GD25B512MEYIGR
GD25B512MEYIGR
    GIGADEVICE(兆易创新)
    WSON-8-EP(6x8)
    统一扇区标准与四路串行闪存
GD25B512MEYIGR 数据手册
Uniform Sector Standard and Quad Serial Flash GD25B512ME GD25B512ME DATASHEET GD25B512ME-Rev1.3 1 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Contents 1 FEATURES .........................................................................................................................................................4 2 GENERAL DESCRIPTIONS..............................................................................................................................5 3 MEMORY ORGANIZATION ...............................................................................................................................9 4 DEVICE OPERATIONS.................................................................................................................................... 10 4.1 SPI MODE ............................................................................................................................................................ 10 4.2 QPI MODE............................................................................................................................................................ 10 4.3 RESET FUNCTION .................................................................................................................................................. 10 5 DATA PROTECTION ........................................................................................................................................ 12 6 REGISTERS...................................................................................................................................................... 14 7 8 6.1 STATUS REGISTER ................................................................................................................................................... 14 6.2 EXTENDED ADDRESS REGISTER .................................................................................................................................. 16 INTERNAL CONFIGURATION REGISTER ................................................................................................... 17 7.1 NONVOLATILE CONFIGURATION REGISTER ................................................................................................................... 17 7.2 VOLATILE CONFIGURATION REGISTER ......................................................................................................................... 18 7.3 SUPPORTED CLOCK FREQUENCIES .............................................................................................................................. 21 7.4 DATA SEQUENCE WRAPS BY DENSITY ......................................................................................................................... 21 COMMAND DESCRIPTIONS .......................................................................................................................... 22 8.1 ENABLE 4-BYTE MODE (B7H) .................................................................................................................................. 27 8.2 DISABLE 4-BYTE MODE (E9H) .................................................................................................................................. 27 8.3 WRITE ENABLE (WREN) (06H) ................................................................................................................................ 28 8.4 WRITE DISABLE (WRDI) (04H) ................................................................................................................................ 28 8.5 WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) ................................................................................................. 29 8.6 WRITE STATUS REGISTER (WRSR) (01H/31H) ........................................................................................................... 29 8.7 WRITE EXTENDED ADDRESS REGISTER (C5H)............................................................................................................... 30 8.8 WRITE NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B1H/81H) ......................................................................... 31 8.9 READ STATUS REGISTER (05H/35H) ......................................................................................................................... 31 8.10 READ NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B5H/85H) ........................................................................... 32 8.11 READ EXTENDED ADDRESS REGISTER (C8H) ................................................................................................................ 33 8.12 READ DATA BYTES (03H/13H) ................................................................................................................................ 33 8.13 READ DATA BYTES AT HIGHER SPEED (0BH/0CH) ........................................................................................................ 34 8.14 QUAD OUTPUT FAST READ (6BH/6CH) ..................................................................................................................... 35 8.15 QUAD I/O FAST READ (EBH/ECH) ........................................................................................................................... 35 8.16 QUAD I/O DTR READ (EDH/EEH) ........................................................................................................................... 37 8.17 PAGE PROGRAM (PP) (02H/12H) ............................................................................................................................ 38 8.18 QUAD PAGE PROGRAM (32H/34H) .......................................................................................................................... 39 GD25B512ME-Rev1.3 2 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 8.19 EXTEND QUAD PAGE PROGRAM (C2H/3EH) .............................................................................................................. 40 8.20 SECTOR ERASE (SE) (20H/21H) ............................................................................................................................... 41 8.21 32KB BLOCK ERASE (BE32) (52H/5CH) ................................................................................................................... 42 8.22 64KB BLOCK ERASE (BE64) (D8H/DCH) .................................................................................................................. 43 8.23 CHIP ERASE (CE) (60H/C7H) .................................................................................................................................. 43 8.24 ENABLE QPI (38H) ................................................................................................................................................ 44 8.25 DISABLE QPI (FFH) ................................................................................................................................................ 44 8.26 DEEP POWER-DOWN (DP) (B9H) ............................................................................................................................. 45 8.27 RELEASE FROM DEEP POWER-DOWN (ABH) ............................................................................................................... 45 8.28 READ UNIQUE ID (4BH) .......................................................................................................................................... 46 8.29 READ IDENTIFICATION (RDID) (9FH/9EH) ................................................................................................................. 47 8.30 PROGRAM/ERASE SUSPEND (PES) (75H) ................................................................................................................... 48 8.31 PROGRAM/ERASE RESUME (PER) (7AH) ................................................................................................................... 48 8.32 ERASE SECURITY REGISTERS (44H) ............................................................................................................................ 49 8.33 PROGRAM SECURITY REGISTERS (42H) ....................................................................................................................... 50 8.34 READ SECURITY REGISTERS (48H) ............................................................................................................................. 51 8.35 INDIVIDUAL BLOCK/SECTOR LOCK (36H)/UNLOCK (39H)/READ (3DH) ........................................................................... 52 8.36 GLOBAL BLOCK/SECTOR LOCK (7EH) OR UNLOCK (98H) ............................................................................................... 53 8.37 ENABLE RESET (66H) AND RESET (99H) ..................................................................................................................... 54 8.38 READ SERIAL FLASH DISCOVERABLE PARAMETER (5AH)................................................................................................. 55 9 ELECTRICAL CHARACTERISTICS .............................................................................................................. 57 9.1 POWER-ON TIMING ................................................................................................................................................ 57 9.2 INITIAL DELIVERY STATE ........................................................................................................................................... 57 9.3 ABSOLUTE MAXIMUM RATINGS ................................................................................................................................ 57 9.4 CAPACITANCE MEASUREMENT CONDITIONS................................................................................................................. 58 9.5 DC CHARACTERISTICS .............................................................................................................................................. 59 9.6 AC CHARACTERISTICS .............................................................................................................................................. 62 10 10.1 11 ORDERING INFORMATION........................................................................................................................ 70 VALID PART NUMBERS ............................................................................................................................................ 71 PACKAGE INFORMATION ......................................................................................................................... 73 11.1 PACKAGE SOP16 300MIL ...................................................................................................................................... 73 11.2 PACKAGE WSON8 (8X6MM) ................................................................................................................................... 73 11.3 PACKAGE TFBGA-24BALL (5X5 BALL ARRAY) ............................................................................................................. 75 12 REVISION HISTORY .................................................................................................................................... 