RJ1S-C-D24
RJ1S-C-D24
    IDEC(日本和泉)
    DIP
    RJ1S-C-D24
RJ1S-C-D24 数据手册
Relays & Sockets RJ Switches & Pilot Lights RJ Series Slim Power Relays Key features: • Compact and rugged power relays. Large switching capacity • Compact housing only 12.7-mm wide. Large contact rating RJ1 (1-pole): 16A (UL general use rating @250V AC) RJ2 (2-pole): 8A • Non-polarized LED indicator available on blade type. IDEC’s unique light guide structure enables high visibility of coil status from any direction. Signaling Lights • The smallest width for 2-pole/bifurcated contact relay • Excellent electrical and mechanical life. Electrical life: 200,000 operations (AC load) Mechanical life: 30 million operations (AC coil) • RoHS directive compliant (EU directive 2002/95/EC). Contains no lead, cadmium, mercury, hexavalent chromium, PBB or PBDE. • Diode model: Diode reverse withstand voltage: 1000V CSA C22.2 No. 14 1608322 CSA File No. LR35144 UL508 UL File No. E55996 Relays & Sockets • UL recognized, CSA certified, EN compliant. EN61810-1 VDE (REG.-Nr B312) EN61810-1 EC Low Voltage Directive Part Number Selection Style Terminal Contact RJ1S-C-0 with LED RJ1S-CL-0 with Surge Suppresion Diode RJ1S-CD-0 with LED & Surge Suppresion Diode RJ1S-CLD-0 Standard RJ2S-C-0 with LED RJ2S-CL-0 with Surge Suppresion Diode RJ2S-CD-0 with LED & Surge Suppresion Diode RJ2S-CLD-0 Standard Bifurcated contacts (without LED indicator) RJ22S-C-0 Bifurated contacts (with LED indicator) RJ22S-CL-0 Bifurcated contacts diode (without LED indicator) RJ22S-CD-0 Bifurcated contacts diode (with LED indicator) RJ22S-CLD-0 Standard RJ1V-C-0 High Capacity RJ1V-CH-0 Standard RJ1V-A-0 High Capacity RJ1V-AH-0 DPDT Standard RJ2V-C-0 DPST-NO Standard RJ2V-A-0 DPDT Bifurcated contacts RJ22V-C-0 DPST-NO Bifurcated contacts RJ22V-A-0 SPDT Blade DPDT SPDT SPST-NO PCB A24, A110, A120, A220, A240, D12, D24, D48, D100 D12, D24, D48, D100 A24, A110, A120, A220, A240, D12, D24, D48, D100 D12, D24, D48, D100 A12, A24, A120, A240, D5, D12, D24, D100 D5, D12, D24, D48, D100 Terminal Blocks Standard Coil Voltage Code (Standard Stock in bold) Contactors Part Number Timers Model A24, A110, A120, A220, A240, D5, D6, D12, D24, D48, D100 A12, A24, A120, A240, D5, D12, D24, D48, D100 Circuit Breakers Ordering Information When ordering, specify the Part No. and coil voltage code: (example) RJ1S-C 1705151135 800-262-IDEC (4332) • USA & Canada A120 Part No. Coil Voltage Code RJ 853 Relays & Sockets Coil Voltage Table Coil Voltage Code Coil Rating A12 A24 A110 A120 A220 A240 D5 D6 D12 D24 D48 D100 12V AC 24V AC 110V AC 120V AC 220V AC 240V AC 5V DC 6V DC 12V DC 24V DC 48V DC 100-110V DC Sockets Replacement Hold Down Springs Finger-safe DIN Rail Mount PCB