output pin. Connect a 4.7uF decoupling capacitor to GND. 3.3V power supply input. Connect to X right electrode of 4-wire touchscreen panel. 7 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Pin No. Name Type 20 Y+ AI/O 21 X- AI/O 22 Y- AI/O 23 24 GND BACKLIGHT P O 25 DE O 26 VSYNC O 27 HSYNC O 28 DISP O 29 PCLK O 30 B7 O 31 B6 O 32 B5 O 33 B4 O 34 B3 O 35 B2 O 36 37 GND G7 P O 38 G6 O 39 G5 O 40 G4 O Copyright © Bridgetek Pte Ltd Clearance No.: BRT#001 Description Pad powered from pin VCC. Connect to Y top electrode of 4-wire touch-screen panel. Pad powered from pin VCC. Connect to X left electrode of 4-wire touchscreen panel. Pad powered from pin VCC. Connect to Y bottom electrode of 4-wire touchscreen panel. Pad powered from pin VCC. Ground LED Backlight brightness PWM controls signal, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. LCD Data Enable, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. LCD Vertical Sync, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. LCD Horizontal Sync, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. General purpose output pin for LCD Display Enable, push-pull output, 4/8mA sink/source current. Control by writing to Bit 7 of REG_GPIO register. Pad powered from pin VCC. LCD Pixel Clock, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 7 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 6 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 5 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 4 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 3 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 2 of Blue RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Ground Bit 7 of Green RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 6 of Green RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 5 of Green RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. Bit 4 of Green RGB signals, push-pull output, 8 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Pin No. Name 41 G3 42 G2 43 R7 44 R6 45 R5 46 R4 47 R3 48 R2 EP GND Clearance No.: BRT#001 Type Description 4/8mA sink/source current. Pad powered from pin VCC. O Bit 3 of Green RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 2 of Green RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 7 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 6 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 5 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 4 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 3 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. O Bit 2 of Red RGB signals, push-pull output, 4/8mA sink/source current. Pad powered from pin VCC. P Ground. Exposed thermal pad. Table 3-1 FT800Q pin description Note: P I O OD I/O AI/O : : : : : : Power or ground Input Output Open drain output Bi-direction Input and Output Analog Input and Output Copyright © Bridgetek Pte Ltd 9 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 4 Function Description The FT800 is a single chip, embedded graphic controller with the following function blocks:        Serial Host Interface System Clock Graphics Engine Parallel RGB video interface Audio Engine Touch-screen Engine Power Management The functions for each block are briefly described in the following subsections. 4.1 Serial Host Interface The FT800 uses a standard serial interface to communicate with most types of microcontrollers and microprocessors. The interface mode is configurable by pull down for SPI and pull up for I²C on pin 10 (MODE). Figure 4-1 shows the two alternative mode connections. Figure 4-1 Host Interface Options Copyright © Bridgetek Pte Ltd 10 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Figure 4-2 illustrates a direct connection to a 1.8-3.3V IO MPU/MCU. 1.8-3.3V 3.3V Vio MPU/MCU 4.7k 4.7k VCC FT800 CS_N CS_N MISO MISO MOSI MOSI SCLK SCLK PD_N PD_N INT_N INT_N GND GND Figure 4-2 SPI Interface 1.8-3.3V connection Figure 4-3 illustrates the FT800 connected to a 5V IO MPU/MCU. The 74LCX125 logic buffer can tolerate 5V signal from the MPU/MCU, and the FT800 input signals are limited to 3.3V. 3.3V 5V 74LCx125 Vio MPU/MCU VCC FT800 CS_N CS_N MISO MISO MOSI MOSI SCLK SCLK PD_N PD_N INT_N INT_N GND 4.7K 3.3V GND 4.7K GND Figure 4-3 SPI Interface 5V connection Copyright © Bridgetek Pte Ltd 11 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 4.1.1 Clearance No.: BRT#001 SPI Interface The SPI slave interface operates up to 30MHz. Only SPI mode 0 is supported. Refer to section 6.4.2 for detailed timing specification. The SPI interface is selected when the MODE pin is tied to GND. 4.1.2 I²C Interface The I²C slave interface operates up to 3.4MHz, supporting standard-mode, fast-mode, fast-mode plus and high-speed mode. Refer to section 6.4.3for detailed timing specification. The I²C device address is configurable between 20h to 27h depending on the I²C_SA[2:0] pin setting, i.e. the 7-bit I2C slave address is 0b’0100A2A1A0. The I²C interface is selected when the MODE pin is tied to VCCIO. 4.1.3 Serial Data Protocol The FT800 appears to the host MPU/MCU as a memory-mapped SPI or I²C device. The host communicates with the FT800 using reads and writes to a large (4 megabyte) address space. Within this address space are dedicated areas for graphics, audio and touch control. Refer to section 5 for the detailed memory map. The host reads and writes the FT800 address space using SPI or I²C transactions. These transactions are memory read, memory write and command write. Serial data is sent by the most significant bit first. For I²C transactions, the same byte sequence is encapsulated in the I²C protocol. For SPI operation, each transaction starts with CS_N goes low, and ends when CS_N goes high. There’s no limit on data length within one transaction, as long as the memory address is continuous. 4.1.4 Host Memory Read For SPI memory read transaction, the host sends two zero bits, followed by the 22-bit address. This is followed by a dummy byte. After the dummy byte, the FT800 responds to each host byte with read data bytes. 7 6 0 0 5 4 3 2 1 0 Address [21:16] Address [15:8] Write Address Address [7:0] Dummy byte Byte 0 Read Data Byte n Table 4-1 Host memory read transaction (SPI) Copyright © Bridgetek Pte Ltd 12 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 For I2C memory read transaction, bytes are packed in the I2C protocol as follow: [start] [restart] .... [stop] 4.1.5 Host Memory Write For SPI memory write transaction, the host sends a ‘1’ bit and ‘0’ bit, followed by the 22-bit address. This is followed by the write data. 7 6 1 0 5 3 4 1 2 0 Address [21:16] Address [15:8] Address [7:0] Write Address Byte 0 Byte n Table 4-2 Host memory write transaction (SPI) For I2C, memory write transaction bytes are packed in the I2C protocol as follow:[start] .... [stop] 4.1.6 Write Data Host Command When sending a command, the host transmits a 3 byte command. Table 4-3 lists all the host command functions. Note: ACTIVE command is generated by dummy memory read from address 0 when FT800 is in sleep or standby mode. For SPI command transaction, the host sends a ‘0’ bit and ‘1’ bit, followed by the 6-bit command code. This is followed by 2 bytes 00h. 7 6 0 1 0 0 0 0 0 0 0 0 0 0 5 4 3 1 0 0 0 0 0 0 0 2 Command [5:0] Table 4-3 Host command transaction (SPI) Copyright © Bridgetek Pte Ltd 13 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 For I2C command transaction, bytes are packed in the I2C protocol as follows: [start] [stop] 2nd byte 3rd byte Command Description 00000000b 00000000b 00000000b 00h ACTIVE 01000001b 00000000b 00000000b 41h STANDBY 01000010b 00000000b 00000000b Switch from Standby/Sleep modes to active mode. Dummy read from address 0 generates ACTIVE command. Put FT800 core to standby mode. Clock gate off, PLL and Oscillator remain on (default). Put FT800 core to sleep mode. Clock gate off, PLL and Oscillator off. 01010000b 00000000b 00000000b 1st Byte Power Modes 42h SLEEP 50h PWRDOWN Switch off 1.2V internal regulator. Clock, PLL and Oscillator off. Clock Switching 