76 GD25B512ME-Rev1.3 3 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 1 FEATURES ◆ 512M-bit Serial Flash ◆ Fast Program/Erase Speed - 64M-Byte - Page Program time: 0.15ms typical - 256 Bytes per programmable page - Sector Erase time: 30ms typical - Block Erase time: 0.15/0.22s typical ◆ Standard, Quad SPI, DTR,QPI - Chip Erase time: 150s typical - Standard SPI: SCLK, CS#, SI, SO, WP#, RESET# - Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# ◆ Flexible Architecture - QPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# - Sector of 4K-Byte - SPI DTR (Double Transfer Rate) Read - Block of 32/64K-Byte - 3 or 4-Byte Address Mode - Erase/Program Suspend/Resume ◆ High Speed Clock Frequency ◆ Low Power Consumption - 133MHz for fast read - 16μA typical stand-by current - Quad I/O Data transfer up to 532Mbits/s - 2μA typical power-down current - QPI Mode Data transfer up to 532Mbits/s - DTR Quad I/O Data transfer up to 720Mbits/s ◆ Advanced Security Features - 128-bit Unique ID ◆ Allows XIP (eXecute in Place) Operation - 4K-Byte Security Registers With OTP Lock - High speed Read reduce overall XiP instruction fetch time - Continuous Read with Wrap further reduce data latency to fill up SoC cache ◆ Single Power Supply Voltage - Full voltage range: 2.7~3.6V ◆ Software/Hardware Write Protection ◆ Endurance and Data Retention - Write protect all/portion of memory via software - Minimum 100,000 Program/Erase Cycles - Enable/Disable protection with WP# Pin - 20-year data retention typical - Individual Block Protection ◆ Package Information - SOP16 300mil - WSON8 (8x6mm) - TFBGA-24ball (5x5 Ball Array) GD25B512ME-Rev1.3 4 January 2022 Uniform Sector Standard and Quad Serial Flash 2 GD25B512ME GENERAL DESCRIPTIONS The GD25B512ME (512M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Quad SPI and DTR mode: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), I/O3, and RESET#. The Quad I/O & Quad output data is transferred with speed of 532Mbits/s, and the DTR Quad I/O data is transferred with speed of 720Mbits/s. CONNECTION DIAGRAM AND PIN DESCRIPTION Figure 1 Connection Diagram for SOP16 package IO3 1 16 SCLK VCC 2 15 SI (IO0) RESET# 3 14 NC NC 4 13 DNU Top View NC 5 12 NC DNU 6 11 DNU CS# 7 10 VSS SO (IO1) 8 9 WP# (IO2) 16-LEAD SOP Table 1 Pin Description for SOP16 package Pin No. Pin Name I/O Description 1 IO3 I/O Data Input Output 3 2 VCC 3 RESET# 6/11/13 DNU 7 CS# I 8 SO (IO1) I/O Data Output (Data Input Output 1) 9 WP# (IO2) I/O Write Protect Input (Data Input Output 2) 10 VSS 15 SI (IO0) I/O 16 SCLK I Power Supply I Reset Input Do Not Use (It may connect to internal signal inside) Chip Select Input Ground Data Input (Data Input Output 0) Serial Clock Input Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. The DNU pin must be floating. It may connect to internal signal inside. 3. The NC pin is not connected to any internal signal. It is OK to connect it to the system ground (GND) or leave it floating. 4. The RESET# pin is a dedicated hardware reset pin regardless of device settings or operation states. If the hardware reset GD25B512ME-Rev1.3 5 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME function is not used, this pin must be connected to VCC in the system. 5. If WP# is unused, it must be driven high by the host, or an external pull-up resistor must be placed on the PCB in order to avoid allowing WP# input to float. Figure 2 Connection Diagram for WSON8 package CS# 1 SO (IO1) 2 WP# (IO2) 3 6 SCLK VSS 4 5 8 VCC 7 IO3 Top View SI (IO0) 8–LEAD WSON Table 2 Pin Description for WSON8 package Pin No. Pin Name I/O Description 1 CS# I 2 SO (IO1) I/O Data Output (Data Input Output 1) 3 WP# (IO2) I/O Write Protect Input (Data Input Output 2) 4 VSS 5 SI (IO0) I/O 6 SCLK I 7 IO3 I/O 8 VCC Chip Select Input Ground Data Input (Data Input Output 0) Serial Clock Input Data Input Output 3 Power Supply Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. If WP# is unused, it must be driven high by the host, or an external pull-up resistor must be placed on the PCB in order to avoid allowing WP# input to float. GD25B512ME-Rev1.3 6 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 3 Connection Diagram for TFBGA24 5x5 ball array package Top View A2 A3 A4 A5 NC NC RESET# DNU B1 B2 B3 B4 B5 NC SCLK VSS VCC NC C1 C2 C3 C4 C5 VSS(5) CS# DNU WP# (IO2) DNU D1 D2 D3 D4 D5 IO3 NC E4 E5 (5) VCC E1 NC SO(IO1) SI(IO0) E2 NC E3 NC (5) VCC VSS(5) 24-BALL TFBGA (5x5 ball array) Table 3 Ball Description for TFBGA24 5x5 ball array package Pin No. Pin Name I/O Description A4 RESET# I Reset Input A5/C3/C5 DNU B2 SCLK B3/C1/E5 VSS Ground B4/D1/E4 VCC Power Supply C2 CS# I C4 WP# (IO2) I/O Write Protect Input (Data Input Output 2) D2 SO (IO1) I/O Data Output (Data Input Output 1) D3 SI (IO0) I/O Data Input (Data Input Output 0) D4 IO3 I/O Data Input Output 3 Do Not Use (It may connect to internal signal inside) I Serial Clock Input Chip Select Input Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. The DNU ball must be floating. It may connect to internal signal inside. 3. The NC ball is not connected to any internal signal. It is OK to connect it to the system ground (GND) or leave it floating. 4. The RESET# pin is a dedicated hardware reset pin regardless of device settings or operation states. If the hardware reset function is not used, this pin must be connected to VCC in the system. 5. If WP# is unused, it must be driven high by the host, or an external pull-up resistor must be placed on the PCB in order to avoid allowing WP# input to float. 6. The device can work with only one group of VCC/VSS connected. Ball B4 must be connected to VCC and Ball B3 must be connected to VSS. The other two groups of VCC/VSS balls (Ball C1/D1/E4/E5) are optional. If Ball C1/D1/E4/E5 are not used, they must be left floating. GD25B512ME-Rev1.3 7 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME BLOCK DIAGRAM Write Control Logic Status Register IO3 SCLK CS# SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Write Protect Logic and Row Decode WP#(IO2) Flash Memory SI(IO0) Column Decode And 256-Byte Page Buffer SO(IO1) RESET# GD25B512ME-Rev1.3 Byte Address Latch/Counter 8 January 2022 Uniform Sector Standard and Quad Serial Flash 3 GD25B512ME MEMORY ORGANIZATION GD25B512ME Each device has Each block has Each sector has Each page has 64M 64/32K 4K 256 Bytes 256K 256/128 16 - pages 16K 16/8 - - sectors 1K/2K - - - blocks UNIFORM BLOCK SECTOR ARCHITECTURE GD25B512ME 64K Bytes Block Sector Architecture Block 1023 1022 …… …… 2 1 0 GD25B512ME-Rev1.3 Sector Address range 16383 3FFF000H 3FFFFFFH …… …… …… 16368 3FF0000H 3FF0FFFH 16367 3FEF000H 3FEFFFFH …… …… …… 16352 3FE0000H 3FE0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH 9 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 4 DEVICE OPERATIONS 4.1 SPI Mode Standard SPI The GD25B512ME features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Quad SPI The GD25B512ME supports Quad SPI operation when using the “Quad Output Fast Read”, “Quad I/O Fast Read”, “Quad Page Program” (6BH/6CH, EBH/ECH, 32H/34H, C2H/3EH) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. DTR Quad SPI The GD25B512ME supports DTR Quad SPI operation when using the “DTR Quad I/O Fast Read” (EDH/EEH) command. These commands allow data to be transferred to or from the device at eight times the rate of the standard SPI, and data output will be latched on both rising and falling edges of the serial clock. When using the DTR Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. 4.2 QPI Mode The GD25B512ME supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Quad SPI mode to QPI mode using the “Enable the QPI (38H)” command. The QPI mode utilizes all four IO pins to input the command code. Standard/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given times. “Enable the QPI (38H)” and “Disable the QPI (FFH)” commands are used to switch between these two modes. Upon power-up and after software reset using “Enable Reset (66H) and Reset (99H)” command, the default state of the device is Standard/Quad SPI mode. 4.3 RESET Function The RESET# pin allows the device to be reset by the control. The RESET# pin goes low for a minimum period of tRLRH will reset the flash. After reset cycle, the flash is at the following states: - Standby mode - All the volatile bits will return to the default status as power on. GD25B512ME-Rev1.3 10 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 4 RESET Condition CS# RESET# RESET GD25B512ME-Rev1.3 11 January 2022 Uniform Sector Standard and Quad Serial Flash 5 GD25B512ME DATA PROTECTION The GD25B512ME provide the following data protection methods: ◆ Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation: - Power-Up/ Software reset (66H+99H) - Write Disable (WRDI) - Write Status Register (WRSR) - Write Extended Address Register (WEAR) - Write Nonvolatile Configuration Register (WNVCR) - Write Volatile Configuration Register (WVCR) - Page Program (PP) - Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE) - Erase Security Registers / Program Security Registers ◆ Software Protection Mode: -The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits define the section of the memory array that can be read but cannot be changed. - Individual Block Protection bit provides the protection selection of each individual block. ◆ Hardware Protection Mode: WP# goes low to protect the BP0~BP4 bits and SRP0 bit. ◆ Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command and reset command (66H+99H). Table 4. GD25B512ME Protected area size Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X 0 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 1023 03FF0000h-03FFFFFFh 64KB Upper 1/1024 0 0 0 1 0 1022 to 1023 03FE0000h-03FFFFFFh 128KB Upper 1/512 0 0 0 1 1 1020 to 1023 03FC0000h-03FFFFFFh 256KB Upper 1/256 0 0 1 0 0 1016 to 1023 03F80000h-03FFFFFFh 512KB Upper 1/128 0 0 1 0 1 1008 to 1023 03F00000h-03FFFFFFh 1MB Upper 1/64 0 0 1 1 0 992 to 1023 03E00000h-03FFFFFFh 2MB Upper 1/32 0 0 1 1 1 960 to 1023 03C00000h-03FFFFFFh 4MB Upper 1/16 0 1 0 0 0 896 to 1023 03800000h-03FFFFFFh 8MB Upper 1/8 0 1 0 0 1 768 to 1023 03000000h-03FFFFFFh 16MB Upper 1/4 0 1 0 1 0 512 to 1023 02000000h-03FFFFFFh 32MB Upper 1/2 1 0 0 0 1 0 00000000h-0000FFFFh 64KB Lower 1/1024 1 0 0 1 0 0 to 1 00000000h-0001FFFFh 128KB Lower 1/512 1 0 0 1 1 0 to 3 00000000h-0003FFFFh 256KB Lower 1/256 1 0 1 0 0 0 to 7 00000000h-0007FFFFh 512KB Lower 1/128 1 0 1 0 1 0 to 15 00000000h-000FFFFFh 1MB Lower 1/64 1 0 1 1 0 0 to 31 00000000h-001FFFFFh 2MB Lower 1/32 GD25B512ME-Rev1.3 12 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 1 0 1 1 1 0 to 63 00000000h-003FFFFFh 4MB Lower 1/16 1 1 0 0 0 0 to 127 00000000h-007FFFFFh 8MB Lower 1/8 1 1 0 0 1 0 to 255 00000000h-00FFFFFFh 16MB Lower 1/4 1 1 0 1 0 0 to 511 00000000h-01FFFFFFh 32MB Lower 1/2 X 1 1 X X ALL 00000000h-03FFFFFFh 64MB ALL X 1 0 1 1 ALL 00000000h-03FFFFFFh 64MB ALL Table 5. GD25B512ME Individual Block Protection (WPS=0) Block Sector Address range Individual Block Lock Operation 16383 03FF F000h 03FF FFFFh 1024 Blocks …… …… …… Block Lock: 36H+Address 16368 03FF 0000h 03FF 0FFFh Block Unlock: 39H+Address 1022 16352~16367 03FE 0000h 03FE FFFFh Read Block Lock: 3DH+Address …… …… …… …… Global Block Lock: 7EH …… …… …… …… Global Block Unlock: 98H …… …… …… …… 1 16~31 0001 0000h 0001 FFFFh 15 0000 F000h 0000 FFFFh …… …… …… 0 0000 0000h 0000 0FFFh 1023 0 Notes: 1. Protection configuration: This bit is used to select which Write Protect scheme should be used. 2. Individual Block Protection bits are volatile lock bits. Each volatile bit corresponds to and provides volatile protection for an individual memory sector, which is locked temporarily (protection is cleared when the device is reset or powered down). 