R141574161
R141574161
    RADIALL
    BNC
R141574161 数据手册
TECHNICAL DATA SHEET 1/2 INSULATED BULKHEAD JACK RECEPTACLE FR. MOUNT. WITH SOLD. POT CONT.+TAG-P100 R141.574.161 Series : BNC-COM All dimensions are in mm. . pn . ao COMPONENTS BODY CENTER CONTACT OUTER CONTACT INSULATOR GASKET OTHERS PARTS - PLATING (µm) MATERIALS NORYL BRASS BRASS NORYL - GOLD 0.2 OVER NICKEL 2 NICKEL 2 - Issue : 0907 D In the effort to improve our products, we reserve the right to make changes judged to be necessary. TECHNICAL DATA SHEET 2/2 R141.574.161 INSULATED BULKHEAD JACK RECEPTACLE Series : BNC-COM FR. MOUNT. WITH SOLD. POT CONT.+TAG-P100 PACKAGING Standard 100 Unit ‘W’ option SPECIFICATION Other Contact us ELECTRICAL CHARACTERISTICS ENVIRONMENTAL Impedance Operating temperature 50 Ω -35/+70 ° C Frequency Hermetic seal 0-1.5 GHz NA Atm.cm3/s VSWR Panel leakage 1.08 + 0,0060 x F(GHz) Maxi NA Insertion loss .025* √F(GHz) dB Maxi RF leakage -( 57 - F(GHz)) dB Maxi Voltage rating 500 Veff Maxi Dielectric withstanding voltage 1500 Veff mini Insulation resistance 5000 MΩ mini OTHER CHARACTERISTICS Assembly instruction Others : * Coaxial Transmission Line Only MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating end Axial force – Opposite end Torque 15 N mini 15 N mini NA N.cm mini Recommended torque Mating Panel nut NA N.cm 80 N.cm Mating life Weight 100 Cycles mini 4,7700 g Issue : 0907 D In the effort to improve our products, we reserve the right to make changes judged to be necessary.
R141574161 价格&库存
很抱歉,暂时无法提供与“R141574161”相匹配的价格&库存,您可以联系我们找货
R141574161
    • 1+107.67600
    • 200+41.66640
    • 500+40.20840
    • 1000+39.48480
