IP2712
IP2712
    INJOINIC(英集芯)
    TSSOP-20
IP2712 数据手册
IP2712 USB TYPE-C PD2.0/PD3.0、QC3.0/2.0/MTK High Voltage Charger Protocol Controller Feature Applications           USB TYPE-C  Integrate TYPE-C DFP protocol  Auto detect TYPE-C device plug in or plug out USB Power Delivery(PD2.0/PD3.0)  Hardware BMC transmitter and receiver  Full feature physical layer  Hardware CRC protect the data integrity  Integrate PD2.0/PD3.0 protocol engine  Support E-MARK cable  Support VCONN  Hardware reset Integrate QC3.0/2.0 Quick charge protocol  QC3.0/2.0 High voltage output protocol  CLASS A and CLASS B  Including BC1.2/APPLE/SAMSUNG charging protocol  Provide feedback voltage to adjust the output voltage dynamically Support MTK PE+1.1 Fast charging technology Support FCP/SCP Fast charging technology Power Manage  Build in VCONN power path switch  External P-MOSFET switch control  Build in ADC to monitor the current of the external MOSFET  Build in power path manage.  Built in automatic control discharge function ADC  Build 14bit ADC  Monitoring Voltage and current of VBUS  Monitoring Voltage of the VCONN Low power consume  Standby current less than 100uA Package  TSSOP20L http://www.injoinic.com/   AC power Adapter for cellphone, notebook, tablet, VR box, UAV, robot Car charger Application with PD output function Description IP2712 is a highly-integrated, flexible high voltage charging protocol controller. It supports the most popular high voltage charging protocol. Such as TYPE-C PD2.0/PD3.0, QC3.0, MTK PE+1.1, DCP, FCP, SCP, BC1.2 etc. The SOC could be a powerful protocol controller used in AC adapter, Car charger or other power charging solution. 1 / 21 Version 1.04 IP2712 1. Logic Block Diagram VBUS SENSEN SENSEP DCH_G DCH_V VOUT_D External Gate Control and Current Sense VCON5V 600mA VBUS LDO 2.5~3.1V + - CC1 VCC VDD LDO 1.5~2.2V PD PHY TYPE-C ADC + - CC2 FB DP HVDCP STAT DM MCU I/O Interface TEST1 PLIM TEST GPIO1 TEST2 GND Figure 1 IP2712 Block Diagrams V1.04 Email: service@injoinic.com 2 / 21 Copyright © 2017, Injoinic Corp. IP2712 2. Typical Application 2.1 Application Block Diagram Figure 2 illustrates the application diagram of power adapter (DFP only) using IP2712. 0.1uF 10uF DC-DC AC-DC Secondary 3.6~20V 10uF 0.1uF 10mOhm 1k VBUS SENSEN SENSEP DCH_G DCH_V VOUT_D External Gate Control and Current Sense VCON5V 600mA VBUS LDO 2.5~3.1V + - CC1 VCC 1uF VDD LDO 1.5~2.2V 1uF PD PHY 1uF TYPE-C ADC Voltage Feedback Network + - CC2 TYPE-C Receptacle FB DP HVDCP STAT DM MCU I/O Interface TEST1 PLIM TEST GPIO1 TEST2 GND Figure 2 Power Adapter Application Diagram V1.04 Email: service@injoinic.com 3 / 21 Copyright © 2017, Injoinic Corp. IP2712 2.2 Application Schematic Diagram Figure 3 illustrates a power adapter application schematic diagram (DFP mode, support 20V max) using IP2712. (Note: Q3/Q4 VGS(th) < 1V, used to prevent current flow backward when the IP2712 is not in working condition) Figure 3 Power Adapter Application Schematic Diagram V1.04 Email: service@injoinic.com 4 / 21 Copyright © 2017, Injoinic Corp. IP2712 Table 1 BOM Number 1 Designator Q1, Q2 Comment VS3508AE/RU30L30M Footprint PDFN3333 Description PMOS NMOS, VGS(th) min = 0.5V; 2 Q3, Q4 LBSS138LT1G SOT-23 note: should use the low threshold voltage mosfet for this low voltage application; 3 Q5, 2N7002 SOT-23 NMOS 4 U1 IP2712 TSSOP20 IP2712 5 R1 1K 0603 Resistance 6 R2, 0R 0603 Resistance, 1% for PLIM pull-up to STAT 7 R3 100K 0603 Resistance, 1% for PLIM pull-down to GND Resistance, 