3. The first and last sectors will have volatile protections at the 4KB sector level. Each 4KB sector in these sectors can be individually locked by volatile lock bits setting. GD25B512ME-Rev1.3 13 January 2022 Uniform Sector Standard and Quad Serial Flash 6 GD25B512ME REGISTERS 6.1 Status Register Table 6. Status Register-SR No.1 No. Bit Name Description Note S7 SRP0 Status Register Protection Bit Non-volatile writable S6 BP4 Block Protect Bit Non-volatile writable S5 BP3 Block Protect Bit Non-volatile writable S4 BP2 Block Protect Bit Non-volatile writable S3 BP1 Block Protect Bit Non-volatile writable S2 BP0 Block Protect Bit Non-volatile writable S1 WEL Write Enable Latch Volatile, read only S0 WIP Erase/Write In Progress Volatile, read only Table 7. Status Register-SR No.2 No. Bit Name Description Note S15 SUS1 Erase Suspend Bit Volatile, read only S14 SRP1 Status Register Protection Bit Non-volatile writable S13 EE Erase Error Bit Volatile, read only S12 PE Program Error Volatile, read only S11 LB Security Register Lock Bit Non-volatile writable (OTP) S10 SUS2 Program Suspend Bit Volatile, read only S9 Reserved Reserved Reserved S8 ADS Current Address Mode Volatile, read only The status and control bits of the Status Register are as follows: WIP bit The Write in Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register or configuration register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register or configuration register progress, when WIP bit sets 0, means the device is not in program/erase/write status register or configuration register progress. WEL bit The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. GD25B512ME-Rev1.3 14 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME When the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are set to 1, the relevant memory area becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed only if none sector or block is protected. SRP0, SRP1 bits The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. SRP1 SRP0 #WP Status Register 0 0 X Software Protected 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 0 X 1 1 X Power Supply LockDown(1)(2) One Time Program(2) Description The Status Register can be written to after a Write Enable command, WEL=1.(Default) WP#=0, the Status Register locked and cannot be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Status Register is protected and cannot be written to again until the next Power-Down, Power-Up cycle. Status Register is permanently protected and cannot be written to. NOTE: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order. Please contact GigaDevice for details. ADS bit The Address Status (ADS) bit is a read only bit that indicates the current address mode the device is operating in. The device is in 3-Byte address mode when ADS=0 (default), and in 4-Byte address mode when ADS=1. SUS1, SUS2 bits The SUS1 and SUS2 bits are read only bits in the status register (S15 and S10) that are set to 1 after executing an Program/Erase Suspend (75H) command (The Erase Suspend will set the SUS1 bit to 1, and the Program Suspend will set the SUS2 bit to 1). The SUS1 and SUS2 bits are cleared to 0 by Erase/Program Resume (7AH) command, software reset (66H+99H) command as well as a power-down, power-up cycle. LB bit The LB bit is non-volatile One Time Program (OTP) bit in Status Register (S11) that provide the write protect control and status to the Security Registers. The default state of LB bit is 0, the security registers are unlocked. The LB bit can be set to 1 using the Write Register instruction. The LB bit is One Time Programmable, once they are set to 1, the Security Registers will become read-only permanently. PE bit The Program Error (PE) bit is a read only bit that indicates a program failure. It will also be set when the user attempts to GD25B512ME-Rev1.3 15 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME program a protected array sector or access the locked OTP space. PE is cleared to "0" after program operation resumes EE bit The Erase Error (EE) bit is a read only bit that indicates an erase failure. It will also be set when the user attempts to erase a protected array sector or access the locked OTP space. EE is cleared to "0" after erase operation resumes 6.2 Extended Address Register Table 8 Extended Address Register No. Name Description Note EA7 Reserved Reserved Reserved EA6 Reserved Reserved Reserved EA5 Reserved Reserved Reserved EA4 Reserved Reserved Reserved EA3 Reserved Reserved Reserved EA2 Reserved Reserved Reserved EA1 A25 Address bit Volatile writable EA0 A24 Address bit Volatile writable The extended address register is only used when the address mode is 3-Byte mode, as to set the higher address. The default value of the address bit is “0”. For the read operation, the whole array can be continually read out with one command. Data output starts from the selected 128Mb, and it can cross the boundary. When the last Byte of the segment is reached, the next Byte (in a continuous reading) is the first Byte of the next segment. However, the EAR (Extended Address Register) value does not change. The random access reading can only be operated in the selected segment. The Chip erase command will erase the whole chip and is not limited by EAR selected segment. However, the sector erase, block erase, program operation are limited in selected segment and will not cross the boundary. A24, A25 bits The Extended Address Bits are used only when the device is operating in the 3-Byte Address Mode (ADS=0), which is volatile writable by C5H command. If Configuration Register Byte set to FEH, or an “Enter 4-Byte Address Mode (B7H)” instruction is issued, the device will require 4-Byte address input for all address related instructions, and the Extended Address Bit setting will be ignored. A25, A24 Address Range 00 0000 0000h-00FF FFFFh 01 0100 0000h-01FF FFFFh 10 0200 0000h-02FF FFFFh 11 0300 0000h-03FF FFFFh GD25B512ME-Rev1.3 16 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 7 INTERNAL CONFIGURATION REGISTER The memory configuration is set by an internal configuration register that is not directly accessible to users. The user can change the default configuration at power up by using the WRITE NONVOLATILE CONFIGURATION REGISTER. Information from the nonvolatile configuration register overwrites the internal configuration register during power on or after a reset. The user can change the configuration during device operation using the WRITE VOLATILE CONFIGURATION REGISTER command. Information from the volatile configuration registers overwrite the internal configuration register immediately after the WRITE command completes. Nonvolatile to volatile register download after power-on or RESET Nonvolatile configuration register Nonvolatile to internal register download after power-on or RESET Volatile configuration register Volatile to internal register download after Write Volatile Configuration Register Command Internal configuration register Device behavior 7.1 Nonvolatile Configuration Register Nonvolatile Configuration Register bits set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ NONVOLATILE CONFIGURATION REGISTER and the WRITE NONVOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme, but only the LSB is used to access different register settings, thereby providing up to 256 Bytes of registers (See the table below for the details). A WRITE command to a reserved address will set the device to the default status of the corresponding Byte. Table 9 Nonvolatile Configuration Register Addr Settings Dummy cycle configuration(6-7) bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 0 0 0 0 0 0 1 1 3 Dummy 0 0 0 0 0 1 0 0 4 Dummy … … … … … … … … Others On die termination GD25B512ME-Rev1.3 05~1E: 5~30 Dummy (Default=06h) Reserved 1 1 1 1 x x x x ODT Disabled (Default) 1 1 1 0 x x x x 300-Ohm ODT 1 1 0 1 x x x x 150-Ohm ODT 17 January 2022 Uniform Sector Standard and Quad Serial Flash 1 1 0 0 x x x x 100-Ohm ODT x x x x 1 1 1 1 50 Ohm (Default) Driver strength x x x x 1 1 1 0 35 Ohm configuration x x x x 1 1 0 1 25 Ohm x x x x 1 1 0 0 18 Ohm x x x x 1 x x x DLP Disabled (Default) x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address DLP enable GD25B512ME Beyond 128Mb addr configuration Continuous Read configuration(9) Wrap configuration(9) Others Reserved 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled Others Reserved 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 1 1 1 1 1 1 0 0 16-Byte Wrap Others Reserved Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI N/A 3. 05H/35H/9EH/9FH: SPI&QPI 0 dummy. 4. 3DH: SPI 0 dummy; QPI 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI 8 dummy. 6. 0BH/0CH/6BH/6CH/48H: SPI 8 dummy; QPI dummy follow CONFIGURATION REGISTER (initiation = 6 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI dummy follow CONFIGURATION REGISTER (initiation = 6 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. 7.2 Volatile Configuration Register Volatile Configuration Register bits temporarily set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ VOLATILE CONFIGURATION REGISTER and the WRITE VOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme; however, only the LSB is used to access different register settings to provide up to 256 Bytes of registers (See the table below for the details). A WRITE command to a reserved address will set the device to the default status of the corresponding Byte. GD25B512ME-Rev1.3 18 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Table 10 Volatile Configuration Register Addr Settings Dummy cycle configuration(6-7) bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 0 0 0 0 0 0 1 1 3 Dummy 0 0 0 0 0 1 0 0 4 Dummy … … … … … … … … Others 1 1 x x x x ODT Disabled (Default) 1 1 1 0 x x x x 300-Ohm ODT 1 1 0 1 x x x x 150-Ohm ODT 1 1 0 0 x x x x 100-Ohm ODT x x x x 1 1 1 1 50 Ohm (Default) Driver strength x x x x 1 1 1 0 35 Ohm configuration x x x x 1 1 0 1 25 Ohm x x x x 1 1 0 0 18 Ohm x x x x 1 x x x DLP Disabled (Default) x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address DLP enable Reserved 1 (Default=06h) 1 On die termination 05~1E: 5~30 Dummy Beyond 128Mb addr configuration Continuous Read configuration(9) Wrap configuration(9) Others Reserved 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled Others Reserved 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 1 1 1 1 1 1 0 0 16-Byte Wrap Others Reserved Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI N/A 3. 05H/35H/9EH/9FH: SPI&QPI 0 dummy. 4. 3DH: SPI 0 dummy; QPI 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI 8 dummy. 6. 0BH/0CH/6BH/6CH/48H: SPI 8 dummy; QPI dummy follow CONFIGURATION REGISTER (initiation = 6 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI dummy follow CONFIGURATION REGISTER (initiation = 6 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. GD25B512ME-Rev1.3 19 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. DLP bit The DLP bit is Data Learning Pattern Enable bit, which is writable by B1/81H command. For Quad output, Quad I/O and Quad I/O DTR Fast Read commands, a pre-defined “Data Learning Pattern” can be used by the flash memory controller to determine the flash data output timing on 4 I/O pins. When DLP=0, from the third dummy clock, the flash will output “00110100” Data Learning Pattern sequence on each of the I/O or 4 I/O pins until data output. If the dummy clock is not enough for the output of the whole Data Learning Pattern, the last several bit of the Data Learning Pattern would be cut-off. During this period, controller can fine tune the data latching timing for each I/O pins to achieve optimum system performance. DLP=1 will disable the Data Learning Pattern output. Figure 5. Data Learning Pattern Sequence Diagram (STR, Dummy Clock ≥ 10) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 F F 0 F 0 0 0 0 D D 7 6 0 7 6 5 4 3 2 1 Data D D Note: 12 dummy cycle example Figure 6. Data Learning Pattern Sequence Diagram (STR, Dummy Clock < 10) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 F F 0 F D D 7 6 5 4 3 Data D D 2 Note: 8 dummy cycle example Figure 7. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock ≥ 6) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 F F 0 F 0 0 0 0 D 7 6 0 7 6 5 4 3 2 1 Data D Note: 7 dummy cycle example GD25B512ME-Rev1.3 20 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 8. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock < 6) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 F F 0 F D D 7 6 5 4 3 Data D D 2 Note: 5 dummy cycle example 7.3 Supported Clock Frequencies Table 11 Clock Frequencies Number of Dummy Clock Cycle Quad Output Fast Read (6BH/6CH) (Only QPI Quad I/O Fast Read DTR Quad I/O Fast Read (EBH/ECH) (EDH/EEH) Mode) (1) 4 40 40 40 6 84 84 66 8 104 104 84 10 and above 133 133 90 Note: 1. Quad Output Fast Read (6BH/6CH): SPI Mode 8 dummy. 