01000100b 00000000b 00000000bN A 01100010b 00000000b 00000000bN A 01100001b 00000000b 00000000b 44h CLKEXT 62h CLK48M 61h CLK36M Enable PLL input from Crystal oscillator or external input clock. Switch PLL output clock to 48MHz (default). Switch PLL output clock to 36MHz. Miscellaneous 00000000b Send reset pulse to FT800 core. All registers and state machines will be reset. Table 4-4 Host Command Table Note: Any command code not specified is reserved and should not be used by the software 01101000b 4.1.7 00000000b 68h CORERST Interrupts The interrupt output pin is enabled by REG_INT_EN. When REG_INT_EN is 0, INT_N is tristate (pulled to high by external pull-up resistor). When REG_INT_EN is 1, INT_N is driven low when any of the interrupt flags in REG_INT_FLAGS are high, after masking with REG_INT_MASK. Writing a ‘1’ in any bit of REG_INT_MASK will enable the correspond interrupt. Each bit in REG_INT_FLAGS is set by a corresponding interrupt source. REG_INT_FLAGS is readable by the host at any time, and clears when read. When the FT800 is in sleep mode, a touch event detected on the touch-screen will drive the INT_N pin to low regardless the setting of REG_INT_EN and REG_INT_MASK. The MCU can use this signal to serve as a wakeup event. Bit Interrupt Sources Conditions Bit Interrupt Sources Conditions 7 CONVCOMPLETE Touch-screen conversions completed 3 SOUND Sound effect ended Table 4-5 Copyright © Bridgetek Pte Ltd 6 CMDFLAG Command FIFO flag 2 TAG Touch-screen tag value change Interrupt Flags bit 5 CMDEMPTY Command FIFO empty 1 TOUCH Touch-screen touch detected assignment 4 PLAYBACK Audio playback ended 0 SWAP Display list swap occurred 14 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 4.2 System Clock 4.2.1 Clock Source The FT800 can be configured to use any of the three clock sources for system clock:    Internal relaxation oscillator clock External 12MHz crystal External 12MHz square wave clock Figure 4-5 and Figure 4-6 shows the pin connections for these clock options. Commands CLKEXT and CLKINT switch between internal oscillator and external crystal oscillator and are synchronised to VSYNC on the fly. The external crystal oscillator is recommended for applications which require higher quality audio reproduction. Figure 4-4 Internal Relaxation Oscillator Connection Figure 4-5 Crystal oscillator connection Figure 4-6 External clock input Copyright © Bridgetek Pte Ltd 15 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 4.2.2 Clearance No.: BRT#001 Phase Locked Loop The internal PLL takes input from the crystal oscillator. The PLL outputs clock to all internal circuits, including graphics engine, audio engine and touch engine. 4.2.3 Clock Enable Upon power on the FT800 enters standby mode, the system clock will be enabled when following steps are executed: - Host sends an “ACTIVE” command (dummy read at address 0) If the application choose to use the external clock source (12MHz crystal or clock), the following steps shall be executed: - Host sends an “ACTIVE” command (dummy read at address 0) Host sends an “CLKEXT” command Host writes to REG_PCLK with non-zero value (i.e. 5) If SPI is used as host interface, the SPI clock shall not exceed 11MHz before system clock is enabled. After system clock is properly enabled, the SPI clock is allowed to go up to 30MHz. 4.2.4 Clock Frequency Upon power-on the internal relaxation oscillator is untrimmed. The frequency range could be quite wide from chip to chip (refer to table x-y for internal relaxation oscillator specifications). If the application utilises the internal clock without external clock source, it is recommended to perform clock trimming by software for better performance. For the details of clock trimming mechanism please refer to application note AN_299_FT800_FT801_Internal_Clock_Trimming. By default the system clock is 48MHz when the input clock is 12MHz. Host is allowed to switch the system clock between 48MHz and 36MHz by the host command “CLK48MHz” and “CLK36MHz” respectively. The clock switching is synchronised to VSYNC edge on the fly. This is to avoid possible graphics glitch during clock switching. As a result, the clock switch will only take effect if the REG_PCLK is a non-zero value. 4.3 Graphics Engine 4.3.1 Introduction The graphics engine executes the display list once for every horizontal line. It executes the primitive objects in the display list and constructs the display line buffer. The horizontal pixel content in the line buffer is updated if the object is visible at the horizontal line. Main features of the graphics engine are:        The primitive objects supported by the graphics processor are: lines, points, rectangles, bitmaps (comprehensive set of formats), text display, plotting bar graph, edge strips, and line strips, etc. Operations such as stencil test, alpha blending and masking are useful for creating a rich set of effects such as shadows, transitions, reveals, fades and wipes. Anti-aliasing of the primitive objects (except bitmaps) gives a smoothing effect to the viewer. Bitmap transformations enable operations such as translate, scale and rotate. Display pixels are plotted with 1/16th pixel precision. Four levels of graphics states Tag buffer detection The graphics engine also supports customized build-in widgets and functionalities such as jpeg decode, screen saver, calibration etc. The graphics engine interprets commands from the MPU host via a 4 Kbyte FIFO in FT800 memory at RAM_CMD. The MPU/MCU writes commands into the FIFO, and the graphics engine reads and executes the commands. The MPU/MCU updates register REG_CMD_WRITE to indicate Copyright © Bridgetek Pte Ltd 16 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 that there are new commands in the FIFO, and the graphics engine updates REG_CMD_READ after commands have been executed. Main features supported are:       Drawing of widgets such as buttons, clock, keys, gauges, text displays, progress bars, sliders, toggle switches, dials, gradients, etc. JPEG decode (Only baseline is supported) Inflate functionality (zlib inflate is supported) Timed interrupt (generate an interrupt to host processor after a specified number of milliseconds) In built animated functionalities such as displaying logo, calibration, spinner, screen saver and sketch Snapshot feature to capture the current graphics display For a complete list of graphics engine display commands and widgets refer to FT800 Series Programmers Guide, Chapter 4. 4.3.2 ROM and RAM Fonts The FT800 has built in ROM character bitmaps as font metrics. The graphics engine can use these metrics when drawing text fonts. There are total 16 ROM fonts, numbered with font handle 16-31. The user can define and load customized font metrics into RAM_G, which can be used by display command with handle 0-15. Each font metric block has a 148 byte font table which defines the parameters of the font and the pointer of font image. The font table format is shown in Table 4-6. Address Offset 0 128 132 136 140 144 Size(byte) Parameter Description 128 width of each font character, in pixels 4 font bitmap format, for example L1, L4 or L8 4 font line stride, in bytes 4 font width, in pixels 4 font height, in pixels 4 pointer to font image data in memory Table 4-6 Font table format The ROM fonts are stored in the memory space ROM_FONT. The ROM font table is also stored in the ROM. The starting address of ROM font table for font index 16 is stored at ROM_FONT_ADDR, with other font tables follow. The ROM font table and individual character width (in pixel) are listed in Table 4-7 through Table 4-9. Font index 16, 18 and 20-31 are for basic ASCII characters (code 0-127), while font index 17 and 19 are for Extended ASCII characters (code 128-255). The character width for font index 17 or 19 is fixed at 8 pixels for any of the Extended ASCII characters. 