Mount Part Number Used With Socket Blade Models Standard DIN Rail Mount RJ1S (Std) SJ1S-05BW SJ1S-07LW SJ1S-61 SJ9Z-CM SJ1S-05BW, SJ1S-07LW, SJ2S-05BW, SJ2S-07LW RJ2S (Std)/RJ22S SJ2S-05BW SJ2S-07LW SJ2S-61 SQ9Z-C SQ1V-07B, SQ2V-07B PCB Models Relays RJ1V (Std) — SQ1V-07B* SQ1V-63* SQ9Z-C63 SQ1V-63, SQ2V-63 RJ1V (HC) RJ2V/RJ22V — SQ2V-07B* SQ2V-63* Jumpers for SJ Sockets Poles Relays & Sockets Signaling Lights Switches & Pilot Lights RJ Part Number 2 SJ9Z-JF2 5 SJ9Z-JF5 8 SJ9Z-JF8 10 SJ9Z-JF10 Quantity Must purchase in quantities of 10. Shown with optional marking plate. *Hold-down clip or spring must be removed to use with RJ PCB relays. Accessories Appearance Use with Part No. Remarks Aluminum DIN Rail (1 meter length) All DIN rail sockets BNDN1000 The BNDN1000 is designed to accommodate DIN mount sockets. Made of durable extruded aluminum, the BNDN1000 measures 0.413 (10.5mm) in height and 1.37 (35mm) in width (DIN standard). Standard length is 39” (1,000mm). DIN Rail End Stop DIN rail BNL5 9.1 mm wide. Marking Plate Finger safe sockets (ONLY) SJ9Z-PWPN10 10 pieces per pack Circuit Breakers Terminal Blocks Contactors Timers Item 854 www.IDEC.com 1705151135 Relays & Sockets RJ Model RJ1 Number of Poles 1-pole Contact Configuration SPDT Contact Material RJ2 DPDT DPDT bifurcated contacts Silver-nickel alloy Contact Resistance (initial value) RJ22V 2-pole DPDT (bifurcated), DPST-NO (bifurcated) AgNi (gold clad) Degree of Protection IP40 Flux-tight structure 50 mΩ maximum 1 15ms maximum (with diode: 20 ms maximum) Release Time 2 Signaling Lights Operating Time 2 Dielectric Strength RJ22S 10 ms maximum (with diode: 20 ms maximum) Between contact and coil 5000V AC, 1 minute Between contacts of the same pole 1000V AC, 1 minute Between contacts of different poles Shock Resistance Operating extremes — 3000V AC, 1 minute 10 to 55 Hz, amplitude 0.75 mm Damage limits 10 to 55 Hz, amplitude 0.75 mm NO contact: 200 m/s2, NC contact: 100 m/s2 Damage limits Relays & Sockets Vibration Resistance Operating extremes 1000 m/s2 Electrical Life (rated load) AC load: 200,000 operations minimum (operation frequency 1800 operations per hour) DC load: 100,000 operations minimum (operation frequency 1800 operations per hour) AC load: 100,000 operations minimum (operation frequency 1,800 per hour) DC load: 200,000 operations minimum (operation frequency 1,800 per hour) Mechanical Life (no load) AC coil: 30,000,000 operations minimum (operation frequency 18,000 operations per hour) DC coil: 50,000,000 operations minimum (operation frequency 18,000 operations per hour) AC load: 10 million operations minimum (operating frequency 18,000 operations per hour) DC load: 20 million operations minimum (operating frequency 18,000 operations per hour) Operating Temperature 3 –40 to +70°C (no freezing) 5 to 85% RH (no condensation) 19g (blade type), 17g (PCB form C type), 16g (PCB form A type) 19g Timers Operating Humidity Weight (approx.) Switches & Pilot Lights Specifications DPDT: 17g, DPST-NO: 16g Note: Above values are initial values. 