AZ5725-01F-MS
AZ5725-01F-MS
    MSKSEMI(美森科)
    DFN-1006P2X
    双向ESD 5V截止 峰值浪涌电流:8A@8/20US
AZ5725-01F-MS 数据手册
www.msksemi.com AZ5725-01F-MS Semiconductor Schematic Diagram Pin Description Specification Features  Small Body Outline Dimensions: nom 0.039″ x 0.024″ (1.0x0.6 mm)  Low Body Height: nom 0.0 19″ (0.5 mm)  Low Capacitance 15 pF  Low Clamping Voltage  Reverse Working (Stand-off) Voltage: 5 V  Low Leakage  Response Time is Typically < 1 ns  IEC61000-4-2 Level 4 ESD Protection  This is a Pb-Free Device Compiance DFN1006P2X Mechanical Characteristics:  CASE: Void-free, transfer-molded, thermosetting plastic Epoxy Meets UL 94 V−0  LEAD FINISH: NiPdAu  MOUNTING POSITION: Any  QUALIFIED MAX REFLOW TEMPERATURE: 260°C  Device Meets MSL 1 Requirements  RoHS/WEEE Compliant  Marking: Marking code Applications  Cellular Handsets & Accessories  Personal Digital Assistants (PDAs)  Notebooks & Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  MP3 Players ELECTRICAL CHARACTERISTICS P/N VC (V) VC (V) @ IPP = 1 A @MAX IPP (Note 3) (Note 3) VRWM (V) IR1(µA) @ VRWM Max Max Max Min Max mA Max Max Max Max Max 5.0 0.5 0.3 5.6 8.0 9.8 12.5 5.5 69 15 AZ5725-01F-MS IR2(µA) VBR (V) @ IT (Note 2) @ VR=3.5V IT 1.0 IPP(A) PPK(W) (Note 3) (Note 3) C (pF) Maximum Ratings Rating Symbol IEC 61000-4-2 (ESD) Contact Peak Power Per 8 x 20µs Waveform Total Power Dissipation on FR-5 Board @ TA = 25°C ① Junction and Storage Temperature Range Lead Solder Temperature - Maximum (10 Second Duration) PPK Value ±30 70 Unit kV W PD 300 mW TJ, Tstg -55 to +150 °C TL 260 °C www.msksemi.com AZ5725-01F-MS Semiconductor Compiance Electrical Parameter Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT FIG1: Pulse Waveform FIG2:Power Derating www.msksemi.com AZ5725-01F-MS Semiconductor Compiance PACKAGE MECHANICAL DATA A Dim B C R D E MIN Millimeters MAX MIN MAX A 0.0125 0.02 0.32 0.52 B 0.000 0.002 0.00 0.05 C 0.037 0.043 0.95 1.080 D 0.022 0.027 0.55 0.680 E 0.016 0.024 0.40 0.60 F 0.008 0.012 0.20 0.30 H R F Inches 0.015Typ. 0.001 0.40Typ. 0.005 0.05 0.15 H 1.20 0.50 0.60 0.70 NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. REEL SPECIFICATION P/N PKG QTY AZ5725-01F-MS DFN1006P2X 10000 www.msksemi.com AZ5725-01F-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
AZ5725-01F-MS 价格&库存
很抱歉,暂时无法提供与“AZ5725-01F-MS”相匹配的价格&库存,您可以联系我们找货