20 L1 2 10 13 21 L1 2 13 17 22 L1 2 14 20 23 L1 3 17 22 24 L1 3 24 29 25 L1 4 30 38 26 L4 6 12 16 Image pointer start address (hex) FFBFC FF7FC FEFFC FE7FC FDAFC FCD3C FBD7C FA17C F7E3C F3D1C F201C 27 L4 8 16 20 28 L4 9 18 25 29 L4 11 22 28 30 L4 14 28 36 31 L4 18 36 49 BB23C 19 L1 1 8 16 D2C3C 18 L1 1 8 16 E01BC 17 L1 1 8 8 E7F9C 16 L1 1 8 8 EDC1C Font Index Font format Line stride Font width Font height 29 - 30 - 31 - Table 4-7 ROM font table ASCII Character width in pixels Font Index => 0 NULL 1 SOH 2 STX 3 ETX 4 EOT 5 ENQ 16 - 18 - Copyright © Bridgetek Pte Ltd 20 - 21 - 22 - 23 - 24 - 25 - 26 - 27 - 28 - 17 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Font Index => 6 ACK 7 BEL 8 BS 9 HT 10 LF 11 VT 12 FF 13 CR 14 SO 15 SI 16 DLE 17 DC1 18 DC2 19 DC3 20 DC4 21 NAK 22 SYN 23 ETB 24 CAN 25 EM 26 SUB 27 ESC 28 FS 29 GS 30 RS 31 US 32 space 33 ! 34 " 35 # 36 $ 37 % 38 & 39 ' 40 ( 41 ) 42 * 43 + 44 , 45 46 . 47 / 48 0 49 1 50 2 51 3 52 4 53 5 54 6 55 7 56 8 57 9 58 : 59 ; 60 < 16 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 Copyright © Bridgetek Pte Ltd 20 3 3 4 6 6 9 8 2 4 4 4 6 3 4 3 3 6 6 6 6 6 6 6 6 6 6 3 3 6 21 4 4 5 8 8 12 10 3 5 5 7 9 3 4 3 4 8 8 8 8 8 8 8 8 8 8 3 4 8 22 5 5 6 9 9 14 11 3 6 6 6 10 4 5 4 5 9 9 9 9 9 9 9 9 9 9 4 4 10 23 5 6 5 10 10 16 13 3 6 6 7 10 5 6 5 5 10 10 10 10 10 10 10 10 10 10 5 5 10 24 6 6 8 14 13 22 17 6 8 8 10 14 6 8 6 7 13 13 13 13 13 13 13 13 13 13 6 6 15 25 9 9 12 19 18 29 22 6 11 11 13 19 9 11 9 9 18 18 18 18 18 18 18 18 18 18 9 9 19 26 3 4 5 9 8 10 9 3 5 5 6 8 3 6 4 6 8 8 8 8 8 8 8 8 8 8 4 4 7 27 4 4 6 11 10 12 11 4 6 6 7 10 4 8 5 7 10 10 10 10 10 10 10 10 10 10 4 4 9 Clearance No.: BRT#001 28 5 6 8 13 12 15 13 5 7 7 9 12 5 9 6 9 12 12 12 12 12 12 12 12 12 12 5 5 11 29 6 6 9 15 14 18 15 5 8 8 10 14 5 11 6 10 14 14 14 14 14 14 14 14 14 14 6 6 12 30 8 8 11 19 18 23 19 7 11 10 13 18 7 14 8 13 17 17 17 17 17 17 17 17 17 17 8 8 16 18 31 10 11 15 26 24 31 26 9 14 14 18 24 9 19 11 17 24 24 24 24 24 24 24 24 24 24 11 11 21 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Font Index => 61 = 62 > 63 ? 64 @ 65 A 66 B 67 C 68 D 69 E 70 F 71 G 72 H 73 I 74 J 75 K 76 L 77 M 78 N 79 O 80 P 81 Q 82 R 83 S 84 T 85 U 86 V 87 W 88 X 89 Y 90 Z 91 [ 92 \ 93 ] 94 ^ 95 _ 96 ` 97 a 98 b 99 c 100 d 101 e 102 f 103 g 104 h 105 i 106 j 107 k 108 l 109 m 110 n 111 o 112 p 113 q 114 r 115 s 16 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 Copyright © Bridgetek Pte Ltd 20 5 6 6 11 7 7 8 8 7 6 8 8 3 5 7 6 9 8 8 7 8 7 7 5 8 7 9 7 7 7 3 3 3 6 6 3 5 6 5 6 5 4 6 6 2 2 5 2 8 6 6 6 6 4 5 21 9 8 8 13 9 9 10 10 9 8 11 10 4 7 9 8 12 10 11 9 11 10 9 9 10 9 13 9 9 9 4 4 4 7 8 5 8 7 7 8 8 4 8 8 3 3 7 3 11 8 8 8 8 5 7 22 10 10 9 17 11 11 12 12 11 10 13 12 4 8 11 9 13 12 13 11 13 12 11 10 12 11 15 11 11 10 5 5 5 8 9 6 9 9 8 9 9 5 9 9 3 4 8 3 14 9 9 9 9 5 8 23 11 10 10 18 13 13 14 14 13 12 15 14 6 10 13 11 16 14 15 13 15 14 13 12 14 13 18 13 13 12 5 5 5 9 11 4 11 11 10 11 10 6 11 10 4 4 9 4 16 10 11 11 11 6 9 24 15 15 12 25 17 17 18 18 16 14 19 18 8 13 18 14 21 18 18 16 18 17 16 16 18 17 22 17 16 15 7 7 7 12 14 7 13 14 12 14 13 8 14 13 6 6 12 6 20 14 13 14 14 9 12 25 19 19 18 34 22 22 24 24 22 20 25 24 9 16 22 18 27 24 25 22 26 24 22 20 24 22 31 22 22 20 9 9 9 16 18 11 18 18 16 18 18 9 18 18 7 7 16 7 27 18 18 18 18 11 16 26 8 7 7 13 9 9 9 9 8 8 9 10 4 8 9 8 12 10 10 9 10 9 9 9 9 12 9 9 8 4 6 4 6 7 4 8 8 7 8 7 5 8 8 4 4 8 4 12 8 8 8 8 5 7 5 27 10 9 8 15 11 11 11 12 9 9 12 12 5 9 11 9 15 12 12 11 12 11 10 10 12 11 15 11 11 10 5 7 5 7 8 5 9 10 9 10 9 6 10 10 4 4 9 4 15 10 10 10 10 6 9 Clearance No.: BRT#001 28 12 11 10 19 13 13 13 14 12 12 14 15 6 12 14 12 18 15 14 13 15 13 13 13 14 14 18 13 13 13 6 9 6 9 10 7 12 12 11 12 11 8 12 12 5 5 11 5 18 12 12 12 12 7 11 29 14 13 11 21 15 15 15 16 13 13 16 17 7 13 15 13 21 17 16 15 17 15 15 14 16 15 21 15 15 14 7 10 6 10 11 8 13 14 13 14 13 9 14 14 6 6 13 6 21 14 14 14 14 8 13 30 17 16 15 28 20 20 20 21 17 17 21 22 9 17 20 17 27 22 21 20 22 20 19 19 21 20 27 20 20 19 8 13 8 13 15 10 17 18 16 18 16 11 18 18 8 8 16 8 27 18 18 18 18 11 16 19 31 24 22 20 38 27 27 27 28 23 23 28 30 12 23 27 23 36 30 29 27 29 27 26 25 28 27 36 27 27 25 11 18 11 18 20 13 23 24 22 24 22 15 24 24 11 11 22 11 37 24 24 24 24 15 22 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Font Index => 116 t 117 u 118 v 119 w 120 x 121 y 122 z 123 { 124 | 125 } 126 ~ 127 DEL Clearance No.: BRT#001 16 18 20 21 22 23 24 25 26 27 28 8 8 4 4 5 6 8 9 8 6 7 8 8 5 7 9 10 14 18 7 10 12 8 8 6 7 8 10 13 16 11 9 11 8 8 8 10 12 14 18 23 7 13 16 8 8 6 7 8 10 12 16 7 9 11 8 8 5 7 8 10 13 16 7 9 11 8 8 5 7 8 9 12 16 5 9 11 8 8 3 5 6 6 8 11 3 6 7 8 8 3 3 4 5 6 9 5 4 5 8 8 3 5 6 6 8 11 10 6 7 8 8 7 8 10 10 14 19 3 12 14 8 8 0 0 0 0 0 0 2 4 5 Table 4-8 ROM font ASCII character width in pixels 29 8 14 12 18 12 12 12 8 6 8 16 6 30 10 18 16 23 16 16 16 11 8 11 21 8 Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Ç 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 É 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 á 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 ░ 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 └ 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 ð 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 Ó 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 ü é â ä à å ç ê ë è ï î ì æ Æ ô ö ò û ù ÿ Ö Ü ø £ Ø í ó ú ñ Ñ ª º ¿ ® ¬ ½ ¼ ¡ ▒ ▓ │ ┤ Á Â À © ╣ ║ ╗ ╝ ¢ ┴ ┬ ├ ─ ┼ ã Ã ╚ ╔ ╩ ╦ ╠ ═ Ð Ê Ë È ı Í Î Ï ┘ ┌ █ ▄ ¦ ß Ô Ò õ Õ µ þ Þ Ú Û Ù ý Ý Symbol Decimal 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 31 13 24 21 32 21 21 21 14 10 14 29 10 ± ‗ ¾ ¶ § ÷ ¸ ° ¨ · ¹ ³ ² Ì ¯ ╬ ■ Å ƒ » ┐ ¤ ´ nbsp ▀ Table 4-9 ROM font Extended ASCII characters Note 1: Font 17 and 19 are extended ASCII characters, with width fixed at 8 pixels for all characters. Ä × « ¥ Note 2: All fonts included in the FT800 ROM are widely available to the market-place for general usage. See section nine for specific copyright data and links to the corresponding license agreements. 4.4 Parallel RGB Interface The RGB parallel interface consists of 23 signals - DISP, PCLK, VSYNC, HSYNC, DE, 6 signals each for R, G and B. Several registers configure the LCD operation of these signals as follow: REG_PCLK is the PCLK divisor the default is 0, and disables the PCLK output. PCLK frequency = System Clock frequency / REG_PCLK PCLK_POL define the clock polarity, =0 for positive active clock edge, and 1 for negative clock edge. REG_CSPREAD controls the transition of RGB signals with respect to PCLK active clock edge. When REG_CSPREAD=0, R[7:2], G[7:2] and B[7:2] signals change following the active edge of PCLK. When Copyright © Bridgetek Pte Ltd 20 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 REG_CSPREAD=1, R[7:2] changes a PCLK clock early and B[7:2] a PCLK clock later, which helps reduce the switching noise. REG_DITHER enables colour dither; the default is enabled. This option improves the half-tone appearance on displays. Internally, the graphics engine computes the colour values at an 8 bit precision; however, the LCD colour at a lower precision is sufficient. The FT800 output is only 6 bits per colour in 6:6:6 formats and a 2X2 dither matrix allow the truncated bits to contribute to the final colour values. REG_OUTBITS gives the bit width of each colour channel, the default is 6, 6, 6 bits for each RGB colour. A lower value means fewer bits are output for each channel allowing dithering on lower precision LCD displays. REG_SWIZZLE controls the arrangement of the output colour pins, to help the PCB route different LCD panel arrangements. Bit 0 of the register causes the order of bits in each colour channel to be reversed. Bits 1-3 control the RGB order. Setting Bit 1 causes R and B channels to be swapped. Setting Bit 3 allows rotation to be enabled. If Bit 3 is set, then (R,G,B) is rotated right if bit 2 is one, or left if bit 2 is zero. REG_SWIZZLE b3 b2 b1 b0 0 0 0 0 1 1 1 1 1 1 1 1 X X X X 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 PINS R7, R6, R5, G7, G6, G5, B7, B6, B5, B4, R4, R3, R2 G4, G3, G2 B3, B2 R[7:2] G[7:2] B[7:2] Power on Default R[2:7] G[2:7] B[2:7] B[7:2] G[7:2] R[7:2] B[2:7] G[2:7] R[2:7] G[7:2] B[7:2] R[7:2] G[2:7] B[2:7] R[2:7] G[7:2] R[7:2] B[7:2] G[2:7] R[2:7] B[2:7] B[7:2] R[7:2] G[7:2] B[2:7] R[2:7] G[2:7] R[7:2] B[7:2] G[7:2] R[2:7] B[2:7] G[2:7] Table 4-10 REG_SWIZZLE RGB Pins Mapping 4.5 Miscellaneous Control 4.5.1 Backlight Control Pin The backlight control pin is a pulse width modulated (PWM) signal controlled by two registers: REG_PWM_HZ and REG_PWM_DUTY. REG_PWM_HZ specifies the PWM output frequency, the range is 250-10000 Hz. REG_PWM_DUTY specifies the duty cycle; the range is 0-128. A value of 0 means that the PWM is completely off and 128 means completely on. 4.5.2 DISP Control Pin The DISP pin is a general purpose output that can be used to enable or as a reset control to LCD display panel. The pin is controlled by writing to Bit 7 of REG_GPIO register. 