1. Measured using 5V DC, 1A voltage drop method. 2. Measured at the rated voltage (at 20°C), excluding contact bounce time. 3. 100% rated voltage. Contactors Terminal Blocks Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 855 Relays & Sockets Coil Ratings Rated Voltage 24V 120V 240V 12V 24V 120V 240V Blade & PCB Models AC Switches & Pilot Lights RJ DC Blade Models PCB Models Bifurcated Models A24 A120 A240 A12 A24 A120 A240 Rated Current (mA) ±15% (at 20ºC) Without LED1 50Hz 43.9 8.8 4.3 87.3 43.9 8.8 4.3 60Hz 60Hz Coil Resistance (ohms)±10% (at 20ºC) 41.1 7.4 3.7 78.8 41.1 7.4 3.7 243 6,400 25,570 62.5 243 6,400 25,570 With LED1 50Hz 37.5 47.5 7.5 8.7 3.7 4.3 75.0 91.1 37.5 47.5 7.5 8.7 3.7 4.3 Rated Current (mA) ±15% (at 20ºC) Without LED With LED 12V D12 44.2 48.0 271 24V 48V 100-110V 5V 6V 12V 24V 48V 100-110V 5V 12V 24V 48V 100-110V D24 D48 D100 D5 D6 D12 D24 D48 D100 D5 D12 D24 D48 D100 22.1 11.0 5.3 - 5.8 106 88.3 44.2 22.1 11.0 5.3 - 5.8 106 44.2 22.1 11 5.3-5.8 25.7 10.7 5.2 - 5.7 – – – – – – 110 48.0 25.7 10.7 5.2-5.7 1,080 4,340 18,870 47.2 67.9 271 1,080 4,340 18,870 47.2 271 1,080 4,340 18,870 1 Pickup Voltage 80% max Coil Resistance (ohms)±10% (at 20ºC) 1 Operating Characteristics2 Dropout Voltage Maximum Allowable Voltage3 Power Consumption 0.9VA (60Hz) Coil Voltage Code Rated Voltage Timers Relays & Sockets Signaling Lights Bifurcated Models Coil Voltage Code 30% min 140% Approx. 1.1VA (50Hz) 0.9 to 1.2VA (60Hz) Operating Characteristics2 Pickup Voltage Dropout Voltage 70% max 10% min Maximum Allowable Voltage3 170% Power Consumption 0.53W 160% 70% max 170% 10% min 0.53-0.64W 160% 70% max 170% 10% min Approx. 0.53 to 0.64W 160% 1. LED Indicator is only available on Blade or Bifurcated relays. 2. Operating characteristics are at 20ºC. 3. The maximum allowable voltage is the maximum value which can be applied to the relay coils. Blade Models Model Terminal Blocks Contactors Contact Ratings 1 pole 2 poles 2 poles (bifurcated contacts) Standard Type NO NC NO NC NO NC NO NC 1 pole High Capacity Type PCB Models Circuit Breakers Contact NO NC NO 2 poles NC 2 poles (bifurcated contacts) 856 NO NC Allowable Contact Power Resistive Inductive Load Load 3000VA 1875VA 3000VA 1875VA 2000VA 1000VA 2000VA 1000VA 250VA AC 30W DC 100VA AC 15W DC 3000VA 360W 3000VA 180W 4000VA 480W 4000VA 240W 2000VA 240W 2000VA 120W 1875VA 180W 1875VA 90W 