8 R4 500R 0603 note: adjust this value to guarantee the discharge time; 9 R5 10K 0603 Resistance 10 RS 0.01R 1206 Resistance , 1%/1W; 11 C1, C2 2.2uF 0603 Capacitor 12 C3, C4, C5 0.1uF 0603 Capacitor 13 C6 10uF 0805/0603 Capacitor 14 C7 10uF 0805/0603 Capacitor 15 D1 LED 0603 LED V1.04 Email: service@injoinic.com 5 / 21 Copyright © 2017, Injoinic Corp. IP2712 3. PINS TEST2 1 20 STAT GPIO1 2 19 VOUT_D GND 3 18 TEST1 VDD 4 17 FB VCC 5 16 PLIM VBUS 6 15 DP SENSEP 7 14 DM SENCEN 8 13 CC1 DCH_V 9 12 CC2 DCH_G 10 11 VCON5V IP2712 TSSOP20L Figure 4 Pinouts of TSSOP20L Package (Top View) Table 2 IP2712 Pin Description for TSSOP20L Devices Pin Map Description Pin Name 1 TEST_2 Debug pin for programming the device and firmware update. For using INJOINIC’s tool to update firmware, please connect to SBU2. 2 GPIO1 General Purpose Input / Output 1 3 GND Ground 4 VDD VDD supply output, connect the 1µF capacitor from VDD to GND. 5 VCC VCC supply output, connect the 1µF capacitor from VCC to GND. 6 VBUS System Power Supply Input, up to 20 V 7 SENSEP connection point to the positive terminal of sense the VBUS current 8 SENSEN connection point to the negative terminal of sense the VBUS current 9 DCH_V Used for voltage detection 10 DCH_G VBUS Gate Driver Control for Producer Switch 11 VCON5V 5V supply input for VCONN FETS , if VCON5V is connected to 5V, the IP2712 support E-MARK cable. 12 CC2 USB TYPE-C connector detect/Configuration Channel 2 13 CC1 USB TYPE-C connector detect/Configuration Channel 1 14 DM USB DM 15 DP USB DP V1.04 Email: service@injoinic.com 6 / 21 Copyright © 2017, Injoinic Corp. IP2712 16 PLIM IP2712 check the voltage of PLIM and configure Source Power limit. Not support E-MARK cable: power Limit Step: 40mV/W. Power Limit Max: 60W; Support E-MARK cable (VCON5V = 5V): power Limit Step: 20mV/W. Power Limit Max: 100W. 17 FB Feedback loop drive output. 18 TEST_1 Debug pin for programming the device and firmware update. For using INJOINIC’s tool to update firmware, please connect to SBU1. 19 VOUT_D Control the discharge function, output high last for some time after the TYPE-C device plug out. 20 STAT LOW indicates the TYPE-C is not connected. HIGH indicates the TYPE-C is connected successfully. V1.04 Email: service@injoinic.com 7 / 21 Copyright © 2017, Injoinic Corp. IP2712 4. Specifications 4.1 Absolute Maximum Ratings Parameter symbol MIN MAX VBUS -0.3 30 VCON5V -0.3 6 VCC -0.3 5 DCH_V -0.3 30 FB -0.3 5 SENSEN -0.3 30 SENSEP -0.3 30 VCC -0.3 3.3 VDD -0.3 2.2 GPIOs -0.3 VCC+0.3 TEST1, TEST2 -0.3 VCC+0.3 CC1, CC2 -0.3 6 DP, DM -0.3 6 Junction temperature TJ -40 125 ℃ Storage temperature Tstg -60 125 ℃ Thermal resistance (from junction to ambient air) θJA 18 ℃/W ESD ESD 4000 V Input voltage range Output voltage range I/O voltage range UNIT V V V *Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. V1.04 Email: service@injoinic.com 8 / 21 Copyright © 2017, Injoinic Corp. IP2712 4.2 Recommend operation conditions Parameter Input voltage range symbol MIN Typical MAX VBUS 4.5 22 VCON5V 4.5 5.5 VCC 2.8 3.3 GPIOs GND-0.3V VCC+0.3V TEST1, TEST2 GND-0.3V VCC+0.3V CC1, CC2 GND-0.3V 5.5 DP, DM GND-0.3V 5.5 I/O voltage range Unit V V *Beyond these operation conditions, the device’s performance will not be guaranteed 4.3 Electrical Characteristics DC Specifications Parameter VCON5V Description MIN VCONN Supply Input 4.5 TYP MAX Unit 5.5 V VCC 3.1 V VDD 1.8 V VBUS 4.5 22 V MAX Unit Details/Test condition GPIO Specifications Parameter Description