4.5.3 General Purpose IO pins The GPIO1 and GPIO0 pins are default inputs. Write '1' to Bit 1 and 0 of REG_GPIO_DIR to change to output pins respectively. In I²C mode the GPIO0 is used as SA2 and is not available as GPIO. GPIO1 and GPIO0 are read from or write to bit 1 and 0 of REG_GPIO register. GPIO1 is recommended to be used as shutdown control for audio power amplifier. Copyright © Bridgetek Pte Ltd 21 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 4.5.4 Clearance No.: BRT#001 Pins Drive Current Control The output drive current of output pins can be changed as per the following table by writing to bit[6:2] of REG_GPIO register: REG_GPIO Value Drive Current Pins 00b# 4mA Bit[6:5] 01b 10b 8mA 12mA 11b 16mA GPIO1 GPIO0 Bit[4] 0b# 1b 4mA 8mA 00b# 4mA Bit[3:2] 01b 10b 8mA 12mA PCLK DISP VSYNC HSYNC DE R7..R2 G7..G2 B7..B2 BACKLIGHT 11b 16mA MISO INT_N Table 4-11 Output drive current selection Note: #Default value 4.6 Audio Engine FT800 provides mono audio output through a PWM output pin, AUDIO_L. It outputs the two audio sources, the sound synthesizer and audio file playback. 4.6.1 Sound Synthesizer A sound processor, AUDIO ENGINE, generates the sound effects from a small ROM library of waves table. To play a sound effect listed in Table 4.3, load the REG_SOUND register with a code value and write 1 to the REG_PLAY register. The REG_PLAY register reads 1 while the effect is playing and returns a ‘0’ when the effects end. Some sound effects play continuously until it is interrupted or commanded to play the next sound effect. To interrupt an effect, write a new value to REG_SOUND and REG_PLAY registers; e.g. write 0 (Silence) to REG_SOUND and 1 to PEG_PLAY to stop the sound effect. The sound volume is controlled by register REG_VOL_SOUND. The 16-bit REG_SOUND register takes an 8-bit sound in the low byte. For some sounds, marked "pitch adjust" in the table below, the high 8 bits contain a MIDI note value. For these sounds, note value of zero indicates middle C. For other sounds the high byte of REG_SOUND is ignored. Value Pitch adjust Effect Value Pitch adjust Effect 00h 01h N Y Silence square wave 32h 33h N N DTMF 2 DTMF 3 02h 03h Y Y sine wave sawtooth wave 34h 35h N N DTMF 4 DTMF 5 04h 05h Y Y triangle wave Beeping 36h 37h N N DTMF 6 DTMF 7 06h 07h Y Y Alarm Warble 38h 39h N N DTMF 8 DTMF 9 08h 10h Y Y Carousel 1 short pip 40h 41h Y Y harp xylophone Copyright © Bridgetek Pte Ltd 22 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 11h Y 2 short pips 42h Y tuba 12h 13h Y Y 3 short pips 4 short pips 43h 44h Y Y glockenspiel organ 14h Y 5 short pips 45h Y trumpet 15h 16h Y Y 6 short pips 7 short pips 46h 47h Y Y piano chimes 17h 18h Y Y 8 short pips 9 short pips 48h 49h music box bell 19h 1Ah Y Y 10 short pips 11 short pips 50h 51h Y Y N N 1Bh 1Ch Y Y 12 short pips 13 short pips 52h 53h N N cowbell notch 1Dh 1Eh Y Y 14 short pips 15 short pips 54h 55h N N hihat kickdrum 1Fh Y 16 short pips 56h pop 23h N DTMF # 57h N N clack 58h 60h N N chack mute N unmute 2Ch 30h N N DTMF * DTMF 0 31h N DTMF 1 61h Table 4-12 Sound Effect MIDI note 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 ANSI note A0 A#0 B0 C1 C#1 D1 D#1 E1 F1 F#1 G1 G#1 A1 A#1 B1 C2 C#2 D2 D#2 E2 F2 F#2 G2 G#2 A2 A#2 B2 C3 C#3 Copyright © Bridgetek Pte Ltd Freq (Hz) 27.5 29.1 30.9 32.7 34.6 36.7 38.9 41.2 43.7 46.2 49.0 51.9 55.0 58.3 61.7 65.4 69.3 73.4 77.8 82.4 87.3 92.5 98.0 103.8 110.0 116.5 123.5 130.8 138.6 MIDI note 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 ANSI note F4 F#4 G4 G#4 A4 A#4 B4 C5 C#5 D5 D#5 E5 F5 F#5 G5 G#5 A5 A#5 B5 C6 C#6 D6 D#6 E6 F6 F#6 G6 G#6 A6 click switch Freq (Hz) 349.2 370.0 392.0 415.3 440.0 466.2 493.9 523.3 554.4 587.3 622.3 659.3 698.5 740.0 784.0 830.6 880.0 932.3 987.8 1046.5 1108.7 1174.7 1244.5 1318.5 1396.9 1480.0 1568.0 1661.2 1760.0 23 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 4.6.2 D3 D#3 E3 F3 F#3 G3 G#3 A3 A#3 B3 C4 C#4 D4 D#4 E4 146.8 94 A#6 155.6 95 B6 164.8 96 C7 174.6 97 C#7 185.0 98 D7 196.0 99 D#7 207.7 100 E7 220.0 101 F7 233.1 102 F#7 246.9 103 G7 261.6 104 G#7 277.2 105 A7 293.7 106 A#7 311.1 107 B7 329.6 108 C8 Table 4-13 MIDI Note Effect Clearance No.: BRT#001 1864.7 1975.5 2093.0 2217.5 2349.3 2489.0 2637.0 2793.8 2960.0 3136.0 3322.4 3520.0 3729.3 3951.1 4186.0 Audio Playback The FT800 can play back recorded sound through its audio output. To do this, load the original sound data into the FT800’s RAM, and set registers to start the playback. The registers controlling audio playback are: REG_PLAYBACK_START: the start address of the audio data REG_PLAYBACK_LENGTH: the length of the audio data, in bytes REG_PLAYBACK_FREQ: the playback sampling frequency, in Hz REG_PLAYBACK_FORMAT: the playback format, one of LINEAR SAMPLES, uLAW SAMPLES, or ADPCM SAMPLES REG_PLAYBACK_LOOP: if zero, sample is played once. If one, sample is repeated indefinitely REG_PLAYBACK_PLAY: a write to this location triggers the start of audio playback, regardless of writing ‘0’ or ‘1’. Read back ‘1’ when playback is ongoing, and ‘0’ when playback finishes REG_VOL_PB: playback volume, 0-255 The mono audio format supported is 8-bits PCM, 8-bits uLAW and 4-bits IMA-ADPCM. For ADPCM_SAMPLES, each sample is 4 bits, so two samples are packed per byte, first sample is in bits 0-3 and the second is in bits 4-7. The current audio playback read pointer can be queried by reading the REG_PLAYBACK_READPTR. Using a large sample buffer, looping, and this read pointer, the host MPU/MCU can supply a continuous stream of audio. 4.7 Touch-Screen Engine The touch-screen consists of touch screen engine, ADC, Axis-switches, and ADC input multiplexer. The touch screen engine reads commands from the memory map register and generates the required control signals to the axis-switches and inputs mux and ADC. The ADC data are acquired and processed and update in the respective register for the MPU/MCU to read. Copyright © Bridgetek Pte Ltd 24 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Y+ FT800 X+ Y+ XY- X- LCD Touch Screen X+ Y- Figure 4-7 Touch screen connection The host controls the TOUCH SCREEN ENGINE operation mode by writing the REG_TOUCH_MODE. REG_TOUCH_MODE 0 1 Mode OFF ONE-SHOT Description Acquisition stopped, only touch detection interrupt is still valid. Perform acquisition once every time MPU write '1' to REG_TOUCH_MODE. 2 FRAME-SYNC Perform acquisition for every frame sync (~60 data acquisition/second. 