2000VA 240W 2000VA 120W 1000VA 120W 1000VA 60W 250VA AC 30W DC 100VA AC 15W DC Voltage 250V AC 250V AC 250V AC 250V AC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC 250V AC 30V DC Rated Load Resistive Inductive Load Load cosø=0.3 L/R=7ms 12A 7.5A 12A 7.5A 8A 4A 8A 4A 1A 0.4A 1A 0.5A 12A 7.5A 12A 6A 12A 7.5A 6A 3A 16A 8A 16A 8A 16A 8A 8A 4A 8A 4A 8A 4A 8A 4A 4A 2A 1A 0.4A 1A 0.5A www.IDEC.com Allowable Switching Current Allowable Switching Voltage Minimum Applicable Load 16A 6A 4A 4A AC250V DC30V DC5V 100mA AC250V DC30V DC5V 10mA 250V AC 125V DC 1V DC 100μA AC250V DC125V DC5V 100mA AC250V DC125V DC5V 100mA AC250V DC125V DC5V 10mA 250V AC 125V DC 1V DC 100μA 1A 12A 6A 16A 8A 8A 4A 1A 1705151135 Relays & Sockets RJ Switches & Pilot Lights Agency Ratings UL General Use Voltage RJ1 Resistive RJ2 RJ22 RJ22 NO NC NO NC NO NC NO NC 250V AC 16A 6A 8A 4A 1A 1A – – 30V DC 12A 6A 8A 4A – – 1A 1A CSA Resistive RJ22 RJ1 Inductive RJ2 RJ22 NO NC NO NC NO NC 250V AC 1A 1A 12A 12A 8A 8A 30V DC – – 12A 6A 8A 4A Signaling Lights Voltage General Use NO RJ1 RJ2 RJ22 NC NO NC NO NC NO NC – – 7.5A 7.5A 4A 4A – – 1A 1A 6A 3A 4A 2A 1A 1A VDE AC-15, DC-13* RJ1 RJ2 NO NO NO RJ22 NC RJ1 RJ2 NO NO 250V AC 12A 8A 1A 30V DC 12A 8A 1A 1A 6A 3A 1A 2.5A 2A Relays & Sockets Voltage Resistive *According to the utilization categories of IEC60947-5-1 Socket Specifications DIN Rail/ Panel Mount PCB Mount Electrical Rating Wire Size Torque SJ1S-05BW M3 screw with captive wire clamp 250V, 12A Maximum up to 2 - #14 AWG 0.6 - 1.0N•m (Maximum 1.2N•m) SJ2S-05BW M3 screw with captive wire clamp 250V, 8A Maximum up to 2 - #14 AWG 0.6 - 1.0N•m (Maximum 1.2N•m) SJ1S-07LW M3 screw with captive wire clamp, fingersafe 250V, 12A Maximum up to 2 - #14 AWG 0.6 - 1.0N•m (Maximum 1.2N•m) SJ2S-07LW M3 screw with captive wire clamp, fingersafe 250V, 8A Maximum up to 2 - #14 AWG 0.6 - 1.0N•m (Maximum 1.2N•m) SQ1V-07B M3 screw with box clamp, fingersafe 300V, 12A Maximum up to 2 - #14 AWG 1.0N•m Maximum SQ2V-07B M3 screw with box clamp, fingersafe 300V, 10A Maximum up to 2 - #14 AWG 1.0N•m Maximum SJ1S-61 PCB mount 250V, 12A — — SJ2S-61 PCB mount 250V, 8A — — SQ1V-63 PCB mount 300V, 12A — — SQ2V-63 PCB mount 300V, 12A — — Contactors Finger-safe DIN Rail/Panel Mount Terminal Timers Socket Terminal Blocks Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 857 Relays & Sockets Electrical Life Curve (Resistive Load) RJ1 RJ1 High Capacity RJ2 1000 30V DC Resistive Load (NO Contact) 10 1 0.1 1 Load Current (A) 1000 250V AC Resistive Load (NO contact) 100 30V DC Resistive Load (NO Contact) 10 1 12 0.1 1 Load Current (A) Load Current (A) Load Current (A) 0.1 1 Load Current (A) 8 10 DC Resistive (NO Contact) DC Resistive (NC Contact) DC