ESL160503-MS
ESL160503-MS
    MSKSEMI(美森科)
    ESL160503-MS
ESL160503-MS 数据手册
www.msksemi.com ESL160503-MS Semiconductor 1.1 Technology Data Symbol Maximum allowable continuous AC voltage at 50-60Hz VRMS 18 V Maximum allowable continuous DC voltage V DC 5.5 V Varistor voltage measured *1 Vv 100~150 V Typical capacitance value measured at 1MHz C 3 pF +80-20 % Value Typical capacitance value tolerance Compiance Unit Maximum ESD allowable clamping Voltage*2 VCLAMP < 240 V Leakage current at VDC*3 (At initial state) I LDC < 0.1 uA Leakage current at VDC*3 (After ESD Test) I LDCA < 2 uA Trise < 0.5 ns Operation ambient temperature -50~ +85 ℃ Storage temperature -50~+125 ℃ 1.2 Reference Data Response time ESD testing IEC61000-4-2 Level 4 1.3 Other Data Body ZnO End termination Ag/Ni/Sn Packaging Reel Complies with Standard IEC61000-4-2 Complies with RoHs Standard Yes Lead Content < 1000 Marking ppm None Notes: * * * * * 1 The varistor voltage was measured at 1 mA current 2 The Clamping voltage was measured at 8*20 us standard current. 3 The Leakage current was measured at working voltage. 4 The Energy only for customer reference. 5 The components shall be employed within 1 year, in the nitrogen condition. SEVERITY LEVEL AIRDIRCHARGE DIRECT DISCHARGE 1 2 KV 2 KV 2 4 KV 4 KV 3 8 KV 6 KV 4 15 KV 8 KV IEC 61000-4-2 Compliant ESD Current Pulse Waveform www.msksemi.com ESL160503-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Dimension (Unit:mm) Min. Max. A 0.9 1.2 B 2.7 3.2 C 0.7 1.0 D 0.9 1.2 0603 The IR reflow and temperature of Soldering for Pb Free ☆ IR reflow Pb Free Process suggestion profile (1) The solder recommend is Sn96.5/Ag 3.5 of 120 to 150μm (2) Ramp-up rate (217℃ to Peak) + 3℃/second max (3) Temp. maintain at 175 +/-25℃ 180 seconds max (4) Temp. maintain above 217 ℃ 60-150 seconds REEL SPECIFICATION P/N PKG QTY ESL160503 0603 4000 www.msksemi.com ESL160503-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
ESL160503-MS 价格&库存
很抱歉,暂时无法提供与“ESL160503-MS”相匹配的价格&库存,您可以联系我们找货
ESL160503-MS
    • 10+0.32595
    • 100+0.26374
    • 300+0.23264
    • 1000+0.20931
    • 4000+0.16168
    • 8000+0.15228
    库存:3568