3 CONTINUOUS Perform acquisition continuously at approximately 1000 data acquisition / second. Table 4-14 Touch Controller Operating Mode The Touch Screen Engine captures the raw X and Y coordinate and writes to register REG_TOUCH_RAW XY. The range of these values is 0-1023. If the touch screen is not being pressed, both registers read 65535 (FFFFh). These touch values are transformed into screen coordinates using the matrix in registers REG_TOUCH_TRANSFORM_A-F. The post-transform coordinates are available in register REG_TOUCH_SCREEN_XY. If the touch screen is not being pressed, both registers read -32768 (8000h). The values for REG TOUCH TRANSFORM A-F may be computed using an on-screen calibration process. If the screen is being touched, the screen coordinates are looked up in the screen's tag buffer, delivering a final 8-bit tag value, in REG TOUCH TAG. Because the tag lookup takes a full frame, and touch coordinates change continuously, the original (x; y) used for the tag lookup is also available in REG_TOUCH_TAG_XY. Screen touch pressure is available in REG_TOUCH_RZ. The value is relative to the resistance of the touch contact, a lower value indicates more pressure. The register defaults to 32767 when touch is not detected. The REG_TOUCH_THRESHOLD can be set to accept a touch only when the force threshold is exceeded. Copyright © Bridgetek Pte Ltd 25 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 4.8 Power Management 4.8.1 Power supply The FT800 may be operated with a single supply of 3.3V apply to VCC and VCCIO pins. For operation with host MPU/MCU at lower supply, connect the VCCIO to MPU power to match the interface power. Symbol VCCIO Typical 1.8V, or 2.5V, or 3.3V VCC 3.3V 4.8.2 Description Supply for Host interface digital I/O pad only, LCD RGB interface supply from VCC. Supply for chip Table 4-15 Power supply Internal Regulator and POR The 1.2V internal regulator provides power to the core circuit. The regulator is disabled when device is in POWERDOWN state. Power down is activated either by the SCU command write or by holding down the PD_N pin for at least 5mS to allow the 1.2V decoupling capacitor to discharge fully. The regulator is enabled only by releasing the PD_N pin. A 47kΩ resistor is recommended to pull the PD_N pin up to VCCIO, together with a 100nF capacitor to ground in order to delay the 1.2V regulator powering up after the VCC and VCCIO are stable. The 1.2V internal regulator requires a compensation capacitor to be stable. A typical design puts a 4.7uF capacitor with ESR >0.5Ω is required between VCC1V2 to GND pins. Do not connect any load to this pin. The 1.2V regulator will generate Power-On-Reset (POR) pulse when the output voltage rises above the POR threshold. The POR will reset all the core digital circuits. It is possible to use PD_N pin as an asynchronous hardware reset input. Drive PD_N low for at least 5ms and then drive it high will reset the FT800 chip. VCC R VCC 47k Cin C 10uF 100nF GND 1.2V VCC1V2 Ccomp FT800 4.7uF GND GND PD_N GND VCCIO GND Figure 4-8 1.2V regulator Copyright © Bridgetek Pte Ltd 26 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 4.8.3 Clearance No.: BRT#001 Power Modes When supply to VCCIO and VCC is applied, internal 1.2V regulator is powered by VCC. An internal POR pulse will be generated during the regulator power up until it is stable. After the initial power up, the FT800 will stay in STANDBY state. When needed, host can set FT800 to ACTIVE state by performing a dummy read to address 0. The graphics engine, the audio engine and the touch engine are only functional in ACTIVE state. To save power host can send command to put FT800 into any of the low power mode: STANDBY, SLEEP and POWERDOWN. In addition, host is allowed to put FT800 in POWERDOWN mode by drive PD_N pin to low, regardless what current state it is in. Refer to Figure 4-9 Power State Transition for the power state transitions. Toggle PD_N from high to low VCC/VCCIO Power ON Toggle PD_N from low to high POWERDOWN STANDBY Dummy Read “0” Write command “POWERDOWN” Toggle PD_N from high to low or Toggle PD_N from high to low Write command “STANDBY” Dummy Read “0” SLEEP ACTIVE Write command “SLEEP” Figure 4-9 Power State Transition 4.8.3.1 ACTIVE state In ACTIVE state, the FT800 is in normal operation. The crystal oscillator and PLL are functioning. The system clock applied to the FT800 core engines is enabled. 4.8.3.2 STANDBY state In STANDBY state, the crystal oscillator and PLL remain functioning; the system clock applied to the FT800 core engines is disabled. All register contents are retained. 4.8.3.3 SLEEP state In SLEEP state, the crystal oscillator, PLL and system clock applied to the FT800 core engines are disabled. All register contents are retained. 4.8.3.4 POWERDOWN state In POWERDOWN state, the internal 1.2V regulator supplying the core digital logic, the crystal oscillator, the PLL and the system clock applied to the FT800 core is disabled. All register contents are lost and reset to default when the chip is next switched on. Copyright © Bridgetek Pte Ltd 27 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 4.8.3.5 Wake up to ACTIVE from other power states Wake up from POWERDOWN state requires the host to pull the PD_N pin down and release, a low to high transition enables the 1.2V regulator. POR generated when 1.2V is stable and FT800 will switch to STANDBY mode after internal oscillator and PLL are up (maximum 20ms from PD_N rising edge). The clock enable sequence mentioned in section 4.2.3 shall be executed to proper enable the system clock. From SLEEP state, host MPU reads at memory address 0 to wake the FT800 into ACTIVE state. Host needs to wait for at least 20ms before accessing any registers or commands. This is to guarantee the crystal oscillator and PLL are up and stable. From STANDBY state, host MPU reads at memory address 0 to wake the FT800 into ACTIVE state. Host can immediately access any register or command. 4.8.3.6 Pin Status at Different Power States The FT800 pin status depends on the power state of the chip. See the following table for more details. At power transition from ACTIVE to STANDBY or ACTIVE to SLEEP, all pins retains their previous status. The software needs to set AUDIO_L, BACKLIGHT and PCLK to a known state before issuing power transition commands. Pin Reset State Reset State Active/Sta Power down Hybrid Mode Name (VCC / VCCIO (VCC / VCCIO ON) ndby/Sleep state (VCC (VCC OFF / ON) Default Output Drive state (VCC ON / VCC1.2 VCCIO ON) Strength / VCCIO OFF) ON) AUDIO_L Tristate Output 16mA Output Retain (hi-Z) previous state SPI_SCL Input (floating) Input Input (floating) K/I2C_S CL MISO/I2 Tristate Output 4mA Input/output Tristate Output C_SDA (hi-Z) (hi-Z) MOSI/I2 Input (floating) Input Input (floating) C_SA0 CS_N/I2 Input (floating) Input Input (floating) C_SA1 GPIO0/I2 Input (floating) Input/output Tristate Output C_SA2 (hi-Z) GPIO1 Tristate Output 4mA Input/output Tristate Output (hi-Z) (hi-Z) MODE Input Input Input (floating) INT_N Open Drain 4mA Open Drain Tristate Output Output (hi-Z) Output (hi-Z) PD_N Input Input Input (floating) X1/CLK Input (floating) Crystal Note: If Oscillator applicable, Input CLK external clock Input on X1/CLK pin should be removed X2 Output (hi-Z) Crystal Oscillator Output X+ Tristate Output Input/output Retain (hi-Z) Previous State Y+ Tristate Output Input/output Retain (hi-Z) Previous State XTristate Output Input/output Retain (hi-Z) Previous State YTristate Output Input/output Retain (hi-Z) Previous State BACKLIG Output 4mA Output Retain Copyright © Bridgetek Pte Ltd 28 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Pin Name HT DE VSYNC HSYNC DISP PCLK R(7:2), G(7:2), B(7:2) Reset State (VCC / VCCIO ON) Reset State (VCC / VCCIO ON) Default Output Drive Strength Active/Sta ndby/Sleep state (VCC / VCCIO ON) Output Output Output Output Output Output 4mA 4mA 4mA 4mA 4mA 4mA Output Output Output Output Output Output Clearance No.: BRT#001 Power down state (VCC ON / VCC1.2 OFF) Hybrid Mode (VCC OFF / VCCIO ON) Previous State Output Low Output Low Output Low Output Low Output Low Output Low Table 4-16 Pin Status Copyright © Bridgetek Pte Ltd 29 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 5 FT800 Memory Map All memory and registers in the FT800 core are memory mapped in 22-bits address space with 2-bits SPI/I2C command prefix. Prefix 0'b00 for read and 0'b10 for write to the address space, 0'b01 reserved for Host Commands and 0'b11 undefined. The following are the memory space defined. Start Address 00 0000h 0C 0000h End Address 03 FFFFh 0C 0003h Size 256 kB 4B NAME Description RAM_G ROM_CHIPID Main graphics RAM FT800 chip identification and revision information: Byte [0:1] Chip ID: “0800” Byte [2:3] Version ID: “0100” 0B B23Ch 0F FFFBh 275 kB ROM_FONT Font table and bitmap 0F FFFCh 0F FFFFh 4B ROM_FONT_ADDR Font table pointer address 10 0000h 10 1FFFh 8 kB RAM_DL Display List RAM 10 2000h 10 23FFh 1 kB RAM_PAL Palette RAM 10 2400h 10 257Fh 380 B REG_* Registers 10 8000 h 10 8FFFh 4 kB RAM_CMD Command buffer 1C 2000 h 1C 27FFh 2 kB RAM_SCREENSHOT Screenshot readout buffer Table 5-1 FT800 Memory Map Note 1: The addresses beyond this table are reserved and shall not be read or written unless otherwise specified. Note 2: The ROM_CHIPID utilizes a part of shadow address from ROM_FONT address space. 