Inductive (NO Contact) 1 10 8 1 DC Inductive (NC Contact) 0.1 10 100 250 Load Voltage (V) 1 AC Resistive (NO Contact) AC Inductive 16 1 10 DC Resistive (NO Contact) 100 0.1 250 Load Voltage (V) 10 1 100 250 Load Voltage (V) Operating Temperature and Coil Temperature Rise 0 Load Current 12A ¥ 1 pole No Load Current 10 20 30 40 50 60 130 120 110 100 90 80 70 60 50 40 30 20 10 0 70 Load Current 12A ¥ 1 pole No Load Current 10 20 DC Coil Load Current 8A ¥ 2 poles No Load Current 10 20 30 40 50 Ambient Temperature (C) 858 40 50 60 70 0 DC Coil Load Current 12A ¥ 1 pole No Load Current 10 60 70 130 120 110 100 90 80 70 60 50 40 30 20 10 0 Load Current 8A ¥ 2 poles No Load Current 20 30 40 50 60 70 RJ2 (DC Coil) AC Coil (50 Hz) 10 20 Ambient Temperature (C) RJ2 (AC Coil, 50 Hz) Temperature Rise (C) Temperature Rise (C) RJ2 (AC Coil, 60 Hz) 0 30 130 120 110 100 90 80 70 60 50 40 30 20 10 Ambient Temperature (C) Ambient Temperature (C) 130 120 110 100 90 80 70 60 50 40 30 20 10 RJ1 (DC Coil) AC Coil (50 Hz) Temperature Rise (C) 130 120 110 100 90 80 70 60 50 40 30 20 10 RJ1 (AC Coil, 50 Hz) AC Coil (60 Hz) Temperature Rise (C) Temperature Rise (C) RJ1 (AC Coil, 60 Hz) Temperature Rise (C) Relays & Sockets 1 0.1 Timers 1 RJ2 AC Resistive 12 10 DC Resistive (NO Contact) Contactors 30V DC Resistive Load (NO Contact) 10 16 RJ1 High Capacity AC Resistive (NO Contact) Terminal Blocks 250V AC Resistive Load (NO contact) 100 Maximum Switching Capacity (Resistive Load) RJ1 Circuit Breakers (× 10,000 operations) 250V AC Resistive Load (NO contact) 100 (× 10,000 operations) (× 10,000 operations) 1000 Load Current (A) Signaling Lights Switches & Pilot Lights RJ 30 40 50 60 Ambient Temperature (C) www.IDEC.com 70 130 120 110 100 90 80 70 60 50 40 30 20 10 0 DC Coil Load Current 8A ¥ 2 poles No Load Current 10 20 30 40 50 60 70 Ambient Temperature (C) 1705151135 Relays & Sockets 0 0 10 20 30 40 50 60 10 30 20 40 30 50 40 60 50 70 60 70 70 0010 20 Ambient Ambient Ambient Temperature Temperature Temperature (°C) (°C) (°C) 130 120 110 100 90 80 70 60 50 40 30 20 10 Temperature Temperature Rise Rise (°C) (°C) AC CoilAC AC (50Coil Coil Hz)(50 (50Hz) Hz) 130 130 120 120 110 110 100 100 90 90 80 80 70 70 60 60 50 50 40 40 Loadcurrent current 1A x 2 1A poles 1Axx22poles poles Load 30 30 Load current No current loadcurrent current No load 20 20 No load 10 10 Temperature Rise (°C) Temperature Rise Rise (°C) (°C) Temperature Temperature Rise (°C) 0010 20 10 30 20 40 30 50 40 60 50 70 60 70 70 10 20 30 40 50 60 Ambient Ambient Ambient Temperature Temperature Temperature (°C) (°C) (°C) 130 120 110 100 90 80 70 60 50 40 30 20 10 RJ22 (DC Coil) DC CoilDC DCCoil Coil 130 130 120 120 110 110 100 100 90 90 80 80 