2. Values are guaranteed by characterization and not 100% tested in production 3. Dummy clock cycle listed above is recommended. Please contact GigaDevice for clock frequency of dummy clock cycle configuration out of the table above. 7.4 Data Sequence Wraps by Density Table 12 Sequence of Bytes during Wrap Starting Address 16-Byte Wrap 32-Byte Wrap 64-Byte Wrap 0 0-1-2- . . . -15-0-1- . . 0-1-2- . . . -31-0-1- . . 0-1-2- . . . -63-0-1- . . 1 1-2- . . . -15-0-1-2- . . 1-2- . . . -31-0-1-2- . . 1-2- . . . -63-0-1-2- . . …. …. 15-16-17- . . . -63-0-1- . . …. …. 15 15-0-1-2-3- . . . -15-0-1- . . 15-16-17- . . . -31-0-1- . . …. …. …. 31 - 31-0-1-2-3- . . . -31-0-1- . . 31-32-33- . . . -63-0-1- . . … …. …. …. 63 - - 63-0-1- . . . -63-0-1- . . GD25B512ME-Rev1.3 21 January 2022 Uniform Sector Standard and Quad Serial Flash 8 GD25B512ME COMMAND DESCRIPTIONS All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-Byte command code must be shifted in to the device, with most significant bit first on SI, and each bit is latched on the rising edges of SCLK. Every command sequence starts with a one-Byte command code. Depending on the command, this might be followed by address Bytes, or by data Bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been completed. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. All read instruction can be completed after any bit of the data-out sequence is being shifted out, and then CS# must be driven high to return to deselected status. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a Byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input Byte is not a full Byte, nothing will happen and WEL will not be reset. Table 13 Commands (Standard/DTR Quad SPI) Standard SPI Command name Code Command- Dummy Clock Address-Data Cycles Address Data Bytes Bytes Software Reset Operations Enable Reset 66h 1-0-0 0 0 0 Reset 99h 1-0-0 0 0 0 9Eh/9Fh 1-0-(1) 0 0 1 to ∞ 5Ah 1-1-(1) 8 3 1 to ∞ 4Bh 1-1-(1) 8 3(4) 1 to ∞ 03h 1-1-(1) 0 3(4) 1 to ∞ 0Bh 1-1-(1) 8 3(4) 1 to ∞ Quad Output Fast Read 6Bh 1-1-(4) 8 3(4) 1 to ∞ Quad I/O Fast Read EBh 1-4-(4) 6 3(4) 1 to ∞ Quad I/O DTR Fast Read EDh 1-4d-(4d) 6 3(4) 1 to ∞ Read ID Operations Read Identification Read Serial Flash Discoverable Parameter Read Unique ID Read Memory Operations Read Data Bytes Read Data Bytes at Higher Speed Read Memory Operations with 4-Byte Address 4-Byte Read Data Bytes 4-Byte Read Data Bytes at Higher Speed GD25B512ME-Rev1.3 13h 1-1-(1) 0 4 1 to ∞ 0Ch 1-1-(1) 8 4 1 to ∞ 22 January 2022 Uniform Sector Standard and Quad Serial Flash 4-Byte Quad Output Fast GD25B512ME 6Ch 1-1-(4) 8 4 1 to ∞ ECh 1-4-(4) 6 4 1 to ∞ EEh 1-4d-(4d) 6 4 1 to ∞ Write Enable 06h 1-0-0 0 0 0 Write Disable 04h 1-0-0 0 0 0 50h 1-0-0 0 0 0 Read Status Register-1 05h 1-0-(1) 0 0 1 to ∞ Read Status Register-2 35h 1-0-(1) 0 0 1 to ∞ B5h 1-1-(1) 8 3(4) 1 85h 1-1-(1) 8 3(4) 1 C8h 1-0-(1) 0 0 1 to ∞ Write Status Register-1 01h 1-0-1 0 0 1 Write Status Register-2 31h 1-0-1 0 0 1 B1h 1-1-1 0 3(4) 1 81h 1-1-1 0 3(4) 1 C5h 1-0-1 0 0 1 Page Program 02h 1-1-1 0 3(4) 1 to 256 Quad Page Program 32h 1-1-4 0 3(4) 1 to 256 C2h 1-4-4 0 3(4) 1 to 256 12h 1-1-1 0 4 1 to 256 34h 1-1-4 0 4 1 to 256 3Eh 1-4-4 0 4 1 to 256 Sector Erase 20h 1-1-0 0 3(4) 0 32KB Block Erase 52h 1-1-0 0 3(4) 0 64KB Block Erase D8h 1-1-0 0 3(4) 0 Read 4-Byte Quad I/O Fast Read 4-Byte Quad I/O DTR Fast Read Write Operations Write Enable for Volatile Status Register Read Register Operations Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register Write Register Operations Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Program Operations Extended Quad Page Program Program Operations with 4-Byte Address 4-Byte Page Program 4-Byte Quad Page Program 4-Byte Extended Quad Page Program Erase Operations GD25B512ME-Rev1.3 23 January 2022 Uniform Sector Standard and Quad Serial Flash Chip Erase C7h/60h GD25B512ME 1-0-0 0 0 0 Erase Operations with 4-Byte Address 4-Byte Sector Erase 21h 1-1-0 0 4 0 4-Byte 32KB Block Erase 5Ch 1-1-0 0 4 0 4-Byte 64KB Block Erase DCh 1-1-0 0 4 0 Program/Erase Suspend 75h 1-0-0 0 0 0 Program/Erase Resume 7Ah 1-0-0 0 0 0 48h 1-1-(1) 8 3(4) 1 to ∞ 42h 1-1-1 0 3(4) 1 to 256 44h 1-1-0 0 3(4) 0 38h 1-0-0 0 0 0 B7h 1-0-0 0 0 0 E9h 1-0-0 0 0 0 B9h 1-0-0 0 0 0 ABh 1-0-0 0 0 0 36h 1-1-0 0 3(4) 0 39h 1-1-0 0 3(4) 0 3Dh 1-1-(1) 0 3(4) 1 Global Block/Sector Lock 7Eh 1-0-0 0 0 0 Global Block/Sector Unlock 98h 1-0-0 0 0 0 Suspend/Resume Operations One-Time Programmable (OTP) Operations Read Security Registers Program Security Registers Erase Security Registers QPI Mode Operation Enable QPI 4-Byte Address Mode Operations Enable 4-Byte Address Mode Disable 4-Byte Address Mode Deep Power-Down Operations Deep Power-Down Release From Deep Power-Down Advanced Sector Protection Operations Individual Block/Sector Lock Individual Block/Sector Unlock Read Individual Block/Sector Lock Table 14 Commands (QPI) Command name Code Command- Dummy Clock Address Data Address-Data Cycles Bytes Bytes Software Reset Operations Enable Reset 66h 4-0-0 0 0 0 Reset 99h 4-0-0 0 0 0 9Eh/9Fh 4-0-(4) 0 0 1 to ∞ Read ID Operations Read Identification GD25B512ME-Rev1.3 24 January 2022 Uniform Sector Standard and Quad Serial Flash Read Serial Flash Discoverable GD25B512ME 5Ah 4-4-(4) 8 3 1 to ∞ 4Bh 4-4-(4) 8 3(4) 1 to ∞ Read Data Bytes at Higher Speed 0Bh 4-4-(4) 6 3(4) 1 to ∞ Quad Output Fast Read 6Bh 4-4-(4) 6 3(4) 1 to ∞ Quad I/O Fast Read EBh 4-4-(4) 6 3(4) 1 to ∞ Quad I/O DTR Fast Read EDh 4-4d-(4d) 6 3(4) 1 to ∞ 0Ch 4-4-(4) 6 4 1 to ∞ 4-Byte Quad Output Fast Read 6Ch 4-4-(4) 6 4 1 to ∞ 4-Byte Quad I/O Fast Read ECh 4-4-(4) 6 4 1 to ∞ 4-Byte Quad I/O DTR Fast Read EEh 4-4d-(4d) 6 4 1 to ∞ Write Enable 06h 4-0-0 0 0 0 Write Disable 04h 4-0-0 0 0 0 Write Enable for Volatile Status 50h 4-0-0 0 0 0 Parameter Read Unique ID Read Memory Operations Read Memory Operations with 4-Byte Address 4-Byte Read Data Bytes at Higher Speed Write Operations Register Read Register Operations Read Status Register-1 05h 4-0-(4) 0 0 1 to ∞ Read Status Register-2 35h 4-0-(4) 0 0 1 to ∞ B5h 4-4-(4) 8 3(4) 1 85h 4-4-(4) 8 3(4) 1 C8h 4-0-(4) 0 0 1 to ∞ FFh 4-0-0 0 0 0 Write Status Register-1 01h 4-0-4 0 0 1 Write Status Register-2 31h 4-0-4 0 0 1 B1h 4-4-4 0 3(4) 1 81h 4-4-4 0 3(4) 1 C5h 4-0-4 0 0 1 Page Program 02h 4-4-4 0 3(4) 1 to 256 Quad Page Program 32h 4-4-4 0 3(4) 1 to 256 Extended Quad Page Program C2h 4-4-4 0 3(4) 1 to 256 Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register QPI Mode Operation Disable QPI Write Register Operations Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Program Operations Program Operations with 4-Byte Address GD25B512ME-Rev1.3 25 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 4-Byte Page Program 12h 4-4-4 0 4 1 to 256 4-Byte Quad Page Program 34h 4-4-4 0 4 1 to 256 3Eh 4-4-4 0 4 1 to 256 Sector Erase 20h 4-4-0 0 3(4) 0 32KB Block Erase 52h 4-4-0 0 3(4) 0 64KB Block Erase D8h 4-4-0 0 3(4) 0 C7h/60h 4-0-0 0 0 0 4-Byte Extended Quad Page Program Erase Operations Chip Erase Erase Operations with 4-Byte Address 4-Byte Sector Erase 21h 4-4-0 0 4 0 4-Byte 32KB Block Erase 5Ch 4-4-0 0 4 0 4-Byte 64KB Block Erase DCh 4-4-0 0 4 0 Program/Erase Suspend 75h 4-0-0 0 0 0 Program/Erase Resume 7Ah 4-0-0 0 0 0 Suspend/Resume Operations One-Time Programmable (OTP) Operations Read Security Registers 48h 4-4-(4) 6 3(4) 1 to ∞ Program Security Registers 42h 4-4-4 0 3(4) 1 to 256 Erase Security Registers 44h 4-4-0 0 3(4) Enable 4-Byte Address Mode B7h 4-0-0 0 0 0 Disable 4-Byte Address Mode E9h 4-0-0 0 0 0 Deep Power-Down B9h 4-0-0 0 0 0 Release From Deep Power-Down ABh 4-0-0 0 0 0 0 4-ByteAddress Mode Operations Deep Power-Down Operations Advanced Sector Protection Operations Individual Block/Sector Lock 36h 4-4-0 0 3(4) 0 Individual Block/Sector Unlock 39h 4-4-0 0 3(4) 0 Read Individual Block/Sector Lock 3Dh 4-4-(4) 8 3(4) 1 Global Block/Sector Lock 7Eh 4-0-0 0 0 0 Global Block/Sector Unlock 98h 4-0-0 0 0 0 Table of ID Definitions GD25B512ME Operation Code M7-M0 ID23-ID16 ID15-ID8 ID7-ID0 9EH/9FH C8 47 1A FF GD25B512ME-Rev1.3 26 January 2022 Uniform Sector Standard and Quad Serial Flash 8.1 GD25B512ME Enable 4-Byte Mode (B7H) The Enable 4-Byte Mode command enables accessing the address length of 32-bit for the memory area of the higher density (larger than 128Mb). After sending the Enable 4-Byte Mode command, the ADS bit (S8) will be set to 1 to indicate the 4-Byte address mode has been enabled. Once the 4-Byte address mode is enabled, the address length becomes 32bit. Figure 9 Enable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI B7H Figure 10 Enable 4-Byte Mode Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] 8.2 B7H Disable 4-Byte Mode (E9H) The Disable 4-Byte Mode command is executed to exit the 4-Byte address mode and enter the 3-Byte address mode. After sending the Disable 4-Byte Mode command, the ADS bit (S8) will be clear to be 0 to indicate the 4-Byte address mode has been disabled, and then the address length will return to 24-bit. Figure 11 Disable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI E9H Figure 12 Disable 4-Byte Mode Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] GD25B512ME-Rev1.3 E9H 27 January 2022 Uniform Sector Standard and Quad Serial Flash 8.3 GD25B512ME Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE), Write Status Register (WRSR), Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register and Erase/Program Security Registers command. The Write Enable (WREN) command sequence: CS# goes low → sending the Write Enable command → CS# goes high. Figure 13 Write Enable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 06H Figure 14 Write Enable Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] 8.4 06H Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes low →Sending the Write Disable command →CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register, Page Program, Sector Erase, Block Erase, Chip Erase, Erase/Program Security Registers and Reset commands. Figure 15 Write Disable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H Figure 16 Write Disable Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] GD25B512ME-Rev1.3 04H 28 January 2022 Uniform Sector Standard and Quad Serial Flash 8.5 GD25B512ME Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command, and any other commands cannot be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure 17 Write Enable for Volatile Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 50H High-Z SO Figure 18 Write Enable for Volatile Status Register Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] 8.6 50H Write Status Register (WRSR) (01H/31H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). CS# must be driven high after the eighth of the data Byte has been latched in. Otherwise, the Write Status Register (WRSR) command is not executed. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits, to define the size of the area that is to be treated as read-only. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP0) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. GD25B512ME-Rev1.3 29 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 19 Write Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI SO Status Register-1/2 01H/31H 7 6 High-Z MSB 5 4 3 2 1 0 Figure 20 Write Status Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK Command SR-1/2 01H/31H SR in IO[3:0] 8.7 Write Extended Address Register (C5H) The Extended Address Register is a volatile register that stores the 4th Byte address (A31-A24) when the device is operating in the 3-Byte Address Mode (ADS=0). To write the Extended Address Register bits, a Write Enable (06h) instruction must previously have been executed for the device to accept the Write Extended Address Register instruction (Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “C5H”, and then writing the Extended Address Register data Byte. Upon power up or the execution of a Software/Hardware Reset, the Extended Address Register bit values will be cleared to 0. The Extended Address Bit is only effective when the device is in the 3-Byte Address Mode. When the device operates in the 4-Byte Address Mode (ADS=1), any command with address input of A31-A24 will replace the Extended Address Register values. It is recommended to check and update the Extended Address Register if necessary when the device is switched from 4-Byte to 3-Byte Address Mode. Figure 21 Write Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 C5H 7 Extended Addr. Register In 6 5 4 3 2 1 High-Z MSB SCLK Command SI SO GD25B512ME-Rev1.3 30 0 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 22 Write Extended Address Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK Command EAR in C5H EAR7~0 IO[3:0] 8.8 Write Nonvolatile/Volatile Configuration Register (B1H/81H) The Write Nonvolatile/Volatile Configuration Register command allows new values to be written to the Nonvolatile/Volatile Configuration Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). CS# must be driven high after the data Byte has been latched in. If not, the Write Configuration Register command is not executed. As soon as CS# is driven high, the self-timed Write Configuration Register cycle (whose duration is tW for B1H) is initiated. The Write In Progress (WIP) bit is 1 during the self-timed Write Configuration Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. Figure 23 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 24-bit address 23 22 21 3 2 1 B1H/81H MSB 0 7 Configuration register in 6 5 4 3 2 1 0 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 24 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 SCLK IO[3:0] Command Address CR in B1H/81H Addr. Addr. Addr. Addr. Addr. Addr. CR7~0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.9 Read Status Register (05H/35H) The Read Status Register command is for reading the Status Register. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write in Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”/“35H”, the SO will output Status Register bits S7~S0/S15~S8. GD25B512ME-Rev1.3 31 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 25 Read Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 7 6 SCLK Command SI 05H/35H High-Z SO SR-1/2 out 5 4 3 2 1 MSB 0 7 6 5 SR-1/2 out 4 3 2 1 0 7 MSB Figure 26 Read Status Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 SCLK Command SR out SR out 05H/35H SR-1/2 SR-1/2 IO[3:0] SR-1/2 8.10 Read Nonvolatile/Volatile Configuration Register (B5H/85H) The Read Nonvolatile/Volatile Configuration Register command is for reading the Nonvolatile/Volatile Configuration Registers. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the Configuration Register, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fC, on the falling edge of SCLK. Read Nonvolatile/Volatile Configuration Register command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 27 Read Configuration Registers Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command 24-bit address B5H/85H SI 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO 7 6 5 4 3 2 1 0 7 6 MSB 5 CR out 4 3 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 32 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 28 Read Configuration Registers Sequence (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address B5H/85H Addr. Addr. Addr. Addr. Addr. Addr. CR out CR7~0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.11 Read Extended Address Register (C8H) The Read Extended Address Register instruction is entered by driving CS# low and shifting the instruction code “C8H” into the SI pin on the rising edge of SCLK. The Extended Address Register bits are then shifted out on the SO pin at the falling edge of SCLK with most significant bit (MSB) first. When the device is in the 4-Byte Address Mode, the value of the address bits is ignored. Figure 29 Read Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 7 6 SCLK Command SI C8H High-Z SO 5 EAR out 4 3 2 1 MSB 0 7 6 5 EAR out 4 3 2 1 0 7 MSB Figure 30 Read Extended Address Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 SCLK IO[3:0] Command EAR out EAR out C8H EAR7~0 EAR7~0 EAR7~0 8.12 Read Data Bytes (03H/13H) The Read Data Bytes (READ) command is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0), and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fR, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. GD25B512ME-Rev1.3 33 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 31 Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 24-bit address 03H 23 22 21 2 1 0 MSB High-Z SO 3 MSB 7 6 5 Data Out1 4 3 2 1 Data Out2 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.13 Read Data Bytes at Higher Speed (0BH/0CH) The Read Data Bytes at Higher Speed (Fast Read) command is for quickly reading data out. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency f C, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 32 Read Data Bytes at Higher Speed Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 0BH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 SO Data Out1 5 4 3 2 7 6 MSB 1 0 Data Out2 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 33 Read Data Bytes at Higher Speed Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 13 14 15 SCLK IO[3:0] dummy Command Address 0BH Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 34 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 8.14 Quad Output Fast Read (6BH/6CH) The Quad Output Fast Read command is followed by 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 34 Quad Output Fast Read Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command 24-bit address 6BH IO0 23 22 21 IO1 High-Z IO2 High-Z IO3 High-Z CS# 3 2 1 0 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Clocks IO0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 35 Quad Output Fast Read Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 13 14 15 SCLK IO[3:0] dummy Command Address 6BH Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.15 Quad I/O Fast Read (EBH/ECH) The Quad I/O Fast Read command is similar to the Quad Output Fast Read command but with the capability to input the 3Byte address (A23-0) or a 4-Byte address (A31-A0) and a “Continuous Read Mode” Byte and dummy clocks. 4-bit per clock is transferred by IO0, IO1, IO2, IO3, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. GD25B512ME-Rev1.3 35 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-Byte address (A23-A0) or 4-Byte address (A31-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH/ECH command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the command code, thus returning to normal operation. The only way to quit the Quad I/O Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 36 Quad I/O Fast Read Sequence Diagram (SPI, M5-4≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 19 20 21 22 23 SCLK Dummy Command EBH 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 IO0 A23-16 A15-8 A7-0 M7-0 Byte1 Byte2 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 37 Quad I/O Fast Read Sequence Diagram (QPI, M5-4≠ (1, 0)) CS# 0 1 2 7 8 9 10 13 14 15 SCLK IO[3:0] Command Address EBH Addr. dummy M7-4 M3-0 Byte 1 Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 38 Quad I/O Fast Read Sequence Diagram (QPI, M5-4= (1, 0)) CS# 0 5 6 7 8 11 12 13 SCLK dummy Address IO[3:0] Addr. M7-4 M3-0 Byte 1 Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O Fast Read command can be used to access a specific portion within a page by issuing Wrap configuration register Byte prior to EBH/ECH. The data being accessed can be limited to either a 16/32/64-Byte section of a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the GD25B512ME-Rev1.3 36 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 8.16 Quad I/O DTR Read (EDH/EEH) The Quad I/O DTR Read instruction enables Double Transfer Rate throughput on quad I/O of Serial Flash in read mode. The address (interleave on 4 I/O pins) is latched on both rising and falling edge of SCLK, and data (interleave on 4 I/O pins) shift out on both rising and falling edge of SCLK. The 8-bit address can be latched-in at one clock, and 8-bit data can be read out at one clock, which means four bits at rising edge of clock, the other four bits at falling edge of clock. The first address Byte can be at any location. The address is automatically increased to the next higher address after each Byte data is shifted out, so the whole memory can be read out at a single Quad I/O DTR Read command. The address counter rolls over to 0 when the highest address has been reached. While Program/Erase/Write Status Register cycle is in progress, Quad I/O DTR Read command is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 39. DTR Quad I/O Fast Read Sequence Diagram (SPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 16 17 18 SCLK Command EDH IO0 Dummy 4 0 4 0 4 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 A23-0 7 3 7 3 M7-0 Byt e1 Byte2 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 40. DTR Quad I/O Fast Read Sequence Diagram (QPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 10 11 12 SCLK Command IO[3:0] EDH dummy Address A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 Byte 1 Byte 2 Byte n D7- D3- D7- D3D4 D0 D4 D0 Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Read with “Continuous Read Mode” The Quad I/O DTR Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input address. If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O DTR Read command (after CS# is raised and then lowered) does not require the EDH/EEH command code. If the “Continuous Read GD25B512ME-Rev1.3 37 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Mode” bits (M5-4) do not equal to (1, 0), the next command requires the first EDH/EEH command code, thus returning to normal operation. The only way to quit the Quad I/O DTR Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 41. DTR Quad I/O Fast Read Sequence Diagram (M5-4 = (1, 0)) CS# 0 1 2 3 4 5 8 9 10 SCLK dummy Address IO[3:0] A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 Byte 1 Byte 2 Byte n D7- D3- D7- D3D4 D0 D4 D0 Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O DTR Fast Read command can be used to access a specific portion within a page by issuing Wrap configuration register Byte prior to EDH/EEH. The data being accessed can be limited to either a 16/32/64-Byte section of a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 8.17 Page Program (PP) (02H/12H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three or four address Bytes and at least one data Byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low → sending Page Program command → 3-Byte address or 4-Byte address on SI → at least 1 Byte data on SI → CS# goes high. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. GD25B512ME-Rev1.3 38 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 42 Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 3 2 1 0 7 6 5 4 3 2 1 0 2078 2079 2076 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2077 2072 CS# 2075 MSB 2074 MSB 2073 02H SI Data Byte 1 1 0 SCLK Data Byte 2 7 SI 6 5 4 3 2 Data Byte 3 1 MSB 0 7 6 5 4 3 2 Data Byte 256 1 MSB 0 7 6 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 43 Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address Byte 1 Byte 2 02H Addr. Data in Data in Byte 256 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.18 Quad Page Program (32H/34H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The quad Page Program command is entered by driving CS# Low, followed by the command code (32H/34H), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Quad Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. GD25B512ME-Rev1.3 39 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 44 Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 32H 23 22 21 3 0 4 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 537 539 540 541 542 543 1 538 2 Byte1 Byte2 0 4 0 IO0 CS# 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 536 MSB SCLK Byte11Byte12 Byte253 Byte256 IO0 4 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 4 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 45 Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address Byte 1 Byte 2 32H Addr. Data out Data out Byte 256 Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.19 Extend Quad Page Program (C2H/3EH) The Extend Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The extend quad Page Program command is entered by driving CS# Low, followed by the command code (C2H/3EH), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are GD25B512ME-Rev1.3 40 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Extend Quad Page Program (EPP) command is not executed. As soon as CS# is driven high, the self-timed Extend Quad Page Program cycle (whose duration is tPP) is initiated. While the Extend Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Extend Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. An Extend Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. Figure 46 Extend Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Address Command C2H 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 7 IO0 A23-16 A15-8 A7-0 Byte1 Byte2 Byte3 Byte4 Byte5 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 47 Extend Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address Byte 1 Byte 2 C2H Addr. Data out Data out Byte 256 Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.20 Sector Erase (SE) (20H/21H) The Sector Erase (SE) command is erased the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3- Byte address or 4-Byte address on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low → sending Sector Erase command → 3-Byte address or 4-Byte address on SI → CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Sector Erase GD25B512ME-Rev1.3 41 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) command applied to a sector which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 48 Sector Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 20H 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 49 Sector Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 20H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.21 32KB Block Erase (BE32) (52H/5CH) The 32KB Block Erase command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 32KB Block Erase command. CS# must be driven low for the entire duration of the sequence. The 32KB Block Erase command sequence: CS# goes low → sending 32KB Block Erase command → 3-Byte address or 4-Byte address on SI → CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 32KB Block Erase command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE1) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 50 32KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 52H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 42 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 51 32KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 52H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.22 64KB Block Erase (BE64) (D8H/DCH) The 64KB Block Erase command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 64KB Block Erase command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low → sending 64KB Block Erase command → 3-Byte address or 4-Byte address on SI → CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 64KB Block Erase command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE2) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 52 64KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address D8H 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 53 64KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK IO[3:0] Command Address D8H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.23 Chip Erase (CE) (60H/C7H) The Chip Erase (CE) command is erased the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the entire duration of the sequence. GD25B512ME-Rev1.3 43 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME The Chip Erase command sequence: CS# goes low → sending Chip Erase command → CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the self-timed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, and BP0) bits are 0 The Chip Erase (CE) command is ignored if one or more sectors are protected. Figure 54 Chip Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 60H/C7H SI Figure 55 Chip Erase Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] 60H/C7H 8.24 Enable QPI (38H) The device support both Standard/Quad SPI and QPI mode. The “Enable QPI (38H)” command can switch the device from SPI mode to QPI mode. In order to switch the device to QPI mode, “Enable QPI (38H)” command must be issued. When the device is switched from SPI mode to QPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 56 Enable QPI mode command Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 38H 8.25 Disable QPI (FFH) To exit the QPI mode and return to Standard/Quad SPI mode, the “Disable QPI (FFH)” command must be issued. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. GD25B512ME-Rev1.3 44 January 2022 Uniform Sector Standard and Quad Serial Flash Figure 57 GD25B512ME Disable QPI mode command Sequence Diagram CS# 0 1 SCLK Command IO[3:0] FFH 8.26 Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down (ABH) or Enable Reset (66H) and Reset (99H) commands. These commands can release the device from this mode. The Release from Deep Power-Down command releases the device from deep power down mode. The Deep Power-Down Mode automatically stops at Power-Down, and the device is in the Standby Mode after Power-Up. The Deep Power-Down command sequence: CS# goes low → sending Deep Power-Down command → CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of t DP before the supply current is reduced to ICC2 and the Deep Power-Down Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 58 Deep Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 tDP 7 SCLK Command SI Deep Power-down mode B9H Figure 59 Deep Power-Down Sequence Diagram (QPI) CS# 0 1 tDP SCLK Deep Power-down mode Command IO[3:0] B9H 8.27 Release from Deep Power-Down (ABH) To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must GD25B512ME-Rev1.3 45 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME remain high during the tRES1 time duration. When used to release the device from the Power-Down state, the command is the same as previously described, After this time duration the device will resume normal operation and other command will be accepted. If the Release from PowerDown command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not have any effects on the current cycle. Figure 60 Release Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 t RES1 7 SCLK Command ABH SI Deep Power-down mode Stand-by mode Figure 61 Release Power-Down Sequence Diagram (QPI) CS# 0 1 tRES1 SCLK Deep Power-down mode Command IO[3:0] Stand-by mode ABH 8.28 Read Unique ID (4BH) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low → sending Read Unique ID command → 3-Byte (000000H) or 4Byte (00000000H) Address →1 Byte Dummy →128bit Unique ID Out →CS# goes high. Figure 62 Read Unique ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 4BH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 Data Out2 7 6 5 4 3 2 1 0 7 6 5 MSB MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. SO GD25B512ME-Rev1.3 46 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 63 Read Unique ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command IO[3:0] 4BH Address (000000H) Addr. Addr. Addr. Addr. Addr. Addr. dummy Byte 1 Byte 2 UID out UID out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.29 Read Identification (RDID) (9FH/9EH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by three Bytes of device identification. The device identification indicates the memory type in the first Byte, and the memory capacity of the device in the second Byte. The Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# low. Then, the 8-bit command code for the command is shifted in. This is followed by the 32-bit device identification, stored in the memory. Each bit is shifted out on the falling edge of Serial Clock. The Read Identification (RDID) command is terminated by driving CS# high at any time during data output. When CS# is driven high, the device is in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. Figure 64 Read Identification ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK SI 9FH/9EH SO CS# 7 6 MSB Manufacturer ID 5 4 3 2 1 0 7 Memory Type ID23-16 6 5 4 3 2 1 0 MSB 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI SO 7 Capacity ID15-8 6 5 4 3 2 1 MSB Device ID7-0 0 7 6 5 4 3 2 Manufacturer ID 1 0 MSB 7 6 5 4 3 2 1 0 MSB Figure 65 Read Identification ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command IO[3:0] GD25B512ME-Rev1.3 9FH/9EH (MID & DID) LOOP MID7~0 DID23~16 47 DID15~8 (MID & DID) LOOP DID7~0 MID7~0 DID January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 8.30 Program/Erase Suspend (PES) (75H) The Program/Erase Suspend command “75H”, allows the system to interrupt a page program or sector/block erase operation and then read data from any other sector or block. The Write Register command (01H, B1H) and Erase/Program Security Registers command (44H, 42H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) and Page Program command (02H/12H, 32H/34H, C2H/3EH) are not allowed during Program suspend. The Write Register command (01H, B1H) and Erase Security Registers command (44H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) are not allowed during Erase suspend. Program/Erase Suspend is valid only during the page program or sector/block erase operation. A maximum of time of “tsus” (See AC Characteristics) is required to suspend the program/erase operation. The Program/Erase Suspend command will be accepted by the device only if the SUS2/SUS1 bit in the Status Register equal to 0 and WIP bit equal to 1 while a Page Program or a Sector or Block Erase operation is on-going. If the SUS2/SUS1 bit equal to 1 or WIP bit equal to 0, the Suspend command will be ignored by the device. The WIP bit will be cleared from 1 to 0 within “tsus” and the SUS2/SUS1 bit will be set from 0 to 1 immediately after Program/Erase Suspend. A power-off during the suspend period will reset the device and release the suspend state. Figure 66 Program/Erase Suspend Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 tSUS SCLK Command SI 75H High-Z SO Accept read command Figure 67 Program/Erase Suspend Sequence Diagram (QPI) CS# 0 1 tSUS SCLK Accept read command Command IO[3:0] 75H 8.31 Program/Erase Resume (PER) (7AH) The Program/Erase Resume command must be written to resume the program or sector/block erase operation after a Program/Erase Suspend command. The Program/Erase Resume command will be accepted by the device only if the SUS2/SUS1 bit equal to 1 and the WIP bit equal to 0. After issued the SUS2/SUS1 bit in the status register will be cleared from 1 to 0 immediately, the WIP bit will be set from 0 to 1 within 200ns and the Sector or Block will complete the erase operation or the page will complete the program operation. The Program/Erase Resume command will be ignored unless a Program/Erase Suspend is active. GD25B512ME-Rev1.3 48 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 68 Program/Erase Resume Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7AH Resume Erase/Program Figure 69 Program/Erase Resume Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] Resume Program/Erase 7AH 8.32 Erase Security Registers (44H) The GD25B512ME provides 4K-Byte Security Registers which can be erased and programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low → sending Erase Security Registers command → CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit in the Status Register can be used to OTP protect the security registers. Once the bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-0 Don’t care Figure 70 Erase Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 44H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 49 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 71 Erase Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 44H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.33 Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. The security register contains 16 pages content. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address Bytes and at least one data Byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-8 Page Address A7-0 Byte Address Figure 72 Program Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 3 2 Data Byte 1 1 0 7 5 4 3 2 1 0 2078 2079 6 2077 7 2076 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2075 CS# 2073 MSB 2072 MSB 6 2074 42H SI 1 0 SCLK Data Byte 2 SI 7 MSB 6 5 4 3 2 Data Byte 3 1 0 7 6 5 4 3 MSB 2 Data Byte 256 1 0 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 50 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 73 Program Security Registers command Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK Command Address Byte 1 Byte 2 42H Addr. Data in Data in IO[3:0] Byte 256 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.34 Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3-Byte or 4-Byte address (A23-A0 or A31-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency f C, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Once the A11-A0 address reaches the last Byte of the register (Byte FFFH), it will reset to 000H, the command is completed by driving CS# high. Address Security Register A23-16 00H A15-12 0000 A11-8 Page Address A7-0 Byte Address Figure 74 Read Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 48H 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 7 MSB SO Data Out1 6 5 4 3 2 1 Data Out2 0 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 75 Read Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 23 24 25 SCLK IO[3:0] dummy Command Address 48H Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 51 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 8.35 Individual Block/Sector Lock (36H)/Unlock (39H)/Read (3DH) The individual block/sector lock provides an alternative way to protect the memory array from adverse Erase/Program. In order to use the Individual Block/Sector Locks, the WPS bit in Configuration Register bit 2 at address 04h must be set to 0. If WPS=1, the write protection will be determined by the combination of BP (4:0) bits in the Status Register. The individual Block/Sector Lock command (36H) sequence: CS# goes low →SI: Sending individual Block/Sector Lock command→ SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address → CS# goes high. The individual Block/Sector Unlock command (39H) sequence: CS# goes low →SI: Sending individual Block/Sector Unlock command→ SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address → CS# goes high. The Read individual Block/Sector lock command (3DH) sequence: CS# goes low → SI: Sending Read individual Block/Sector Lock command→ SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address → SO: The Block/Sector Lock Bit will out →CS# goes high. If the least significant bit (LSB) is1, the corresponding block/sector is locked, if the LSB is 0, the corresponding block/sector is unlocked, Erase/Program operation can be performed. Figure 76 Individual Block/Sector Lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 36H 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 77 Individual Block/Sector Lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 36H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 78 Individual Block/Sector Unlock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 39H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. GD25B512ME-Rev1.3 52 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 79 Individual Block/Sector Unlock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 39H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 80 Read Individual Block/Sector lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 3DH 23 22 3 2 Lock value out X X X X X X X 0 High-Z SO 4 MSB MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 81 Read Individual Block/Sector lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address 3DH Addr. Addr. Addr. Addr. Addr. Addr. Data out Lock Value Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 8.36 Global Block/Sector Lock (7EH) or Unlock (98H) All Block/Sector Lock bits can be set to 1 by the Global Block/Sector Lock command, or can set to 0 by the Global Block/Sector Unlock command. The Global Block/Sector Lock command (7EH) sequence: CS# goes low →SI: Sending Global Block/Sector Lock command→ CS# goes high. The Global Block/Sector Unlock command (98H) sequence: CS# goes low →SI: Sending Global Block/Sector Unlock command→ CS# goes high. Figure 82 Global Block/Sector Lock Sequence Diagram (SPI) CS# 0 1 SCLK Command IO[3:0] GD25B512ME-Rev1.3 7EH 53 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 83 Global Block/Sector Lock Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7EH High-Z SO Figure 84 Global Block/Sector Unlock Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 98H High-Z SO Figure 85 Global Block/Sector Unlock Sequence Diagram (QPI) CS# 0 1 SCLK Command IO[3:0] 98H 8.37 Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation (except in Continuous Read Mode) will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Program/Erase Suspend status, Read Parameter setting (P7-P0), Deep Power Down Mode, Continuous Read Mode bit setting (M7-M0). When Flash is in QPI Mode or Continuous Read Mode (XIP), 66H&99H cannot reset Flash to power-on state. Therefore, it is recommended to send the following sequence to reset Flash in these modes: 1. 8CLK with IO= all “H” or all “L”: ensure Flash quit XIP mode 2. QPI format 66H/99H: ensure Flash in QPI mode can be reset 3. SPI format 66H/99H: ensure Flash in SPI mode can be reset The “Enable Reset (66H)” and the “Reset (99H)” commands can be issued in either SPI or QPI mode. The “Reset (99H)” command sequence as follow: CS# goes low → Sending Enable Reset command → CS# goes high → CS# goes low → Sending Reset command → CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST / tRST_E to reset. During this period, no command will be accepted. Data corruption may happen if there is an on-going or suspended internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the WIP bit and the SUS2/SUS1 bits in Status Register before issuing the Reset command sequence. GD25B512ME-Rev1.3 54 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 86 Enable Reset and Reset command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command Command 66H 99H SI High-Z SO Figure 87 Enable Reset and Reset command Sequence Diagram (QPI) CS# 0 1 0 1 SCLK Command Command 66H 99H IO[3:0] 8.38 Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216B. Figure 88 Read Serial Flash Discoverable Parameter command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 5AH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO GD25B512ME-Rev1.3 7 6 5 4 3 2 1 0 7 6 MSB 55 Data Out1 5 4 3 2 1 0 Data Out2 7 6 5 MSB January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 89 Read Serial Flash Discoverable Parameter command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address 5AH Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Byte 2 SFDP out SFDP Table 15 Signature and Parameter Identification Data Values (Please contact GigaDevice for details) GD25B512ME-Rev1.3 56 January 2022 Uniform Sector Standard and Quad Serial Flash 9 GD25B512ME ELECTRICAL CHARACTERISTICS 9.1 Power-On Timing Figure 90 Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) Device is fully accessible tVSL VWI Time Table 16 Power-Up Timing and Write Inhibit Threshold Symbol Parameter Min. tVSL VCC (min.) to device operation 1.8 VWI Write Inhibit Voltage 1.5 Max. Unit ms 2.5 V 9.2 Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1 (each Byte contains FFH). The Status Register contains 00H (all Status Register bits are 0). 9.3 Absolute Maximum Ratings Parameter Value Ambient Operating Temperature (TA) -40 to 85 Unit ℃ -40 to 105 -40 to 125 ℃ Storage Temperature -65 to 150 Transient Input/Output Voltage (note: overshoot) -2.0 to VCC+2.0 V Applied Input/Output Voltage -0.6 to VCC+0.4 V -0.6 to 4.2 V VCC GD25B512ME-Rev1.3 57 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 91. Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns Maximum Positive Overshoot Waveform 20ns 20ns Vss Vcc + 2.0V Vss-2.0V Vcc 20ns 20ns 20ns 9.4 Capacitance Measurement Conditions Symbol CIN/COUT CIN COUT CL Parameter Min Typ. Input/Output Capacitance Max Unit Conditions VIN=0V 14 pF Input Capacitance (except IO pins) 10 pF VIN=0V Output Capacitance (except IO pins) 10 pF VOUT=0V (IO pins: IO[3:0]) Load Capacitance 30 pF Input Rise And Fall time 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.3VCC to 0.7VCC V Output Timing Reference Voltage VOUT=0V 0.5VCC V Figure 92. Absolute Maximum Ratings Diagram Input timing reference level 0.8VCC 0.7VCC 0.1VCC 0.3VCC Output timing reference level AC Measurement Level 0.5VCC Note: Input pulse rise and fall time are50MHz) 0.3 V/ns 0.6 V/ns tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX tCHQX tDVCH tDVCH tDVCL tCHDX tCHDX tCLDX Output Disable Time 8 Output Hold Time ns 1.8 ns Data In Setup Time (STR) 2 ns Data In Setup Time (DTR) 1 ns Data In Hold Time (STR) 2 ns Data In Hold Time (DTR) 1 ns Clock Low To Output Valid (VCC=2.7~3.0V, loading=30pF) Clock Low To Output Valid (VCC=2.7~3.0V, tCLQV loading=10pF) tCHQV Clock Low To Output Valid (VCC=3.0~3.6V, loading=30pF, CR = xxxx xx00b) Clock Low To Output Valid (VCC=3.0~3.6V, loading=10pF,CR = xxxx xx00b) 8 ns 7 ns 7 ns 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns GD25B512ME-Rev1.3 62 January 2022 Uniform Sector Standard and Quad Serial Flash tDP tRES1 CS# High To Deep Power-Down Mode CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST GD25B512ME 3 μs 30 μs 20 μs 100 μs CS# High To Next Command After Reset (From Read 40 μs 25 ms 5 30 ms or From Program) CS# High To Next Command After Reset (From Erase tRST_E or From Write Status/Non-volatile Configuration Register) tW Write Status/Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 50 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 12 μs tPP Page Programming Time 0.15 1.0 ms tSE Sector Erase Time 30 400 ms tBE1 Block Erase Time (32K Bytes) 0.15 1.5 s tBE2 Block Erase Time (64K Bytes) 0.22 2 s tCE Chip Erase Time (GD25B512ME) 150 300 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST GD25B512ME-Rev1.3 63 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME (TA = -40℃~105℃, VCC=2.7~3.6V) Symbol fC1 fC2 fR Parameter Min. Serial Clock Frequency for all instructions except 03H, 13H, EEH, EDH Serial Clock Frequency for DTR Quad I/O Fast Read (EEH, EDH) instructions Serial Clock Frequency For: Read (03H, 13H) tCLH Serial Clock High Time tCLL Serial Clock Low Time (fSCLK≤50MHz) tCHCL Serial Clock Rise/Fall Time (Slew Rate) Max. Unit. 133 MHz 90 MHz 60 MHz 45% ns (1/fcmax) 45% ns (1/fcmax) Serial Clock Rise/Fall Time (Slew Rate) tCLCH Typ. (fSCLK>50MHz) 0.3 V/ns 0.6 V/ns tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX tCHQX tDVCH tDVCH tDVCL tCHDX tCHDX tCLDX Output Disable Time 8 Output Hold Time ns 1.8 ns Data In Setup Time (STR) 2 ns Data In Setup Time (DTR) 1 ns Data In Hold Time (STR) 2 ns Data In Hold Time (DTR) 1 ns Clock Low To Output Valid (VCC=2.7~3.0V, loading=30pF) Clock Low To Output Valid (VCC=2.7~3.0V, tCLQV loading=10pF) tCHQV Clock Low To Output Valid (VCC=3.0~3.6V, loading=30pF, CR = xxxx xx00b) Clock Low To Output Valid (VCC=3.0~3.6V, loading=10pF,CR = xxxx xx00b) 8 ns 7 ns 7 ns 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode GD25B512ME-Rev1.3 3 64 μs January 2022 Uniform Sector Standard and Quad Serial Flash tRES1 CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST GD25B512ME 30 μs 20 μs 100 μs CS# High To Next Command After Reset (From Read 40 μs 25 ms 5 40 ms or From Program) CS# High To Next Command After Reset (From Erase tRST_E or From Write Status/Non-volatile Configuration Register) tW Write Status/Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 140 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 25 μs tPP Page Programming Time 0.15 2.0 ms tSE Sector Erase Time 30 600 ms tBE1 Block Erase Time (32K Bytes) 0.15 1.6 s tBE2 Block Erase Time (64K Bytes) 0.22 3 s tCE Chip Erase Time (GD25B512ME) 150 450 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST GD25B512ME-Rev1.3 65 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME (TA = -40℃~125℃, VCC=2.7~3.6V) Symbol fC1 fC2 fR Parameter Min. Serial Clock Frequency for all instructions except 03H, 13H, EEH, EDH Serial Clock Frequency for DTR Quad I/O Fast Read (EEH, EDH) instructions Serial Clock Frequency For: Read (03H, 13H) tCLH Serial Clock High Time tCLL Serial Clock Low Time (fSCLK≤50MHz) tCHCL Serial Clock Rise/Fall Time (Slew Rate) Max. Unit. 133 MHz 84 MHz 60 MHz 45% ns (1/fcmax) 45% ns (1/fcmax) Serial Clock Rise/Fall Time (Slew Rate) tCLCH Typ. (fSCLK>50MHz) 0.3 V/ns 0.6 V/ns tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX tCHQX tDVCH tDVCH tDVCL tCHDX tCHDX tCLDX Output Disable Time 8 Output Hold Time ns 1.8 ns Data In Setup Time (STR) 2 ns Data In Setup Time (DTR) 1 ns Data In Hold Time (STR) 2 ns Data In Hold Time (DTR) 1 ns Clock Low To Output Valid (VCC=2.7~3.0V, loading=30pF) Clock Low To Output Valid (VCC=2.7~3.0V, tCLQV loading=10pF) tCHQV Clock Low To Output Valid (VCC=3.0~3.6V, loading=30pF, CR = xxxx xx00b) Clock Low To Output Valid (VCC=3.0~3.6V, loading=10pF,CR = xxxx xx00b) 8 ns 7 ns 7 ns 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode GD25B512ME-Rev1.3 3 66 μs January 2022 Uniform Sector Standard and Quad Serial Flash tRES1 CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST GD25B512ME 30 μs 20 μs 100 μs CS# High To Next Command After Reset (From Read 40 μs 25 ms 5 40 ms or From Program) CS# High To Next Command After Reset (From Erase tRST_E or From Write Status/Non-volatile Configuration Register) tW Write Status/Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 140 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 25 μs tPP Page Programming Time 0.15 2.0 ms tSE Sector Erase Time 30 800 ms tBE1 Block Erase Time (32K Bytes) 0.15 1.6 s tBE2 Block Erase Time (64K Bytes) 0.22 3 s tCE Chip Erase Time (GD25B512ME) 150 500 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST Figure 93. Serial Input Timing tSHSL CS# tCHSL tSLCH tCHSH tSHCH SCLK tDVCH SI MSB SO High-Z GD25B512ME-Rev1.3 tCHCL tCLCH tCHDX LSB 67 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 94. Output Timing CS# tCLH SCLK tCLQV tCLQV tCLQX tSHQZ tCLL tCLQX SO LSB SI Least significant address bit (LIB) in Figure 95. Serial Input Timing (DTR) tSHSL CS# tSLCH tCLSH tCHSL tSHCH SCLK tDVCL tDVCH tCLDX IO tCLCH tCHCL MSB LSB tCHDX Figure 96. Serial Output Timing (DTR) CS# tCLQV tCLH SCLK IO tCLL tCHQV tCLQX tSHQZ MSB LSB tCHQX Figure 97. Resume to Suspend Timing Diagram CS# GD25B512ME-Rev1.3 Resume Command tRS 68 Suspend Command January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Figure 98. WP# Timing CS# tWHSL tSHWL WP# SCLK IO Input Write Status Register allowed Write Status Register NOT allowed Figure 99. RESET Timing tRB CS# RESET# tRLRH tRHSL Table 17. Reset Timing Symbol Parameter Min. Typ. Max. Unit. tRLRH Reset Pulse Width 1 μs tRHSL Reset Hold time before next Operation 50 ns tRB Reset Recovery Time (From Read or Program) 40 μs Reset Recovery Time (From Erase) 25 ms Note: 1. Time of Reset Recovery Time from 01H/B1H command would be tW + tRB 2. The device need tRB (max) at most to get ready for all commands after RESET# low. GD25B512ME-Rev1.3 69 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 10 ORDERING INFORMATION GD XX XX XX X X X X X Packing T or no mark: Tube Y: Tray R: Tape and Reel Green Code G: Pb Free + Halogen Free Green Package S: Pb Free + Halogen Free Green Package + SRP1 Function R: Pb Free + Halogen Free Green Package + RESET# Pin K: Pb Free + Halogen Free Green Package + RESET# Pin + SRP1 Function Temperature Range I: Industrial (-40℃ to +85℃) J: Industrial+ (-40℃ to +105℃) E: Industrial+ (-40℃ to +125℃) F: Industrial+ (-40℃ to +85℃)** 3: Automotive (-40℃ to +85℃)* 2: Automotive (-40℃ to +105℃)* A: Automotive (-40℃ to +125℃)* Package Type F: SOP16 300mil Y: WSON8 (8x6mm) B: TFBGA-24ball (5x5 Ball Array) Generation E: E Version Density 512M: 512M bit Series B: 3V, 4KB Uniform Sector, default x4I/O Product Family 25: SPI NOR Flash *Please contact GigaDevice sales for automotive products. **F grade has implemented additional test flows to ensure higher product quality than I grade. GD25B512ME-Rev1.3 70 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 10.1 Valid Part Numbers Please contact GigaDevice regional sales for the latest product selection and available form factors. Temperature Range I: Industrial (-40℃ to +85℃) Product Number Clock GD55B512MEFIR GD55B512MEFIK GD55B512MEYIG GD55B512MEYIS GD55B512MEBIR 133MHz 133MHz 133MHz 133MHz 133MHz GD55B512MEBIK 133MHz Density Package Type 512Mbit SOP16 300mil 512Mbit WSON8 (8x6mm) 512Mbit TFBGA-24ball (5x5 Ball Array) Packing Options T/Y/R T/Y/R Y/R Y/R Y/R Y/R Temperature Range J: Industrial+ (-40℃ to +105℃) Product Number Clock GD55B512MEFJR GD55B512MEFJK GD55B512MEYJG GD55B512MEYJS GD55B512MEBJR 133MHz 133MHz 133MHz 133MHz 133MHz GD55B512MEBJK 133MHz Density Package Type 512Mbit SOP16 300mil 512Mbit WSON8 (8x6mm) 512Mbit TFBGA-24ball (5x5 Ball Array) Packing Options T/Y/R T/Y/R Y/R Y/R Y/R Y/R Temperature Range E: Industrial+ (-40℃ to +125℃) Product Number Clock GD55B512MEFER GD55B512MEFEK GD55B512MEYEG GD55B512MEYES GD55B512MEBER 133MHz 133MHz 133MHz 133MHz 133MHz GD55B512MEBEK 133MHz GD25B512ME-Rev1.3 Density Package Type 512Mbit SOP16 300mil 512Mbit WSON8 (8x6mm) 512Mbit TFBGA-24ball (5x5 Ball Array) 71 Packing Options T/Y/R T/Y/R Y/R Y/R Y/R Y/R January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Temperature Range F: Industrial+ (-40℃ to +85℃) Product Number Clock GD55B512MEFFR GD55B512MEFFK GD55B512MEYFG GD55B512MEYFS GD55B512MEBFR 133MHz 133MHz 133MHz 133MHz 133MHz GD55B512MEBFK 133MHz GD25B512ME-Rev1.3 Density Package Type 512Mbit SOP16 300mil 512Mbit WSON8 (8x6mm) 512Mbit TFBGA-24ball (5x5 Ball Array) 72 Packing Options T/Y/R T/Y/R Y/R Y/R Y/R Y/R January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 11 PACKAGE INFORMATION 11.1 Package SOP16 300MIL D 16 9 E1 E h L 1 h 8 L1 θ A b Base Metal c A2 A 0.1 C SEATING PLANE b A1 e Detail A Dimensions Symbol A A1 A2 b c D E E1 Min - 0.10 2.05 0.31 0.10 10.20 10.10 7.40 Nom - 0.20 - 0.41 0.25 10.30 10.30 7.50 Max 2.65 0.30 2.55 0.51 0.33 10.40 10.50 7.60 Unit mm e L L1 0.40 1.27 1.27 1.40 h θ 0.25 0 - - 0.75 8 Note: 1. Both the package length and width do not include the mold flash. GD25B512ME-Rev1.3 73 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 11.2 Package WSON8 (8x6mm) c D PIN 1# E A1 A Top View Side View D2 4 5 E2 e b 1 8 L Bottom View Dimensions Symbol A A1 c b D D2 E E2 Min 0.70 0.00 0.180 0.35 7.90 3.30 5.90 4.20 Nom 0.75 0.02 0.203 0.40 8.00 3.40 6.00 4.30 Max 0.80 0.05 0.250 0.45 8.10 3.50 6.10 4.40 Unit mm e L 0.45 1.27 0.50 0.55 Note: 1. Both the package length and width do not include the mold flash. 2. The exposed metal pad area on the bottom of the package is floating. 3. Coplanarity ≤0.08mm. Package edge tolerance≤0.10mm. 4. The lead shape may be of little difference according to different package lead frames. These lead shapes are compatible with each other. GD25B512ME-Rev1.3 74 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 11.3 Package TFBGA-24BALL (5x5 ball array) 1 2 3 4 5 5 4 3 2 1 A A B B b C D C D1 D D e E E e E E1 A2 A A1 Dimensions Symbol A A1 A2 b E Min - 0.25 0.75 0.35 5.90 Nom - 0.30 0.80 0.40 6.00 Max 1.20 0.35 0.85 0.45 6.10 Unit mm E1 D D1 e 4.00 1.00 7.90 4.00 8.00 8.10 Note: Both the package length and width do not include the mold flash. GD25B512ME-Rev1.3 75 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME 12 REVISION HISTORY Version No 1.0 1.1 Description Initial Release Page Date All 2020-9-28 Modify VIL from 0.2VCC to 0.3VCC P59, 60, 61 Modify tCHSH/tCLSH from 3ns to 4ns P62, 64, 66 Modify tSHCH from 3ns to 5ns P62, 64, 66 Update Description of RESET# P5-P7 2020-12-15 Modify Quad Output Fast Read(6BH,6CH) Max Frequency from 1.2 166Mhz to 133Mhz P4, P59-67 Modify Supported Clock Frequencies P21 Update ILI / ILO of 125℃ from ±2μA to ±3μA P61 Add Note of WP# Pin P6-7 Modify Typo of DLP 1.3 P20-21 Modify Description of AC parameter tCLCH/tCHCL Update Ordering Information P62, P64, P66 2022-1-10 P70-72 Add Coplanarity of SOP16 GD25B512ME-Rev1.3 2021-5-10 P73 76 January 2022 Uniform Sector Standard and Quad Serial Flash GD25B512ME Important Notice This document is the property of GigaDevice Semiconductor (Beijing) Inc. and its subsidiaries (the "Company"). This document, including any product of the Company described in this document (the “Product”), is owned by the Company according to the laws of the People’s Republic of China and other applicable laws. The Company reserves all rights under such laws and no Intellectual Property Rights are transferred (either wholly or partially) or licensed (either expressly or impliedly). The names and brands of third party referred thereto (if any) are the property of their respective owner and referred to for identification purposes only. The Company does not assume any warranty or condition, express or implied, with regard to this document or any Product, including, but not limited to, the implied warranties of merchantability, fitness for any particular purpose, noninfringement, or any warranty arising out of the application or use of any Product described in this document. Any information provided in this document is provided only for reference purposes. It is the responsibility of the user of this document to properly design, program, and test the functionality and safety of any application and any product produced. Except for customized products which has been expressly identified in the applicable agreement, the Products are designed, developed, and/or manufactured for ordinary business, industrial, personal, and/or household applications only. The Products are not designed or intended for use in, and no warranty is made respect to, any applications designed or intended for the operation of weaponry, nuclear equipment, atomic energy control instruments, combustion control instruments, airplane or spaceship instruments, traffic signal instruments, life-support devices or systems, other medical devices or systems (including resuscitation equipment and surgical implants etc.), pollution control or hazardous substances management, or other uses where failure to perform can reasonably be expected to result in personal injury, death, property or environmental damage ("Unintended Uses"). Customers shall take any and all actions to ensure using and selling the Products in accordance with the applicable laws and regulations. The Company is not liable, in whole or in part, and customers shall and hereby do release the Company as well as it’s suppliers and/or distributors from any claim, damage, or other liability arising from or related to all Unintended Uses of the Products. Customers shall indemnify and hold the Company as well as it’s suppliers and/or distributors harmless from and against all claims, costs, damages, and other liabilities, including claims for personal injury or death, arising from or related to any Unintended Uses of the Products. Customers shall discard the device according to the local environmental law. Information in this document is provided solely in connection with the Products. The Company reserves the right to make changes, corrections, modifications or improvements to this document and the Products and services described herein at any time, without notice. And the company shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to them. GD25B512ME-Rev1.3 77 January 2022