5.1 FT800 Registers Table 5.1 shows the complete list of the FT800 registers. Refer to FT800 Series Programmers Guide , Chapter 2 for details of the register function. Address 102400h Register Name REG_ID Bits Access 8 r/o Reset value 7Ch 102404h REG_FRAMES 32 r/o 102408h REG_CLOCK 32 r/o 10240Ch REG_FREQUENCY 27 r/w 102410h REG_RENDERMODE 1 r/w 000000 00h 000000 00h 02DC6C 00h 00h 102414h 102418h 10241Ch REG_SNAPY REG_SNAPSHOT REG_CPURESET 9 1 1 r/w r/o r/w 00h 00h 102420h REG_TAP_CRC 32 r/o - 102424h REG_TAP_MASK 32 r/w 102428h 10242Ch 102430h 102434h 102438h 10243Ch 102440h 102444h 102448h REG_HCYCLE REG_HOFFSET REG_HSIZE REG_HSYNC0 REG_HSYNC1 REG_VCYCLE REG_VOFFSET REG_VSIZE REG_VSYNC0 10 10 10 10 10 10 10 10 10 r/w r/w r/w r/w r/w r/w r/w r/w r/w FFFFFFF Fh 224h 02Bh 1E0h 000h 029h 124h 00Ch 110h 000h Copyright © Bridgetek Pte Ltd Description Identification register, always reads as 7Ch Frame counter, since reset Clock cycles, since reset Main clock frequency Rendering mode: 0 = normal, 1 = single-line Scan line select for RENDERMODE 1 trigger for RENDERMODE 1 Graphics, audio and touch engines reset control Live video tape crc. Frame CRC is computed every DL SWAP. Live video tape mask Horizontal total cycle count Horizontal display start offset Horizontal display pixel count Horizontal sync fall offset Horizontal sync rise offset Vertical total cycle count Vertical display start offset Vertical display line count Vertical sync fall offset 30 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Address Register Name 10244Ch 102450h 102454h 102458h 10245Ch 102460h 102464h 102468h REG_VSYNC1 REG_DLSWAP REG_ROTATE REG_OUTBITS REG_DITHER REG_SWIZZLE REG_CSPREAD REG_PCLK_POL 10 2 1 9 1 4 1 1 r/w r/w r/w r/w r/w r/w r/w r/w Reset value 00Ah 00h 00h 1B6h 1 00h 1 0 10246Ch 102470h 102474h 102478h 10247Ch 102480h 102484h 102488h 10248Ch REG_PCLK REG_TAG_X REG_TAG_Y REG_TAG REG_VOL_PB REG_VOL_SOUND REG_SOUND REG_PLAY REG_GPIO_DIR 8 9 9 8 8 8 16 1 8 r/w r/w r/w r/o r/w r/w r/w r/w r/w 00h 000h 000h 00h FFh FFh 0000h 0h 80h 102490h REG_GPIO 8 r/w 00h 102494h 102498h 10249Ch 1024A0h 1024A4h 1024A8h Reserved REG_INT_FLAGS REG_INT_EN REG_INT_MASK REG_PLAYBACK_START REG_PLAYBACK_LENGT H REG_PLAYBACK_READPT R REG_PLAYBACK_FREQ 8 1 8 20 20 r/o r/w r/w r/w r/w 00h 0h FFh 00000h 00000h 20 r/o - 16 r/w 1F40h 2 r/w 0h 1 1 14 r/w r/o r/w 0h 0h 00FAh 8 r/w 80h 000000 00h 000000 00h - 1024ACh 1024B0h 1024B4h Bits Access 1024B8h 1024BCh 1024C0h REG_PLAYBACK_FORMA T REG_PLAYBACK_LOOP REG_PLAYBACK_PLAY REG_PWM_HZ 1024C4h REG_PWM_DUTY 1024C8h REG_MACRO_0 32 r/w 1024CCh REG_MACRO_1 32 r/w 1024D0h – 1024E0h 1024E4h 1024E8h 1024ECh 1024F0h 1024F4h Reserved - - 1024F8h REG_CMD_READ REG_CMD_WRITE REG_CMD_DL REG_TOUCH_MODE REG_TOUCH_ADC_MOD E REG_TOUCH_CHARGE 1024FCh REG_TOUCH_SETTLE 4 r/w 3h 102500h REG_TOUCH_OVERSAMP 4 r/w 7h Copyright © Bridgetek Pte Ltd 12 12 13 2 1 r/w r/w r/w r/w r/w 000h 000h 0000h 3h 1h 16 r/w 1770h Clearance No.: BRT#001 Description Vertical sync rise offset Display list swap control Screen 180 degree rotate Output bit resolution, 3x3x3 bits Output dither enable Output RGB signal swizzle Output clock spreading enable PCLK polarity: 0 = output on PCLK rising edge, 1 = output on PCLK falling edge PCLK frequency divider, 0 = disable Tag query X coordinate Tag query Y coordinate Tag query result Volume for playback Volume for synthesizer sound Sound effect select Start effect playback GPIO pin direction, 0 = input , 1 = output GPIO pin value (bit 0,1,7); output pin drive strength(bit 2-6) Reserved Interrupt flags, clear by read Global interrupt enable Interrupt enable mask Audio playback RAM start address Audio playback sample length (bytes) Audio playback current read pointer Audio playback sampling frequency (Hz) Audio playback format Audio playback loop enable Start audio playback BACKLIGHT PWM output frequency (Hz) BACKLIGHT PWM output duty cycle 0=0%, 128=100% Display list macro command 0 Display list macro command 1 Reserved Command buffer read pointer Command buffer write pointer Command display list offset Touch-screen sampling mode Select single ended (low power) or differential (accurate) sampling Touch-screen charge time, units of 6 clocks Touch-screen settle time, units of 6 clocks Touch-screen oversample factor 31 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Address 102504h 102508h 10250Ch 102510h 102514h 102518h 10251Ch 102520h 102524h 102528h 10252Ch 102530h 102534h – 102470h 102574h 102578h 109000h Register Name Bits LE REG_TOUCH_ RZTHRESH REG_TOUCH_ RAW_XY REG_TOUCH_RZ REG_TOUCH_ SCREEN_XY REG_TOUCH_ TAG_XY REG_TOUCH_TAG REG_TOUCH_TRANSFOR M_A REG_TOUCH_TRANSFOR M_B REG_TOUCH_TRANSFOR M_C REG_TOUCH_TRANSFOR M_D REG_TOUCH_TRANSFOR M_E REG_TOUCH_TRANSFOR M_F Reserved REG_TOUCH_DIRECT_X Y REG_TOUCH_DIRECT_Z 1Z2 REG_TRACKER Access Reset value Clearance No.: BRT#001 Description 16 r/w FFFFh 32 r/o - Touch-screen raw (x-MSB16; y-LSB16) 16 32 r/o r/o - 32 r/o - 8 32 r/o r/w 32 r/w 32 r/w 32 r/w 32 r/w 32 r/w 000100 00h 000000 00h 000000 00h 000000 00h 000100 00h 000000 00h - Touch-screen resistance Touch-screen screen (x-MSB16; yLSB16) Touch-screen screen (x-MSB16; yLSB16) used for tag lookup Touch-screen tag result Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Reserved 32 r/o Touch-screen resistance threshold - Touch screen direct (x-MSB16; yLSB16) conversions 32 r/o - Touch screen direct (z1-MSB16; z2LSB16) conversions 32 r/w 000000 Track register (Track value – MSB16; 00h Tag value - LSB8) Table 5-2 Overview of FT800 Registers Note: All register addresses are 4-byte aligned. The value in “Bits” column refers to the number of valid bits from bit 0 unless otherwise specified; other bits are reserved. Copyright © Bridgetek Pte Ltd 32 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 6 Devices Characteristics and Ratings 6.1 Absolute Maximum Ratings The absolute maximum ratings for the FT800 device are as follows. These are in accordance with the Absolute Maximum Rating System (IEC 60134). Exceeding these may cause permanent damage to the device. Parameter Value Unit Storage Temperature Floor Life (Out of Bag) At Factory Ambient (30°C / 60% Relative Humidity) -65 to +150 168 (IPC/JEDEC J-STD-033A MSL Level 3 Compliant)* Ambient Temperature (Power Applied) -40 to +85 VCC Supply Voltage 0 to +4 VCCIO Supply Voltage 0 to +4 DC Input Voltage -0.5 to + (VCCIO + 0.3) Table 6-1 Absolute Maximum Ratings °C Hours °C V V V * If the devices are stored out of the packaging, beyond this time limit, the devices should be baked before use. The devices should be ramped up to a temperature of +125°C and baked for up to 17 hours. 