A17251-01
A17251-01
    LAIRD(莱尔德)
    A17251-01
A17251-01 数据手册
TputtyTM 607 High Performance Dispensable Gap Filler PRODUCT DESCRIPTION Laird Tputty™ 607 is a high thermally conductive single part dispensable material designed with automation and vertical stability in mind. Laird has leveraged its knowledge of thermally conductive fillers and resin systems to develop a single part dispensable that demonstrates reliability in a variety of application orientations. Tputty™ 607 is ideal for applications that can benefit from automation and allows minimization of SKUs in applications with gap variability. In addition to providing application flexibility and variable gap adaptation, Tputty™ 607 will exert minimal stress on your component while maintaining interface contact to maximize thermal transfer. Combined with Laird’s global technical support and global footprint, deploying Tputty™ 607 is easier than ever. When it is time to integrate TputtyTM 607 into your production environment, Laird can work with your existing dispensing partner or provide recommendations for a dispensing equipment provider. FEATURES AND BENEFITS • • • • • RoHS compliant Complete dispensing solution options available 6.4 W/mK Demonstrated thermal cycling stability Low outgassing per ASTM E595 Available in cartridges (30cc, 75cc, 180cc, 360cc, 600cc) and pails (1 gallon and 5 gallon) Packaging Size Fill Volume Fill Weight 30cc 75cc (2.5 oz) 30cc 58cc 105g 200g 180cc (6 oz) 360cc (12 oz) 161cc 328cc 556g 1130g 600cc (20 oz) 1 gallon 5 gallon 605cc 4090cc 5860cc 2090g 14kg 20kg Americas: +1.866.928.8181 Europe: +44.(0).8031.2460.0 Asia: +86.755.2714.1166 www.laird.com THR-DS-Tputty 607 03/17/2021 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. TputtyTM 607 High Performance Dispensable Gap Filler TYPICAL PROPERTIES PROPERTY TYPICAL VALUE Construction Ceramic filled silicone dispensable Color Thermal Conductivity Flow Rate (75cc taper tip, 0.125” orifice, 90 psi) Blue 6.4 W/mK Density Flammability Operating Temperature Range 3.45 g/cc V-0 -40 to 200°C Helium Pycnometer UL 94 Laird Test Method Outgassing TML (weight) Outgassing CVCM (weight) Dielectric Breakdown 0.204 % 0.01 % >6000 VAC (at 1 mm) ASTM E595 ASTM E595 ASTM D149 Dielectric Constant @ 1MHz Minimum Bond line Thickness 15.0 0.150 mm (0.006”) Volume Resistivity 1013 ohm·cm ASTM D150 Laird Test Method A16112-00 ASTM D257 60 g/min METHOD Visual Hot Disk Laird Test Method A16724-00 Americas: +1.866.928.8181 Europe: +44.(0).8031.2460.0 Asia: +86.755.2714.1166 www.laird.com THR-DS-Tputty 607 03/17/2021 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
A17251-01 价格&库存
很抱歉,暂时无法提供与“A17251-01”相匹配的价格&库存,您可以联系我们找货