MIN VIH Input voltage HIGH level 0.7x VCC VIL Input voltage LOW level TYP Details/Test condition V 0.3x VCC V VOH Output voltage HIGH level VCC V VOL Output voltage HIGH level GND V Rpu Pull–up resistor value 10 k Pull–up resistor Enabled Output current capability 2 mA Source current until 0.8xVCC Source current V1.04 Email: service@injoinic.com 9 / 21 4 Copyright © 2017, Injoinic Corp. IP2712 TYPE-C DC Specifications Parameter Description MIN TYP MAX Unit Rp_default DFPCC termination for default USB Power 80 µA Rp_1.5A DFP CC termination for 1.5A power 180 µA Rp_3.0A DFP CC termination for 3.0A power 330 µA Details/Test condition ADC Specifications Parameter Description MIN TYP MAX Unit Resolution ADC resolution ADCVBUSV VBUS Voltage ADC range 0 24 V ADCVBUSI VBUS Current ADC range -6.28 6.28 A ADCVCON5V VCON5V Voltage ADC range 0 7.4 V V1.04 Email: service@injoinic.com 14 10 / 21 Details/Test condition Bits 10mOhm Copyright © 2017, Injoinic Corp. IP2712 5. Function Description 5.1 Overview USB-PD Controller Bi-Phase Marked Encoding/Decoding (BMC) Physical Layer (PHY) Protocol Policy Engine USB TYPE-C Controller Detect USB Cable Plug Attach Assign CC and VCONN Pins Advertise Default, 1.5A or 3A for TYPE-C Power Power Switch Gate Control and Current Sense for External 5-V to 20-V, 5A Bi-directional Switch 5-V, 600mA Switches for VCONN Over-Current Limiter, Overvoltage Protector Hard Reset Support Support Mainstream Fast Charge Mode QC3.0, DCP, BC1.2, Pump Express Plus, FCP, SCP, 5.2 Power Delivery Over The USB Type-C Connector Using IP2712 Power delivery over the USB Type-C connector takes advantage of the existing USB methods as defined by: the USB 2.0 and USB 3.1 specifications, the USB BC 1.2 Specification and the USB Power Delivery specification. The USB Type-C Current mechanism allows the DFP to offer more current than defined by the USB BC 1.2 Specification. Additionally, IP2712 integrate QC3.0/2.0 Quick charge output Protocol, include BC1.2/APPLE/SAMSUNG charging protocol, Support MTK PE+ Fast charging technology. 5.3 USB Power Delivery Controller The USB Power Delivery (PD) controller provides the physical layer (PHY) functionality of the USB-PD protocol. It is comprised of the following: - Mode Configuration for Source (Host), Sink (Device), or Source-Sink - Physical Layer (PHY) Protocol - Policy Engine Physical Layer (PHY) Functions The USB PD Physical Layer consists of a pair of transmitters and receivers that communicate across a single signal V1.04 Email: service@injoinic.com 11 / 21 Copyright © 2017, Injoinic Corp. IP2712 wire (CC). All communication is half duplex. The PHY Layer practices collision avoidance to minimize communication errors on the channel. The transmitter performs the following functions: - Receive packet data from the protocol layer - Calculate and append a CRC - Encode the packet data including the CRC (i.e. the payload) - Transmit the Packet (Preamble, SOP*, payload, CRC and EOP) across the channel using Bi-Phase Mark Coding (BMC) over CC The receiver performs the following functions: - Recover the clock and lock onto the Packet from the Preamble - Detect the SOP* - Decode the received data including the CRC - Detect the EOP and validate the CRC ·If the CRC is valid, deliver the packet data to the protocol layer. ·If the CRC is not valid, flush the received data. Policy Engine Policy Engine interacts with the Device Policy Manager in order to implement the present Local Policy. 