70 70 60 60 50 50 40 40 30 30 20 20 Load current Loadcurrent current 1Axx22poles poles 1A x 2 1A poles Load 10 10 No load No loadcurrent current current No load Signaling Lights AC CoilAC AC (60Coil Coil Hz)(60 (60Hz) Hz) 130 130 120 120 110 110 100 100 90 90 80 80 70 70 60 60 50 50 40 40 1A x 2 1A poles Loadcurrent current 1Axx22poles poles Load 30 Load current 30 current No loadcurrent current No load 20 No load 20 10 10 130 120 110 100 90 80 70 60 50 40 30 20 10 Temperature Rise Rise (°C) (°C) Temperature Temperature Rise (°C) RJ22 (AC Coil, 50 Hz) Switches & Pilot Lights RJ22 (AC Coil, 60 Hz) RJ 10 30 20 40 30 50 40 60 50 70 60 70 10 20 30 40 50 60 70 0010 20 Ambient Ambient Ambient Temperature Temperature Temperature (°C) (°C) (°C) 0 The above temperature rise curves show characteristics when 100% the rated coil voltage is applied. The slanted dashed line indicates allowable temperature rise for the coil at different ambient temperatures. Internal Connection (View from Bottom) RJ2-C/RJ22-C-* Standard 1 (A1) RJ22V-A-* 1 (A1) 1 (A1) 3(11) 4(14) 2(12) 3(11) 4(14) 2(12) 4(11) 3(14) 5 (A2) 8 (A2) RJ1-CL-* With LED Indicator 8 (A2) 7(22) 6(21) 5(24) 1 (A1) 1 (A1) 1 (A1) 2(12) 3(11) 4(14) 2(12) 3(11) 4(14) Coil voltage 24V AC/DC and below 5 (A2) 2(12) 4(11) 3(14) Coil voltage greater than 24V AC/DC RJ1-CD-* With Diode 8 (A2) Coil voltage 24V AC/DC and below 8 (A2) Coil voltage greater than 24V AC/DC 1 (A1) – 2(12) 4(11) 3(14) 1 (A1) – 2(12) 3(11) 4(14) 7(22) 6(21) 5(24) RJ2-CLD/ RJ22-CLD-* With LED Indicator and Diode 1 (A1) – 1 (A1) – 1 (A1) – 2(12) 3(11) 4(14) 2(12) 4(11) 3(14) Coil voltage 24V DC and below Contactors 8 + (A2) RJ1-CLD-* With LED Indicator and Diode 5 + (A2) 7(22) 6(21) 5(24) RJ2-CD-/ RJ22-CD-* With Diode 1 (A1) – 5 + (A2) 7(22) 6(21) 5(24) Timers 2(12) 4(11) 3(14) 5 6(21) 5(24) RJ2-CL/RJ22-CL-* With LED Indicator 1 (A1) (A2) Relays & Sockets RJ1-C-* Standard 5 + (A2) 2(12) 4(11) 3(14) 8 + (A2) Coil voltage greater than 24V DC 7(22) 6(21) 5(24) Coil voltage 24V DC and below 2(12) 3(11) 4(14) 8 + (A2) 7(22) 6(21) 5(24) Coil voltage greater than 24V DC Terminal Blocks Circuit Breakers 1705151135 800-262-IDEC (4332) • USA & Canada 859 Relays & Sockets Dimensions (mm) Blade Relay (mm) RJ1S RJ2S/RJ22S 5.0 6.0 27.0 28.0 27.0 Signaling Lights Switches & Pilot Lights RJ 3h 31.1 .2 ¥ ø1 .8 ø1 4 7 6 5 0.5 12.7 2 3 1 3 4 2 8 5 12.7 ho le 31.1 ¥3 2.6 1 Relays & Sockets 4.8 4.8 2.6 0.5 0.5 ole 0.5 28.8 28.8 All dimensions in mm. PCB Relay (mm) RJ1V-A-* (1.9) (1.9) 7.5 7.5 20.0 20.0 (1.9) 0.5 1.0 1.0 13 max.13 max. (12.7) (12.7) (1.9) 20.0 3.5 3.5 0.5 1.0 1.0 13 max. 13 max. (12.7) (12.7) (1.9) (1.9) RJ22V-C-* 20.0 20.0 0.3 (1.9) (1.9) 20.0 20.0 5.0 7.5 7.5 (2.6) 0.5 0.5 