04FMS-1.0SP-TF(LF)(SN) 数据手册
FMS CONNECTOR
1.0mm
Emboss Tape
Connectors for FFC
pitch
Features ––––––––––––––––––––––––
• Compact
This connector measures 1.0mm in pitch, 2.8mm in mounting
height, and 6.3mm in width.
• Double-sided contact
This connector has highly resilient phosphor bronze contacts,
each of which has two independent mating spring members
that ensure continuity even when subjected to severe vibration.
Because each of the contacts simultaneously mates with both
sides of the FFC, the engineer has greater freedom in designing
his circuitry.
• Simple snap-in action
The FFC is securely connected by simply inserting its leads
into the connector.
• SMT configuration
The FMS series connectors are designed
for surface mounting (SMT) and to meet
the demand for high-density packaging.
They are miniature connectors with a
height of only 2.8mm, and can be supplied
packaged in embossed tape to facilitate
automatic mounting.
Its housing is made of heat resistant resin so that it is not
adversely affected during reflow soldering. Because of its tiny
size and ability to be surface mounted, this connector meets
the demand for high-density mounting of components inside
electronic products.
• Solder tabs
This connector also features reinforcing solder tabs to prevent
lifting of the connector during mating and unmating.
Specifications –––––––––––––––––––
• Current rating: 0.5A AC, DC
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/30m Ω max.
• Insulation resistance: 800M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable FFC: Conductor pitch/1.0mm
Conductor width/0.7mm
Mating part thickness/0.30±0.05mm
FFC to be actually used should be checked for applicability.
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
1
FMS
CONNECTOR
Connector –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
B
A
6.3
5.3
1.5
0.4
2.8
1.0
Dimensions (mm)
Model No.
A
B
Q'ty /
reel
3
03FMS-1.0SP-TF
2.0
5.0
2,500
4
04FMS-1.0SP-TF
3.0
6.0
2,500
5
05FMS-1.0SP-TF
4.0
7.0
2,500
6
06FMS-1.0SP-TF
5.0
8.0
2,500
8
08FMS-1.0SP-TF
7.0
10.0
2,500
10
10FMS-1.0SP-TF
9.0
12.0
2,000
11
11FMS-1.0SP-TF
10.0
13.0
2,000
12
12FMS-1.0SP-TF
11.0
14.0
2,000
14
14FMS-1.0SP-TF
13.0
16.0
2,000
Material and Finish
Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: PPS, UL94V-0
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Note: The products listed above are supplied on embossed tape.
Lead section dimensions of FFC–––––––––––––––––––––––––––––––––––––––––––––
1.0x(N+1)±0.12
1.0±0.15
1.0x(N-1)±0.1
1.0±0.1
1.0±0.15
0.3±0.05
Conductor
10.0
3.0min.
0.7±0.1
Reinforcing layer
Base layer
Film cover layer
Note: N --- Number of circuits
PC board layout (viewed from component side) and Assembly layout ––––––––––––––––––
0.6±0.05
6.3
5.3
1.0±0.05
2.8
4.0±0.1
0.75±0.1
2.5±0.1
0.8±0.1
FFC
Note:
1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. The dimensions above should serve as a guideline.
2
04FMS-1.0SP-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“04FMS-1.0SP-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.84216
- 50+1.61536
- 150+1.51816
- 500+1.39688
- 2500+1.34288
