AMCW2012S-2-900T
AMCW2012S-2-900T
    SUNLORD(顺络)
    共模电感 0805
AMCW2012S-2-900T 数据手册
Wire Wound Chip Common Mode Choke Coil –AMCW-S Series Operating Temp: -40℃~+125℃ FEATURES     Small size, high reliability High quality, fast delivery, low cost Support vehicle signal transmission interface (USB2.0, USB3.0, HDMI2.0), support 3D transmission, meet higher resolution, refresh rate and color depth, support 1080P above playback AEC-Q200 verified APPLICATIONS Automotive USB 2.0/HDMI signal transmission  PRODUCT IDENTIFICATION AMCW 2012 ① ② ① S -2 ③ ④ -900 AMCW ⑥ ③ ② Type T ⑤ Code External Dimensions (L×W) (mm) 2012 [0805] 2.0×1.2 S Winding Type Common Mode Choke Coil Signal ⑤ Nominal Impedance(Ω) Example Nominal Value 670 67 900 90 181 180 361 360 ④ Number of Lines 2 ⑥ Packing T Tape & Reel SHAPE AND DIMENSIONS Recommended Land Pattern Unit: mm Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS AMCW2012S TYPE Part Number Common Mode Impedance @ 100MHz ±25% DC Resistance Rated Current Rated Voltage Insulation Resistance Max. Max. Max. Min. MΩ Units Ω Ω mA Volts Symbol |Z| DCR Irms VDC IR AMCW2012S-2-670T 67 0.25 400 50 10 AMCW2012S-2-900T 90 0.35 330 50 10 AMCW2012S-2-181T 180 0.35 330 50 10 AMCW2012S-2-361T 360 0.45 280 50 10 1 .Storage temperature range (packaging conditions): -10℃~+40℃ and RH 70% (Max.) ※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency AMCW2012S TYPE Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
