RB060L-40
RB060L-40
    LGE(鲁光)
    SMA(DO-214AC)
    特性:肖特基势垒整流器。 保护环保护。 低正向电压。 反向能量测试。 高电流能力。 极低的热阻
RB060L-40 数据手册
RB060L-40 Surface Mount Schottky Barrier Rectifiers REVERSE VOLTAGE: 40V FORWARD CURRENT: 2.0 A Features  SMA/DO-214AC Schottky barrier rectifier 0. 181( 4. 60) 0. 161( 4. 10)  Guardring protection  Low forward voltage  Reverse energy tested   High current capability Extremely low thermal resistance 0. 108( 2. 75) 0. 096( 2. 45) 0. 063(1.60) 0. 051(1.30) 0. 209( 5. 30) 0. 193( 4. 90) Mechanical Data 0. 012(0.30) 0. 006(0.15) 0.096(2.45) 0.078(2.00)  Case: SMA molded plastic body 1111  Polarity: Color band denotes cathode end  Mounting position: ANY  Weight: 0.002 ounces, 0.064 gram 0. 059( 1. 50) 0. 035( 0. 90) 0.008(0.20) 0. 002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS o Ratings at 25 C ambient temperature unless otherwise specified RB060L-40 UNITS Maximum repetitive peak reverse voltage VRRM 40 V Maximum RMS voltage VRWS 28 V Maximum DC blocking voltage VDC 40 V Maximum average forward rectified current at TL=90 IF(AV) 2.0 A Peak forward surge current 8.3ms single half-sine-wave IFSM 50 A Maximum instantaneous forward voltage at I FM=2.0A (NOTE1) VF 0.50 V Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range 0.4 IR R 10 JL 28 mA o C/W TJ -55 ---- +125 o C TSTG -55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com RB060L-40 Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves 2.0 FIG.2-- PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,AMPERES CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE Resistive or inductive Load 1.0 0 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 50 60 70 80 90 100 110 120 130 140 150 160 170 50 30 20 10 0 LEAD TEMPERATURE 1 10 10 0 NUMBER OF CYCLES AT 60Hz FIG.4 -- TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT,MICRO AMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG.3 -- TYPICAL FORWARD CHARACTERISTICS INSTANTANEOUS FORWARD VOLTAGE,VOLTS 10 1.0 0.1 0.01 TJ=125℃ T J=25℃ 0.001 0.001 0 20 40 60 80 1 00 PERCENT OF RATED PEAK REVERSE VOLTAGE, PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 T L =100℃ 8.3ms Single Half Sine-Wave (JED E C M ethod) 40 www.lgesemi .c o m mail:lge@lgesemi.com
RB060L-40 价格&库存
很抱歉,暂时无法提供与“RB060L-40”相匹配的价格&库存,您可以联系我们找货
RB060L-40
  • 5+0.63676
  • 50+0.51711
  • 150+0.45733
  • 500+0.41242
  • 2500+0.31085
  • 5000+0.29287
库存:214