6.2 DC Characteristics (Ambient Temperature = -40°C to +85°C) Parameter Description Minimum Typical Maximum VCCIO VCCIO operating 1.62 1.80 1.98 supply voltage 2.25 2.50 2.75 2.97 3.30 3.63 VCC VCC operating supply 2.97 3.30 3.63 voltage Icc1 Power Down current 1.0 Icc2 Sleep current 250 Icc3 Standby current 1.5 Icc4 Operating current 24 VCC1V2 Regulator Output 1.20 voltage Table 6-2 Operating Voltage and Current Parameter Voh Vol Vih Vil Vth Iin Ioz Description Minimum Typical Maximum Units V V V V Conditions Normal Operation µA µA mA mA V Power down mode Sleep Mode Standby Mode Normal Operation Normal Operation Units Normal Operation Conditions Output Voltage High 2.4 V Ioh=4mA Output Voltage Low 0.4 V Iol=4mA Input High Voltage 2.0 V Input Low Voltage 0.8 V Schmitt Hysteresis 0.3 0.45 0.5 V Voltage Input leakage -10 10 uA Vin = VCCIO or 0 current Tristate output -10 10 uA Vin = VCCIO or 0 leakage current Table 6-3 Digital I/O Pin Characteristics (VCC/VCCIO = +3.3V, Standard Drive Level) Copyright © Bridgetek Pte Ltd 33 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Parameter Description Minimum Voh Vol Vih Output Voltage High Output Voltage Low Input High Voltage Vil Input Low Voltage VCCIO-0.4 0.7 X VCCIO - Vth Iin Ioz Typical Maximum Clearance No.: BRT#001 Units Conditions - 0.4 - V V V Ioh=4mA Iol=4mA - - 0.3 X VCCIO 0.5 V - Schmitt Hysteresis 0.28 0.39 V Voltage Input leakage -10 10 uA Vin = VCCIO or 0 current Tristate output -10 10 uA Vin = VCCIO or 0 leakage current Table 6-4 Digital I/O Pin Characteristics (VCCIO = +2.5V, Standard Drive Level) Parameter Description Minimum Typical Maximum Units Conditions Voh Vol Vih Output Voltage High Output Voltage Low Input High Voltage - 0.4 - V V V Ioh=4mA Iol=4mA - Vil Input Low Voltage VCCIO-0.4 0.7 X VCCIO - - 0.3 X VCCIO 0.5 V - Vth Iin Ioz Schmitt Hysteresis 0.25 0.35 V Voltage Input leakage -10 10 uA Vin = VCCIO or 0 current Tristate output -10 10 uA Vin = VCCIO or 0 leakage current Table 6-5 Digital I/O Pin Characteristics (VCCIO = +1.8V, Standard Drive Level) 6.3 Touch Sense Characteristics Parameter Rsw-on Rsw-off Rpu Vth+ VthVhys Rl Description Minimum Typical X-,X+,Y- and Y+ Drive On resistance X-,X+,Y- and Y+ 10M Drive Off resistance Touch sense pull up 72k resistance Touch Detection 1.53 rising-edge threshold level Touch Detection 1.17 falling-edge threshold level Touch Detection 0.36 Hysteresis X-axis and Y-axis 200 drive load resistance Table 6-6 Touch Sense Description ADC Resolution Integral Nonlinearity Differential Nonlinearity Offset Error Minimum Maximum Units 5 10 Ω - - Ω 100k 128k Ω 1.7 1.87 V 1.3 -1.47 V 0.39 0.4 V - - Ω Conditions Characteristics (VCC=3.3V) Typical Maximum Units Conditions 10 bits +/-1 LSB +/-0.5 LSB +/-2 LSB Table 6-7 ADC Characteristics (VCC=3.3V) Copyright © Bridgetek Pte Ltd 34 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 6.4 AC Characteristics 6.4.1 System clock Parameter Value Typical Minimum Unit Maximum Crystal Frequency 12.000 MHz X1/X2 5 10 pF Capacitance External clock input Frequency 12.000 MHz Duty cycle 45 50 55 % Input voltage on 3.3 Vp-p X1/CLKIN Table 6-8 System clock characteristics (Ambient Temperature = -40°C to +85°C) 6.4.2 Host Interface SPI Mode 0 Figure 6-1 SPI Interface Timing Parameter Fsclk Tsclk Tsclkl Tsclkh Tsac Tisu Tih Tzo Toz Description SPI Clock frequency SPI clock period SPI clock low duration SPI clock high duration SPI access time Input Setup Input Hold Output enable delay Output disable delay Copyright © Bridgetek Pte Ltd VCC(I/O)=1.8 VCC(I/O)=2.5 VCC(I/O)=3.3 V V V Unit Min Max Min Max Min Max 0 25 0 30 0 30 Mhz 40 16 - 33 13 - 33 13 - ns ns 16 - 13 - 13 - ns 10 5 10 5 10 10 5 10 5 10 10 5 10 5 10 ns ns ns ns 5 10 5 10 5 10 ns 35 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Tosu Tod Tcsnh 6.4.3 Output setup time Tsclkl-5 Tsclkl-5 Tsclkl-5 Output data delay 5 10 5 10 5 CSN hold time 15 15 15 Table 6-9 SPI Interface Timing Specification Parameter Tscll Tsclh Tsu Thd Tr Tf 6.4.4 Description I2C SCL clock frequency clock low period clock high period Data setup time Data hold time Rise time Fall time Fast-mode mode Fast-plus High speed mode mode Th Tvsu Tvhd Thsu Thhd Tdsu Tdhd Tesu Tehd Unit Min Max Min Max Min Max Min Max 0 100 0 400 0 1000 0 3400 kHz 4.7 4.0 - 1.3 0.6 - 0.5 0.26 - 0.16 0.06 - µs µs 120 120 10 0 10 10 70 40 40 ns ns ns ns 250 100 50 0 0 0 1000 300 300 300 Table 6-10 I2C Interface Timing Description VCC=3.3V Min Tvwh ns ns ns RGB Video Timing Parameter Tpclk Tpclkdc Thc Thwh 10 - Host Interface I2C Mode Timing Standard- Fscl Clearance No.: BRT#001 Typ Pixel Clock period 78 104 Pixel Clock duty cycle 40 Hsync to Clock 30 HSYNC width 1 41 (REG_HSYNC1-REG_HSYNC0) VSYNC width 1 10 (REG_VSYNC1-REG_VSYNC0) HSYNC Cycle 525 (REG_HCYCLE) VSYNC setup 30 VSYNC hold 10 HSYNC setup 30 HSYNC hold 10 DATA setup 20 DATA hold 10 DE setup 30 DE hold 10 Table 6-11 RGB Video timing characteristics Copyright © Bridgetek Pte Ltd Unit Max 60 - ns % ns Tpclk - Th - Tpclk - ns ns ns ns ns ns ns ns 36 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Figure 6-2 RGB Video Signal Timing Copyright © Bridgetek Pte Ltd 37 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 7 Application Examples 7.1 Examples of LCD Interface connection Figure 7-1 FT800 Reference Design Schematic (LCD) 7.2 Examples of PWM Audio Circuits Figure 7-2 FT800 Reference Design Schematic (audio) Copyright © Bridgetek Pte Ltd 38 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 8 Package Parameters The FT800 is available in VQFN-48 package. The solder reflow profile for all packages is described in following sections. 8.1 VQFN-48 Package Dimensions 8.1.1 Top Side Notes: 1. 2. 3. 4. YYWW = Date Code, where YY is year and WW is week number Pre-date code 1727 company logo was FTDI Marking alignment should be centre justified Laser Marking should be used 8.1.2 Bottom Side No markings should be placed on the bottom side. Copyright © Bridgetek Pte Ltd 39 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 8.2 VQFN-48 Package Dimensions Figure 8-1 VQFN-48 Package Dimensions Copyright © Bridgetek Pte Ltd 40 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 8.3 Solder Reflow Profile The FT800 is supplied in a Pb free VQFN-48 package. The recommended solder reflow profile for the package is shown in Figure 8-2. Temperature, T (Degrees C) tp Tp Critical Zone: when T is in the range TL to Tp Ramp Up TL tL TS Max Ramp Down TS Min tS Preheat 25 T = 25º C to TP Time, t (seconds) Figure 8-2 FT800 Solder Reflow Profile The recommended values for the solder reflow profile are detailed in Table 8-1. Values are shown for both a completely Pb free solder process (i.e. the FT800 is used with Pb free solder), and for a non-Pb free solder process (i.e. the FT800 is used with non-Pb free solder). Profile Feature Pb Free Solder Non-Pb Free Solder Process Process Average Ramp Up Rate (Ts to Tp) 3°C / second Max. 3°C / Second Max. Preheat - Temperature Min (Ts Min.) 150°C - Temperature Max (Ts Max.) 200°C - Time (ts Min to ts Max) 60 to 120 seconds 100°C 150°C 60 to 120 seconds Time Maintained Above Critical Temperature TL: 217°C - Temperature (TL) 60 to 150 seconds 183°C 60 to 150 seconds - Time (tL) Peak Temperature (Tp) 260°C 240°C Time within 5°C of actual Peak 20 to 40 seconds 20 to 40 seconds 6°C / second Max. 6°C / second Max. 8 minutes Max. 6 minutes Max. Temperature (tp) Ramp Down Rate Time for T= 25°C to Peak Temperature, Tp Table 8-1 Reflow Profile Parameter Values Copyright © Bridgetek Pte Ltd 41 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 9 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 5691 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Bridgetek Pte Ltd (BRT Chip) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested Bridgetek devices and other materials) is provided for reference only. While Bridgetek has taken care to assure it is accurate, this information is subject to customer confirmation, and Bridgetek disclaims all liability for system designs and for any applications assistance provided by Bridgetek. Use of Bridgetek devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless Bridgetek from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of t his document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H. Copyright © Bridgetek Pte Ltd 42 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Appendix A – References Document References FT800 Series Programmers Guide AN_240 FT800 From the Ground Up AN_245 Sample Application Introduction for VM800B & VM800C Development Kits & Windows PC AN_246 VM800 Series ‘Sample App’ AN_252 FT800 Audio Primer AN_299 FT800_FT801 Internal Clock Trimming Acronyms and Abbreviations Terms Description ADPCM Adaptive Differential Pulse Code Modulation ASCII American Standard Code for Information Interchange EVE Embedded Video Engine HMI Human Machine Interfaces I2C Inter-Integrated Circuit LCD Liquid Crystal Display LED Light Emitting Diode MCU Micro Controller Unit MPU Micro Processor Unit PCM Pulse Code Modulation PLL Phased Locked Loop PWM Pulse Width Modulation QVGA Quarter Video Graphics Array ROM SPI VQFN Read Only Memory Serial Peripheral Interface Very Thin Quad Flat Non-Leaded Package Copyright © Bridgetek Pte Ltd 43 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Appendix B - List of Figures and Tables List of Figures Figure 2-1 FT800 Block Diagram ..................................................................................................... 