1.0 1.0 0.5 0.5 0.3 13 max. 13 max. 29 max. (28.8) 29 max. (28.8) (12.7) (12.7) 6-ø 1.3 hol hol es es (2.6) 1.3 25.5 max. (25.3) 0.3 7.5 25.5 max. (25.3) 0.3 5.0 7.5 5.0 5.0 4.0 0.5 0.5 0.5 0.5 0.5 0.3 29 max. 29(28.8) max. (28.8) (2.6) (2.6) 8 1.3 -ø1.3 5.0 5.0 hol h es oles 4.0 4.0 RJ22V-A-* 25.5 max. (25.3) 0.3 0.3 0.6 4.0 0.6 0.4 860 0.6 0.6 29 max. (28.8) 1.1 13 max. (12.7) 4.0 4.0 0.3 20.0 7.5 7.5 (2.6) (2.6) 0.5 0.5 0.5 0.3 29 max.29(28.8) max. (28.8) 6-ø 8-ø 25.5 max. (25.3) Terminal Blocks Circuit Breakers 4 1.3 -ø1.3 hol h es oles RJ1V-AH-*/RJ2V-A-* 25.5 max. (25.3) 0.3 25.5 max. (25.3) 0.3 Contactors RJ1V-CH-*/RJ2V-C-* 0.3 4.0 0.5 1.0 1.0 13 max. 13 max. (12.7) (12.7) 3.5 4.0 0.5 0.5 0.5 0.5 0.5 0.3 29 max. 29(28.8) max. (28.8) (2.6) (2.6) 5 1.3 -ø1.3 3.5 3.5 hol 3.5 h es oles 25.5 max. (25.3) 0.3 4-ø 5-ø 25.5 max. (25.3) 0.3 25.5 max. (25.3) 0.3 0.3 4.0 4.0 Timers 25.5 max. (25.3) 0.3 RJ1V-C-* www.IDEC.com 0.4 0.6 29 max. (28.8) 1.1 13 max. (12.7) 1705151135 Relays & Sockets RJ SJ1S-05BW Switches & Pilot Lights Dimensions con’t (mm) Standard DIN Rail Mount Sockets SJ2S-05BW 6 15.5 M3 Terminal Screws 29.7 55.7 29.7 4 4.3 71 3 (14) 5 (A2) (A2) (A1) 1 2 (A1) (11) 4 (12) 8 7 1 2 (22) (24) (12) (14) 4 2 71 2 4.3 Signaling Lights 55.7 6 15.5 M3 Terminal Screws 6 (21) 5 (11) 3 4 (TOP VIEW) (TOP VIEW) Relays & Sockets Finger-safe DIN Rail Mount Sockets SJ1S-07LW SJ2S-07LW M3 Teminal Screws M3 Terminal Screws ø5.6 71 4.3 5 (A2) 3 (14) 8 (11) 4 1 (A1) 1 2 (12) (A2) (A1) (TOP VIEW) 35.5 49.5 55.7 ø3 2 ø3 21.5 29.7 35.5 49.5 55.7 21.5 71 2 4.3 Timers 29.7 15.5 15.5 ø5.6 5 (24) 7 (22) (14) 4 (12) 2 (21) 6 3 (11) (TOP VIEW) Contactors SQ1V-07B SQ2V-07B Terminal Blocks A1 14 11 12 (TOP VIEW) 1705151135 800-262-IDEC (4332) • USA & Canada A2 24 21 22 A1 14 11 12 Circuit Breakers A2 (TOP VIEW) 861 Relays & Sockets Dimensions con’t (mm) PC Mount Sockets SJ1S-61 SJ2S-61 32.5 32.5 6.0 (Bottom View) 7.0 ±0.1 Terminal Arrangement 1 5 3 1 2 3 4 8 7 6 5 36.5 1.0 4.0 SQ2V-63 Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets 1.0 s 36.5 Terminal Arrangement (Bottom View) s le ho le 4.0 ±0.1 .3 ø1 ho SQ1V-63 5.0 ±0.1 1.6 Signaling Lights 4 20.0 ±0.1 5.0 ±0.1 8- 15.0 2 ø 5- 4.0 ±0.1 (4.3) ±0.1 7.5 ±0.1 ±0.1 14.0 4.5 4.0 ±0.1 (4.7) 14.0 Switches & Pilot Lights RJ 862 www.IDEC.com 1705151135
RJ1S-C-D24 价格&库存
很抱歉,暂时无法提供与“RJ1S-C-D24”相匹配的价格&库存,您可以联系我们找货
RJ1S-C-D24
    • 1+71.10720
    • 10+62.37000
    • 30+57.04560
    • 100+52.57440
    RJ1S-C-D24
    • 1+59.751071+7.73986
    • 10+53.2682610+6.90011
    • 25+50.8692625+6.58935
    • 50+49.1245150+6.36335
    • 100+47.44078100+6.14524
    • 250+45.29972250+5.86790
    • 500+43.74316500+5.66627
    • 1000+42.239491000+5.47149
    库存:9030