5.4 Detecting a Valid DFP-to-UFP Connection For the USB TYPE-C solution, two pins on the connector, CC1 and CC2, are used to establish and manage the DFP-to-UFP connection. Functionally, the configuration channel is used to serve the following purposes. - DFP-to-UFP attach/detach detection - Plug orientation/cable twist detection - Initial DFP-to-UFP (host-to-device) and power relationships detection - USB Type-C VBUS current detection and usage - USB PD communication - Configure VCONN - Discover and configure optional Alternate and Accessory modes The general concept for setting up a valid connection between a DFP and UFP is based on being able to detect terminations residing in the product being attached. To aid in defining the functional behavior of CC, a pull-up (Rp) and pull-down (Rd) termination model is used – actual implementation in hosts and devices may vary, for example, the pull-up termination could be replaced by a current source. (see Figure 5) V1.04 Email: service@injoinic.com 12 / 21 Copyright © 2017, Injoinic Corp. IP2712 Figure 5 Current Source/Pull-Down CC Model Figure 6 shows the IP2712 plug and orientation detection block at each CC pin. VCC VREF1 IH_DF IH_1P5 IH_3P0 VREF2 CC1/CC2 VREF3 Figure 6 Plug and Orientation Detection Block V1.04 Email: service@injoinic.com 13 / 21 Copyright © 2017, Injoinic Corp. IP2712 Configure as a DFP When configured as a DFP, the IP2712 detects when a cable or a UFP is attached using the both CC pins. When in a disconnected state, the IP2712 monitors the voltages on these pins to determine what is connected. Table 3 Cable Detect States for a DFP CC1 CC2 Open Open Rd Open Open Rd Open Ra Ra Open Rd Ra Ra Rd Rd Ra STATE Sink Behavior Source Behavior - Sense CC pins for attach - Do not apply VBUS or VCONN - Sense CC for orientation - Sense CC for detach - Apply VBUS and VCONN - Sense VBUS for attach Powered cable without Sink attached - Sense CC pins for attach - Do not apply VBUS or VCONN - Sense VBUS for attach Powered cable with Sink or VCONN-powered Accessory attached - Sense CC for orientation - Sense CC for detach - Apply VBUS and VCONN - If accessories are supported, see Source Behavior with exception that VBUS is not applied., otherwise, N/A. Rd Debug Accessory Mode attached (Appendix B) - Sense CC pins for detach - Reconfigure for debug - If accessories are supported, see Source Behavior, otherwise, N/A Ra Audio Adapter Accessory Mode attached (Appendix A) - Sense CC pins for detach - Reconfigure for analog audio - If accessories are supported, see Source Behavior, otherwise, N/A Nothing attached Sink attached - Sense CC pins for orientation - Sense loss of VBUS for detach Dead Battery Detection support A system that supports Dead Battery Detection shall apply Rd to both CC pins. When the system with a dead battery has sufficient charge, it may use the USB PD DR_Swap message to become the DFP. 5.5 USB Type-C Current The USB Type-C connector uses CC pins for configuration including the ability for a Source to advertise to its port partner (Sink) the amount of current it can apply: - Default values defined by the USB Specification (500 mA for USB 2.0 ports, 900 mA for USB 3.1 ports) - 1.5A - 3.0A A Sink that takes advantage of the additional current offered shall monitor the CC pins and shall adjust its current consumption to remain within the value advertised by the Source. While a USB PD contract is in place, a Sink is not required to monitor USB Type-C current advertisements and shall not