3 Figure 2-2 FT800 System Design Diagram ....................................................................................... 3 Figure 3-1 Pin Configuration VQFN-48 (top view) .............................................................................. 6 Figure 4-1 Host Interface Options ................................................................................................. 10 Figure 4-2 SPI Interface 1.8-3.3V connection ................................................................................. 11 Figure 4-3 SPI Interface 5V connection .......................................................................................... 11 Figure 4-4 Internal Relaxation Oscillator Connection ....................................................................... 15 Figure 4-5 Crystal oscillator connection ......................................................................................... 15 Figure 4-6 External clock input ..................................................................................................... 15 Figure 4-7 Touch screen connection .............................................................................................. 25 Figure 4-8 1.2V regulator ............................................................................................................ 26 Figure 4-9 Power State Transition ................................................................................................. 27 Figure 6-1 SPI Interface Timing .................................................................................................... 35 Figure 6-2 RGB Video Signal Timing .............................................................................................. 37 Figure 7-1 FT800 Reference Design Schematic (LCD) ...................................................................... 38 Figure 7-2 FT800 Reference Design Schematic (audio) .................................................................... 38 Figure 8-1 VQFN-48 Package Dimensions ...................................................................................... 40 Figure 8-2 FT800 Solder Reflow Profile .......................................................................................... 41 List of Tables Table 3-1 FT800Q pin description.................................................................................................... 9 Table 4-1 Host memory read transaction (SPI) ............................................................................... 12 Table 4-2 Host memory write transaction (SPI) .............................................................................. 13 Table 4-3 Host command transaction (SPI) .................................................................................... 13 Table 4-4 Host Command Table .................................................................................................... 14 Table 4-5 Interrupt Flags bit assignment ....................................................................................... 14 Table 4-6 Font table format ......................................................................................................... 17 Table 4-7 ROM font table ............................................................................................................. 17 Table 4-8 ROM font ASCII character width in pixels ......................................................................... 20 Table 4-9 ROM font Extended ASCII characters .............................................................................. 20 Table 4-10 REG_SWIZZLE RGB Pins Mapping ................................................................................. 21 Table 4-11 Output drive current selection ...................................................................................... 22 Table 4-12 Sound Effect .............................................................................................................. 23 Table 4-13 MIDI Note Effect ......................................................................................................... 24 Table 4-14 Touch Controller Operating Mode .................................................................................. 25 Table 4-15 Power supply ............................................................................................................. 26 Copyright © Bridgetek Pte Ltd 44 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Table 4-16 Pin Status .................................................................................................................. 29 Table 5-1 FT800 Memory Map ...................................................................................................... 30 Table 5-2 Overview of FT800 Registers .......................................................................................... 32 Table 6-1 Absolute Maximum Ratings ............................................................................................ 33 Table 6-2 Operating Voltage and Current ....................................................................................... 33 Table 6-3 Digital I/O Pin Characteristics (VCC/VCCIO = +3.3V, Standard Drive Level) ......................... 33 Table 6-4 Digital I/O Pin Characteristics (VCCIO = +2.5V, Standard Drive Level) ................................ 34 Table 6-5 Digital I/O Pin Characteristics (VCCIO = +1.8V, Standard Drive Level) ................................ 34 Table 6-6 Touch Sense Characteristics (VCC=3.3V) ........................................................................ 34 Table 6-7 ADC Characteristics (VCC=3.3V) .................................................................................... 34 Table 6-8 System clock characteristics (Ambient Temperature = -40°C to +85°C) .............................. 35 Table 6-9 SPI Interface Timing Specification .................................................................................. 36 Table 6-10 I2C Interface Timing ................................................................................................... 36 Table 6-11 RGB Video timing characteristics .................................................................................. 36 Table 8-1 Reflow Profile Parameter Values ..................................................................................... 41 Copyright © Bridgetek Pte Ltd 45 FT800 Embedded Video Engine Datasheet Version 1.4 Document No.: BRT_000039 Clearance No.: BRT#001 Appendix C - Revision History Document Title: FT800 Embedded Video Engine Datasheet Document Reference No.: BRT_000039 Clearance No.: BRT#001 Product Page: http://brtchip.com/product Document Feedback: Send Feedback Revision Changes Date Version 1.0 Initial Release 2013-07-18 Version 1.1 Updated Release 2013-08-28 Version 1.2 Version 1.3 Version 1.4 Copyright © Bridgetek Pte Ltd Dual branding to reflect the migration of the product to the Bridgetek name – logo changed, copyright changed, contact information changed Document Migrated from Dual branding (FTDI/BRT) to Bridgetek – Dual branding logo replaced with BRT Logo; All document reference hyperlinks updated to point BRT wesbite as required; Updated the chip markings from FTDI to BRT in Figure 3-1 Pin Configuration VQFN-48 (top view) Updated section 1.1 Packaging Quantities Updated Figure 8.1 2106-09-13 2017-06-30 2019-04-24 46
FT800Q-R 价格&库存
很抱歉,暂时无法提供与“FT800Q-R”相匹配的价格&库存,您可以联系我们找货