respond to USB Type-C current advertisements. The Source adjusts current source (or Rp) to advertise which of the three current levels it supports. (see Table 4) V1.04 Email: service@injoinic.com 14 / 21 Copyright © 2017, Injoinic Corp. IP2712 Table 4 Source CC Termination (Rp) Requirements Table 5, Table 6 and Table 7 provide the CC voltage values that a Source shall use to detect what is attached base on what is attached based on the USB Type-C Current advertisement that the Source is offering. Table 5 CC Voltages on Source Side – Default USB Table 6 CC Voltages on Source Side – 1.5 A @ 5 V Table 7 CC Voltages on Source Side – 3.0 A @ 5 V V1.04 Email: service@injoinic.com 15 / 21 Copyright © 2017, Injoinic Corp. IP2712 The voltage (Rd) on CC is used by the Sink to determine the maximum current it may draw. Table 8 provides the CC voltage threshold on Sink side. Table 8 Voltage on Sink CC pins (Multiple Source Current Advertisements) (Note: For more details about USB TYPE-C, please see “USB Type-C Specification Release 1.2”) V1.04 Email: service@injoinic.com 16 / 21 Copyright © 2017, Injoinic Corp. IP2712 5.6 Support Mainstream Fast Charge Mode Quick Charge Interface The IP2712 can automatically detects Quick Charge 2.0/3.0 capable devices with handshake by USB D+/D- data line. It’s also complaint with BC1.2 / APPLE 2.4A mode / Samsung Mode.  Apple Device: Applying 2.7V on D+ line and 2.7V on D- line.  Samsung Smart-Phone: Applying 1.2V on D+ line and 1.2V on D- line.  BC1.2: Shorting D+ Line to D- Line.  Quick Charge 2.0/3.0: D+ and D- line configuration see Table 9. Table 9 QC2.0/3.0 DP/DM configuration DP DM Result(Class A) Result(Class B) 0.6 V GND 5V 5V 3.3 V 0.6 V 9V 9V 0.6 V 0.6 V 12 V 12 V 0.6 V 3.3 V Continue Mode Continue Mode 3.3 V 3.3 V Keep 20V Pump Express Plus Protocol The IP2712 is compatible with Pump Express Plus fast charge protocol 1.1. The Pump Express Plus Fast Charge protocol enables communication between devices. V1.04 Email: service@injoinic.com 17 / 21 Copyright © 2017, Injoinic Corp. IP2712 6. Application Information 6.1 Support E-MARK Cable IP2712 supports EMARK cable Function through VCON5V configuration. When VCON5V = 5V, IP2712 is automatically configured to support E-MARK cable. If the E-MARK cable support a maximum current of 5A, the maximum output power can be configured as 100W. When VCON5V < 5V, IP2712 can’t support E-MARK cable, the maximum output power can be configured as 60W. 6.2 Use PLIM to set the Source Power Limit The IP2712 checks the voltage at PLIM to set the power limit. When VCON5V < 5V, the IP2712 can’t support E-MARK cable. The voltage step of power limit is 40mV/W. When the voltage at PLIM is greater than or equal to 2400mV, the power limit reaches the max power of 60W. When VCON5V = 5V, the IP2712 can support E-MARK cable. The voltage step of power limit is 20mV/W. When the voltage at PLIM is greater than or equal to 2000mV, the power limit reaches the max power of 100W. The power limit is used for different purpose. 1. The value of power limit is used to set the output current limit in real time. 2. The value of power limit is used to Change the Maximum Current of Source Capabilities Message. 6.3 Programmable Power Supply (PPS) The voltages and currents a Source supported is as define in Table 10. Table 10 Normative Voltages and Currents (without E-MARK cable) Power (W) Current at 5V (A) Current at 9V (A) Current at 12V (A) 0 ≤ x
IP2712 价格&库存
很抱歉,暂时无法提供与“IP2712”相匹配的价格&库存,您可以联系我们找货
